root/radiance/ray/src/rt/README
Revision: 2.4
Committed: Sun Nov 22 10:55:08 1992 UTC (32 years, 5 months ago) by greg
Changes since 2.3: +1 -0 lines
added freeobjmem module for rview when memory is scarce
1 RENDERING PROGRAMS
2 SCCSid "$SunId$ LBL"
3
4 This directory contains the RADIANCE renderers "rpict", "rtrace" and "rview".
5
6 ambient.h common definitions for interreflection routines
7 data.h header file for routines which interpolate data
8 driver.h header file for interactive device drivers
9 func.h header file for modifiers using function files
10 nwsdev.h header file for NeWS driver
11 otspecial.h special type flags for objects used in rendering
12 ray.h header file for routines using rays
13 rpaint.h header file for image painting (rview)
14 source.h header file for ray tracing sources
15 x11icon.h icon for rview under X11
16 x11twind.h header for X11 text window routines
17 xtwind.h header for X10 text window routines
18 Version.c program version
19 aed.c driver for AED 512 terminal
20 ambcomp.c routines to compute "ambient" values using Monte Carlo
21 ambient.c routines dealing with ambient (inter-reflected) component
22 ambio.c ambient value input and output routines
23 aniso.c material functions for plastic2, metal2 and trans2
24 caldefn.c store variable definitions
25 calexpr.c compute data values using expression parser
26 colortab.c allocate and control dynamic color table
27 data.c routines dealing with interpolated data
28 devcomm.c communication routines for separate drivers
29 devmain.c main for independent drivers
30 devtable.c device table for rview
31 dielectric.c shading function for transparent materials
32 editline.c routine for editing raw input for rview
33 freeobjmem.c routines for freeing unneeded object structures
34 func.c interface to calcomp functions
35 glass.c simpler shading function for thin glass surfaces
36 initotypes.c initialize ofun[] list for renderers
37 lookamb.c program to examine ambient components
38 m_brdf.c shading for materials with arbitrary BRDF's
39 m_clip.c routine for clipped (cut) objects
40 m_direct.c routines for prism material types
41 m_mirror.c routines for mirror material supporting virtual light sources
42 malloc.c memory allocation routines
43 mx_data.c routine for stored mixtures
44 mx_func.c routine for mixture functions
45 noise3.c noise functions for random textures
46 normal.c shading function for normal materials
47 nwsdev.c NeWS driver, by Isaac Kwo
48 nwsdev.cps NeWS driver source
49 o_cone.c routine to determine ray intersection with cones
50 o_face.c compute ray intersection with faces
51 o_instance.c routines for computing ray intersections with octrees
52 p_data.c routine for stored patterns
53 p_func.c routine for procedural patterns
54 rayinit.cal initialization function file
55 raytrace.c routines for tracing and shading rays
56 readfargs.c allocate, read and free object arguments
57 rmain.c main for ray tracing programs
58 rpict.c routines and variables for picture generation
59 rtrace.c program and variables for individual ray tracing
60 rv2.c command routines used in tracing a view
61 rv3.c miscellaneous routines for rview
62 rview.c routines and variables for interactive view generation
63 source.c routines dealing with illumination sources
64 sphere.c compute ray intersection with spheres
65 srcsamp.c source sampling routines
66 srcsupp.c support routines for source objects and materials
67 suncom.c program to read and edit raw tty input
68 sundev.c standalone driver for Sunwindows
69 t_data.c routine for stored textures
70 t_func.c routine for procedural textures
71 text.c functions for text patterns and mixtures
72 tty.c i/o for terminal drivers
73 virtuals.c routines for simulating virtual light sources
74 x10.c driver for X-windows version 10R4
75 x11.c driver for X-windows version 11R3
76 x11twind.c routines for X11 text windows
77 xtwind.c routines for X text windows
78 zeroes.c compute roots for various equations
