--- ray/src/rt/README 1991/11/11 16:14:22 1.1 +++ ray/src/rt/README 1992/11/22 10:55:08 2.4 @@ -6,6 +6,7 @@ This directory contains the RADIANCE renderers "rpict" ambient.h common definitions for interreflection routines data.h header file for routines which interpolate data driver.h header file for interactive device drivers +func.h header file for modifiers using function files nwsdev.h header file for NeWS driver otspecial.h special type flags for objects used in rendering ray.h header file for routines using rays @@ -18,6 +19,8 @@ Version.c program version aed.c driver for AED 512 terminal ambcomp.c routines to compute "ambient" values using Monte Carlo ambient.c routines dealing with ambient (inter-reflected) component +ambio.c ambient value input and output routines +aniso.c material functions for plastic2, metal2 and trans2 caldefn.c store variable definitions calexpr.c compute data values using expression parser colortab.c allocate and control dynamic color table @@ -27,6 +30,7 @@ devmain.c main for independent drivers devtable.c device table for rview dielectric.c shading function for transparent materials editline.c routine for editing raw input for rview +freeobjmem.c routines for freeing unneeded object structures func.c interface to calcomp functions glass.c simpler shading function for thin glass surfaces initotypes.c initialize ofun[] list for renderers @@ -35,16 +39,19 @@ m_brdf.c shading for materials with arbitrary BRDF's m_clip.c routine for clipped (cut) objects m_direct.c routines for prism material types m_mirror.c routines for mirror material supporting virtual light sources +malloc.c memory allocation routines mx_data.c routine for stored mixtures mx_func.c routine for mixture functions noise3.c noise functions for random textures normal.c shading function for normal materials nwsdev.c NeWS driver, by Isaac Kwo +nwsdev.cps NeWS driver source o_cone.c routine to determine ray intersection with cones o_face.c compute ray intersection with faces o_instance.c routines for computing ray intersections with octrees p_data.c routine for stored patterns p_func.c routine for procedural patterns +rayinit.cal initialization function file raytrace.c routines for tracing and shading rays readfargs.c allocate, read and free object arguments rmain.c main for ray tracing programs
