1 |
/* RCSid $Id: RcontribSimulManager.h,v 2.4 2024/11/01 23:05:01 greg Exp $ */ |
2 |
3 |
* RcontribSimulManager.h |
4 |
5 |
* Rcontrib simulation manager class declaration |
6 |
7 |
* Created by Greg Ward on 10/11/2024. |
8 |
9 |
10 |
#ifndef RcontribSimulManager_h |
11 |
#define RcontribSimulManager_h |
12 |
13 |
#include "RtraceSimulManager.h" |
14 |
#include "RdataShare.h" |
15 |
#include "lookup.h" |
16 |
#include "rtprocess.h" |
17 |
18 |
19 |
* As with other single-object classes, many global variable affect |
20 |
* behavior. Besides rendering parameters, there are spectral parameters |
21 |
* and output dimensions taken from the environment. |
22 |
23 |
* NOTE: "record" and "row" are used interchangeably throughout. |
24 |
25 |
26 |
extern char RCCONTEXT[]; // global rcontrib context |
27 |
28 |
extern int contrib; // computing contributions? |
29 |
30 |
extern int xres, yres; // global resolution settings |
31 |
32 |
class RcontribSimulManager; // need forward decl |
33 |
34 |
/// Shared data object for record output (includes header; may be write-only) |
35 |
class RcontribOutput { |
36 |
RcontribOutput * next; // next in sorted list |
37 |
char * ofname; // output file name |
38 |
uint32 rowCountPos; // row count position in header |
39 |
void * rowp; // current row memory |
40 |
bool NewHeader(const RcontribSimulManager *rcp); |
41 |
int CheckHeader(const RcontribSimulManager *rcp); |
42 |
public: |
43 |
RdataShare * rData; // data sharing object |
44 |
size_t rowBytes; // byte count per row |
45 |
const char * omod; // single modifier (or NULL) |
46 |
int32 obin; // single output bin (or -1) |
47 |
uint32 begData; // start of data (type-aligned) |
48 |
int32 curRow; // current output row |
49 |
uint32 nRows; // total number of rows |
50 |
RcontribOutput(const char *fnm = NULL) { |
51 |
next = NULL; |
52 |
omod = NULL; |
53 |
obin = -1; |
54 |
rData = NULL; |
55 |
ofname = savqstr(fnm); |
56 |
rowBytes = 0; |
57 |
nRows = 0; |
58 |
rowp = NULL; curRow = -1; |
59 |
60 |
~RcontribOutput() { |
61 |
DoneRow(); |
62 |
delete rData; |
63 |
delete next; |
64 |
freeqstr(ofname); |
65 |
66 |
/// Return output channel name |
67 |
const char * GetName() const { |
68 |
if (rData) return rData->GetName(); |
69 |
return ofname; |
70 |
71 |
/// Update output row count |
72 |
bool SetRowsDone(int r) { |
73 |
if (!rData | (0 >= r) | (r > nRows)) return false; |
74 |
char * rbuf = (char *)rData->GetMemory(rowCountPos, 17, 0); |
75 |
sprintf(rbuf, "%-16d", r); |
76 |
rbuf[16] = '\n'; // replaces nul byte |
77 |
return rData->ReleaseMemory(rbuf, RDSwrite); |
78 |
79 |
/// Get buffer for indicated row (contents may be random) |
80 |
void * GetRow(int r) { |
81 |
if (!rData | (r < 0)) return NULL; |
82 |
if (r != curRow) { |
83 |
DoneRow(); |
84 |
if (r < nRows) |
85 |
rowp = rData->GetMemory(begData + r*rowBytes, |
86 |
rowBytes, 0); |
87 |
if (rowp) curRow = r; |
88 |
89 |
return rowp; |
90 |
91 |
/// Current row with byte offset |
92 |
void * InsertionP(int coffset) const { |
93 |
if (!rowp | (coffset < 0) | (coffset >= rowBytes)) |
94 |
return NULL; |
95 |
return (char *)rowp + coffset; |
96 |
97 |
/// Release current row, writing contents |
98 |
void DoneRow() { |
99 |
if (rowp) rData->ReleaseMemory(rowp, RDSwrite); |
100 |
101 |
102 |
/// Get next in list |
103 |
const RcontribOutput * Next() const { |
104 |
return next; |
105 |
106 |
RcontribOutput * Next() { |
107 |
return next; |
108 |
109 |
/// RcontribSimulManager gets full access |
110 |
friend class RcontribSimulManager; |
111 |
112 |
113 |
typedef double DCOLORV; // color accumulator type |
114 |
115 |
/// Modifier channel for recording contributions (no constructor/destructor) |
116 |
struct RcontribMod; |
117 |
118 |
/// Allocate rcontrib accumulator |
119 |
extern RcontribMod * NewRcMod(const char *prms = NULL, const char *binexpr = NULL, int ncbins = 1); |
120 |
/// Free an RcontribMod |
121 |
extern lut_free_t FreeRcMod; |
122 |
123 |
124 |
* General RcontribSimulManager class operation: |
125 |
126 |
* 1) Call LoadOctree(), then alter the header as desired |
127 |
* 2) Set number of spectral samples (NCSAMP) and call SetDataFormat() |
