--- ray/src/rt/RcontribSimulManager.cpp 2024/10/29 00:36:54 2.1 +++ ray/src/rt/RcontribSimulManager.cpp 2024/10/29 19:47:19 2.2 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: RcontribSimulManager.cpp,v 2.1 2024/10/29 00:36:54 greg Exp $"; +static const char RCSid[] = "$Id: RcontribSimulManager.cpp,v 2.2 2024/10/29 19:47:19 greg Exp $"; #endif /* * RcontribSimulManager.cpp @@ -24,9 +24,11 @@ extern const char HDRSTR[]; extern const char BIGEND[]; extern const char FMTSTR[]; -extern int contrib; /* computing contributions? */ -extern int lim_dist; /* limit distance? */ +int contrib = 0; // computing contributions? +int xres = 0; // horizontal (scan) size +int yres = 0; // vertical resolution + // new/exclusive, overwrite if exists, or recover data int RSDOflags[] = {RDSwrite|RDSexcl|RDSextend, RDSwrite|RDSextend, RDSread|RDSwrite}; @@ -49,7 +51,7 @@ struct RcontribMod { } }; -// used to assign record calc to child +// Struct used to assign record calculation to child struct RowAssignment { uint32 row; // row to do uint32 ac; // accumulation count @@ -287,21 +289,6 @@ RcontribSimulManager::AddModFile(const char *modfn, co return true; } -// Run through current list of output struct's -int -RcontribSimulManager::GetOutputs(RoutputShareF *osF, void *cd) const -{ - int cnt = 0; - - for (const RcontribOutput *op = outList; op; op = op->next) { - int rv = 1; - if (osF && (rv = (*osF)(op, cd)) < 0) - return rv; - cnt += rv; - } - return cnt; -} - // Prepare output channels and return # completed rows int RcontribSimulManager::PrepOutput() @@ -341,11 +328,6 @@ RcontribSimulManager::PrepOutput() !op->rData->Resize(op->begData + op->nRows*op->rowBytes)) return -1; // calls error() for us } - if (lim_dist) // XXX where else to put this? - rtFlags |= RTlimDist; - else - rtFlags &= ~RTlimDist; - rowsDone.NewBitMap(outList->nRows); // create row completion map rowsDone.ClearBits(0, rInPos, true); return rInPos;
