root/radiance/ray/src/rt/CMakeLists.txt
Revision: 1.15
Committed: Thu Aug 10 16:59:35 2017 UTC (7 years, 9 months ago) by greg
Changes since 1.14: +16 -37 lines
Changes for OOC photon map under Windows
1 set(VERSION_FILE "${radiance_BINARY_DIR}/src/rt/Version.c")
2 create_version_file("${VERSION_FILE}")
3
4 add_library(radiance
5 ambcomp.c ambient.c ambio.c aniso.c ashikhmin.c data.c dielectric.c fprism.c freeobjmem.c
6 func.c glass.c initotypes.c m_alias.c m_brdf.c m_bsdf.c m_clip.c m_direct.c
7 m_mirror.c m_mist.c mx_func.c mx_data.c noise3.c normal.c o_face.c o_cone.c
8 o_instance.c o_mesh.c p_data.c p_func.c preload.c raytrace.c renderopts.c
9 source.c sphere.c srcobstr.c srcsupp.c srcsamp.c t_data.c t_func.c text.c
10 pmap.c pmapsrc.c pmapmat.c pmaprand.c pmapio.c
11 pmapbias.c pmapparm.c pmapcontrib.c pmapamb.c pmapray.c pmapopt.c
12 pmapdata.c pmapdiag.c pmaptype.c pmutil.c pmcontrib2.c
13 ../common/random.h ../common/platform.h func.c
14 "${VERSION_FILE}" virtuals.c ../common/paths.c)
15
16 if(WIN32)
17 set(rayp_SOURCES raypwin.c)
18 else()
19 set(rayp_SOURCES raypcalls.c)
20 endif()
21
22 add_library(raycalls raycalls.c ${rayp_SOURCES} rayfifo.c)
23
24 add_executable(rtrace rtmain.c rtrace.c duphead.c persist.c)
25 target_link_libraries(rtrace raycalls radiance rtrad)
26
27 add_executable(rpict rpmain.c rpict.c srcdraw.c duphead.c persist.c)
28 target_link_libraries(rpict radiance rtrad)
29
30 add_executable(lookamb lookamb.c ambio.c)
31 target_link_libraries(lookamb rtrad)
32
33 add_executable(rcontrib rcmain.c rcontrib.c rc2.c rc3.c)
34 target_link_libraries(rcontrib radiance rtrad)
35
36 add_executable(mkpmap mkpmap.c)
37 target_link_libraries(mkpmap radiance rtrad)
38 add_executable(pmapdump pmapdump.c pmaptype.c pmapparm.c)
39 target_link_libraries(pmapdump raycalls radiance rtrad)
40
41 set(targets_to_install lookamb radiance raycalls rtrace rpict rcontrib mkpmap pmapdump)
42
43 if(X11_FOUND)
44 set(X11_SOURCES x11.c x11twind.c)
45 add_definitions("-DHAS_X11")
46 endif()
47 if(Qt5Widgets_DIR)
48 include_directories(${Qt5Widgets_INCLUDE_DIRS})
49 add_definitions("-DHAS_QT")
50 endif()
51 if(NOT BUILD_HEADLESS)
52 if (X11_FOUND OR Qt5Widgets_DIR)
53 add_executable(rvu
54 rvmain.c rview.c rv2.c rv3.c devtable.c devcomm.c editline.c ${X11_SOURCES}
55 colortab.c)
56 target_link_libraries(rvu raycalls radiance rtrad ${X11_LIBRARIES})
57 list(APPEND targets_to_install rvu)
58
59 # only link to rvu-qt-lib if qt is found
60 if(Qt5Widgets_DIR)
61 target_link_libraries(rvu qtrvu)
62 endif()
63 endif()
64 endif()
65
66 add_test(rtrace_Version ${EXECUTABLE_OUTPUT_PATH}/rtrace -version)
67 set_tests_properties(rtrace_Version PROPERTIES
68 PASS_REGULAR_EXPRESSION "RADIANCE")
69
70 install(TARGETS ${targets_to_install}
71 RUNTIME DESTINATION bin
72 LIBRARY DESTINATION bin
73 ARCHIVE DESTINATION bin)
74 install(FILES rayinit.cal DESTINATION lib)
75
76 #install qt.conf & Qt plugins loaded by rvu at runtime. Ignore if we are building as headless
77 if(NOT BUILD_HEADLESS)
78 get_target_property(GIF_PLUGIN Qt5::QGifPlugin LOCATION)
79 get_target_property(ICO_PLUGIN Qt5::QICOPlugin LOCATION)
80 get_target_property(JPEG_PLUGIN Qt5::QJpegPlugin LOCATION)
81 get_target_property(MNG_PLUGIN Qt5::QMngPlugin LOCATION)
82 get_target_property(TIFF_PLUGIN Qt5::QTiffPlugin LOCATION)
83 install(PROGRAMS "${GIF_PLUGIN}" DESTINATION bin/plugins/imageformats)
84 install(PROGRAMS "${ICO_PLUGIN}" DESTINATION bin/plugins/imageformats)
85 install(PROGRAMS "${JPEG_PLUGIN}" DESTINATION bin/plugins/imageformats)
86 install(PROGRAMS "${MNG_PLUGIN}" DESTINATION bin/plugins/imageformats)
87 install(PROGRAMS "${TIFF_PLUGIN}" DESTINATION bin/plugins/imageformats)
88 install(FILES ${CMAKE_SOURCE_DIR}/InstallRules/qt.conf DESTINATION bin)
89
90 if(APPLE OR WIN32)
91 if(WIN32)
92 get_target_property(QPA_PLUGIN Qt5::QWindowsIntegrationPlugin LOCATION)
93 elseif(APPLE)
94 get_target_property(QPA_PLUGIN Qt5::QCocoaIntegrationPlugin LOCATION)
95 endif()
96
97 install(PROGRAMS "${QPA_PLUGIN}" DESTINATION bin/plugins/platforms)
98 endif()
99 endif()
