root/Development/ray/src/rt/RdataShare.h
Revision: 2.1
Committed: Tue Oct 29 00:36:54 2024 UTC (14 months ago) by greg
CVS Tags: rad6R0, HEAD
feat(rxcontrib): First compiled version of rxcontrib tool to test new C++ classes
1 /* RCSid $Id$ */
2 /*
3 * RdataShare.h
4 *
5 * Radiance classes for interprocess data sharing
6 *
7 * Errors end up calling error() from rterror.h, so
8 * checking return values is not normally needed.
9 *
10 * Created by Greg Ward on 10/14/2024.
11 */
12
13 #ifndef RdataShare_h
14 #define RdataShare_h
15
16 #include <sys/types.h>
17
18 /// Channel creation and i/o flags
19 enum {RDSexcl=1, RDSextend=2, RDSread=4, RDSwrite=8};
20
21 /*
22 * When data sharing object is created, flag meanings are:
23 * RDSexcl = Create a new file, or fail if it exists
24 * RDSextend = Set data extent to match size parameter
25 * RDSread = Data may be read
26 * RDSwrite = Data may be written
27 *
28 * The RDSread flag should be given to GetMemory() if a data
29 * read operation is desired. Similarly, the RDSwrite flag
30 * should be given when writing data in ReleaseMemory().
31 * Memory-mapped files always read *and* write data if opened
32 * in the appropriate mode. (Beware that writing to read-only data
33 * or reading write-only data will generate a system fault.)
34 * The RDSextend flag may be given with RDSread in GetMemory()
35 * and RDSwrite in ReleaseMemory() to allow the file size to
36 * increase as needed for a given operation.
37 * In some implementations, the RDSexcl flag may guarantee
38 * data consistency by placing locks on the requested memory areas.
39 * In such cases, it may make sense to include the RDSwrite flag
40 * in GetMemory() calls if the intention is to write new results
41 * in ReleaseMemory(), so an exclusive lock will be held.
42 */
43
44 /// Data share object types returned by GetType()
45 enum RDSType {RDSTanonMap=1, RDSTfileMap, RDSTfile,
46 RDSTcust1, RDSTcust2, RDSTcust3, RDSTcust4};
47
48 extern const char RDSnoname[];
49
50 /// Abstract base class for shared memory object
51 class RdataShare {
52 protected:
53 char * chName; // channel name
54 size_t osiz; // current object size
55 int mode; // open mode
56 public:
57 RdataShare() {
58 chName = NULL; osiz = 0; mode = 0;
59 }
60 virtual ~RdataShare();
61 /// Get channel name, or RDSnoname if anonymous
62 const char * GetName() const {
63 return chName ? chName : RDSnoname;
64 }
65 /// Get R/W flags
66 int GetMode() const {
67 return mode & (RDSread|RDSwrite);
68 }
69 /// Get current object size
70 size_t GetSize() const {
71 return osiz;
72 }
73 /// Return data sharing type
74 virtual RDSType GetType() const = 0;
75 /// Attempt to extend or shrink object (adjust if 0)
76 virtual size_t Resize(size_t new_siz = 0) = 0;
77 /// Get data buffer
78 virtual void * GetMemory(size_t offs, size_t len, int fl = RDSread) = 0;
79 /// Return data buffer
80 virtual bool ReleaseMemory(void *bp, int fl = RDSwrite) = 0;
81 };
82
83 /// Memory sharing implemented with mmap'ed file (or anonymous area)
84 class RdataShareMap : public RdataShare {
85 void * mmorg; // memory-mapped origin
86 int bufCount; // count of allocated buffers
87 public:
88 RdataShareMap(const char *name, int flags, size_t siz = 0);
89 virtual ~RdataShareMap();
90 RDSType GetType() const {
91 return chName ? RDSTfileMap : RDSTanonMap;
92 }
93 size_t Resize(size_t new_siz = 0);
94 void * GetMemory(size_t offs, size_t len, int fl);
95 bool ReleaseMemory(void *dp, int fl);
96 };
97
98 struct RDSbuffer; // Private struct for buffer list
99
100 /// Memory sharing implemented with simple file
101 class RdataShareFile : public RdataShare {
102 int fd; // open file descriptor
103 RDSbuffer * blist; // allocated buffer list
104 public:
105 RdataShareFile(const char *name, int flags, size_t siz = 0);
106 virtual ~RdataShareFile();
107 RDSType GetType() const {
108 return RDSTfile;
109 }
110 size_t Resize(size_t new_siz = 0);
111 void * GetMemory(size_t offs, size_t len, int fl);
112 bool ReleaseMemory(void *dp, int fl);
113 };
114
115 #endif // RdataShare_h
