root/radiance/ray/src/rt/README
Fri Nov 5 03:31:38 2004 UTC (20 years, 7 months ago) by greg
CVS Tags: HEAD, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.8: +0 -11 lines
Sat Feb 22 02:07:28 2003 UTC (22 years, 4 months ago) by greg
Fri Mar 15 21:02:01 1996 UTC (29 years, 3 months ago) by greg
Changes since 2.6: +1 -0 lines
Fri Aug 25 20:03:50 1995 UTC (29 years, 10 months ago) by greg
Changes since 2.5: +12 -6 lines
Updated entries
Mon Aug 8 16:47:04 1994 UTC (30 years, 10 months ago) by greg
brought up to date
Sun Nov 22 10:55:08 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.3: +1 -0 lines
added freeobjmem module for rview when memory is scarce
Wed Sep 30 11:53:52 1992 UTC (32 years, 9 months ago) by greg
Changes since 2.2: +5 -0 lines
update for new routines
Mon Nov 25 09:51:12 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 2.1
Tue Nov 12 17:10:24 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1
Mon Nov 11 16:14:22 1991 UTC (33 years, 7 months ago) by greg
