| 1 | <?xml version="1.0" encoding="UTF-8"?> |
| 2 | <ui version="4.0"> |
| 3 | <class>parameterDialog</class> |
| 4 | <widget class="QDialog" name="parameterDialog"> |
| 5 | <property name="geometry"> |
| 6 | <rect> |
| 7 | <x>0</x> |
| 8 | <y>0</y> |
| 9 | <width>617</width> |
| 10 | <height>392</height> |
| 11 | </rect> |
| 12 | </property> |
| 13 | <property name="windowTitle"> |
| 14 | <string>Parameters</string> |
| 15 | </property> |
| 16 | <layout class="QVBoxLayout" name="verticalLayout"> |
| 17 | <item> |
| 18 | <widget class="QTabWidget" name="tabWidget"> |
| 19 | <property name="cursor"> |
| 20 | <cursorShape>IBeamCursor</cursorShape> |
| 21 | </property> |
| 22 | <property name="currentIndex"> |
| 23 | <number>0</number> |
| 24 | </property> |
| 25 | <widget class="QWidget" name="ambientTab"> |
| 26 | <attribute name="title"> |
| 27 | <string>Ambient</string> |
| 28 | </attribute> |
| 29 | <layout class="QGridLayout" name="gridLayout"> |
| 30 | <item row="0" column="2"> |
| 31 | <spacer name="verticalSpacer_9"> |
| 32 | <property name="orientation"> |
| 33 | <enum>Qt::Vertical</enum> |
| 34 | </property> |
| 35 | <property name="sizeHint" stdset="0"> |
| 36 | <size> |
| 37 | <width>20</width> |
| 38 | <height>83</height> |
| 39 | </size> |
| 40 | </property> |
| 41 | </spacer> |
| 42 | </item> |
| 43 | <item row="1" column="0"> |
| 44 | <widget class="QLabel" name="label"> |
| 45 | <property name="text"> |
| 46 | <string>Value:</string> |
| 47 | </property> |
| 48 | <property name="alignment"> |
| 49 | <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set> |
| 50 | </property> |
| 51 | </widget> |
| 52 | </item> |
| 53 | <item row="1" column="1"> |
| 54 | <widget class="QLineEdit" name="valueX"> |
| 55 | <property name="sizePolicy"> |
| 56 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 57 | <horstretch>0</horstretch> |
| 58 | <verstretch>0</verstretch> |
| 59 | </sizepolicy> |
| 60 | </property> |
| 61 | </widget> |
| 62 | </item> |
| 63 | <item row="1" column="2"> |
| 64 | <widget class="QLabel" name="label_2"> |
| 65 | <property name="layoutDirection"> |
| 66 | <enum>Qt::LeftToRight</enum> |
| 67 | </property> |
| 68 | <property name="text"> |
| 69 | <string>Weight:</string> |
| 70 | </property> |
| 71 | <property name="alignment"> |
| 72 | <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set> |
| 73 | </property> |
| 74 | </widget> |
| 75 | </item> |
| 76 | <item row="1" column="3"> |
| 77 | <widget class="QLineEdit" name="weight"> |
| 78 | <property name="sizePolicy"> |
| 79 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 80 | <horstretch>0</horstretch> |
| 81 | <verstretch>0</verstretch> |
| 82 | </sizepolicy> |
| 83 | </property> |
| 84 | </widget> |
| 85 | </item> |
| 86 | <item row="1" column="4"> |
| 87 | <widget class="QLabel" name="label_5"> |
| 88 | <property name="layoutDirection"> |
| 89 | <enum>Qt::LeftToRight</enum> |
| 90 | </property> |
| 91 | <property name="text"> |
| 92 | <string>Super-samples:</string> |
| 93 | </property> |
| 94 | <property name="alignment"> |
| 95 | <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set> |
| 96 | </property> |
| 97 | </widget> |
| 98 | </item> |
| 99 | <item row="1" column="5"> |
| 100 | <widget class="QLineEdit" name="supersamples"/> |
| 101 | </item> |
| 102 | <item row="2" column="1"> |
| 103 | <widget class="QLineEdit" name="valueY"> |
| 104 | <property name="sizePolicy"> |
| 105 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 106 | <horstretch>0</horstretch> |
| 107 | <verstretch>0</verstretch> |
| 108 | </sizepolicy> |
| 109 | </property> |
| 110 | </widget> |
| 111 | </item> |
| 112 | <item row="2" column="2"> |
| 113 | <widget class="QLabel" name="label_3"> |
| 114 | <property name="layoutDirection"> |
| 115 | <enum>Qt::LeftToRight</enum> |
| 116 | </property> |
| 117 | <property name="text"> |
| 118 | <string>Accuracy:</string> |
| 119 | </property> |
| 120 | <property name="alignment"> |
| 121 | <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set> |
| 122 | </property> |
| 123 | </widget> |
| 124 | </item> |
