root/radiance/ray/src/qtrvu/parameterdialog.ui
Revision: 1.1
Committed: Sat Oct 22 22:38:10 2011 UTC (13 years, 7 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R2P1, rad5R3, HEAD
Added qt interface for rvu and cmake files from Bill Hoffman
1 <?xml version="1.0" encoding="UTF-8"?>
2 <ui version="4.0">
3 <class>parameterDialog</class>
4 <widget class="QDialog" name="parameterDialog">
5 <property name="geometry">
6 <rect>
7 <x>0</x>
8 <y>0</y>
9 <width>617</width>
10 <height>392</height>
11 </rect>
12 </property>
13 <property name="windowTitle">
14 <string>Parameters</string>
15 </property>
16 <layout class="QVBoxLayout" name="verticalLayout">
17 <item>
18 <widget class="QTabWidget" name="tabWidget">
19 <property name="cursor">
20 <cursorShape>IBeamCursor</cursorShape>
21 </property>
22 <property name="currentIndex">
23 <number>0</number>
24 </property>
25 <widget class="QWidget" name="ambientTab">
26 <attribute name="title">
27 <string>Ambient</string>
28 </attribute>
29 <layout class="QGridLayout" name="gridLayout">
30 <item row="0" column="2">
31 <spacer name="verticalSpacer_9">
32 <property name="orientation">
33 <enum>Qt::Vertical</enum>
34 </property>
35 <property name="sizeHint" stdset="0">
36 <size>
37 <width>20</width>
38 <height>83</height>
39 </size>
40 </property>
41 </spacer>
42 </item>
43 <item row="1" column="0">
44 <widget class="QLabel" name="label">
45 <property name="text">
46 <string>Value:</string>
47 </property>
48 <property name="alignment">
49 <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
50 </property>
51 </widget>
52 </item>
53 <item row="1" column="1">
54 <widget class="QLineEdit" name="valueX">
55 <property name="sizePolicy">
56 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
57 <horstretch>0</horstretch>
58 <verstretch>0</verstretch>
59 </sizepolicy>
60 </property>
61 </widget>
62 </item>
63 <item row="1" column="2">
64 <widget class="QLabel" name="label_2">
65 <property name="layoutDirection">
66 <enum>Qt::LeftToRight</enum>
67 </property>
68 <property name="text">
69 <string>Weight:</string>
70 </property>
71 <property name="alignment">
72 <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
73 </property>
74 </widget>
75 </item>
76 <item row="1" column="3">
77 <widget class="QLineEdit" name="weight">
78 <property name="sizePolicy">
79 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
80 <horstretch>0</horstretch>
81 <verstretch>0</verstretch>
82 </sizepolicy>
83 </property>
84 </widget>
85 </item>
86 <item row="1" column="4">
87 <widget class="QLabel" name="label_5">
88 <property name="layoutDirection">
89 <enum>Qt::LeftToRight</enum>
90 </property>
91 <property name="text">
92 <string>Super-samples:</string>
93 </property>
94 <property name="alignment">
95 <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
96 </property>
97 </widget>
98 </item>
99 <item row="1" column="5">
100 <widget class="QLineEdit" name="supersamples"/>
101 </item>
102 <item row="2" column="1">
103 <widget class="QLineEdit" name="valueY">
104 <property name="sizePolicy">
105 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
106 <horstretch>0</horstretch>
107 <verstretch>0</verstretch>
108 </sizepolicy>
109 </property>
110 </widget>
111 </item>
112 <item row="2" column="2">
113 <widget class="QLabel" name="label_3">
114 <property name="layoutDirection">
115 <enum>Qt::LeftToRight</enum>
116 </property>
117 <property name="text">
118 <string>Accuracy:</string>
119 </property>
120 <property name="alignment">
121 <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
122 </property>
123 </widget>
124 </item>
125 <item row="2" column="3">
126 <widget class="QLineEdit" name="accuracy">
127 <property name="sizePolicy">
128 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
129 <horstretch>0</horstretch>
130 <verstretch>0</verstretch>
131 </sizepolicy>
132 </property>
133 </widget>
134 </item>
135 <item row="2" column="4">
136 <widget class="QLabel" name="label_6">
137 <property name="layoutDirection">
138 <enum>Qt::LeftToRight</enum>
139 </property>
140 <property name="text">
141 <string>Bounces:</string>
142 </property>
143 <property name="alignment">
144 <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
145 </property>
146 </widget>
147 </item>
148 <item row="2" column="5">
149 <widget class="QLineEdit" name="bounces">
150 <property name="sizePolicy">
151 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
152 <horstretch>0</horstretch>
153 <verstretch>0</verstretch>
