root/Development/ray/src/rt/RcontribSimulManager.h
Sat Oct 25 03:30:35 2025 UTC (2 months ago) by greg
Changes since 2.13: +9 -8 lines
Diff to previous 2.13
fix(rxcontrib,rxfluxmtx): Repaired logic with NCOLS= and -r + speed improvement
Thu Oct 23 16:33:39 2025 UTC (2 months, 1 week ago) by greg
Changes since 2.12: +7 -3 lines
Diff to previous 2.12
refactor: Added fileDataShare() definition for convenience
Fri Oct 17 17:43:53 2025 UTC (2 months, 1 week ago) by greg
Changes since 2.11: +1 -6 lines
refactor(rxcontrib): Privatized things that didn't need to be extern
Mon Aug 18 17:55:03 2025 UTC (4 months, 1 week ago) by greg
fix: Allow rows to be reset to 0 so ResetRow(0) actually works
Thu Jan 2 16:16:49 2025 UTC (11 months, 3 weeks ago) by greg
CVS Tags: rad6R0
Changes since 2.9: +21 -4 lines
fix(rxtrace,rxcontrib): Improvements and bug fixes in flag initialization, handling of light source tracing
Tue Dec 24 20:57:13 2024 UTC (12 months ago) by greg
fix(rxcontrib): Turn off memory sharing before releasing octree
Tue Dec 3 17:39:42 2024 UTC (12 months, 3 weeks ago) by greg
refactor(rxcontrib): Moved definition of formstr() to make it more accessible
Fri Nov 8 15:49:34 2024 UTC (13 months, 3 weeks ago) by greg
Changes since 2.6: +14 -8 lines
feat(rxcontrib): Added ClearModifiers() call to restart with same octree
Wed Nov 6 19:45:59 2024 UTC (13 months, 3 weeks ago) by greg
Changes since 2.5: +16 -15 lines
feat(rxcontrib): Folded resolution and contrib flag into main class
Wed Nov 6 18:28:52 2024 UTC (13 months, 3 weeks ago) by greg
perf(rxtrace,rxpict,rxpiece,rxcontrib): Improved exit strategy in children
Fri Nov 1 23:05:01 2024 UTC (13 months, 4 weeks ago) by greg
feat(rxcontrib): Added a couple of minor sanity checks
Wed Oct 30 01:38:21 2024 UTC (14 months ago) by greg
fix(rxcontrib): Fixes in file loading & process management
Tue Oct 29 19:47:19 2024 UTC (14 months ago) by greg
Changes since 2.1: +25 -7 lines
fix(rxcontrib): Fixed handling of -ld and -I command-line flags
Tue Oct 29 00:36:54 2024 UTC (14 months ago) by greg
feat(rxcontrib): First compiled version of rxcontrib tool to test new C++ classes