128 |
* 3) Call AddModifier() and AddModFile() to indicate tracked modifiers |
129 |
* 4) Set outOp and cdsF according to desired output/recovery |
130 |
* 5) Call PrepOutput() to open output channels |
131 |
* 6) Call SetThreadCount() to fork children if desired |
132 |
* 7) Set accum to the number of ray samples per record |
133 |
* 8) Call ComputeRecord() with accum ray samples |
134 |
* 9) Continue until GetRowMax() records have been sent |
135 |
* 10) Call Cleanup() |
136 |
137 |
* The order of some of these calls may be changed. Technically, the octree |
138 |
* may be loaded anytime before PrepOutput() is called. Also, SetThreadCount() |
139 |
* may be called anytime after PrepOutput() and interleaved with |
140 |
* calls to ComputeRecord(). The accum setting may be changed at any time. |
141 |
* Finally, it is possible to restart the output using ResetRow(), and |
142 |
* a zero argument will rewind to the beginning, whence all records |
143 |
* may be recalculated. The previous output rows are not zeroed or deleted, |
144 |
* but are overwritten as the calculation proceeds from the new starting point. |
145 |
* However, the output file(s) will indicate in the NROWS= line in the header |
146 |
* that only the newly calculated rows are present. |
147 |
148 |
* It is not possible to write to standard output, but the output |
149 |
* model is quite flexible thanks to the RdataShare polymorphic class. |
150 |
* The current default output class creates a shared, memory-mapped file, |
151 |
* which is the most efficient object on most systems. |
152 |
153 |
* ASCII output is not supported, so full data recovery is. |
154 |
155 |
156 |
/// Output channel opening options: new/exclusive, overwrite if exists, or recover data |
157 |
enum RCOutputOp {RCOnew=0, RCOforce, RCOrecover}; |
158 |
159 |
/// Converts above to RdataShare open flags (may be adjusted by calling program) |
160 |
extern int RSDOflags[]; |
161 |
162 |
/// Call-back function type to create named data channel (freed using "delete" operator) |
163 |
typedef RdataShare * RcreateDataShareF(const char *name, RCOutputOp op, size_t siz); |
164 |
165 |
/// Our default data share function |
166 |
extern RcreateDataShareF defDataShare; |
167 |
168 |
/// Modifiable ray-tracing flags for rcontrib |
169 |
#define RCmask (RTlimDist|RTimmIrrad) |
170 |
171 |
/// rcontrib-like simulation manager (at most one such object) |
172 |
class RcontribSimulManager : protected RtraceSimulManager { |
173 |
protected: |
174 |
static RayReportCall RctCall; // our callback for traced rays |
175 |
ABitMap rowsDone; // bit mask of completed rows |
176 |
uint32 rInPos; // which row (record) is next on input? |
177 |
uby8 nChan; // NCSAMP setting for this calculation |
178 |
char dtyp; // data type ('f', 'd', or 'c') |
179 |
uint16 dsiz; // N-component element size in bytes |
180 |
RcontribOutput * outList; // ordered list of output channels |
181 |
LUTAB modLUT; // modifier lookup table |
182 |
SUBPROC * kid; // array of child processes |
183 |
int32 * kidRow; // row assigned to each child |
184 |
int nkids; // child process count (-1 in child) |
185 |
bool UpdateRowsDone(int r); |
186 |
int GetChild(bool forceWait = false); |
187 |
bool StartKids(int n2go); |
188 |
int StopKids(int n2end = 0); |
189 |
void RunChild(); |
190 |
public: |
191 |
RCOutputOp outOp; // output operation |
192 |
RcreateDataShareF * cdsF; // data share creator |
193 |
uint32 accum; // # rays to accumulate per record |
194 |
RcontribSimulManager(const char *octn = NULL) |
195 |
: RtraceSimulManager(NULL, NULL, octn) { |
196 |
rInPos = 0; |
197 |
nChan = 0; |
198 |
dtyp = 'f'; |
199 |
dsiz = 0; |
200 |
outList = NULL; |
201 |
memset(&modLUT, 0, sizeof(modLUT)); |
202 |
modLUT.hashf = lu_shash; |
203 |
modLUT.keycmp = strcmp; |
204 |
modLUT.freek = efree; |
205 |
modLUT.freed = FreeRcMod; |
206 |
kid = NULL; kidRow = NULL; nkids = 0; |
207 |
rtFlags = RTtraceSources; |
208 |
SetTraceCall(&RctCall, this); |
209 |
outOp = RCOnew; |
210 |
cdsF = &defDataShare; |
211 |
accum = 1; |
212 |
213 |
~RcontribSimulManager() { |
214 |
Cleanup(); |
215 |
216 |
/// Check modifiable ray-tracing computation flag(s) |
