#ifndef lint static const char RCSid[] = "$Id: RcontribSimulManager.cpp,v 2.24 2025/11/12 19:41:21 greg Exp $"; #endif /* * RcontribSimulManager.cpp * * Rcontrib simulation manager implementation * * Created by Greg Ward on 10/17/2024. */ #include #include #include "platform.h" #include "selcall.h" #include "RcontribSimulManager.h" #include "func.h" #include "resolu.h" #include "source.h" char RCCONTEXT[] = "RC."; extern const char HDRSTR[]; extern const char BIGEND[]; extern const char FMTSTR[]; // new/exclusive, overwrite if exists, or recover data int RSDOflags[] = {RDSwrite|RDSexcl|RDSextend, RDSwrite|RDSextend, RDSread|RDSwrite}; static const char ROWZEROSTR[] = "NROWS=0000000000000000\n"; #define LNROWSTR 6 // Modifier channel for recording contributions (no constructor/destructor) struct RcontribMod { RcontribOutput * opl; // pointer to first output channel char * params; // parameters string EPNODE * binv; // bin expression (NULL if 1 bin) int nbins; // bin count this modifier int coffset; // column offset in bytes DCOLORV cbin[1]; // bin accumulator (extends struct) /// Access specific (spectral) color bin DCOLORV * operator[](int n) { if ((n < 0) | (n >= nbins)) return NULL; return cbin + n*NCSAMP; } }; // Struct used to assign record calculation to child struct RowAssignment { uint32 row; // row to do uint32 ac; // accumulation count }; static const char ROW_DONE[] = "ROW FINISHED\n"; // allocate rcontrib accumulator static RcontribMod * NewRcMod(const char *prms, const char *binexpr, int ncbins) { if (binexpr && !*binexpr) binexpr = NULL; if (!prms) prms = ""; if ((ncbins > 1) & !binexpr) { error(USER, "missing bin expression"); return NULL; } if (ncbins < 1) ncbins = 1; RcontribMod * mp = (RcontribMod *)ecalloc(1, sizeof(RcontribMod) + sizeof(DCOLORV)*(NCSAMP*ncbins-1) + strlen(prms)+1); if (binexpr) { // get/check bin expression mp->binv = eparse(const_cast(binexpr)); if (mp->binv->type == NUM) { // constant expression (0)? if ((int)evalue(mp->binv) != 0) { sprintf(errmsg, "illegal non-zero constant for bin (%s)", binexpr); error(USER, errmsg); } if (ncbins > 1) { sprintf(errmsg, "bad bin count (%d should be 1)", ncbins); error(USER, errmsg); } epfree(mp->binv, true); mp->binv = NULL; prms = ""; ncbins = 1; } } mp->params = strcpy((char *)(mp->cbin + ncbins*NCSAMP), prms); mp->nbins = ncbins; return mp; } // Free an RcontribMod (public for RcontribSimulManager constructor) void FreeRcMod(void *p) { if (!p) return; EPNODE * bep = (*(RcontribMod *)p).binv; if (bep) epfree(bep, true); efree(p); } // Get format identifier const char * formstr(int f) { switch (f) { case 'a': return("ascii"); case 'f': return("float"); case 'd': return("double"); case 'c': return(NCSAMP==3 ? COLRFMT : SPECFMT); } return("unknown"); } // Standard file data share function RdataShare * fileDataShare(const char *name, RCOutputOp op, size_t siz) { if (op == RCOrecover && access(name, R_OK|W_OK) < 0) { sprintf(errmsg, "cannot recover from '%s'", name); error(SYSTEM, errmsg); return NULL; } RdataShare * rds = new RdataShareFile(name, RSDOflags[op], siz*(op != RCOforce)); if (!rds || (op == RCOforce && rds->Resize(siz) < siz)) { delete rds; sprintf(errmsg, "cannot create %lu byte output file '%s'", (unsigned long)siz, name); error(SYSTEM, errmsg); return NULL; } return rds; } // Memory-mapped data share function RdataShare * mapDataShare(const char *name, RCOutputOp op, size_t siz) { if (op == RCOrecover && access(name, R_OK|W_OK) < 0) { sprintf(errmsg, "cannot recover from '%s'", name); error(SYSTEM, errmsg); return NULL; } RdataShare * rds = new RdataShareMap(name, RSDOflags[op], siz*(op != RCOforce)); if (!rds || (op == RCOforce && rds->Resize(siz) < siz)) { delete rds; sprintf(errmsg, "cannot create %lu byte output map '%s'", (unsigned long)siz, name); error(SYSTEM, errmsg); return NULL; } return rds; } // Set output format ('f', 'd', or 'c') bool RcontribSimulManager::SetDataFormat(int ty) { if (outList) { error(INTERNAL, "cannot call SetDataFormat() after AddModifier()"); return false; } switch (ty) { case 'f': dsiz = sizeof(float)*NCSAMP; break; case 'd': dsiz = sizeof(double)*NCSAMP; break; case 'c': dsiz = LSCOLR; break; default: sprintf(errmsg, "unsupported output format '%c'", ty); error(INTERNAL, errmsg); return false; } dtyp = ty; return true; } // static call-back for rcontrib ray-tracing int RcontribSimulManager::RctCall(RAY *r, void *cd) { int i; if (!r->ro || (i = r->ro->omod) == OVOID) return 0; // hit nothing if (r->rsrc >= 0 && source[r->rsrc].so != r->ro) return 0; // shadow ray not on source const char * mname = objptr(i)->oname; RcontribSimulManager * rcp = (RcontribSimulManager *)cd; RcontribMod * mp = (RcontribMod *)lu_find(&rcp->modLUT,mname)->data; if (!mp) return 0; // not in our modifier list if (rcp->HasFlag(RCcontrib)) { // pre-emptive check for zero for (i = NCSAMP; i--; ) if (r->rcoef[i]*r->rcol[i] > FTINY) break; if (i < 0) return 0; // zero contribution } else if (sintens(r->rcoef) <= FTINY) return 0; // zero coefficient int bi = 0; // get bin index if (mp->binv) { worldfunc(RCCONTEXT, r); set_eparams(mp->params); double bval = evalue(mp->binv); if (bval <= -.5) return 0; // silently ignore negative bin index bi = int(bval + .5); } DCOLORV * dvp = (*mp)[bi]; if (!dvp) { sprintf(errmsg, "bad bin number for '%s' (%d ignored)", mname, bi); error(WARNING, errmsg); return 0; } SCOLOR contr; raycontrib(contr, r, PRIMARY); // compute coefficient if (rcp->HasFlag(RCcontrib)) smultscolor(contr, r->rcol); // -> value contribution for (i = 0; i < NCSAMP; i++) *dvp++ += contr[i]; // accumulate color/spectrum return 1; } // check for given format type in string, return last char position static int hasFormat(const char *tst, const char *match) { static const char allPoss[] = "%diouxXfFeEgGaAcsb"; const char * s = tst; while (*s) { if (*s++ != '%') continue; while (!strchr(allPoss, *s)) s++; if (strchr(match, *s)) break; s++; } return (*s != '\0')*(s - tst); } // Add a modifier and arguments, opening output file(s) bool RcontribSimulManager::AddModifier(const char *modn, const char *outspec, const char *prms, const char *binval, int bincnt) { if (!modn | !outspec || !*modn | !