root/radiance/ray/src/qtrvu/viewdialog.ui
Revision: 1.2
Committed: Mon Aug 6 17:51:45 2012 UTC (12 years, 10 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1, rad5R3, HEAD
Changes since 1.1: +7 -0 lines
Error occurred while calculating annotation data.
Zack's patch to add stereographic view type
1 <?xml version="1.0" encoding="UTF-8"?>
2 <ui version="4.0">
3 <class>viewDialog</class>
4 <widget class="QDialog" name="viewDialog">
5 <property name="geometry">
6 <rect>
7 <x>0</x>
8 <y>0</y>
9 <width>576</width>
10 <height>456</height>
11 </rect>
12 </property>
13 <property name="windowTitle">
14 <string>View</string>
15 </property>
16 <layout class="QVBoxLayout" name="verticalLayout_2">
17 <item>
18 <widget class="QWidget" name="topWidget" native="true">
19 <layout class="QHBoxLayout" name="horizontalLayout">
20 <item>
21 <widget class="QFrame" name="typeFrame">
22 <property name="frameShape">
23 <enum>QFrame::StyledPanel</enum>
24 </property>
25 <property name="frameShadow">
26 <enum>QFrame::Raised</enum>
27 </property>
28 <layout class="QVBoxLayout" name="verticalLayout">
29 <item>
30 <widget class="QLabel" name="label">
31 <property name="text">
32 <string>Type</string>
33 </property>
34 </widget>
35 </item>
36 <item>
37 <widget class="QRadioButton" name="angular">
38 <property name="text">
39 <string>Angular</string>
40 </property>
41 </widget>
42 </item>
43 <item>
44 <widget class="QRadioButton" name="cylindrical">
45 <property name="text">
46 <string>Cylindrical</string>
47 </property>
48 </widget>
49 </item>
50 <item>
51 <widget class="QRadioButton" name="hemispherical">
52 <property name="text">
53 <string>Hemispherical</string>
54 </property>
55 </widget>
56 </item>
57 <item>
58 <widget class="QRadioButton" name="planispheric">
59 <property name="text">
60 <string>Planispheric</string>
61 </property>
62 </widget>
63 </item>
64 <item>
65 <widget class="QRadioButton" name="parallel">
66 <property name="text">
67 <string>Parallel</string>
68 </property>
69 </widget>
70 </item>
71 <item>
72 <widget class="QRadioButton" name="perspective">
73 <property name="text">
74 <string>Perspective</string>
75 </property>
76 <property name="checked">
77 <bool>true</bool>
78 </property>
79 </widget>
80 </item>
81 </layout>
82 </widget>
83 </item>
84 <item>
85 <widget class="QFrame" name="viewFrame">
86 <property name="frameShape">
87 <enum>QFrame::StyledPanel</enum>
88 </property>
89 <property name="frameShadow">
90 <enum>QFrame::Raised</enum>
91 </property>
92 <layout class="QGridLayout" name="gridLayout">
93 <item row="0" column="0" colspan="2">
94 <widget class="QLabel" name="label_5">
95 <property name="text">
96 <string>Viewpoint</string>
97 </property>
98 </widget>
99 </item>
100 <item row="1" column="0">
101 <widget class="QLabel" name="label_2">
102 <property name="text">
103 <string>X:</string>
104 </property>
105 </widget>
106 </item>
107 <item row="1" column="1">
108 <widget class="QLineEdit" name="viewX">
109 <property name="sizePolicy">
110 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
111 <horstretch>0</horstretch>
112 <verstretch>0</verstretch>
113 </sizepolicy>
114 </property>
115 <property name="maximumSize">
116 <size>
117 <width>60</width>
118 <height>16777215</height>
119 </size>
120 </property>
121 </widget>
122 </item>
123 <item row="2" column="0">
124 <widget class="QLabel" name="label_3">
125 <property name="text">
126 <string>Y:</string>
127 </property>
128 </widget>
129 </item>
130 <item row="2" column="1">
131 <widget class="QLineEdit" name="viewY">