154 </sizepolicy>
155 </property>
156 </widget>
157 </item>
158 <item row="3" column="1">
159 <widget class="QLineEdit" name="valueZ">
160 <property name="sizePolicy">
161 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
162 <horstretch>0</horstretch>
163 <verstretch>0</verstretch>
164 </sizepolicy>
165 </property>
166 </widget>
167 </item>
168 <item row="3" column="2">
169 <widget class="QLabel" name="label_4">
170 <property name="layoutDirection">
171 <enum>Qt::LeftToRight</enum>
172 </property>
173 <property name="text">
174 <string>Divisions:</string>
175 </property>
176 <property name="alignment">
177 <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
178 </property>
179 </widget>
180 </item>
181 <item row="3" column="3">
182 <widget class="QLineEdit" name="divisions">
183 <property name="sizePolicy">
184 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
185 <horstretch>0</horstretch>
186 <verstretch>0</verstretch>
187 </sizepolicy>
188 </property>
189 </widget>
190 </item>
191 <item row="3" column="4">
192 <widget class="QLabel" name="label_7">
193 <property name="layoutDirection">
194 <enum>Qt::LeftToRight</enum>
195 </property>
196 <property name="text">
197 <string>Resolution:</string>
198 </property>
199 <property name="alignment">
200 <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
201 </property>
202 </widget>
203 </item>
204 <item row="3" column="5">
205 <widget class="QLineEdit" name="resolution">
206 <property name="sizePolicy">
207 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
208 <horstretch>0</horstretch>
209 <verstretch>0</verstretch>
210 </sizepolicy>
211 </property>
212 </widget>
213 </item>
214 <item row="4" column="2">
215 <spacer name="verticalSpacer_10">
216 <property name="orientation">
217 <enum>Qt::Vertical</enum>
218 </property>
219 <property name="sizeHint" stdset="0">
220 <size>
221 <width>20</width>
222 <height>84</height>
223 </size>
224 </property>
225 </spacer>
226 </item>
227 </layout>
228 </widget>
229 <widget class="QWidget" name="directTab">
230 <attribute name="title">
231 <string>Direct</string>
232 </attribute>
233 <layout class="QGridLayout" name="gridLayout_2">
234 <item row="0" column="1">
235 <widget class="QLabel" name="label_8">
236 <property name="sizePolicy">
237 <sizepolicy hsizetype="Maximum" vsizetype="Preferred">
238 <horstretch>0</horstretch>
239 <verstretch>0</verstretch>
240 </sizepolicy>
241 </property>
242 <property name="layoutDirection">
243 <enum>Qt::LeftToRight</enum>
244 </property>
245 <property name="text">
246 <string>Certainty:</string>
247 </property>
248 <property name="alignment">
249 <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
250 </property>
251 </widget>
252 </item>
253 <item row="0" column="2">
254 <widget class="QLineEdit" name="certainty">
255 <property name="sizePolicy">
256 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
257 <horstretch>0</horstretch>
258 <verstretch>0</verstretch>
259 </sizepolicy>
260 </property>
261 </widget>
262 </item>
263 <item row="1" column="1">
264 <widget class="QLabel" name="label_9">
265 <property name="sizePolicy">
266 <sizepolicy hsizetype="Maximum" vsizetype="Preferred">
267 <horstretch>0</horstretch>
268 <verstretch>0</verstretch>
269 </sizepolicy>
270 </property>
271 <property name="layoutDirection">
272 <enum>Qt::LeftToRight</enum>
273 </property>
274 <property name="text">
275 <string>Jitter:</string>
276 </property>
277 <property name="alignment">
278 <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
279 </property>
280 </widget>
281 </item>
282 <item row="1" column="2">
283 <widget class="QLineEdit" name="jitter">
284 <property name="sizePolicy">
285 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
286 <horstretch>0</horstretch>
287 <verstretch>0</verstretch>
288 </sizepolicy>
289 </property>
290 </widget>
291 </item>
292 <item row="2" column="0">
293 <spacer name="horizontalSpacer_5">
294 <property name="orientation">
295 <enum>Qt::Horizontal</enum>
296 </property>
297 <property name="sizeHint" stdset="0">
298 <size>
299 <width>153</width>
300 <height>20</height>
301 </size>
302 </property>
303 </spacer>
304 </item>
305 <item row="2" column="1">
306 <widget class="QLabel" name="label_10">
307 <property name="sizePolicy">
308 <sizepolicy hsizetype="Maximum" vsizetype="Preferred">
309 <horstretch>0</horstretch>
310 <verstretch>0</verstretch>
311 </sizepolicy>
312 </property>
313 <property name="layoutDirection">