| 125 | <item row="2" column="3"> |
| 126 | <widget class="QLineEdit" name="accuracy"> |
| 127 | <property name="sizePolicy"> |
| 128 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 129 | <horstretch>0</horstretch> |
| 130 | <verstretch>0</verstretch> |
| 131 | </sizepolicy> |
| 132 | </property> |
| 133 | </widget> |
| 134 | </item> |
| 135 | <item row="2" column="4"> |
| 136 | <widget class="QLabel" name="label_6"> |
| 137 | <property name="layoutDirection"> |
| 138 | <enum>Qt::LeftToRight</enum> |
| 139 | </property> |
| 140 | <property name="text"> |
| 141 | <string>Bounces:</string> |
| 142 | </property> |
| 143 | <property name="alignment"> |
| 144 | <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set> |
| 145 | </property> |
| 146 | </widget> |
| 147 | </item> |
| 148 | <item row="2" column="5"> |
| 149 | <widget class="QLineEdit" name="bounces"> |
| 150 | <property name="sizePolicy"> |
| 151 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 152 | <horstretch>0</horstretch> |
| 153 | <verstretch>0</verstretch> |
| 154 | </sizepolicy> |
| 155 | </property> |
| 156 | </widget> |
| 157 | </item> |
| 158 | <item row="3" column="1"> |
| 159 | <widget class="QLineEdit" name="valueZ"> |
| 160 | <property name="sizePolicy"> |
| 161 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 162 | <horstretch>0</horstretch> |
| 163 | <verstretch>0</verstretch> |
| 164 | </sizepolicy> |
| 165 | </property> |
| 166 | </widget> |
| 167 | </item> |
| 168 | <item row="3" column="2"> |
| 169 | <widget class="QLabel" name="label_4"> |
| 170 | <property name="layoutDirection"> |
| 171 | <enum>Qt::LeftToRight</enum> |
| 172 | </property> |
| 173 | <property name="text"> |
| 174 | <string>Divisions:</string> |
| 175 | </property> |
| 176 | <property name="alignment"> |
| 177 | <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set> |
| 178 | </property> |
| 179 | </widget> |
| 180 | </item> |
| 181 | <item row="3" column="3"> |
| 182 | <widget class="QLineEdit" name="divisions"> |
| 183 | <property name="sizePolicy"> |
| 184 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 185 | <horstretch>0</horstretch> |
| 186 | <verstretch>0</verstretch> |
| 187 | </sizepolicy> |
| 188 | </property> |
| 189 | </widget> |
| 190 | </item> |
| 191 | <item row="3" column="4"> |
| 192 | <widget class="QLabel" name="label_7"> |
| 193 | <property name="layoutDirection"> |
| 194 | <enum>Qt::LeftToRight</enum> |
| 195 | </property> |
| 196 | <property name="text"> |
| 197 | <string>Resolution:</string> |
| 198 | </property> |
| 199 | <property name="alignment"> |
| 200 | <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set> |
| 201 | </property> |
| 202 | </widget> |
| 203 | </item> |
| 204 | <item row="3" column="5"> |
| 205 | <widget class="QLineEdit" name="resolution"> |
| 206 | <property name="sizePolicy"> |
| 207 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 208 | <horstretch>0</horstretch> |
| 209 | <verstretch>0</verstretch> |
| 210 | </sizepolicy> |
| 211 | </property> |
| 212 | </widget> |
| 213 | </item> |
| 214 | <item row="4" column="2"> |
| 215 | <spacer name="verticalSpacer_10"> |
| 216 | <property name="orientation"> |
| 217 | <enum>Qt::Vertical</enum> |
| 218 | </property> |
| 219 | <property name="sizeHint" stdset="0"> |
| 220 | <size> |
| 221 | <width>20</width> |
| 222 | <height>84</height> |
| 223 | </size> |
| 224 | </property> |
| 225 | </spacer> |
| 226 | </item> |
| 227 | </layout> |
| 228 | </widget> |
| 229 | <widget class="QWidget" name="directTab"> |
| 230 | <attribute name="title"> |
| 231 | <string>Direct</string> |
| 232 | </attribute> |
| 233 | <layout class="QGridLayout" name="gridLayout_2"> |
| 234 | <item row="0" column="1"> |
| 235 | <widget class="QLabel" name="label_8"> |
| 236 | <property name="sizePolicy"> |
| 237 | <sizepolicy hsizetype="Maximum" vsizetype="Preferred"> |
| 238 | <horstretch>0</horstretch> |
| 239 | <verstretch>0</verstretch> |
| 240 | </sizepolicy> |
| 241 | </property> |
| 242 | <property name="layoutDirection"> |
| 243 | <enum>Qt::LeftToRight</enum> |
| 244 | </property> |
| 245 | <property name="text"> |