132 <property name="sizePolicy">
133 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
134 <horstretch>0</horstretch>
135 <verstretch>0</verstretch>
136 </sizepolicy>
137 </property>
138 <property name="maximumSize">
139 <size>
140 <width>60</width>
141 <height>16777215</height>
142 </size>
143 </property>
144 </widget>
145 </item>
146 <item row="3" column="0">
147 <widget class="QLabel" name="label_4">
148 <property name="text">
149 <string>Z:</string>
150 </property>
151 </widget>
152 </item>
153 <item row="3" column="1">
154 <widget class="QLineEdit" name="viewZ">
155 <property name="sizePolicy">
156 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
157 <horstretch>0</horstretch>
158 <verstretch>0</verstretch>
159 </sizepolicy>
160 </property>
161 <property name="maximumSize">
162 <size>
163 <width>60</width>
164 <height>16777215</height>
165 </size>
166 </property>
167 </widget>
168 </item>
169 </layout>
170 </widget>
171 </item>
172 <item>
173 <widget class="QFrame" name="directionFrame">
174 <property name="frameShape">
175 <enum>QFrame::StyledPanel</enum>
176 </property>
177 <property name="frameShadow">
178 <enum>QFrame::Raised</enum>
179 </property>
180 <layout class="QGridLayout" name="gridLayout_2">
181 <item row="0" column="0" colspan="2">
182 <widget class="QLabel" name="label_12">
183 <property name="text">
184 <string>Direction</string>
185 </property>
186 </widget>
187 </item>
188 <item row="1" column="0">
189 <widget class="QLabel" name="label_6">
190 <property name="text">
191 <string>X:</string>
192 </property>
193 </widget>
194 </item>
195 <item row="1" column="1">
196 <widget class="QLineEdit" name="dirX">
197 <property name="sizePolicy">
198 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
199 <horstretch>0</horstretch>
200 <verstretch>0</verstretch>
201 </sizepolicy>
202 </property>
203 <property name="maximumSize">
204 <size>
205 <width>60</width>
206 <height>16777215</height>
207 </size>
208 </property>
209 </widget>
210 </item>
211 <item row="2" column="0">
212 <widget class="QLabel" name="label_7">
213 <property name="text">
214 <string>Y:</string>
215 </property>
216 </widget>
217 </item>
218 <item row="2" column="1">
219 <widget class="QLineEdit" name="dirY">
220 <property name="sizePolicy">
221 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
222 <horstretch>0</horstretch>
223 <verstretch>0</verstretch>
224 </sizepolicy>
225 </property>
226 <property name="maximumSize">
227 <size>
228 <width>60</width>
229 <height>16777215</height>
230 </size>
231 </property>
232 </widget>
233 </item>
234 <item row="3" column="0">
235 <widget class="QLabel" name="label_8">
236 <property name="text">
237 <string>Z:</string>
238 </property>
239 </widget>
240 </item>
241 <item row="3" column="1">
242 <widget class="QLineEdit" name="dirZ">
243 <property name="sizePolicy">
244 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
245 <horstretch>0</horstretch>
246 <verstretch>0</verstretch>
247 </sizepolicy>
248 </property>
249 <property name="maximumSize">
250 <size>
251 <width>60</width>
252 <height>16777215</height>
253 </size>
254 </property>
255 </widget>
256 </item>
257 </layout>
258 </widget>
259 </item>
260 <item>
261 <widget class="QFrame" name="upFrame">
262 <property name="frameShape">
263 <enum>QFrame::StyledPanel</enum>
264 </property>
265 <property name="frameShadow">
266 <enum>QFrame::Raised</enum>
267 </property>
268 <layout class="QGridLayout" name="gridLayout_3">
269 <item row="0" column="0" colspan="2">
