root/radiance/ray/src/rt/RcontribSimulManager.cpp
Thu Jan 2 16:16:49 2025 UTC (4 months, 4 weeks ago) by greg
Changes since 2.10: +18 -13 lines
fix(rxtrace,rxcontrib): Improvements and bug fixes in flag initialization, handling of light source tracing
Tue Dec 10 00:38:59 2024 UTC (5 months, 3 weeks ago) by greg
Changes since 2.9: +21 -12 lines
fix(rxcontrib): Allow for non-constant expressions for lone bin
Tue Dec 3 17:39:42 2024 UTC (5 months, 4 weeks ago) by greg
Changes since 2.8: +14 -1 lines
refactor(rxcontrib): Moved definition of formstr() to make it more accessible
Thu Nov 7 18:07:43 2024 UTC (6 months, 3 weeks ago) by greg
Changes since 2.7: +11 -11 lines
fix(rxcontrib): Fixed issues with modifier names in output files
Wed Nov 6 19:45:59 2024 UTC (6 months, 3 weeks ago) by greg
Changes since 2.6: +12 -13 lines
feat(rxcontrib): Folded resolution and contrib flag into main class
Wed Nov 6 18:28:52 2024 UTC (6 months, 3 weeks ago) by greg
perf(rxtrace,rxpict,rxpiece,rxcontrib): Improved exit strategy in children
Fri Nov 1 23:05:01 2024 UTC (7 months ago) by greg
Changes since 2.4: +6 -2 lines
feat(rxcontrib): Added a couple of minor sanity checks
Fri Nov 1 16:17:33 2024 UTC (7 months ago) by greg
Changes since 2.3: +44 -14 lines
feat(rxcontrib): more robust checking of bin expressions, etc.
Wed Oct 30 01:38:21 2024 UTC (7 months ago) by greg
Changes since 2.2: +5 -4 lines
fix(rxcontrib): Fixes in file loading & process management
Tue Oct 29 19:47:19 2024 UTC (7 months ago) by greg
Changes since 2.1: +6 -24 lines
fix(rxcontrib): Fixed handling of -ld and -I command-line flags
Tue Oct 29 00:36:54 2024 UTC (7 months ago) by greg
feat(rxcontrib): First compiled version of rxcontrib tool to test new C++ classes