| 246 | <string>Certainty:</string> |
| 247 | </property> |
| 248 | <property name="alignment"> |
| 249 | <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set> |
| 250 | </property> |
| 251 | </widget> |
| 252 | </item> |
| 253 | <item row="0" column="2"> |
| 254 | <widget class="QLineEdit" name="certainty"> |
| 255 | <property name="sizePolicy"> |
| 256 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 257 | <horstretch>0</horstretch> |
| 258 | <verstretch>0</verstretch> |
| 259 | </sizepolicy> |
| 260 | </property> |
| 261 | </widget> |
| 262 | </item> |
| 263 | <item row="1" column="1"> |
| 264 | <widget class="QLabel" name="label_9"> |
| 265 | <property name="sizePolicy"> |
| 266 | <sizepolicy hsizetype="Maximum" vsizetype="Preferred"> |
| 267 | <horstretch>0</horstretch> |
| 268 | <verstretch>0</verstretch> |
| 269 | </sizepolicy> |
| 270 | </property> |
| 271 | <property name="layoutDirection"> |
| 272 | <enum>Qt::LeftToRight</enum> |
| 273 | </property> |
| 274 | <property name="text"> |
| 275 | <string>Jitter:</string> |
| 276 | </property> |
| 277 | <property name="alignment"> |
| 278 | <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set> |
| 279 | </property> |
| 280 | </widget> |
| 281 | </item> |
| 282 | <item row="1" column="2"> |
| 283 | <widget class="QLineEdit" name="jitter"> |
| 284 | <property name="sizePolicy"> |
| 285 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 286 | <horstretch>0</horstretch> |
| 287 | <verstretch>0</verstretch> |
| 288 | </sizepolicy> |
| 289 | </property> |
| 290 | </widget> |
| 291 | </item> |
| 292 | <item row="2" column="0"> |
| 293 | <spacer name="horizontalSpacer_5"> |
| 294 | <property name="orientation"> |
| 295 | <enum>Qt::Horizontal</enum> |
| 296 | </property> |
| 297 | <property name="sizeHint" stdset="0"> |
| 298 | <size> |
| 299 | <width>153</width> |
| 300 | <height>20</height> |
| 301 | </size> |
| 302 | </property> |
| 303 | </spacer> |
| 304 | </item> |
| 305 | <item row="2" column="1"> |
| 306 | <widget class="QLabel" name="label_10"> |
| 307 | <property name="sizePolicy"> |
| 308 | <sizepolicy hsizetype="Maximum" vsizetype="Preferred"> |
| 309 | <horstretch>0</horstretch> |
| 310 | <verstretch>0</verstretch> |
| 311 | </sizepolicy> |
| 312 | </property> |
| 313 | <property name="layoutDirection"> |
| 314 | <enum>Qt::LeftToRight</enum> |
| 315 | </property> |
| 316 | <property name="text"> |
| 317 | <string>Sampling:</string> |
| 318 | </property> |
| 319 | <property name="alignment"> |
| 320 | <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set> |
| 321 | </property> |
| 322 | </widget> |
| 323 | </item> |
| 324 | <item row="2" column="2"> |
| 325 | <widget class="QLineEdit" name="sampling"> |
| 326 | <property name="sizePolicy"> |
| 327 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 328 | <horstretch>0</horstretch> |
| 329 | <verstretch>0</verstretch> |
| 330 | </sizepolicy> |
| 331 | </property> |
| 332 | </widget> |
| 333 | </item> |
| 334 | <item row="2" column="3"> |
| 335 | <spacer name="horizontalSpacer_6"> |
| 336 | <property name="orientation"> |
| 337 | <enum>Qt::Horizontal</enum> |
| 338 | </property> |
| 339 | <property name="sizeHint" stdset="0"> |
| 340 | <size> |
| 341 | <width>153</width> |
| 342 | <height>20</height> |
| 343 | </size> |
| 344 | </property> |
| 345 | </spacer> |
| 346 | </item> |
| 347 | <item row="3" column="1"> |
| 348 | <widget class="QLabel" name="label_11"> |
| 349 | <property name="sizePolicy"> |
| 350 | <sizepolicy hsizetype="Maximum" vsizetype="Preferred"> |
| 351 | <horstretch>0</horstretch> |
| 352 | <verstretch>0</verstretch> |
| 353 | </sizepolicy> |
| 354 | </property> |
| 355 | <property name="layoutDirection"> |
| 356 | <enum>Qt::LeftToRight</enum> |
| 357 | </property> |
| 358 | <property name="text"> |
| 359 | <string>Threshold:</string> |
| 360 | </property> |
| 361 | <property name="alignment"> |
| 362 | <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set> |
| 363 | </property> |
| 364 | </widget> |
| 365 | </item> |
| 366 | <item row="3" column="2"> |