*outspec) { error(WARNING, "ignoring bad call to AddModifier()"); return false; } if (*outspec == '!') { error(USER, "command output not supported by RcontribSimulManager"); return false; } if (!nChan) { // initial call? if ((xres < 0) | (yres <= 0)) { error(USER, "xres, yres must be set before first modifier"); return false; } if (!SetDataFormat(dtyp)) return false; nChan = NCSAMP; } else if (nChan != NCSAMP) { error(USER, "# spectral channels must be fixed in AddModifier()"); return false; } if (Ready()) { error(INTERNAL, "call to AddModifier() after PrepOutput()"); return false; } LUENT * lp = lu_find(&modLUT, modn); if (lp->data) { sprintf(errmsg, "duplicate modifier '%s'", modn); error(USER, errmsg); return false; } if (!lp->key) // create new entry lp->key = strcpy((char *)emalloc(strlen(modn)+1), modn); RcontribMod * mp = NewRcMod(prms, binval, bincnt); if (!mp) return false; lp->data = (char *)mp; const int modndx = hasFormat(outspec, "sb"); const int binndx = hasFormat(outspec, "diouxX"); int bin0 = 0; char fnbuf[512]; if (!modndx || (binndx > 0) & (modndx > binndx)) sprintf(fnbuf, outspec, bin0, modn); else sprintf(fnbuf, outspec, modn, bin0); RcontribOutput * olast = NULL; RcontribOutput * op; for (op = outList; op; op = (olast=op)->next) { if (strcmp(op->GetName(), fnbuf)) continue; if (modndx) { // this ain't right sprintf(errmsg, "output name collision for '%s'", fnbuf); error(USER, errmsg); return false; } if ((binndx > 0) & (xres > 0)) { sprintf(fnbuf, outspec, ++bin0); continue; // each bin goes to another image } mp->coffset = op->rowBytes; // else add to what's there break; } if (!op) { // create new output channel? op = new RcontribOutput(fnbuf); if (olast) olast->next = op; else outList = op; } mp->opl = op; // first (maybe only) output channel if (modndx) // remember modifier if part of name op->omod = lp->key; if (binndx) { // append output image/bin list op->rowBytes += dsiz; op->obin = bin0; for (bincnt = 1; bincnt < mp->nbins; bincnt++) { if (!modndx || (binndx > 0) & (modndx > binndx)) sprintf(fnbuf, outspec, bin0+bincnt, modn); else sprintf(fnbuf, outspec, modn, bin0+bincnt); if (!op->next) { olast = op; olast->next = op = new RcontribOutput(fnbuf); if (modndx) op->omod = lp->key; op->obin = bin0+bincnt; } else { op = op->next; CHECK(op->obin != bin0+bincnt, CONSISTENCY, "bin number mismatch in AddModifier()"); } CHECK(op->rowBytes != mp->coffset, CONSISTENCY, "row offset mismatch in AddModifier()"); op->rowBytes += dsiz; } } else // else send all results to this channel op->rowBytes += mp->nbins*dsiz; return true; } // Add a file of modifiers with associated arguments bool RcontribSimulManager::AddModFile(const char *modfn, const char *outspec, const char *prms, const char *binval, int bincnt) { char * path = getpath(const_cast(modfn), getrlibpath(), R_OK); FILE * fp; if (!path || !(fp = fopen(path, "r"))) { sprintf(errmsg, "cannot %s modifier file '%s'", path ? "open" : "find", modfn); error(SYSTEM, errmsg); return false; } char mod[MAXSTR]; while (fgetword(mod, sizeof(mod), fp)) if (!AddModifier(mod, outspec, prms, binval, bincnt)) { fclose(fp); return false; } fclose(fp); return true; } // call-back to check if modifier has been loaded static int checkModExists(const LUENT *lp, void *p) { OBJECT mod = modifier(lp->key); if ((mod != OVOID) & (mod < nsceneobjs)) return 1; sprintf(errmsg, "tracked modifier '%s' not found in main scene", lp->key); error(WARNING, errmsg); return 0; } // Prepare output channels