root/radiance/ray/src/qtrvu/qt.c
Revision: 1.1
Committed: Sat Oct 22 22:38:10 2011 UTC (13 years, 9 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R1, rad4R2P1, rad4R2P2, HEAD
Added qt interface for rvu and cmake files from Bill Hoffman
# User Rev Content
1 greg 1.1 #ifndef lint
2     static const char RCSid[] = "$Id$";
3     #endif
4     /*
5     * qt.c - driver for qt
6     */
7     #include "math.h"
8     #include "copyright.h"
9     #include "standard.h"
10     #include "platform.h"
11     #include "color.h"
12     #include "driver.h"
13     #include "rpaint.h"
14     #include "color.h"
15
16     static char lastPrompt[1024];
17     static const char* currentCommand =0;
18     static int abort_render = 0;
19     static int progress = 0;
20     static int last_total_progress = 0;
21     #define GAMMA 2.2 /* default exponent correction */
22
23     static dr_closef_t qt_close;
24     static dr_clearf_t qt_clear;
25     static dr_paintrf_t qt_paintr;
26     static dr_getcurf_t qt_getcur;
27     static dr_comoutf_t qt_comout;
28     static dr_cominf_t qt_comin;
29     static dr_flushf_t qt_flush;
30
31     static struct driver qt_driver = {
32     qt_close, qt_clear, qt_paintr, qt_getcur,
33     qt_comout, qt_comin, qt_flush, 1.0
34     };
35
36     /* functions from qt_rvu_main.cxx */
37     extern qt_rvu_init(char*, char*, int*, int* );
38     extern qt_resize(int, int);
39     extern qt_rvu_paint(int r,int g,int b,int xmin,
40     int ymin,int xmax,int ymax);
41     extern void qt_flush_display();
42     extern int qt_rvu_run();
43     extern void qt_window_comout(const char*);
44     extern void qt_set_progress(int);
45     extern int qt_open_text_dialog(char* , const char*);
46
47     extern struct driver *
48     qt_init( /* initialize driver */
49     char *name,
50     char *id
51     )
52     {
53     lastPrompt[0] = 0;
54     make_gmap(GAMMA);
55     qt_rvu_init(name, id, &qt_driver.xsiz, &qt_driver.ysiz);
56     return(&qt_driver);
57     }
58
59
60     static void
61     qt_close(void) /* close our display */
62     {
63     fprintf(stderr, "Qt close\n");
64     }
65
66     static void
67     qt_clear( /* clear our display */
68     int xres,
69     int yres
70     )
71     {
72     qt_resize(xres, yres);
73     }
74
75
76     static void
77     qt_paintr( /* fill a rectangle */
78     COLOR col,
79     int xmin,
80     int ymin,
81     int xmax,
82     int ymax
83     )
84     {
85     uby8 rgb[3];
86     map_color(rgb, col);
87     qt_rvu_paint(rgb[RED], rgb[GRN], rgb[BLU],
88     xmin, ymin, xmax, ymax);
89     }
90
91     #define SCALE 1.2
92
93     static void
94     qt_flush(void) /* flush output */
95     {
96     int p;
97     if(last_total_progress)
98     {
99     progress++;
100     p = pdepth*10 +
101     (int)floor(10 *
102     atan( SCALE * progress / last_total_progress) * 2.0/3.141593);
103     qt_set_progress(p);
104     }
105     qt_flush_display();
106     }
107
108
109     static int comincalls = 0;
110     static void
111     qt_comin( /* read in command line qt gui */
112     char *inp,
113     char *prompt
114     )
115     {
116     if (prompt && strlen(prompt))
117     {
118     qt_comout(prompt);
119     }
120     if(comincalls < 2)
121     {
122     comincalls++;
123     }
124     /* if prompt is not set, then use the lastPrompt which
125     comes from the last call to comout */
126     if(!prompt)
127     {
128     prompt = lastPrompt;
129     }
130     /* first time call to qt_comin start qt event loop */
131     if(comincalls == 1)
132     {
133     qt_rvu_run();
134     /* when qt is done we are done so exit */
135     exit(0);
136     }
137     /* This code will be called from inside the running
138     qt_rvu_run loop in two cases:
139     1. when a user enters a new command to the text widget. In
140     this case the currentCommand is not null.
141     2. when a command calls comin directly, that is the else
142     case. */
143     if(currentCommand)
144     {
145     /* A user has entered a new command */
146     qt_comout((char*)currentCommand);
147     /* copy the user command into inp, set
148     currentCommand to null so as not to use it again,
149     and then return */
150     strcpy(inp, currentCommand);
151     currentCommand = 0;
152     return;
153     }
154     else
155     {
156     /* in this case comin has been called from inside a
157     command call like view.
158     OK tricky bit here. If the prompt is empty, it
159     is just trying to get the user to hit enter so that
160     the most recent comout does not scrool away. Since the
161     qt interface has a scroll bar we don't have to do that,
162     and do not want to prompt the user. Also, if the prompt
163     is set to "done: ", then we don't want to prompt the user.
164     In other cases we assume that we are inside a command
165     that is asking for more input and we use a dialog box
166     to get it. */
167     if(strlen(prompt) > 0 && strcmp(prompt, "done: ") != 0)
168     {
169     /* if the user entered new text, then echo that
170     to the output window. */
171     if(qt_open_text_dialog(inp, prompt))
172     {
173     qt_window_comout(inp);
174     }
175     lastPrompt[0] = 0;
176     }
177     }
178     }
179
180     static void
181     qt_comout( /* write out string to stdout */
182     char *outp
183     )
184     {
185     if (!outp)
186     {
187     return;
188     }
189     if (strlen(outp) > 0)
190     {
191     if(outp[strlen(outp)-2] == ':')
192     {
193     strcpy(lastPrompt, outp);
194     }
195     qt_window_comout(outp);
196     }
197     }
198
199     extern void qt_rvu_get_position(int *x, int *y);
200
201     static int
202     qt_getcur( /* get cursor position */
203     int *xp,
204     int *yp
205     )
206     {
207     qt_rvu_get_position(xp, yp);
208     return 0;
209     }
210
211     void qt_set_abort(int value)
212     {
213     dev->inpready = value;
214     }
215
216
217     /* process one command from the GUI */
218     void qt_process_command(const char* com)
219     {
220     char buf[512];
221     buf[0] = 0;
222     /* set the currentCommand to the command */
223     currentCommand = com;
224     /* Call command with no prompt, this will in
225     turn call qt_comin which will use the currentCommand
226     pointer as the command to process */
227     command("");
228     /* after processing a command try to do a render */
229     for ( ; ; )
230     {
231     if (hresolu <= 1<<pdepth && vresolu <= 1<<pdepth)
232     {
233     qt_set_progress(100);
234     qt_comout("done");
235     return;
236     }
237     errno = 0;
238     if (hresolu <= psample<<pdepth && vresolu <= psample<<pdepth)
239     {
240     sprintf(buf, "%d sampling...\n", 1<<pdepth);
241     qt_comout(buf);
242     last_total_progress = progress ? progress:1;
243     progress = 0;
244     rsample();
245     }
246     else
247     {
248     sprintf(buf, "%d refining...\n", 1<<pdepth);
249     qt_comout(buf);
250     last_total_progress = progress ? progress:1;
251     progress = 0;
252     refine(&ptrunk, pdepth+1);
253     }
254     if (dev->inpready)
255     {
256     qt_comout("abort");
257     dev->inpready = 0;
258     pdepth = 10;
259     return;
260     }
261     /* finished this depth */
262     pdepth++;
263     }
264     }
265
