root/radiance/ray/src/rt/RcontribSimulManager.h
Thu Jan 2 16:16:49 2025 UTC (7 months ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.9: +21 -4 lines
fix(rxtrace,rxcontrib): Improvements and bug fixes in flag initialization, handling of light source tracing
Tue Dec 24 20:57:13 2024 UTC (7 months, 1 week ago) by greg
fix(rxcontrib): Turn off memory sharing before releasing octree
Tue Dec 3 17:39:42 2024 UTC (8 months ago) by greg
refactor(rxcontrib): Moved definition of formstr() to make it more accessible
Fri Nov 8 15:49:34 2024 UTC (8 months, 3 weeks ago) by greg
Changes since 2.6: +14 -8 lines
feat(rxcontrib): Added ClearModifiers() call to restart with same octree
Wed Nov 6 19:45:59 2024 UTC (8 months, 3 weeks ago) by greg
Changes since 2.5: +16 -15 lines
feat(rxcontrib): Folded resolution and contrib flag into main class
Wed Nov 6 18:28:52 2024 UTC (8 months, 3 weeks ago) by greg
perf(rxtrace,rxpict,rxpiece,rxcontrib): Improved exit strategy in children
Fri Nov 1 23:05:01 2024 UTC (9 months ago) by greg
feat(rxcontrib): Added a couple of minor sanity checks
Wed Oct 30 01:38:21 2024 UTC (9 months ago) by greg
fix(rxcontrib): Fixes in file loading & process management
Tue Oct 29 19:47:19 2024 UTC (9 months ago) by greg
Changes since 2.1: +25 -7 lines
Diff to previous 2.1
fix(rxcontrib): Fixed handling of -ld and -I command-line flags
Tue Oct 29 00:36:54 2024 UTC (9 months ago) by greg
feat(rxcontrib): First compiled version of rxcontrib tool to test new C++ classes
