--- ray/src/rt/RcontribSimulManager.cpp 2024/11/01 16:17:33 2.4 +++ ray/src/rt/RcontribSimulManager.cpp 2024/11/06 19:45:59 2.7 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: RcontribSimulManager.cpp,v 2.4 2024/11/01 16:17:33 greg Exp $"; +static const char RCSid[] = "$Id: RcontribSimulManager.cpp,v 2.7 2024/11/06 19:45:59 greg Exp $"; #endif /* * RcontribSimulManager.cpp @@ -24,11 +24,6 @@ extern const char HDRSTR[]; extern const char BIGEND[]; extern const char FMTSTR[]; -int contrib = 0; // computing contributions? - -int xres = 0; // horizontal (scan) size -int yres = 0; // vertical resolution - // new/exclusive, overwrite if exists, or recover data int RSDOflags[] = {RDSwrite|RDSexcl|RDSextend, RDSwrite|RDSextend, RDSread|RDSwrite}; @@ -148,7 +143,7 @@ RcontribSimulManager::RctCall(RAY *r, void *cd) int bi = 0; // get bin index if (mp->binv) { - worldfunc(RCCONTEXT, r); // compute bin # + worldfunc(RCCONTEXT, r); set_eparams(mp->params); double bval = evalue(mp->binv); if (bval <= -.5) @@ -163,7 +158,7 @@ RcontribSimulManager::RctCall(RAY *r, void *cd) } SCOLOR contr; raycontrib(contr, r, PRIMARY); // compute coefficient - if (contrib) + if (rcp->HasFlag(RCcontrib)) smultscolor(contr, r->rcol); // -> value contribution for (int i = 0; i < NCSAMP; i++) *dvp++ += contr[i]; // accumulate color/spectrum @@ -198,6 +193,10 @@ RcontribSimulManager::AddModifier(const char *modn, co return false; } if (!nChan) { // initial call? + if ((xres < 0) | (yres <= 0)) { + error(INTERNAL, "xres, yres must be set before first modifier"); + return false; + } if (!SetDataFormat(dtyp)) return false; nChan = NCSAMP; @@ -324,6 +323,10 @@ RcontribSimulManager::PrepOutput() error(INTERNAL, "PrepOutput() called before octree & modifiers assigned"); return -1; } + if (!cdsF) { + error(INTERNAL, "missing RdataShare constructor call (*cdsF)"); + return -1; + } if (lu_doall(&modLUT, checkModExists, NULL) < 0) return -1; @@ -388,7 +391,7 @@ RcontribOutput::NewHeader(const RcontribSimulManager * strcpy(hdr+begData, ROWZEROSTR); rowCountPos = begData+LNROWSTR; begData += sizeof(ROWZEROSTR)-1; - if (!xres | (rowBytes > esiz)) { + if (!rcp->xres | (rowBytes > esiz)) { sprintf(hdr+begData, "NCOLS=%d\n", int(rowBytes/esiz)); begData += strlen(hdr+begData); } @@ -426,8 +429,8 @@ RcontribOutput::NewHeader(const RcontribSimulManager * hdr[begData++] = ' '; hdr[begData++] = '\n'; // EOL for data format hdr[begData++] = '\n'; // end of nominal header - if ((xres > 0) & (rowBytes == esiz)) { // tack on resolution string? - sprintf(hdr+begData, PIXSTDFMT, yres, xres); + if ((rcp->xres > 0) & (rowBytes == esiz)) { // tack on resolution string? + sprintf(hdr+begData, PIXSTDFMT, rcp->yres, rcp->xres); begData += strlen(hdr+begData); } return rData->ReleaseMemory(hdr, RDSwrite); @@ -481,7 +484,7 @@ RcontribOutput::CheckHeader(const RcontribSimulManager } // check #columns if (((cp = findArgs(hdr, "NCOLS=", begData)) && atoi(cp)*esiz != rowBytes) || - !xres | (rowBytes > esiz)) { + !rcp->xres | (rowBytes > esiz)) { sprintf(errmsg, "expected NCOLS=%d in '%s'", int(rowBytes/esiz), GetName()); error(USER, errmsg); @@ -496,9 +499,9 @@ RcontribOutput::CheckHeader(const RcontribSimulManager rowCountPos = cp - hdr; int rlast = atoi(cp); begData++; // advance past closing EOL - if ((xres > 0) & (rowBytes == esiz)) { // check/skip resolution string? + if ((rcp->xres > 0) & (rowBytes == esiz)) { // check/skip resolution string? char rbuf[64]; - sprintf(rbuf, PIXSTDFMT, yres, xres); + sprintf(rbuf, PIXSTDFMT, rcp->yres, rcp->xres); int rlen = strlen(rbuf); if (strncmp(rbuf, hdr+begData, rlen)) { sprintf(errmsg, "bad resolution string in '%s'", GetName()); @@ -796,7 +799,7 @@ RcontribSimulManager::SetThreadCount(int nt) return 0; } if (nt < 0) - return nkids; + return NThreads(); if (!nt) nt = GetNCores(); int status = 0; if (nt == 1) @@ -809,5 +812,5 @@ RcontribSimulManager::SetThreadCount(int nt) sprintf(errmsg, "non-zero (%d) status from child", status); error(WARNING, errmsg); } - return nkids; + return NThreads(); }
