--- ray/src/rt/CMakeLists.txt 2015/10/27 22:14:34 1.12 +++ ray/src/rt/CMakeLists.txt 2023/05/16 22:58:18 1.18 @@ -2,15 +2,68 @@ set(VERSION_FILE "${radiance_BINARY_DIR}/src/rt/Versio create_version_file("${VERSION_FILE}") add_library(radiance - ambcomp.c ambient.c ambio.c aniso.c ashikhmin.c data.c dielectric.c fprism.c freeobjmem.c - func.c glass.c initotypes.c m_alias.c m_brdf.c m_bsdf.c m_clip.c m_direct.c - m_mirror.c m_mist.c mx_func.c mx_data.c noise3.c normal.c o_face.c o_cone.c - o_instance.c o_mesh.c p_data.c p_func.c preload.c raytrace.c renderopts.c - source.c sphere.c srcobstr.c srcsupp.c srcsamp.c t_data.c t_func.c text.c - pmap.c pmapsrc.c pmapmat.c pmaprand.c pmapio.c - pmapbias.c pmapparm.c pmapcontrib.c pmapamb.c pmapray.c pmapopt.c - pmapdata.c pmapdiag.c pmaptype.c - "${VERSION_FILE}" virtuals.c) + "${VERSION_FILE}" + ../common/paths.c + ../common/platform.h + ../common/random.h + ambcomp.c + ambient.c + ambio.c + aniso.c + ashikhmin.c + data.c + dielectric.c + fprism.c + freeobjmem.c + func.c + glass.c + initotypes.c + m_alias.c + m_brdf.c + m_bsdf.c + m_clip.c + m_direct.c + m_mirror.c + m_mist.c + mx_data.c + mx_func.c + noise3.c + normal.c + o_cone.c + o_face.c + o_instance.c + o_mesh.c + p_data.c + p_func.c + pmap.c + pmapamb.c + pmapbias.c + pmapcontrib.c + pmapdata.c + pmapdiag.c + pmapio.c + pmapmat.c + pmapopt.c + pmapparm.c + pmaprand.c + pmapray.c + pmapsrc.c + pmaptype.c + pmcontrib2.c + pmutil.c + preload.c + raytrace.c + renderopts.c + source.c + sphere.c + srcobstr.c + srcsamp.c + srcsupp.c + t_data.c + t_func.c + text.c + virtuals.c +) if(WIN32) set(rayp_SOURCES raypwin.c) @@ -20,7 +73,7 @@ endif() add_library(raycalls raycalls.c ${rayp_SOURCES} rayfifo.c) -add_executable(rtrace rtmain.c rtrace.c duphead.c persist.c) +add_executable(rtrace rtmain.c rtrace.c duphead.c persist.c) target_link_libraries(rtrace raycalls radiance rtrad) add_executable(rpict rpmain.c rpict.c srcdraw.c duphead.c persist.c) @@ -34,64 +87,87 @@ target_link_libraries(rcontrib radiance rtrad) add_executable(mkpmap mkpmap.c) target_link_libraries(mkpmap radiance rtrad) - add_executable(pmapdump pmapdump.c pmaptype.c pmapparm.c) -target_link_libraries(pmapdump radiance rtrad) +target_link_libraries(pmapdump raycalls radiance rtrad) -set(targets_to_install lookamb radiance raycalls rtrace rpict rcontrib mkpmap pmapdump) +set(targets_to_install + lookamb + mkpmap + pmapdump + radiance + raycalls + rcontrib + rpict + rtrace +) if(X11_FOUND) set(X11_SOURCES x11.c x11twind.c) - add_definitions("-DHAS_X11") + add_definitions(-DHAS_X11) endif() -if(Qt5Widgets_DIR) +if(Qt5Widgets_FOUND AND BUILD_QT) include_directories(${Qt5Widgets_INCLUDE_DIRS}) - add_definitions("-DHAS_QT") + add_definitions(-DHAS_QT) endif() -if (X11_FOUND OR Qt5Widgets_DIR) - add_executable(rvu - rvmain.c rview.c rv2.c rv3.c devtable.c devcomm.c editline.c ${X11_SOURCES} - colortab.c) - target_link_libraries(rvu raycalls