--- ray/src/rt/CMakeLists.txt 2018/01/08 16:51:32 1.17 +++ ray/src/rt/CMakeLists.txt 2023/05/16 22:58:18 1.18 @@ -105,12 +105,12 @@ if(X11_FOUND) set(X11_SOURCES x11.c x11twind.c) add_definitions(-DHAS_X11) endif() -if(Qt5Widgets_DIR) +if(Qt5Widgets_FOUND AND BUILD_QT) include_directories(${Qt5Widgets_INCLUDE_DIRS}) add_definitions(-DHAS_QT) endif() if(NOT BUILD_HEADLESS) - if(X11_FOUND OR Qt5Widgets_DIR) + if(X11_FOUND OR BUILD_QT) add_executable(rvu colortab.c devcomm.c @@ -126,7 +126,7 @@ if(NOT BUILD_HEADLESS) list(APPEND targets_to_install rvu) # only link to rvu-qt-lib if qt is found - if(Qt5Widgets_DIR) + if(BUILD_QT) target_link_libraries(rvu qtrvu) endif() endif() @@ -147,7 +147,7 @@ file(COPY rayinit.cal ) #install qt.conf & Qt plugins loaded by rvu at runtime. Ignore if we are building as headless -if(NOT BUILD_HEADLESS) +if(NOT BUILD_HEADLESS AND BUILD_QT) get_target_property(GIF_PLUGIN Qt5::QGifPlugin LOCATION) get_target_property(ICO_PLUGIN Qt5::QICOPlugin LOCATION) get_target_property(JPEG_PLUGIN Qt5::QJpegPlugin LOCATION)
