root/radiance/ray/src/rt/CMakeLists.txt
Revision: 1.9
Committed: Thu Mar 20 22:49:21 2014 UTC (11 years, 2 months ago) by greg
CVS Tags: rad4R2P2, rad4R2, rad4R2P1
Changes since 1.8: +21 -14 lines
Changes to speed installation on cloud computing systems
1 set(VERSION_FILE "${radiance_BINARY_DIR}/src/rt/Version.c")
2 create_version_file("${VERSION_FILE}")
3
4 add_library(radiance
5 ambcomp.c ambient.c ambio.c aniso.c ashikhmin.c data.c dielectric.c fprism.c freeobjmem.c
6 func.c glass.c initotypes.c m_alias.c m_brdf.c m_bsdf.c m_clip.c m_direct.c
7 m_mirror.c m_mist.c mx_func.c mx_data.c noise3.c normal.c o_face.c o_cone.c
8 o_instance.c o_mesh.c p_data.c p_func.c preload.c raytrace.c renderopts.c
9 source.c sphere.c srcobstr.c srcsupp.c srcsamp.c t_data.c t_func.c text.c
10 "${VERSION_FILE}" virtuals.c)
11
12 if(WIN32)
13 set(rayp_SOURCES raypwin.c)
14 else()
15 set(rayp_SOURCES raypcalls.c)
16 endif()
17
18 add_library(raycalls raycalls.c ${rayp_SOURCES} rayfifo.c)
19
20 add_executable(rtrace rtmain.c rtrace.c duphead.c persist.c)
21 target_link_libraries(rtrace raycalls radiance rtrad)
22
23 add_executable(rpict rpmain.c rpict.c srcdraw.c duphead.c persist.c)
24 target_link_libraries(rpict radiance rtrad)
25
26 add_executable(lookamb lookamb.c ambio.c)
27 target_link_libraries(lookamb rtrad)
28
29 add_executable(rcontrib rcmain.c rcontrib.c rc2.c rc3.c)
30 target_link_libraries(rcontrib radiance rtrad)
31
32 set(targets_to_install lookamb radiance raycalls rtrace rpict rcontrib)
33
34 if(X11_FOUND)
35 set(X11_SOURCES x11.c x11twind.c)
36 add_definitions("-DHAS_X11")
37 endif()
38 if(QT4_FOUND)
39 add_definitions("-DHAS_QT")
40 endif()
41 if (X11_FOUND OR QT4_FOUND)
42 add_executable(rvu
43 rvmain.c rview.c rv2.c rv3.c devtable.c devcomm.c editline.c ${X11_SOURCES}
44 colortab.c)
45 target_link_libraries(rvu raycalls radiance rtrad ${X11_LIBRARIES})
46 list(APPEND targets_to_install rvu)
47
48 # only link to rvu-qt-lib if qt is found
49 if(QT4_FOUND)
50 target_link_libraries(rvu qtrvu)
51 endif()
52 endif()
53
54 add_test(rtrace_Version ${EXECUTABLE_OUTPUT_PATH}/rtrace -version)
55 set_tests_properties(rtrace_Version PROPERTIES
56 PASS_REGULAR_EXPRESSION "RADIANCE")
57
58 install(TARGETS ${targets_to_install}
59 RUNTIME DESTINATION bin
60 LIBRARY DESTINATION bin
61 ARCHIVE DESTINATION bin)
62 install(FILES rayinit.cal DESTINATION lib)
63
64 #install qt.conf & Qt plugins loaded by rvu at runtime
65 install(FILES ${QT_QGIF_${qt_plugin_term}_RELEASE} DESTINATION bin/plugins/imageformats)
66 install(FILES ${QT_QICO_${qt_plugin_term}_RELEASE} DESTINATION bin/plugins/imageformats)
67 install(FILES ${QT_QJPEG_${qt_plugin_term}_RELEASE} DESTINATION bin/plugins/imageformats)
68 install(FILES ${QT_QMNG_${qt_plugin_term}_RELEASE} DESTINATION bin/plugins/imageformats)
69 install(FILES ${QT_QSVG_${qt_plugin_term}_RELEASE} DESTINATION bin/plugins/imageformats)
70 install(FILES ${QT_QTIFF_${qt_plugin_term}_RELEASE} DESTINATION bin/plugins/imageformats)
71 install(FILES ${CMAKE_SOURCE_DIR}/InstallRules/qt.conf DESTINATION bin)
72