| 367 | <widget class="QLineEdit" name="threshold"> |
| 368 | <property name="sizePolicy"> |
| 369 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 370 | <horstretch>0</horstretch> |
| 371 | <verstretch>0</verstretch> |
| 372 | </sizepolicy> |
| 373 | </property> |
| 374 | </widget> |
| 375 | </item> |
| 376 | <item row="4" column="1"> |
| 377 | <widget class="QLabel" name="label_12"> |
| 378 | <property name="sizePolicy"> |
| 379 | <sizepolicy hsizetype="Maximum" vsizetype="Preferred"> |
| 380 | <horstretch>0</horstretch> |
| 381 | <verstretch>0</verstretch> |
| 382 | </sizepolicy> |
| 383 | </property> |
| 384 | <property name="layoutDirection"> |
| 385 | <enum>Qt::LeftToRight</enum> |
| 386 | </property> |
| 387 | <property name="text"> |
| 388 | <string>Visibility:</string> |
| 389 | </property> |
| 390 | <property name="alignment"> |
| 391 | <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set> |
| 392 | </property> |
| 393 | </widget> |
| 394 | </item> |
| 395 | <item row="4" column="2"> |
| 396 | <widget class="QLineEdit" name="visibility"> |
| 397 | <property name="sizePolicy"> |
| 398 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 399 | <horstretch>0</horstretch> |
| 400 | <verstretch>0</verstretch> |
| 401 | </sizepolicy> |
| 402 | </property> |
| 403 | </widget> |
| 404 | </item> |
| 405 | </layout> |
| 406 | </widget> |
| 407 | <widget class="QWidget" name="limitTab"> |
| 408 | <attribute name="title"> |
| 409 | <string>Limit</string> |
| 410 | </attribute> |
| 411 | <layout class="QGridLayout" name="gridLayout_3"> |
| 412 | <item row="0" column="2"> |
| 413 | <spacer name="verticalSpacer"> |
| 414 | <property name="orientation"> |
| 415 | <enum>Qt::Vertical</enum> |
| 416 | </property> |
| 417 | <property name="sizeHint" stdset="0"> |
| 418 | <size> |
| 419 | <width>20</width> |
| 420 | <height>73</height> |
| 421 | </size> |
| 422 | </property> |
| 423 | </spacer> |
| 424 | </item> |
| 425 | <item row="1" column="0"> |
| 426 | <spacer name="horizontalSpacer"> |
| 427 | <property name="orientation"> |
| 428 | <enum>Qt::Horizontal</enum> |
| 429 | </property> |
| 430 | <property name="sizeHint" stdset="0"> |
| 431 | <size> |
| 432 | <width>173</width> |
| 433 | <height>20</height> |
| 434 | </size> |
| 435 | </property> |
| 436 | </spacer> |
| 437 | </item> |
| 438 | <item row="1" column="1"> |
| 439 | <widget class="QLabel" name="label_13"> |
| 440 | <property name="sizePolicy"> |
| 441 | <sizepolicy hsizetype="Maximum" vsizetype="Maximum"> |
| 442 | <horstretch>0</horstretch> |
| 443 | <verstretch>0</verstretch> |
| 444 | </sizepolicy> |
| 445 | </property> |
| 446 | <property name="layoutDirection"> |
| 447 | <enum>Qt::LeftToRight</enum> |
| 448 | </property> |
| 449 | <property name="text"> |
| 450 | <string>Reflection:</string> |
| 451 | </property> |
| 452 | <property name="alignment"> |
| 453 | <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set> |
| 454 | </property> |
| 455 | </widget> |
| 456 | </item> |
| 457 | <item row="1" column="2"> |
| 458 | <widget class="QLineEdit" name="reflection"> |
| 459 | <property name="sizePolicy"> |
| 460 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 461 | <horstretch>0</horstretch> |
| 462 | <verstretch>0</verstretch> |
| 463 | </sizepolicy> |
| 464 | </property> |
| 465 | </widget> |
| 466 | </item> |
| 467 | <item row="1" column="3"> |
| 468 | <spacer name="horizontalSpacer_2"> |
| 469 | <property name="orientation"> |
| 470 | <enum>Qt::Horizontal</enum> |
| 471 | </property> |
| 472 | <property name="sizeHint" stdset="0"> |
| 473 | <size> |
| 474 | <width>143</width> |
| 475 | <height>20</height> |
| 476 | </size> |
| 477 | </property> |
| 478 | </spacer> |
| 479 | </item> |
| 480 | <item row="2" column="0"> |
| 481 | <spacer name="horizontalSpacer_3"> |
| 482 | <property name="orientation"> |
| 483 | <enum>Qt::Horizontal</enum> |
| 484 | </property> |
| 485 | <property name="sizeHint" stdset="0"> |
| 486 | <size> |
| 487 | <width>173</width> |
| 488 | <height>20</height> |
| 489 | </size> |
| 490 | </property> |
| 491 | </spacer> |
| 492 | </item> |