217 |
bool HasFlag(int fl) const { |
218 |
return ((rtFlags & RCmask & fl) != 0); |
219 |
220 |
/// Set/reset modifiable ray-tracing computation flag(s) |
221 |
bool SetFlag(int fl, bool val = true) { |
222 |
if (!(fl &= RCmask)) return false; |
223 |
if (val) rtFlags |= fl; |
224 |
else rtFlags &= ~fl; |
225 |
return true; |
226 |
227 |
/// Load octree and prepare renderer |
228 |
bool LoadOctree(const char *octn) { |
229 |
return RtraceSimulManager::LoadOctree(octn); |
230 |
231 |
/// Prepare header from previous input (or clear) |
232 |
bool NewHeader(const char *inspec=NULL) { |
233 |
return RtraceSimulManager::NewHeader(inspec); |
234 |
235 |
/// Add a string to header (adds newline if none) |
236 |
bool AddHeader(const char *str) { |
237 |
return RtraceSimulManager::AddHeader(str); |
238 |
239 |
/// Append program line to header |
240 |
bool AddHeader(int ac, char *av[]) { |
241 |
return RtraceSimulManager::AddHeader(ac, av); |
242 |
243 |
/// Get current header length in bytes |
244 |
int GetHeadLen() const { |
245 |
return RtraceSimulManager::GetHeadLen(); |
246 |
247 |
/// Get header lines if any |
248 |
const char * GetHeadStr() const { |
249 |
return RtraceSimulManager::GetHeadStr(); |
250 |
251 |
/// Look for specific header keyword, return value |
252 |
const char * GetHeadStr(const char *key, bool inOK = false) const { |
253 |
return RtraceSimulManager::GetHeadStr(key, inOK); |
254 |
255 |
/// Set output format ('f', 'd', or 'c'), call before mods |
256 |
bool SetDataFormat(int ty); |
257 |
/// Get current format (and element size in bytes) |
258 |
int GetFormat(int *siz = NULL) const { |
259 |
if (siz) *siz = dsiz; |
260 |
return dtyp; |
261 |
262 |
/// Add a modifier and arguments, create output(s) |
263 |
bool AddModifier(const char *modn, const char *outspec, |
264 |
const char *prms = NULL, |
265 |
const char *binval = NULL, int bincnt = 1); |
266 |
/// Add a file of modifiers with associated arguments |
267 |
bool AddModFile(const char *modfn, const char *outspec, |
268 |
269 |
270 |
/// Get named rcontrib output (or list) |
271 |
const RcontribOutput * GetOutput(const char *nm = NULL) const { |
272 |
if (!nm) return outList; |
273 |
const RcontribOutput * op = outList; |
274 |
while (op && strcmp(op->GetName(), nm)) |
275 |
op = op->next; |
276 |
return op; |
277 |
278 |
/// Open output channels and return # completed rows |
279 |
int PrepOutput(); |
280 |
/// Are we ready to compute some records? |
281 |
bool Ready() const { |
282 |
return (rowsDone.Length() > 0) & (accum > 0); |
283 |
284 |
/// Set number of computation threads (0 => #cores) |
285 |
int SetThreadCount(int nt = 0); |
286 |
/// Check thread count (1 means no multi-processing) |
287 |
int NThreads() const { |
288 |
return nkids + !nkids; |
289 |
290 |
/// What is maximum row? |
291 |
int GetRowMax() const { |
292 |
if (!outList) return yres * (xres + !xres); |
293 |
return outList->nRows; |
294 |
295 |
/// Get current row count (# rows sent for computation) |
296 |
int GetRowCount() const { |
297 |
return rInPos; |
298 |
299 |
/// Get # rows completed |
300 |
int GetRowFinished() const { |
301 |
if (!nkids) return rInPos; |
302 |
uint32 nDone = rowsDone.Find(0, false); |
303 |
if (nDone == ABMend) |
304 |
return rowsDone.Length(); |
305 |
return nDone; |
306 |
307 |
/// Rewind calculation (previous results unchanged) |
308 |
bool ResetRow(int r); |
309 |
/// Add a ray/bundle to compute next record (n=accum) |
310 |
int ComputeRecord(const FVECT orig_direc[]); |
311 |
/// Finish pending rays if multi-processing |
312 |
bool FlushQueue() { |
313 |
if (nkids <= 0) return true; |
314 |
while (GetChild(true) >= 0) |
315 |
316 |
return true; |
317 |
318 |
/// Close octree, free data, return status |
319 |
int Cleanup(bool everything = false) { |
320 |
if (nkids < 0) return 0; // skip 4 child |
321 |
if (rowsDone.Length()) { |
322 |
SetThreadCount(1); |
323 |
cow_doneshare(); |
324 |
rowsDone.NewBitMap(0); |
325 |
326 |
lu_done(&modLUT); |
327 |
delete outList; outList = NULL; |
328 |
nChan = 0; |
329 |
return RtraceSimulManager::Cleanup(everything); |
330 |
331 |
332 |
333 |
#endif /* RcontribSimulManager_h */ |