and return # completed rows int RcontribSimulManager::PrepOutput() { if (!outList || !RtraceSimulManager::Ready()) { error(INTERNAL, "PrepOutput() called before octree & modifiers set"); return -1; } if (!cdsF) { error(INTERNAL, "missing RdataShare constructor call (cdsF)"); return -1; } if (lu_doall(&modLUT, checkModExists, NULL) < 0) return -1; outList->nRows = yres * (xres + !xres); // all outputs have same #rows int remWarnings = 20; for (RcontribOutput *op = outList; op; op = op->next) { if (op->rData) { error(INTERNAL, "output channel already open in PrepOutput()"); return -1; } op->nRows = outList->nRows; op->rData = (*cdsF)(op->ofname, outOp, GetHeadLen()+1024 + op->nRows*op->rowBytes); freeqstr(op->ofname); op->ofname = NULL; if (outOp == RCOrecover) { int rd = op->CheckHeader(this); if (rd < 0) return -1; if (rd >= op->nRows) { if (remWarnings > 0) { sprintf(errmsg, "recovered output '%s' is complete", op->GetName()); error(WARNING, --remWarnings ? errmsg : "etc..."); } rd = op->nRows; } if (!rInPos | (rInPos > rd)) rInPos = rd; } else if (!op->NewHeader(this)) return -1; // make sure there's room if (op->rData->GetSize() < op->begData + op->nRows*op->rowBytes && !op->rData->Resize(op->begData + op->nRows*op->rowBytes)) return -1; // calls error() for us } rowsDone.NewBitMap(outList->nRows); // create row completion map rowsDone.ClearBits(0, rInPos, true); return nrDone = rInPos; } // Create header in open write-only channel bool RcontribOutput::NewHeader(const RcontribSimulManager *rcp) { int headlim = rcp->GetHeadLen() + 1024; char * hdr = (char *)rData->GetMemory(0, headlim, 0); int esiz; const int etyp = rcp->GetFormat(&esiz); strcpy(hdr, HDRSTR); strcat(hdr, "RADIANCE\n"); begData = strlen(hdr); strcpy(hdr+begData, rcp->GetHeadStr()); begData += rcp->GetHeadLen(); if (omod) { sprintf(hdr+begData, "MODIFIER=%s\n", omod); begData += strlen(hdr+begData); } if (obin >= 0) { sprintf(hdr+begData, "BIN=%d\n", obin); begData += strlen(hdr+begData); } strcpy(hdr+begData, ROWZEROSTR); rowCountPos = begData+LNROWSTR; begData += sizeof(ROWZEROSTR)-1; if (!rcp->xres | (rowBytes > esiz)) { sprintf(hdr+begData, "NCOLS=%d\n", int(rowBytes/esiz)); begData += strlen(hdr+begData); } sprintf(hdr+begData, "%s%d\n", NCOMPSTR, NCSAMP); begData += strlen(hdr+begData); if (NCSAMP > 3) { sprintf(hdr+begData, "%s %g %g %g %g\n", WLSPLTSTR, WLPART[0], WLPART[1], WLPART[2], WLPART[3]); begData += strlen(hdr+begData); } if (etyp != 'c') { sprintf(hdr+begData, "%s%d\n", BIGEND, nativebigendian()); begData += strlen(hdr+begData); } int align = 0; switch (etyp) { case 'f': align = sizeof(float); break; case 'd': align = sizeof(double); break; case 'c': break; default: error(INTERNAL, "unsupported data type in NewHeader()"); return false; } strcpy(hdr+begData, FMTSTR); // write format string begData += strlen(hdr+begData); strcpy(hdr+begData, formstr(etyp)); begData += strlen(hdr+begData); if (align) // align data at end of header while ((begData+2) % align) hdr[begData++] = ' '; hdr[begData++] = '\n'; // EOL for data format hdr[begData++] = '\n'; // end of nominal header if ((rcp->xres > 0) & (rowBytes == esiz)) { // tack on resolution string? sprintf(hdr+begData, PIXSTDFMT, rcp->yres, rcp->xres); begData += strlen(hdr+begData); } return rData->ReleaseMemory(hdr, RDSwrite); } // find string argument in header for named variable static const char * findArgs(const char *hdr, const char *vnm, int len) { const char * npos = strnstr(hdr, vnm, len); if (!npos) return NULL; npos += strlen(vnm); // find start of (first) argument len -= npos - hdr; while (len-- > 0 && (*npos == '=') | isspace(*npos)) if (*npos++ == '\n') return NULL; return (len >= 0) ? npos : NULL; } // Load and check header in read/write channel int RcontribOutput::CheckHeader(const RcontribSimulManager *rcp) { int esiz; const int etyp = rcp->GetFormat(&esiz); const int maxlen = rcp->GetHeadLen() + 1024; char * hdr = (char *)rData->GetMemory(0, maxlen, RDSread); const char * cp; // find end of header if (!hdr || !(cp = strnstr(hdr, "\n\n", maxlen))) { sprintf(errmsg, "cannot find end of header in '%s'", GetName()); error(USER, errmsg); return -1; } begData = cp - hdr + 1; // increment again at end // check # components if (((cp = findArgs(hdr, NCOMPSTR, begData)) ? atoi(cp) : 3) != NCSAMP) { sprintf(errmsg, "expected %s%d in '%s'", NCOMPSTR, NCSAMP, GetName()); error(USER, errmsg); return -1; } // check format if (!(cp = findArgs(hdr, FMTSTR, begData)) || strncmp(cp, formstr(etyp), strlen(formstr(etyp)))) { sprintf(errmsg, "expected %s%s in '%s'", FMTSTR, formstr(etyp), GetName()); error(USER, errmsg); return -1; } // check #columns if ((cp = findArgs(hdr, "NCOLS=", begData)) ? (atoi(cp)*esiz != rowBytes) : (!rcp->xres | (rowBytes > esiz))) { sprintf(errmsg, "expected NCOLS=%d in '%s'", int(rowBytes/esiz), GetName()); error(USER, errmsg); return -1; } // find row count if (!(cp = findArgs(hdr, "NROWS=", begData))) { sprintf(errmsg, "missing NROWS in '%s'", GetName()); error(USER, errmsg); return -1; } rowCountPos = cp - hdr; int rlast = atoi(cp); begData++; // advance past closing EOL if ((rcp->xres > 0) & (rowBytes == esiz)) { // check/skip resolution string? char rbuf[64]; sprintf(rbuf, PIXSTDFMT, rcp->yres, rcp->xres); int rlen = strlen(rbuf); if (strncmp(rbuf, hdr+begData, rlen)) { sprintf(errmsg, "bad resolution string in '%s'", GetName()); error(USER, errmsg); return -1; } begData += rlen; } // XXX assume the rest is OK: endianness, wavelength splits, modifier, bin return rData->ReleaseMemory(hdr, 0) ? rlast : -1; } // Rewind calculation (previous results unchanged) bool RcontribSimulManager::ResetRow(int r) { if (!rowsDone.Length() | (0 > r) | (r >= rInPos)) { error(WARNING, "ignoring bad call to ResetRow()"); return (r == rInPos); } FlushQueue(); // finish current and reset for (RcontribOutput *op = outList; op; op = op->next) if (!op->SetRowsDone(r)) return false; rowsDone.ClearBits(r, rInPos-r, false); nrDone = rInPos = r; return true; } // call-back for averaging each modifier's contributions to assigned channel(s) static int putModContrib(const LUENT *lp, void *p) { RcontribMod * mp = (RcontribMod *)lp->data; const RcontribSimulManager * rcp = (const RcontribSimulManager *)p; const double sca = 1./rcp->accum; const DCOLORV * dvp = mp->cbin; RcontribOutput * op = mp->opl; int i, n; switch (rcp->GetFormat()) { // conversion based on output type case 'd': { double * dvo = (double *)op->InsertionP(mp->coffset); for (n = mp->nbins; n--; ) { for (i = 0; i < NCSAMP; i++) *dvo++ = *dvp++ * sca; if ((op->obin >= 0) & (n > 0)) dvo = (double *)(op = op->Next())->InsertionP(mp->coffset); } } break; case 'f': { float * fvo = (float *)op->InsertionP(mp->coffset); for (n = mp->nbins; n--; ) { for (i = 0; i < NCSAMP; i++) *fvo++ = float(*dvp++ * sca); if ((op->obin >= 0) & (n > 0)) fvo = (float *)(op = op->Next())->InsertionP(mp->coffset); } } break; case 'c': { COLRV * cvo = (COLRV *)op->InsertionP(mp->coffset); for (n = mp->nbins; n--; ) { SCOLOR scol; for (i = 0; i < NCSAMP; i++) scol[i] = COLORV(*dvp++ * sca); scolor_scolr(cvo, scol); cvo += LSCOLR; if ((op->obin >= 0) & (n > 0)) cvo = (COLRV *)(op = op->Next())->InsertionP(mp->coffset); } } break; default: error(CONSISTENCY, "unsupported output type in putModContrib()"); return -1; } // clear for next tally memset(mp->cbin, 0, sizeof(DCOLORV)*NCSAMP*mp->nbins); return 1; } // Add a ray/bundle to compute next record int RcontribSimulManager::ComputeRecord(const FVECT orig_direc[]) { if (!Ready()) return 0; if (rInPos >= outList->nRows) { error(WARNING, "ComputeRecord() called after last record"); return 0; } if (nkids > 0) { // in parent process? int k = GetChild(false); // updates output rows if (k < 0) return -1; // someone died? RowAssignment rass; rass.row = kidRow[k] = rInPos++; rass.ac = accum; if (write(kid[k].w, &rass, sizeof(rass)) != sizeof(rass) || writebuf(kid[k].w, orig_direc, sizeof(FVECT)*2*accum) != sizeof(FVECT)*2*accum) { error(SYSTEM, "cannot write to child; dead process?"); return -1; } return accum; // tracing/output happens in child } if (NCSAMP != nChan) { error(INTERNAL, "number of color channels must remain fixed"); return -1; } // actual work is done here... if (EnqueueBundle(orig_direc, accum) < 0) return -1; RcontribOutput * op; // prepare output buffers for (op = outList; op; op = op->next) if (!op->GetRow(rInPos)) return -1; // convert averages & clear if (lu_doall(&modLUT, putModContrib, this) < 0) return -1; // write buffers for (op = outList; op; op = op->next) op->DoneRow(); if (!nkids) // update row if solo process UpdateRowsDone(rInPos++); // XXX increment here is critical return accum; } // Get next available child, returning index or -1 if forceWait & idling int RcontribSimulManager::GetChild(bool forceWait) { if (nkids <= 0) return -1; // take inventory int pn, n = 0; fd_set readset, errset; FD_ZERO(&readset); FD_ZERO(&errset); for (pn = nkids; pn--; ) { if (kidRow[pn] < 0) { // child already ready? if (forceWait) continue; return pn; // good enough } FD_SET(kid[pn].r, &readset); // will check on this one FD_SET(kid[pn].r, &errset); if (kid[pn].r >= n) n = kid[pn].r + 1; } if (!n) // every child is idle? return -1; // wait on "busy" child(ren) while ((n = select(n, &readset, NULL, &errset, NULL)) <= 0) if (errno != EINTR) { error(SYSTEM, "select call failed in GetChild()"); return -1; } char buf[sizeof(ROW_DONE)] = "X"; pn = -1; // get flags set by select for (n = nkids; n--; ) if (kidRow[n] >= 0 && FD_ISSET(kid[n].r, &readset) | FD_ISSET(kid[n].r, &errset)) { // check for error if (FD_ISSET(kid[n].r, &errset) || read(kid[n].r, buf, sizeof(ROW_DONE)) <= 0 || memcmp(buf, ROW_DONE, sizeof(ROW_DONE))) return -1; // update output row counts UpdateRowsDone(kidRow[n]); kidRow[n] = -1; // flag child available pn = n; } return pn; } // Update row completion bitmap and update outputs (does not change rInPos) bool RcontribSimulManager::UpdateRowsDone(int r) { if (!rowsDone.TestAndSet(r)) { error(WARNING, "redundant call to UpdateRowsDone()"); return false; } GetRowFinished(); if (nrDone <= r) return true; // nothing to update, yet for (RcontribOutput *op = outList; op; op = op->next) if (!op->SetRowsDone(nrDone)) return false; return true; // up-to-date } // Run rcontrib child process (never returns) void RcontribSimulManager::RunChild() { FVECT * vecList = NULL; RowAssignment rass; ssize_t nr; accum = 0; errno = 0; while ((nr = read(0, &rass, sizeof(rass))) == sizeof(rass)) { if (!rass.ac) { error(CONSISTENCY, "bad accumulator count in child"); exit(1); } if (rass.ac > accum) { efree(vecList); vecList = (FVECT *)emalloc(sizeof(FVECT)*2*rass.ac); } accum = rass.ac; rInPos = rass.row; if (readbuf(0, vecList, sizeof(FVECT)*2*accum) != sizeof(FVECT)*2*accum) break; if (ComputeRecord(vecList) <= 0) exit(1); // signal this row is done if (write(1, ROW_DONE, sizeof(ROW_DONE)) != sizeof(ROW_DONE)) exit(1); } if (nr) { error(SYSTEM, "read error in child process"); exit(1); } exit(0); } // Add child processes as indicated bool RcontribSimulManager::StartKids(int n2go) { if ((n2go <= 0) | (nkids + n2go <= 1)) return false; if (!nkids) cow_memshare(); // preload objects n2go += nkids; // => desired brood size kid = (SUBPROC *)erealloc(kid, sizeof(SUBPROC)*n2go); kidRow = (int32 *)erealloc(kidRow, sizeof(int32)*n2go); fflush(stdout); // shouldn't use, anyway while (nkids < n2go) { kid[nkids] = sp_inactive; int rv = open_process(&kid[nkids], NULL); if (!rv) { // in child process? while (nkids-- > 0) { close(kid[nkids].r); close(kid[nkids].w); } free(kid); free(kidRow); kid = NULL; kidRow = NULL; RunChild(); // should never return _exit(1); } if (rv < 0) { error(SYSTEM, "cannot fork worker process"); return false; } kidRow[nkids++] = -1; // newborn is ready } return true; } // Reap the indicated number of children (all if 0) int RcontribSimulManager::StopKids(int n2end) { if (nkids <= 0) return 0; FlushQueue(); int status = 0; if (!n2end | (n2end >= nkids)) { // end all subprocesses? status = close_processes(kid, nkids); free(kid); free(kidRow); kid = NULL; kidRow = NULL; nkids = 0; } else { // else shrink family int st; while (n2end-- > 0) if ((st = close_process(&kid[--nkids])) > 0) status = st; // could call realloc(), but it hardly matters } if (status) { sprintf(errmsg, "non-zero (%d) status from child", status); error(WARNING, errmsg); } return status; } // Set number of computation threads (0 => #cores) int RcontribSimulManager::SetThreadCount(int nt) { if (!Ready()) { error(INTERNAL, "must call PrepOutput() before SetThreadCount()"); return 0; } if (nt < 0) return NThreads(); if (!nt) nt = GetNCores(); int status = 0; if (nt == 1) status = StopKids(); else if (nt < nkids) status = StopKids(nkids-nt); else if (nt > nkids) StartKids(nt-nkids); if (status) { sprintf(errmsg, "non-zero (%d) status from child", status); error(WARNING, errmsg); } return NThreads(); }