| 493 | <item row="2" column="1"> |
| 494 | <widget class="QLabel" name="label_14"> |
| 495 | <property name="sizePolicy"> |
| 496 | <sizepolicy hsizetype="Maximum" vsizetype="Maximum"> |
| 497 | <horstretch>0</horstretch> |
| 498 | <verstretch>0</verstretch> |
| 499 | </sizepolicy> |
| 500 | </property> |
| 501 | <property name="layoutDirection"> |
| 502 | <enum>Qt::LeftToRight</enum> |
| 503 | </property> |
| 504 | <property name="text"> |
| 505 | <string>Weight:</string> |
| 506 | </property> |
| 507 | </widget> |
| 508 | </item> |
| 509 | <item row="2" column="2"> |
| 510 | <widget class="QLineEdit" name="limit_weight"> |
| 511 | <property name="sizePolicy"> |
| 512 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 513 | <horstretch>0</horstretch> |
| 514 | <verstretch>0</verstretch> |
| 515 | </sizepolicy> |
| 516 | </property> |
| 517 | </widget> |
| 518 | </item> |
| 519 | <item row="2" column="3"> |
| 520 | <spacer name="horizontalSpacer_4"> |
| 521 | <property name="orientation"> |
| 522 | <enum>Qt::Horizontal</enum> |
| 523 | </property> |
| 524 | <property name="sizeHint" stdset="0"> |
| 525 | <size> |
| 526 | <width>143</width> |
| 527 | <height>20</height> |
| 528 | </size> |
| 529 | </property> |
| 530 | </spacer> |
| 531 | </item> |
| 532 | <item row="3" column="2"> |
| 533 | <spacer name="verticalSpacer_2"> |
| 534 | <property name="orientation"> |
| 535 | <enum>Qt::Vertical</enum> |
| 536 | </property> |
| 537 | <property name="sizeHint" stdset="0"> |
| 538 | <size> |
| 539 | <width>20</width> |
| 540 | <height>124</height> |
| 541 | </size> |
| 542 | </property> |
| 543 | </spacer> |
| 544 | </item> |
| 545 | </layout> |
| 546 | </widget> |
| 547 | <widget class="QWidget" name="mediumTab"> |
| 548 | <attribute name="title"> |
| 549 | <string>Medium</string> |
| 550 | </attribute> |
| 551 | <layout class="QGridLayout" name="gridLayout_4"> |
| 552 | <item row="0" column="1"> |
| 553 | <spacer name="verticalSpacer_3"> |
| 554 | <property name="orientation"> |
| 555 | <enum>Qt::Vertical</enum> |
| 556 | </property> |
| 557 | <property name="sizeHint" stdset="0"> |
| 558 | <size> |
| 559 | <width>20</width> |
| 560 | <height>48</height> |
| 561 | </size> |
| 562 | </property> |
| 563 | </spacer> |
| 564 | </item> |
| 565 | <item row="1" column="1"> |
| 566 | <widget class="QLabel" name="label_15"> |
| 567 | <property name="sizePolicy"> |
| 568 | <sizepolicy hsizetype="Maximum" vsizetype="Maximum"> |
| 569 | <horstretch>0</horstretch> |
| 570 | <verstretch>0</verstretch> |
| 571 | </sizepolicy> |
| 572 | </property> |
| 573 | <property name="layoutDirection"> |
| 574 | <enum>Qt::LeftToRight</enum> |
| 575 | </property> |
| 576 | <property name="text"> |
| 577 | <string>Scattering albedo:</string> |
| 578 | </property> |
| 579 | </widget> |
| 580 | </item> |
| 581 | <item row="1" column="2"> |
| 582 | <widget class="QLabel" name="label_16"> |
| 583 | <property name="sizePolicy"> |
| 584 | <sizepolicy hsizetype="Maximum" vsizetype="Maximum"> |
| 585 | <horstretch>0</horstretch> |
| 586 | <verstretch>0</verstretch> |
| 587 | </sizepolicy> |
| 588 | </property> |
| 589 | <property name="layoutDirection"> |
| 590 | <enum>Qt::LeftToRight</enum> |
| 591 | </property> |
| 592 | <property name="text"> |
| 593 | <string>Extinction coefficient:</string> |
| 594 | </property> |
| 595 | </widget> |
| 596 | </item> |
| 597 | <item row="2" column="1"> |
| 598 | <widget class="QLineEdit" name="albedoX"> |
| 599 | <property name="sizePolicy"> |
| 600 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 601 | <horstretch>0</horstretch> |
| 602 | <verstretch>0</verstretch> |
| 603 | </sizepolicy> |
| 604 | </property> |
| 605 | </widget> |
| 606 | </item> |
| 607 | <item row="2" column="2"> |
| 608 | <widget class="QLineEdit" name="extinctionX"> |
| 609 | <property name="sizePolicy"> |
| 610 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 611 | <horstretch>0</horstretch> |
| 612 | <verstretch>0</verstretch> |
| 613 | </sizepolicy> |
| 614 | </property> |
| 615 | </widget> |
| 616 | </item> |
| 617 | <item row="3" column="1"> |