270 <widget class="QLabel" name="label_13">
271 <property name="text">
272 <string>Up</string>
273 </property>
274 </widget>
275 </item>
276 <item row="1" column="0">
277 <widget class="QLabel" name="label_9">
278 <property name="text">
279 <string>X:</string>
280 </property>
281 </widget>
282 </item>
283 <item row="1" column="1">
284 <widget class="QLineEdit" name="upX">
285 <property name="sizePolicy">
286 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
287 <horstretch>0</horstretch>
288 <verstretch>0</verstretch>
289 </sizepolicy>
290 </property>
291 <property name="maximumSize">
292 <size>
293 <width>60</width>
294 <height>16777215</height>
295 </size>
296 </property>
297 </widget>
298 </item>
299 <item row="2" column="0">
300 <widget class="QLabel" name="label_10">
301 <property name="text">
302 <string>Y:</string>
303 </property>
304 </widget>
305 </item>
306 <item row="2" column="1">
307 <widget class="QLineEdit" name="upY">
308 <property name="sizePolicy">
309 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
310 <horstretch>0</horstretch>
311 <verstretch>0</verstretch>
312 </sizepolicy>
313 </property>
314 <property name="maximumSize">
315 <size>
316 <width>60</width>
317 <height>16777215</height>
318 </size>
319 </property>
320 </widget>
321 </item>
322 <item row="3" column="0">
323 <widget class="QLabel" name="label_11">
324 <property name="text">
325 <string>Z:</string>
326 </property>
327 </widget>
328 </item>
329 <item row="3" column="1">
330 <widget class="QLineEdit" name="upZ">
331 <property name="sizePolicy">
332 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
333 <horstretch>0</horstretch>
334 <verstretch>0</verstretch>
335 </sizepolicy>
336 </property>
337 <property name="maximumSize">
338 <size>
339 <width>60</width>
340 <height>16777215</height>
341 </size>
342 </property>
343 </widget>
344 </item>
345 </layout>
346 </widget>
347 </item>
348 </layout>
349 </widget>
350 </item>
351 <item>
352 <widget class="QWidget" name="bottomWidget" native="true">
353 <layout class="QHBoxLayout" name="horizontalLayout_2">
354 <item>
355 <widget class="QFrame" name="sizeFrame">
356 <property name="frameShape">
357 <enum>QFrame::StyledPanel</enum>
358 </property>
359 <property name="frameShadow">
360 <enum>QFrame::Raised</enum>
361 </property>
362 <layout class="QGridLayout" name="gridLayout_4">
363 <item row="0" column="0">
364 <widget class="QLabel" name="label_16">
365 <property name="text">
366 <string>Size</string>
367 </property>
368 </widget>
369 </item>
370 <item row="1" column="0">
371 <widget class="QLabel" name="label_14">
372 <property name="text">
373 <string>Horiz:</string>
374 </property>
375 </widget>
376 </item>
377 <item row="1" column="1">
378 <widget class="QLineEdit" name="sizeHoriz">
379 <property name="maximumSize">
380 <size>
381 <width>60</width>
382 <height>16777215</height>
383 </size>
384 </property>
385 </widget>
386 </item>
387 <item row="2" column="0">
388 <widget class="QLabel" name="label_15">
389 <property name="text">
390 <string>Vert:</string>
391 </property>
392 </widget>
393 </item>
394 <item row="2" column="1">
395 <widget class="QLineEdit" name="sizeVert">
396 <property name="maximumSize">
397 <size>
398 <width>60</width>
399 <height>16777215</height>
400 </size>
401 </property>
402 </widget>
403 </item>
404 </layout>
405 </widget>
406 </item>
407 <item>
408 <widget class="QFrame" name="frame_2">
409 <property name="frameShape">
410 <enum>QFrame::StyledPanel</enum>
411 </property>
