root/radiance/ray/src/rt/CMakeLists.txt
Revision: 1.1
Committed: Sat Oct 22 22:38:10 2011 UTC (13 years, 9 months ago) by greg
Added qt interface for rvu and cmake files from Bill Hoffman
1 set(VERSION_FILE "${radiance_BINARY_DIR}/src/rt/Version.c")
2 add_custom_command(
3 OUTPUT "${VERSION_FILE}"
4 COMMAND "${CMAKE_COMMAND}"
5 -DVERSION_OUT_FILE="${VERSION_FILE}"
6 -DVERSION_IN_FILE="${radiance_SOURCE_DIR}/src/util/VERSION"
7 -P "${radiance_SOURCE_DIR}/src/common/create_version.cmake"
8 )
9
10 add_library(radiance
11 ambcomp.c ambient.c ambio.c aniso.c data.c dielectric.c fprism.c freeobjmem.c
12 func.c glass.c initotypes.c m_alias.c m_brdf.c m_bsdf.c m_clip.c m_direct.c
13 m_mirror.c m_mist.c mx_func.c mx_data.c noise3.c normal.c o_face.c o_cone.c
14 o_instance.c o_mesh.c p_data.c p_func.c preload.c raytrace.c renderopts.c
15 source.c sphere.c srcobstr.c srcsupp.c srcsamp.c t_data.c t_func.c text.c
16 "${VERSION_FILE}" virtuals.c)
17
18 if(WIN32)
19 set(rayp_SOURCES raypwin.c)
20 else()
21 set(rayp_SOURCES raypcalls.c)
22 endif()
23
24 add_library(raycalls raycalls.c ${rayp_SOURCES} rayfifo.c)
25
26 add_executable(rtrace rtmain.c rtrace.c duphead.c persist.c)
27 target_link_libraries(rtrace raycalls radiance rtrad)
28
29 add_executable(rpict rpmain.c rpict.c srcdraw.c duphead.c persist.c)
30 target_link_libraries(rpict radiance rtrad)
31 if(X11_FOUND)
32 set(X11_SOURCES x11.c x11twind.c)
33 add_definitions("-DHAS_X11")
34 endif()
35 if(QT4_FOUND)
36 add_definitions("-DHAS_QT")
37 endif()
38 add_executable(rvu
39 rvmain.c rview.c rv2.c rv3.c devtable.c devcomm.c editline.c ${X11_SOURCES}
40 colortab.c)
41 target_link_libraries(rvu raycalls radiance rtrad ${X11_LIBRARIES})
42 # only link to rvu-qt-lib if qt is found
43 if(QT4_FOUND)
44 target_link_libraries(rvu qtrvu)
45 endif()
46
47 add_executable(lookamb lookamb.c ambio.c)
48 target_link_libraries(lookamb rtrad)
49
50 add_test(rtrace_Version ${EXECUTABLE_OUTPUT_PATH}/rtrace -version)
51 set_tests_properties(rtrace_Version PROPERTIES
52 PASS_REGULAR_EXPRESSION "RADIANCE")
53
54 install(TARGETS radiance raycalls rtrace rpict rvu
55 RUNTIME DESTINATION bin
56 LIBRARY DESTINATION bin
57 ARCHIVE DESTINATION bin)
58 install(FILES rayinit.cal DESTINATION bin)