| 618 | <widget class="QLineEdit" name="albedoY"> |
| 619 | <property name="sizePolicy"> |
| 620 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 621 | <horstretch>0</horstretch> |
| 622 | <verstretch>0</verstretch> |
| 623 | </sizepolicy> |
| 624 | </property> |
| 625 | </widget> |
| 626 | </item> |
| 627 | <item row="3" column="2"> |
| 628 | <widget class="QLineEdit" name="extinctionY"> |
| 629 | <property name="sizePolicy"> |
| 630 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 631 | <horstretch>0</horstretch> |
| 632 | <verstretch>0</verstretch> |
| 633 | </sizepolicy> |
| 634 | </property> |
| 635 | </widget> |
| 636 | </item> |
| 637 | <item row="4" column="1"> |
| 638 | <widget class="QLineEdit" name="albedoZ"> |
| 639 | <property name="sizePolicy"> |
| 640 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 641 | <horstretch>0</horstretch> |
| 642 | <verstretch>0</verstretch> |
| 643 | </sizepolicy> |
| 644 | </property> |
| 645 | </widget> |
| 646 | </item> |
| 647 | <item row="4" column="2"> |
| 648 | <widget class="QLineEdit" name="extinctionZ"> |
| 649 | <property name="sizePolicy"> |
| 650 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 651 | <horstretch>0</horstretch> |
| 652 | <verstretch>0</verstretch> |
| 653 | </sizepolicy> |
| 654 | </property> |
| 655 | </widget> |
| 656 | </item> |
| 657 | <item row="5" column="0"> |
| 658 | <spacer name="horizontalSpacer_7"> |
| 659 | <property name="orientation"> |
| 660 | <enum>Qt::Horizontal</enum> |
| 661 | </property> |
| 662 | <property name="sizeHint" stdset="0"> |
| 663 | <size> |
| 664 | <width>109</width> |
| 665 | <height>20</height> |
| 666 | </size> |
| 667 | </property> |
| 668 | </spacer> |
| 669 | </item> |
| 670 | <item row="5" column="1"> |
| 671 | <widget class="QLabel" name="label_17"> |
| 672 | <property name="sizePolicy"> |
| 673 | <sizepolicy hsizetype="Maximum" vsizetype="Maximum"> |
| 674 | <horstretch>0</horstretch> |
| 675 | <verstretch>0</verstretch> |
| 676 | </sizepolicy> |
| 677 | </property> |
| 678 | <property name="layoutDirection"> |
| 679 | <enum>Qt::LeftToRight</enum> |
| 680 | </property> |
| 681 | <property name="text"> |
| 682 | <string>Scattering eccentricity:</string> |
| 683 | </property> |
| 684 | </widget> |
| 685 | </item> |
| 686 | <item row="5" column="2"> |
| 687 | <widget class="QLabel" name="label_18"> |
| 688 | <property name="sizePolicy"> |
| 689 | <sizepolicy hsizetype="Maximum" vsizetype="Maximum"> |
| 690 | <horstretch>0</horstretch> |
| 691 | <verstretch>0</verstretch> |
| 692 | </sizepolicy> |
| 693 | </property> |
| 694 | <property name="layoutDirection"> |
| 695 | <enum>Qt::LeftToRight</enum> |
| 696 | </property> |
| 697 | <property name="text"> |
| 698 | <string>Mist sampling distance:</string> |
| 699 | </property> |
| 700 | </widget> |
| 701 | </item> |
| 702 | <item row="5" column="3"> |
| 703 | <spacer name="horizontalSpacer_8"> |
| 704 | <property name="orientation"> |
| 705 | <enum>Qt::Horizontal</enum> |
| 706 | </property> |
| 707 | <property name="sizeHint" stdset="0"> |
| 708 | <size> |
| 709 | <width>108</width> |
| 710 | <height>20</height> |
| 711 | </size> |
| 712 | </property> |
| 713 | </spacer> |
| 714 | </item> |
| 715 | <item row="6" column="1"> |
| 716 | <widget class="QLineEdit" name="eccentricity"> |
| 717 | <property name="sizePolicy"> |
| 718 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 719 | <horstretch>0</horstretch> |
| 720 | <verstretch>0</verstretch> |
| 721 | </sizepolicy> |
| 722 | </property> |
| 723 | </widget> |
| 724 | </item> |
| 725 | <item row="6" column="2"> |
| 726 | <widget class="QLineEdit" name="mistDistance"> |
| 727 | <property name="sizePolicy"> |
| 728 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 729 | <horstretch>0</horstretch> |
| 730 | <verstretch>0</verstretch> |
| 731 | </sizepolicy> |
| 732 | </property> |
| 733 | </widget> |
| 734 | </item> |
| 735 | <item row="7" column="1"> |
| 736 | <spacer name="verticalSpacer_4"> |
| 737 | <property name="orientation"> |
| 738 | <enum>Qt::Vertical</enum> |
| 739 | </property> |
| 740 | <property name="sizeHint" stdset="0"> |
