--- ray/src/rt/CMakeLists.txt 2011/10/26 16:48:01 1.2 +++ ray/src/rt/CMakeLists.txt 2014/03/20 22:49:21 1.9 @@ -1,14 +1,8 @@ set(VERSION_FILE "${radiance_BINARY_DIR}/src/rt/Version.c") -add_custom_command( - OUTPUT "${VERSION_FILE}" - COMMAND "${CMAKE_COMMAND}" - -DVERSION_OUT_FILE="${VERSION_FILE}" - -DVERSION_IN_FILE="${radiance_SOURCE_DIR}/src/rt/VERSION" - -P "${radiance_SOURCE_DIR}/src/rt/create_version.cmake" -) +create_version_file("${VERSION_FILE}") add_library(radiance - ambcomp.c ambient.c ambio.c aniso.c data.c dielectric.c fprism.c freeobjmem.c + ambcomp.c ambient.c ambio.c aniso.c ashikhmin.c data.c dielectric.c fprism.c freeobjmem.c func.c glass.c initotypes.c m_alias.c m_brdf.c m_bsdf.c m_clip.c m_direct.c m_mirror.c m_mist.c mx_func.c mx_data.c noise3.c normal.c o_face.c o_cone.c o_instance.c o_mesh.c p_data.c p_func.c preload.c raytrace.c renderopts.c @@ -28,6 +22,15 @@ target_link_libraries(rtrace raycalls radiance rtrad) add_executable(rpict rpmain.c rpict.c srcdraw.c duphead.c persist.c) target_link_libraries(rpict radiance rtrad) + +add_executable(lookamb lookamb.c ambio.c) +target_link_libraries(lookamb rtrad) + +add_executable(rcontrib rcmain.c rcontrib.c rc2.c rc3.c) +target_link_libraries(rcontrib radiance rtrad) + +set(targets_to_install lookamb radiance raycalls rtrace rpict rcontrib) + if(X11_FOUND) set(X11_SOURCES x11.c x11twind.c) add_definitions("-DHAS_X11") @@ -35,24 +38,35 @@ endif() if(QT4_FOUND) add_definitions("-DHAS_QT") endif() -add_executable(rvu - rvmain.c rview.c rv2.c rv3.c devtable.c devcomm.c editline.c ${X11_SOURCES} - colortab.c) -target_link_libraries(rvu raycalls radiance rtrad ${X11_LIBRARIES}) -# only link to rvu-qt-lib if qt is found -if(QT4_FOUND) - target_link_libraries(rvu qtrvu) +if (X11_FOUND OR QT4_FOUND) + add_executable(rvu + rvmain.c rview.c rv2.c rv3.c devtable.c devcomm.c editline.c ${X11_SOURCES} + colortab.c) + target_link_libraries(rvu raycalls radiance rtrad ${X11_LIBRARIES}) + list(APPEND targets_to_install rvu) + + # only link to rvu-qt-lib if qt is found + if(QT4_FOUND) + target_link_libraries(rvu qtrvu) + endif() endif() -add_executable(lookamb lookamb.c ambio.c) -target_link_libraries(lookamb rtrad) - add_test(rtrace_Version ${EXECUTABLE_OUTPUT_PATH}/rtrace -version) set_tests_properties(rtrace_Version PROPERTIES PASS_REGULAR_EXPRESSION "RADIANCE") -install(TARGETS radiance raycalls rtrace rpict rvu +install(TARGETS ${targets_to_install} RUNTIME DESTINATION bin LIBRARY DESTINATION bin ARCHIVE DESTINATION bin) -install(FILES rayinit.cal DESTINATION bin) +install(FILES rayinit.cal DESTINATION lib) + +#install qt.conf & Qt plugins loaded by rvu at runtime +install(FILES ${QT_QGIF_${qt_plugin_term}_RELEASE} DESTINATION bin/plugins/imageformats) +install(FILES ${QT_QICO_${qt_plugin_term}_RELEASE} DESTINATION bin/plugins/imageformats) +install(FILES ${QT_QJPEG_${qt_plugin_term}_RELEASE} DESTINATION bin/plugins/imageformats) +install(FILES ${QT_QMNG_${qt_plugin_term}_RELEASE} DESTINATION bin/plugins/imageformats) +install(FILES ${QT_QSVG_${qt_plugin_term}_RELEASE} DESTINATION bin/plugins/imageformats) +install(FILES ${QT_QTIFF_${qt_plugin_term}_RELEASE} DESTINATION bin/plugins/imageformats) +install(FILES ${CMAKE_SOURCE_DIR}/InstallRules/qt.conf DESTINATION bin) +
