root/radiance/ray/src/qtrvu/qt.c
Revision: 1.1
Committed: Sat Oct 22 22:38:10 2011 UTC (12 years, 7 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R2P1, rad5R3, HEAD
Added qt interface for rvu and cmake files from Bill Hoffman
5 * qt.c - driver for qt
6 */
7 #include "math.h"
8 #include "copyright.h"
9 #include "standard.h"
10 #include "platform.h"
11 #include "color.h"
12 #include "driver.h"
13 #include "rpaint.h"
14 #include "color.h"
15
16 static char lastPrompt[1024];
17 static const char* currentCommand =0;
18 static int abort_render = 0;
19 static int progress = 0;
20 static int last_total_progress = 0;
21 #define GAMMA 2.2 /* default exponent correction */
22
23 static dr_closef_t qt_close;
24 static dr_clearf_t qt_clear;
25 static dr_paintrf_t qt_paintr;
26 static dr_getcurf_t qt_getcur;
27 static dr_comoutf_t qt_comout;
28 static dr_cominf_t qt_comin;
29 static dr_flushf_t qt_flush;
30
31 static struct driver qt_driver = {
32 qt_close, qt_clear, qt_paintr, qt_getcur,
33 qt_comout, qt_comin, qt_flush, 1.0
34 };
35
36 /* functions from qt_rvu_main.cxx */
37 extern qt_rvu_init(char*, char*, int*, int* );
38 extern qt_resize(int, int);
39 extern qt_rvu_paint(int r,int g,int b,int xmin,
40 int ymin,int xmax,int ymax);
41 extern void qt_flush_display();
42 extern int qt_rvu_run();
43 extern void qt_window_comout(const char*);
44 extern void qt_set_progress(int);
45 extern int qt_open_text_dialog(char* , const char*);
46
47 extern struct driver *
48 qt_init( /* initialize driver */
49 char *name,
50 char *id
51 )
52 {
53 lastPrompt[0] = 0;
54 make_gmap(GAMMA);
55 qt_rvu_init(name, id, &qt_driver.xsiz, &qt_driver.ysiz);
56 return(&qt_driver);
57 }
58
59
60 static void
61 qt_close(void) /* close our display */
62 {
63 fprintf(stderr, "Qt close\n");
64 }
65
66 static void
67 qt_clear( /* clear our display */
68 int xres,
69 int yres
70 )
71 {
72 qt_resize(xres, yres);
73 }
74
75
76 static void
77 qt_paintr( /* fill a rectangle */
78 COLOR col,
79 int xmin,
80 int ymin,
81 int xmax,
82 int ymax
83 )
84 {
85 uby8 rgb[3];
86 map_color(rgb, col);
87 qt_rvu_paint(rgb[RED], rgb[GRN], rgb[BLU],
88 xmin, ymin, xmax, ymax);
89 }
90
91 #define SCALE 1.2
92
93 static void
94 qt_flush(void) /* flush output */
95 {
96 int p;
97 if(last_total_progress)
98 {
99 progress++;
100 p = pdepth*10 +
101 (int)floor(10 *
102 atan( SCALE * progress / last_total_progress) * 2.0/3.141593);
103 qt_set_progress(p);
104 }
105 qt_flush_display();
106 }
107
108
109 static int comincalls = 0;
110 static void
111 qt_comin( /* read in command line qt gui */
112 char *inp,
113 char *prompt
114 )
115 {
116 if (prompt && strlen(prompt))
117 {
118 qt_comout(prompt);
119 }
120 if(comincalls < 2)
121 {
122 comincalls++;
123 }
124 /* if prompt is not set, then use the lastPrompt which
125 comes from the last call to comout */
126 if(!prompt)
127 {
128 prompt = lastPrompt;
129 }
130 /* first time call to qt_comin start qt event loop */
131 if(comincalls == 1)
132 {
133 qt_rvu_run();
134 /* when qt is done we are done so exit */
135 exit(0);
136 }
137 /* This code will be called from inside the running
138 qt_rvu_run loop in two cases:
139 1. when a user enters a new command to the text widget. In
140 this case the currentCommand is not null.
141 2. when a command calls comin directly, that is the else
142 case. */
143 if(currentCommand)
144 {
145 /* A user has entered a new command */
146 qt_comout((char*)currentCommand);
147 /* copy the user command into inp, set
148 currentCommand to null so as not to use it again,
149 and then return */
150 strcpy(inp, currentCommand);
151 currentCommand = 0;
152 return;
153 }
154 else
155 {
156 /* in this case comin has been called from inside a
157 command call like view.
158 OK tricky bit here. If the prompt is empty, it
159 is just trying to get the user to hit enter so that
160 the most recent comout does not scrool away. Since the
161 qt interface has a scroll bar we don't have to do that,
162 and do not want to prompt the user. Also, if the prompt
163 is set to "done: ", then we don't want to prompt the user.
164 In other cases we assume that we are inside a command
165 that is asking for more input and we use a dialog box
166 to get it. */
167 if(strlen(prompt) > 0 && strcmp(prompt, "done: ") != 0)
168 {
169 /* if the user entered new text, then echo that
170 to the output window. */
171 if(qt_open_text_dialog(inp, prompt))
172 {
173 qt_window_comout(inp);
174 }
175 lastPrompt[0] = 0;
176 }
177 }
178 }
179
180 static void
181 qt_comout( /* write out string to stdout */
182 char *outp
183 )
184 {
185 if (!outp)
186 {
187 return;
188 }
189 if (strlen(outp) > 0)
190 {
191 if(outp[strlen(outp)-2] == ':')
192 {
193 strcpy(lastPrompt, outp);
194 }
195 qt_window_comout(outp);
196 }
197 }
198
199 extern void qt_rvu_get_position(int *x, int *y);
200
201 static int
202 qt_getcur( /* get cursor position */
203 int *xp,
204 int *yp
205 )
206 {
207 qt_rvu_get_position(xp, yp);
208 return 0;
209 }
210
211 void qt_set_abort(int value)
212 {
213 dev->inpready = value;
214 }
215
216
217 /* process one command from the GUI */
218 void qt_process_command(const char* com)
219 {
220 char buf[512];
221 buf[0] = 0;
222 /* set the currentCommand to the command */
223 currentCommand = com;
224 /* Call command with no prompt, this will in
225 turn call qt_comin which will use the currentCommand
226 pointer as the command to process */
227 command("");
228 /* after processing a command try to do a render */
229 for ( ; ; )
230 {
231 if (hresolu <= 1<<pdepth && vresolu <= 1<<pdepth)
232 {
233 qt_set_progress(100);
234 qt_comout("done");
235 return;
236 }
237 errno = 0;
238 if (hresolu <= psample<<pdepth && vresolu <= psample<<pdepth)
239 {
240 sprintf(buf, "%d sampling...\n", 1<<pdepth);
241 qt_comout(buf);
242 last_total_progress = progress ? progress:1;
243 progress = 0;
244 rsample();
245 }
246 else
247 {
248 sprintf(buf, "%d refining...\n", 1<<pdepth);
249 qt_comout(buf);
250 last_total_progress = progress ? progress:1;
251 progress = 0;
252 refine(&ptrunk, pdepth+1);
253 }
254 if (dev->inpready)
255 {
256 qt_comout("abort");
257 dev->inpready = 0;
258 pdepth = 10;
259 return;
260 }
261 /* finished this depth */
262 pdepth++;
263 }
264 }
265