| 741 | <size> |
| 742 | <width>20</width> |
| 743 | <height>28</height> |
| 744 | </size> |
| 745 | </property> |
| 746 | </spacer> |
| 747 | </item> |
| 748 | </layout> |
| 749 | </widget> |
| 750 | <widget class="QWidget" name="pixelTab"> |
| 751 | <attribute name="title"> |
| 752 | <string>Pixel</string> |
| 753 | </attribute> |
| 754 | <layout class="QGridLayout" name="gridLayout_5"> |
| 755 | <item row="0" column="1"> |
| 756 | <spacer name="verticalSpacer_6"> |
| 757 | <property name="orientation"> |
| 758 | <enum>Qt::Vertical</enum> |
| 759 | </property> |
| 760 | <property name="sizeHint" stdset="0"> |
| 761 | <size> |
| 762 | <width>20</width> |
| 763 | <height>99</height> |
| 764 | </size> |
| 765 | </property> |
| 766 | </spacer> |
| 767 | </item> |
| 768 | <item row="1" column="0"> |
| 769 | <spacer name="horizontalSpacer_9"> |
| 770 | <property name="orientation"> |
| 771 | <enum>Qt::Horizontal</enum> |
| 772 | </property> |
| 773 | <property name="sizeHint" stdset="0"> |
| 774 | <size> |
| 775 | <width>156</width> |
| 776 | <height>20</height> |
| 777 | </size> |
| 778 | </property> |
| 779 | </spacer> |
| 780 | </item> |
| 781 | <item row="1" column="1"> |
| 782 | <widget class="QLabel" name="label_19"> |
| 783 | <property name="sizePolicy"> |
| 784 | <sizepolicy hsizetype="Maximum" vsizetype="Preferred"> |
| 785 | <horstretch>0</horstretch> |
| 786 | <verstretch>0</verstretch> |
| 787 | </sizepolicy> |
| 788 | </property> |
| 789 | <property name="layoutDirection"> |
| 790 | <enum>Qt::LeftToRight</enum> |
| 791 | </property> |
| 792 | <property name="text"> |
| 793 | <string>Sample:</string> |
| 794 | </property> |
| 795 | </widget> |
| 796 | </item> |
| 797 | <item row="1" column="2"> |
| 798 | <widget class="QLineEdit" name="sample"> |
| 799 | <property name="sizePolicy"> |
| 800 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 801 | <horstretch>0</horstretch> |
| 802 | <verstretch>0</verstretch> |
| 803 | </sizepolicy> |
| 804 | </property> |
| 805 | </widget> |
| 806 | </item> |
| 807 | <item row="1" column="3"> |
| 808 | <spacer name="horizontalSpacer_10"> |
| 809 | <property name="orientation"> |
| 810 | <enum>Qt::Horizontal</enum> |
| 811 | </property> |
| 812 | <property name="sizeHint" stdset="0"> |
| 813 | <size> |
| 814 | <width>146</width> |
| 815 | <height>20</height> |
| 816 | </size> |
| 817 | </property> |
| 818 | </spacer> |
| 819 | </item> |
| 820 | <item row="2" column="1"> |
| 821 | <widget class="QLabel" name="label_20"> |
| 822 | <property name="sizePolicy"> |
| 823 | <sizepolicy hsizetype="Maximum" vsizetype="Preferred"> |
| 824 | <horstretch>0</horstretch> |
| 825 | <verstretch>0</verstretch> |
| 826 | </sizepolicy> |
| 827 | </property> |
| 828 | <property name="layoutDirection"> |
| 829 | <enum>Qt::LeftToRight</enum> |
| 830 | </property> |
| 831 | <property name="text"> |
| 832 | <string>Threshold</string> |
| 833 | </property> |
| 834 | </widget> |
| 835 | </item> |
| 836 | <item row="2" column="2"> |
| 837 | <widget class="QLineEdit" name="px_threshold"/> |
| 838 | </item> |
| 839 | <item row="3" column="1"> |
| 840 | <spacer name="verticalSpacer_5"> |
| 841 | <property name="orientation"> |
| 842 | <enum>Qt::Vertical</enum> |
| 843 | </property> |
| 844 | <property name="sizeHint" stdset="0"> |
| 845 | <size> |
| 846 | <width>20</width> |
| 847 | <height>99</height> |
| 848 | </size> |
| 849 | </property> |
| 850 | </spacer> |
| 851 | </item> |
| 852 | </layout> |
| 853 | </widget> |
| 854 | <widget class="QWidget" name="specularTab"> |
| 855 | <attribute name="title"> |
| 856 | <string>Specular</string> |
| 857 | </attribute> |
| 858 | <layout class="QGridLayout" name="gridLayout_6"> |
| 859 | <item row="0" column="1"> |
| 860 | <spacer name="verticalSpacer_7"> |
| 861 | <property name="orientation"> |
| 862 | <enum>Qt::Vertical</enum> |
| 863 | </property> |
| 864 | <property name="sizeHint" stdset="0"> |
| 865 | <size> |
| 866 | <width>20</width> |
| 867 | <height>99</height> |
| 868 | </size> |
| 869 | </property> |
| 870 | </spacer> |
| 871 | </item> |
