root/Development/ray/src/rt/RcontribSimulManager.cpp
Wed Nov 12 19:41:21 2025 UTC (6 weeks, 5 days ago) by greg
Changes since 2.23: +9 -8 lines
Diff to previous 2.23 , to selected 2.14
perf(rtcontrib,rxfluxmtx): Minor optimization
Tue Nov 11 02:08:52 2025 UTC (7 weeks ago) by greg
Changes since 2.22: +12 -5 lines
Diff to previous 2.22 , to selected 2.14
perf(rcontrib,rxfluxmtx,rxcontrib,rxfluxmtx): Better preemptive check
Tue Nov 11 00:19:10 2025 UTC (7 weeks ago) by greg
Diff to previous 2.21 , to selected 2.14
perf(rcontrib,rxcontrib,rxfluxmtx): Added preemptive test for zero contribution
Mon Oct 27 18:38:32 2025 UTC (2 months ago) by greg
Changes since 2.20: +23 -3 lines
Diff to previous 2.20 , to selected 2.14
fix(rxfluxmtx,rxcontrib): initial truncation of forced output overwrite
Sat Oct 25 18:01:23 2025 UTC (2 months ago) by greg
Diff to previous 2.19 , to selected 2.14
refactor: Minor correction to WLSPLIT= header line format (no affect on correctness, just neater)
Sat Oct 25 03:30:35 2025 UTC (2 months ago) by greg
Changes since 2.18: +9 -10 lines
Diff to previous 2.18 , to selected 2.14
fix(rxcontrib,rxfluxmtx): Repaired logic with NCOLS= and -r + speed improvement
Fri Oct 24 18:37:05 2025 UTC (2 months ago) by greg
Changes since 2.17: +12 -2 lines
Diff to previous 2.17 , to selected 2.14
fix(rxcontrib,rxfluxmtx): recovery mode issues
Thu Oct 23 16:33:39 2025 UTC (2 months ago) by greg
Changes since 2.16: +10 -3 lines
Diff to previous 2.16 , to selected 2.14
refactor: Added fileDataShare() definition for convenience
Thu Oct 23 01:26:48 2025 UTC (2 months, 1 week ago) by greg
Changes since 2.15: +2 -1 lines
Diff to previous 2.15 , to selected 2.14
fix(rxfluxmtx): Added -t option and numerous bug fixes
Fri Oct 17 17:43:53 2025 UTC (2 months, 1 week ago) by greg
Changes since 2.14: +24 -24 lines
Diff to previous 2.14
refactor(rxcontrib): Privatized things that didn't need to be extern
Fri Oct 17 01:15:53 2025 UTC (2 months, 1 week ago) by greg
Changes since 2.13: +28 -18 lines
Diff to previous 2.13
perf(rxcontrib): Added handshake to ensure each row is complete in children
Thu Oct 16 23:14:31 2025 UTC (2 months, 1 week ago) by greg
Changes since 2.12: +6 -5 lines
perf: Minor fixes/optimizations
Thu Oct 16 18:36:23 2025 UTC (2 months, 1 week ago) by greg
Changes since 2.11: +5 -1 lines
fix: Added missing error diagnostics
Thu Jan 2 16:16:49 2025 UTC (11 months, 3 weeks ago) by greg
CVS Tags: rad6R0
Changes since 2.10: +18 -13 lines
fix(rxtrace,rxcontrib): Improvements and bug fixes in flag initialization, handling of light source tracing
Tue Dec 10 00:38:59 2024 UTC (12 months, 2 weeks ago) by greg
Changes since 2.9: +21 -12 lines
fix(rxcontrib): Allow for non-constant expressions for lone bin
Tue Dec 3 17:39:42 2024 UTC (12 months, 3 weeks ago) by greg
Changes since 2.8: +14 -1 lines
refactor(rxcontrib): Moved definition of formstr() to make it more accessible
Thu Nov 7 18:07:43 2024 UTC (13 months, 3 weeks ago) by greg
Changes since 2.7: +11 -11 lines
fix(rxcontrib): Fixed issues with modifier names in output files
Wed Nov 6 19:45:59 2024 UTC (13 months, 3 weeks ago) by greg
Changes since 2.6: +12 -13 lines
feat(rxcontrib): Folded resolution and contrib flag into main class
Wed Nov 6 18:28:52 2024 UTC (13 months, 3 weeks ago) by greg
perf(rxtrace,rxpict,rxpiece,rxcontrib): Improved exit strategy in children
Fri Nov 1 23:05:01 2024 UTC (13 months, 4 weeks ago) by greg
Changes since 2.4: +6 -2 lines
feat(rxcontrib): Added a couple of minor sanity checks
Fri Nov 1 16:17:33 2024 UTC (13 months, 4 weeks ago) by greg
Changes since 2.3: +44 -14 lines
feat(rxcontrib): more robust checking of bin expressions, etc.
Wed Oct 30 01:38:21 2024 UTC (14 months ago) by greg
Changes since 2.2: +5 -4 lines
fix(rxcontrib): Fixes in file loading & process management
Tue Oct 29 19:47:19 2024 UTC (14 months ago) by greg
Changes since 2.1: +6 -24 lines
fix(rxcontrib): Fixed handling of -ld and -I command-line flags
Tue Oct 29 00:36:54 2024 UTC (14 months ago) by greg
Diff to selected 2.14
feat(rxcontrib): First compiled version of rxcontrib tool to test new C++ classes