314 <enum>Qt::LeftToRight</enum>
315 </property>
316 <property name="text">
317 <string>Sampling:</string>
318 </property>
319 <property name="alignment">
320 <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
321 </property>
322 </widget>
323 </item>
324 <item row="2" column="2">
325 <widget class="QLineEdit" name="sampling">
326 <property name="sizePolicy">
327 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
328 <horstretch>0</horstretch>
329 <verstretch>0</verstretch>
330 </sizepolicy>
331 </property>
332 </widget>
333 </item>
334 <item row="2" column="3">
335 <spacer name="horizontalSpacer_6">
336 <property name="orientation">
337 <enum>Qt::Horizontal</enum>
338 </property>
339 <property name="sizeHint" stdset="0">
340 <size>
341 <width>153</width>
342 <height>20</height>
343 </size>
344 </property>
345 </spacer>
346 </item>
347 <item row="3" column="1">
348 <widget class="QLabel" name="label_11">
349 <property name="sizePolicy">
350 <sizepolicy hsizetype="Maximum" vsizetype="Preferred">
351 <horstretch>0</horstretch>
352 <verstretch>0</verstretch>
353 </sizepolicy>
354 </property>
355 <property name="layoutDirection">
356 <enum>Qt::LeftToRight</enum>
357 </property>
358 <property name="text">
359 <string>Threshold:</string>
360 </property>
361 <property name="alignment">
362 <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
363 </property>
364 </widget>
365 </item>
366 <item row="3" column="2">
367 <widget class="QLineEdit" name="threshold">
368 <property name="sizePolicy">
369 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
370 <horstretch>0</horstretch>
371 <verstretch>0</verstretch>
372 </sizepolicy>
373 </property>
374 </widget>
375 </item>
376 <item row="4" column="1">
377 <widget class="QLabel" name="label_12">
378 <property name="sizePolicy">
379 <sizepolicy hsizetype="Maximum" vsizetype="Preferred">
380 <horstretch>0</horstretch>
381 <verstretch>0</verstretch>
382 </sizepolicy>
383 </property>
384 <property name="layoutDirection">
385 <enum>Qt::LeftToRight</enum>
386 </property>
387 <property name="text">
388 <string>Visibility:</string>
389 </property>
390 <property name="alignment">
391 <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
392 </property>
393 </widget>
394 </item>
395 <item row="4" column="2">
396 <widget class="QLineEdit" name="visibility">
397 <property name="sizePolicy">
398 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
399 <horstretch>0</horstretch>
400 <verstretch>0</verstretch>
401 </sizepolicy>
402 </property>
403 </widget>
404 </item>
405 </layout>
406 </widget>
407 <widget class="QWidget" name="limitTab">
408 <attribute name="title">
409 <string>Limit</string>
410 </attribute>
411 <layout class="QGridLayout" name="gridLayout_3">
412 <item row="0" column="2">
413 <spacer name="verticalSpacer">
414 <property name="orientation">
415 <enum>Qt::Vertical</enum>
416 </property>
417 <property name="sizeHint" stdset="0">
418 <size>
419 <width>20</width>
420 <height>73</height>
421 </size>
422 </property>
423 </spacer>
424 </item>
425 <item row="1" column="0">
426 <spacer name="horizontalSpacer">
427 <property name="orientation">
428 <enum>Qt::Horizontal</enum>
429 </property>
430 <property name="sizeHint" stdset="0">
431 <size>
432 <width>173</width>
433 <height>20</height>
434 </size>
435 </property>
436 </spacer>
437 </item>
438 <item row="1" column="1">
439 <widget class="QLabel" name="label_13">
440 <property name="sizePolicy">
441 <sizepolicy hsizetype="Maximum" vsizetype="Maximum">
442 <horstretch>0</horstretch>
443 <verstretch>0</verstretch>
444 </sizepolicy>
445 </property>
446 <property name="layoutDirection">
447 <enum>Qt::LeftToRight</enum>
448 </property>
449 <property name="text">
450 <string>Reflection:</string>
451 </property>
452 <property name="alignment">
453 <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
454 </property>
455 </widget>
456 </item>
457 <item row="1" column="2">
458 <widget class="QLineEdit" name="reflection">
459 <property name="sizePolicy">
460 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
461 <horstretch>0</horstretch>
462 <verstretch>0</verstretch>
463 </sizepolicy>
464 </property>
465 </widget>
466 </item>
467 <item row="1" column="3">
468 <spacer name="horizontalSpacer_2">
469 <property name="orientation">
470 <enum>Qt::Horizontal</enum>
471 </property>
472 <property name="sizeHint" stdset="0">
473 <size>
474 <width>143</width>
475 <height>20</height>
476 </size>
477 </property>
