root/radiance/ray/src/rt/README
Revision: 2.9
Committed: Fri Nov 5 03:31:38 2004 UTC (20 years, 7 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
Changes since 2.8: +0 -11 lines
Error occurred while calculating annotation data.
1 RENDERING PROGRAMS
2 SCCSid "@(#)README 2.7 3/15/96 LBL"
3
4 This directory contains the RADIANCE renderers "rpict", "rtrace" and "rview".
5
6 VERSION system version number
7 ambient.h common definitions for interreflection routines
8 data.h header file for routines which interpolate data
9 driver.h header file for interactive device drivers
10 func.h header file for modifiers using function files
11 otspecial.h special type flags for objects used in rendering
12 ray.h header file for routines using rays
13 rpaint.h header file for image painting (rview)
14 source.h header file for ray tracing sources
15 x11icon.h icon for rview under X11
16 x11twind.h header for X11 text window routines
17 xtwind.h header for X10 text window routines
18 Version.c program version (made from VERSION and current date)
19 ambcomp.c routines to compute "ambient" values using Monte Carlo
20 ambient.c routines dealing with ambient (inter-reflected) component
21 ambio.c ambient value input and output routines
22 aniso.c material functions for plastic2, metal2 and trans2
23 caldefn.c store variable definitions (symbolic link to ../common)
24 calexpr.c compute data values using expression parser (symbolic link)
25 colortab.c allocate and control dynamic color table
26 data.c routines dealing with interpolated data
27 devcomm.c communication routines for separate drivers
28 devmain.c main for independent drivers
29 devtable.c device table for rview
30 dielectric.c shading function for transparent materials
31 duphead.c routine to duplicate picture header multiple times
32 editline.c routine for editing raw input for rview
33 fprism.c routines for prismatic glazing calculations
34 freeobjmem.c routines for freeing unneeded object structures
35 func.c interface to calcomp functions
36 glass.c simpler shading function for thin glass surfaces
37 initotypes.c initialize ofun[] list for renderers
38 lookamb.c program to examine ambient components
39 m_brdf.c shading for materials with arbitrary BRDF's
40 m_clip.c routine for clipped (cut) objects
41 m_direct.c routines for prism material types
42 m_mirror.c routines for mirror material supporting virtual light sources
43 malloc.c memory allocation routines (symbolic link to ../common)
44 mx_data.c routine for stored mixtures
45 mx_func.c routine for mixture functions
46 noise3.c noise functions for random textures
47 normal.c shading function for normal materials
48 nwsdev.c NeWS driver, by Isaac Kwo
49 nwsdev.cps NeWS driver source
50 o_cone.c routine to determine ray intersection with cones
51 o_face.c compute ray intersection with faces
52 o_instance.c routines for computing ray intersections with octrees
53 p_data.c routine for stored patterns
54 p_func.c routine for procedural patterns
55 persist.c routines for persistent (& parallel) execution
56 preload.c routines for preloading (initializing) data structures
57 raytrace.c routines for tracing and shading rays
58 readfargs.c allocate, read and free object arguments (symbolic link)
59 rmain.c main for ray tracing programs
60 rpict.c routines and variables for picture generation
61 rtrace.c program and variables for individual ray tracing
62 rv2.c command routines used in tracing a view
63 rv3.c miscellaneous routines for rview
64 rview.c routines and variables for interactive view generation
65 source.c routines dealing with illumination sources
66 sphere.c compute ray intersection with spheres
67 srcdraw.c routines for drawing small sources into pictures (for rpict)
68 srcsamp.c source sampling routines
69 srcsupp.c support routines for source objects and materials
70 t_data.c routine for stored textures
71 t_func.c routine for procedural textures
72 text.c functions for text patterns and mixtures
73 virtuals.c routines for simulating virtual light sources
74 x11.c driver for X-windows version 11R3
75 x11twind.c routines for X11 text windows
76 xtwind.c routines for X text windows
77 rayinit.cal initialization function file