radiance rtrad ${X11_LIBRARIES}) - list(APPEND targets_to_install rvu) +if(NOT BUILD_HEADLESS) + if(X11_FOUND OR BUILD_QT) + add_executable(rvu + colortab.c + devcomm.c + devtable.c + editline.c + rv2.c + rv3.c + rview.c + rvmain.c + ${X11_SOURCES} + ) + target_link_libraries(rvu raycalls radiance rtrad ${X11_LIBRARIES}) + list(APPEND targets_to_install rvu) - # only link to rvu-qt-lib if qt is found - if(Qt5Widgets_DIR) - target_link_libraries(rvu qtrvu) + # only link to rvu-qt-lib if qt is found + if(BUILD_QT) + target_link_libraries(rvu qtrvu) + endif() endif() endif() -add_test(rtrace_Version ${EXECUTABLE_OUTPUT_PATH}/rtrace -version) -set_tests_properties(rtrace_Version PROPERTIES - PASS_REGULAR_EXPRESSION "RADIANCE") +#add_test(rtrace_version "${EXECUTABLE_OUTPUT_PATH}/rtrace" -version) +#set_tests_properties(rtrace_version PROPERTIES +# PASS_REGULAR_EXPRESSION "RADIANCE" +#) install(TARGETS ${targets_to_install} - RUNTIME DESTINATION bin - LIBRARY DESTINATION bin - ARCHIVE DESTINATION bin) -install(FILES rayinit.cal DESTINATION lib) + RUNTIME DESTINATION "bin" + LIBRARY DESTINATION "bin" + ARCHIVE DESTINATION "bin" +) +file(COPY rayinit.cal + DESTINATION "${CMAKE_BINARY_DIR}/lib" +) #install qt.conf & Qt plugins loaded by rvu at runtime. Ignore if we are building as headless -if(NOT BUILD_HEADLESS) +if(NOT BUILD_HEADLESS AND BUILD_QT) get_target_property(GIF_PLUGIN Qt5::QGifPlugin LOCATION) get_target_property(ICO_PLUGIN Qt5::QICOPlugin LOCATION) get_target_property(JPEG_PLUGIN Qt5::QJpegPlugin LOCATION) - get_target_property(MNG_PLUGIN Qt5::QMngPlugin LOCATION) get_target_property(TIFF_PLUGIN Qt5::QTiffPlugin LOCATION) - install(PROGRAMS "${GIF_PLUGIN}" DESTINATION bin/plugins/imageformats) - install(PROGRAMS "${ICO_PLUGIN}" DESTINATION bin/plugins/imageformats) - install(PROGRAMS "${JPEG_PLUGIN}" DESTINATION bin/plugins/imageformats) - install(PROGRAMS "${MNG_PLUGIN}" DESTINATION bin/plugins/imageformats) - install(PROGRAMS "${TIFF_PLUGIN}" DESTINATION bin/plugins/imageformats) - install(FILES ${CMAKE_SOURCE_DIR}/InstallRules/qt.conf DESTINATION bin) + install(PROGRAMS "${GIF_PLUGIN}" "${ICO_PLUGIN}" "${JPEG_PLUGIN}" "${TIFF_PLUGIN}" + DESTINATION "bin/plugins/imageformats" + ) + install(FILES "${CMAKE_SOURCE_DIR}/InstallRules/qt.conf" + DESTINATION "bin" + ) - if(APPLE OR WIN32) - if(WIN32) - get_target_property(QPA_PLUGIN Qt5::QWindowsIntegrationPlugin LOCATION) - elseif(APPLE) - get_target_property(QPA_PLUGIN Qt5::QCocoaIntegrationPlugin LOCATION) - endif() - - install(PROGRAMS "${QPA_PLUGIN}" DESTINATION bin/plugins/platforms) + if(WIN32) + get_target_property(QPA_PLUGIN Qt5::QWindowsIntegrationPlugin LOCATION) + elseif(APPLE) + get_target_property(QPA_PLUGIN Qt5::QCocoaIntegrationPlugin LOCATION) + elseif(UNIX) + get_target_property(QPA_PLUGIN Qt5::QXcbIntegrationPlugin LOCATION) endif() + + install(PROGRAMS "${QPA_PLUGIN}" + DESTINATION "bin/plugins/platforms" + ) endif()
