root/radiance/ray/src/rt/CMakeLists.txt
Mon Jan 8 16:51:32 2018 UTC (7 years, 4 months ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 1.16: +114 -40 lines
Diff to previous 1.16 , to selected 1.12
Update to CMake build system from Rob G. and Alex S., adding test cases
Thu Aug 17 21:32:29 2017 UTC (7 years, 8 months ago) by greg
Changes since 1.15: +2 -2 lines
Diff to previous 1.15 , to selected 1.12
Final check-ins to get evalglare working and addition of bsdfview -t option
Thu Aug 10 16:59:35 2017 UTC (7 years, 9 months ago) by greg
Changes since 1.14: +16 -37 lines
Diff to previous 1.14 , to selected 1.12
Changes for OOC photon map under Windows
Fri Sep 30 17:59:27 2016 UTC (8 years, 7 months ago) by greg
Changes since 1.13: +37 -16 lines
Diff to previous 1.13 , to selected 1.12
Changes to compile under Windows
Tue Mar 22 21:36:24 2016 UTC (9 years, 1 month ago) by greg
Changes since 1.12: +12 -10 lines
Diff to previous 1.12
Rob G. fixes for "headless" target
Revision 1.12 - (view) (download) (annotate) - [selected]
Tue Oct 27 22:14:34 2015 UTC (9 years, 6 months ago) by greg
Changes since 1.11: +21 -20 lines
Diff to previous 1.11
Patch by RG to support "headless" installs
Fri May 8 18:07:38 2015 UTC (10 years ago) by greg
Changes since 1.10: +24 -9 lines
Diff to previous 1.10 , to selected 1.12
Fixes for rvu under Windows
Thu Apr 2 16:42:50 2015 UTC (10 years, 1 month ago) by greg
Changes since 1.9: +10 -1 lines
Diff to previous 1.9 , to selected 1.12
Changes to support new pmap compilation
Thu Mar 20 22:49:21 2014 UTC (11 years, 1 month ago) by greg
Changes since 1.8: +21 -14 lines
Diff to previous 1.8 , to selected 1.12
Changes to speed installation on cloud computing systems
Tue Jul 31 16:52:32 2012 UTC (12 years, 9 months ago) by greg
Diff to previous 1.7 , to selected 1.12
Added ashikhmin.c to library list
Tue Jun 19 17:08:55 2012 UTC (12 years, 10 months ago) by greg
Changes since 1.6: +4 -1 lines
Diff to previous 1.6 , to selected 1.12
Added compilation of rcontrib
Tue Jun 19 16:41:47 2012 UTC (12 years, 10 months ago) by greg
Changes since 1.5: +6 -6 lines
Diff to previous 1.5 , to selected 1.12
Added missing cmake files
Wed May 30 18:31:11 2012 UTC (12 years, 11 months ago) by greg
Changes since 1.4: +10 -0 lines
Diff to previous 1.4 , to selected 1.12
Patches to cmake build system and QT driver for rvu
Wed Apr 25 22:21:06 2012 UTC (13 years ago) by greg
Diff to previous 1.3 , to selected 1.12
Fri Oct 28 20:46:47 2011 UTC (13 years, 6 months ago) by greg
Changes since 1.2: +1 -7 lines
Diff to previous 1.2 , to selected 1.12
Fixes to Version.c update in cmake build system
Wed Oct 26 16:48:01 2011 UTC (13 years, 6 months ago) by greg
Diff to previous 1.1 , to selected 1.12
Sat Oct 22 22:38:10 2011 UTC (13 years, 6 months ago) by greg
Diff to selected 1.12
Added qt interface for rvu and cmake files from Bill Hoffman