| 872 | <item row="1" column="0"> |
| 873 | <spacer name="horizontalSpacer_12"> |
| 874 | <property name="orientation"> |
| 875 | <enum>Qt::Horizontal</enum> |
| 876 | </property> |
| 877 | <property name="sizeHint" stdset="0"> |
| 878 | <size> |
| 879 | <width>155</width> |
| 880 | <height>20</height> |
| 881 | </size> |
| 882 | </property> |
| 883 | </spacer> |
| 884 | </item> |
| 885 | <item row="1" column="1"> |
| 886 | <widget class="QLabel" name="label_22"> |
| 887 | <property name="sizePolicy"> |
| 888 | <sizepolicy hsizetype="Maximum" vsizetype="Preferred"> |
| 889 | <horstretch>0</horstretch> |
| 890 | <verstretch>0</verstretch> |
| 891 | </sizepolicy> |
| 892 | </property> |
| 893 | <property name="layoutDirection"> |
| 894 | <enum>Qt::LeftToRight</enum> |
| 895 | </property> |
| 896 | <property name="text"> |
| 897 | <string>Jitter:</string> |
| 898 | </property> |
| 899 | </widget> |
| 900 | </item> |
| 901 | <item row="1" column="2"> |
| 902 | <widget class="QLineEdit" name="sp_jitter"> |
| 903 | <property name="sizePolicy"> |
| 904 | <sizepolicy hsizetype="Maximum" vsizetype="Fixed"> |
| 905 | <horstretch>0</horstretch> |
| 906 | <verstretch>0</verstretch> |
| 907 | </sizepolicy> |
| 908 | </property> |
| 909 | </widget> |
| 910 | </item> |
| 911 | <item row="1" column="3"> |
| 912 | <spacer name="horizontalSpacer_11"> |
| 913 | <property name="orientation"> |
| 914 | <enum>Qt::Horizontal</enum> |
| 915 | </property> |
| 916 | <property name="sizeHint" stdset="0"> |
| 917 | <size> |
| 918 | <width>145</width> |
| 919 | <height>20</height> |
| 920 | </size> |
| 921 | </property> |
| 922 | </spacer> |
| 923 | </item> |
| 924 | <item row="2" column="1"> |
| 925 | <widget class="QLabel" name="label_23"> |
| 926 | <property name="sizePolicy"> |
| 927 | <sizepolicy hsizetype="Maximum" vsizetype="Preferred"> |
| 928 | <horstretch>0</horstretch> |
| 929 | <verstretch>0</verstretch> |
| 930 | </sizepolicy> |
| 931 | </property> |
| 932 | <property name="layoutDirection"> |
| 933 | <enum>Qt::LeftToRight</enum> |
| 934 | </property> |
| 935 | <property name="text"> |
| 936 | <string>Threshold:</string> |
| 937 | </property> |
| 938 | </widget> |
| 939 | </item> |
| 940 | <item row="2" column="2"> |
| 941 | <widget class="QLineEdit" name="sp_threshold"/> |
| 942 | </item> |
| 943 | <item row="3" column="1"> |
| 944 | <spacer name="verticalSpacer_8"> |
| 945 | <property name="orientation"> |
| 946 | <enum>Qt::Vertical</enum> |
| 947 | </property> |
| 948 | <property name="sizeHint" stdset="0"> |
| 949 | <size> |
| 950 | <width>20</width> |
| 951 | <height>99</height> |
| 952 | </size> |
| 953 | </property> |
| 954 | </spacer> |
| 955 | </item> |
| 956 | </layout> |
| 957 | </widget> |
| 958 | </widget> |
| 959 | </item> |
| 960 | <item> |
| 961 | <widget class="QDialogButtonBox" name="buttonBox"> |
| 962 | <property name="orientation"> |
| 963 | <enum>Qt::Horizontal</enum> |
| 964 | </property> |
| 965 | <property name="standardButtons"> |
| 966 | <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set> |
| 967 | </property> |
| 968 | </widget> |
| 969 | </item> |
| 970 | </layout> |
| 971 | </widget> |
| 972 | <resources/> |
| 973 | <connections> |
| 974 | <connection> |
| 975 | <sender>buttonBox</sender> |
| 976 | <signal>accepted()</signal> |
| 977 | <receiver>parameterDialog</receiver> |
| 978 | <slot>accept()</slot> |
| 979 | <hints> |
| 980 | <hint type="sourcelabel"> |
| 981 | <x>248</x> |
| 982 | <y>254</y> |
| 983 | </hint> |
| 984 | <hint type="destinationlabel"> |
| 985 | <x>157</x> |
| 986 | <y>274</y> |
| 987 | </hint> |
| 988 | </hints> |
| 989 | </connection> |
| 990 | <connection> |
| 991 | <sender>buttonBox</sender> |
| 992 | <signal>rejected()</signal> |
| 993 | <receiver>parameterDialog</receiver> |
| 994 | <slot>reject()</slot> |
| 995 | <hints> |
| 996 | <hint type="sourcelabel"> |
| 997 | <x>316</x> |
| 998 | <y>260</y> |
| 999 | </hint> |
| 1000 | <hint type="destinationlabel"> |
| 1001 | <x>286</x> |
| 1002 | <y>274</y> |
| 1003 | </hint> |
| 1004 | </hints> |
| 1005 | </connection> |
| 1006 | </connections> |
| 1007 | </ui> |