412 <property name="frameShadow">
413 <enum>QFrame::Raised</enum>
414 </property>
415 <layout class="QGridLayout" name="gridLayout_5">
416 <item row="0" column="0" colspan="2">
417 <widget class="QLabel" name="label_19">
418 <property name="text">
419 <string>Clipping plane</string>
420 </property>
421 </widget>
422 </item>
423 <item row="1" column="0">
424 <widget class="QLabel" name="label_17">
425 <property name="text">
426 <string>Fore:</string>
427 </property>
428 </widget>
429 </item>
430 <item row="1" column="1">
431 <widget class="QLineEdit" name="fore">
432 <property name="maximumSize">
433 <size>
434 <width>60</width>
435 <height>16777215</height>
436 </size>
437 </property>
438 </widget>
439 </item>
440 <item row="2" column="0">
441 <widget class="QLabel" name="label_18">
442 <property name="text">
443 <string>Aft:</string>
444 </property>
445 </widget>
446 </item>
447 <item row="2" column="1">
448 <widget class="QLineEdit" name="aft">
449 <property name="maximumSize">
450 <size>
451 <width>60</width>
452 <height>16777215</height>
453 </size>
454 </property>
455 </widget>
456 </item>
457 </layout>
458 </widget>
459 </item>
460 <item>
461 <widget class="QFrame" name="frame_3">
462 <property name="frameShape">
463 <enum>QFrame::StyledPanel</enum>
464 </property>
465 <property name="frameShadow">
466 <enum>QFrame::Raised</enum>
467 </property>
468 <layout class="QGridLayout" name="gridLayout_6">
469 <item row="0" column="0">
470 <widget class="QLabel" name="label_22">
471 <property name="text">
472 <string>Offset</string>
473 </property>
474 </widget>
475 </item>
476 <item row="1" column="0">
477 <widget class="QLabel" name="label_20">
478 <property name="text">
479 <string>Horiz:</string>
480 </property>
481 </widget>
482 </item>
483 <item row="1" column="1">
484 <widget class="QLineEdit" name="offsetHoriz">
485 <property name="maximumSize">
486 <size>
487 <width>60</width>
488 <height>16777215</height>
489 </size>
490 </property>
491 </widget>
492 </item>
493 <item row="2" column="0">
494 <widget class="QLabel" name="label_21">
495 <property name="text">
496 <string>Vert:</string>
497 </property>
498 </widget>
499 </item>
500 <item row="2" column="1">
501 <widget class="QLineEdit" name="offsetVert">
502 <property name="maximumSize">
503 <size>
504 <width>60</width>
505 <height>16777215</height>
506 </size>
507 </property>
508 </widget>
509 </item>
510 </layout>
511 </widget>
512 </item>
513 </layout>
514 </widget>
515 </item>
516 <item>
517 <widget class="QDialogButtonBox" name="buttonBox">
518 <property name="orientation">
519 <enum>Qt::Horizontal</enum>
520 </property>
521 <property name="standardButtons">
522 <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
523 </property>
524 </widget>
525 </item>
526 </layout>
527 </widget>
528 <resources/>
529 <connections>
530 <connection>
531 <sender>buttonBox</sender>
532 <signal>accepted()</signal>
533 <receiver>viewDialog</receiver>
534 <slot>accept()</slot>
535 <hints>
536 <hint type="sourcelabel">
537 <x>248</x>
538 <y>254</y>
539 </hint>
540 <hint type="destinationlabel">
541 <x>157</x>
542 <y>274</y>
543 </hint>
544 </hints>
545 </connection>
546 <connection>
547 <sender>buttonBox</sender>
548 <signal>rejected()</signal>
549 <receiver>viewDialog</receiver>
550 <slot>reject()</slot>
551 <hints>
552 <hint type="sourcelabel">
553 <x>316</x>
554 <y>260</y>
555 </hint>
556 <hint type="destinationlabel">
557 <x>286</x>
558 <y>274</y>
559 </hint>
560 </hints>
561 </connection>
562 </connections>
563 </ui>