478 </spacer>
479 </item>
480 <item row="2" column="0">
481 <spacer name="horizontalSpacer_3">
482 <property name="orientation">
483 <enum>Qt::Horizontal</enum>
484 </property>
485 <property name="sizeHint" stdset="0">
486 <size>
487 <width>173</width>
488 <height>20</height>
489 </size>
490 </property>
491 </spacer>
492 </item>
493 <item row="2" column="1">
494 <widget class="QLabel" name="label_14">
495 <property name="sizePolicy">
496 <sizepolicy hsizetype="Maximum" vsizetype="Maximum">
497 <horstretch>0</horstretch>
498 <verstretch>0</verstretch>
499 </sizepolicy>
500 </property>
501 <property name="layoutDirection">
502 <enum>Qt::LeftToRight</enum>
503 </property>
504 <property name="text">
505 <string>Weight:</string>
506 </property>
507 </widget>
508 </item>
509 <item row="2" column="2">
510 <widget class="QLineEdit" name="limit_weight">
511 <property name="sizePolicy">
512 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
513 <horstretch>0</horstretch>
514 <verstretch>0</verstretch>
515 </sizepolicy>
516 </property>
517 </widget>
518 </item>
519 <item row="2" column="3">
520 <spacer name="horizontalSpacer_4">
521 <property name="orientation">
522 <enum>Qt::Horizontal</enum>
523 </property>
524 <property name="sizeHint" stdset="0">
525 <size>
526 <width>143</width>
527 <height>20</height>
528 </size>
529 </property>
530 </spacer>
531 </item>
532 <item row="3" column="2">
533 <spacer name="verticalSpacer_2">
534 <property name="orientation">
535 <enum>Qt::Vertical</enum>
536 </property>
537 <property name="sizeHint" stdset="0">
538 <size>
539 <width>20</width>
540 <height>124</height>
541 </size>
542 </property>
543 </spacer>
544 </item>
545 </layout>
546 </widget>
547 <widget class="QWidget" name="mediumTab">
548 <attribute name="title">
549 <string>Medium</string>
550 </attribute>
551 <layout class="QGridLayout" name="gridLayout_4">
552 <item row="0" column="1">
553 <spacer name="verticalSpacer_3">
554 <property name="orientation">
555 <enum>Qt::Vertical</enum>
556 </property>
557 <property name="sizeHint" stdset="0">
558 <size>
559 <width>20</width>
560 <height>48</height>
561 </size>
562 </property>
563 </spacer>
564 </item>
565 <item row="1" column="1">
566 <widget class="QLabel" name="label_15">
567 <property name="sizePolicy">
568 <sizepolicy hsizetype="Maximum" vsizetype="Maximum">
569 <horstretch>0</horstretch>
570 <verstretch>0</verstretch>
571 </sizepolicy>
572 </property>
573 <property name="layoutDirection">
574 <enum>Qt::LeftToRight</enum>
575 </property>
576 <property name="text">
577 <string>Scattering albedo:</string>
578 </property>
579 </widget>
580 </item>
581 <item row="1" column="2">
582 <widget class="QLabel" name="label_16">
583 <property name="sizePolicy">
584 <sizepolicy hsizetype="Maximum" vsizetype="Maximum">
585 <horstretch>0</horstretch>
586 <verstretch>0</verstretch>
587 </sizepolicy>
588 </property>
589 <property name="layoutDirection">
590 <enum>Qt::LeftToRight</enum>
591 </property>
592 <property name="text">
593 <string>Extinction coefficient:</string>
594 </property>
595 </widget>
596 </item>
597 <item row="2" column="1">
598 <widget class="QLineEdit" name="albedoX">
599 <property name="sizePolicy">
600 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
601 <horstretch>0</horstretch>
602 <verstretch>0</verstretch>
603 </sizepolicy>
604 </property>
605 </widget>
606 </item>
607 <item row="2" column="2">
608 <widget class="QLineEdit" name="extinctionX">
609 <property name="sizePolicy">
610 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
611 <horstretch>0</horstretch>
612 <verstretch>0</verstretch>
613 </sizepolicy>
614 </property>
615 </widget>
616 </item>
617 <item row="3" column="1">
618 <widget class="QLineEdit" name="albedoY">
619 <property name="sizePolicy">
620 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
621 <horstretch>0</horstretch>
622 <verstretch>0</verstretch>
623 </sizepolicy>
624 </property>
625 </widget>
626 </item>
627 <item row="3" column="2">
628 <widget class="QLineEdit" name="extinctionY">
629 <property name="sizePolicy">
630 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
631 <horstretch>0</horstretch>
632 <verstretch>0</verstretch>
633 </sizepolicy>
634 </property>
635 </widget>
636 </item>
637 <item row="4" column="1">
638 <widget class="QLineEdit" name="albedoZ">
639 <property name="sizePolicy">
640 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
641 <horstretch>0</horstretch>
642 <verstretch>0</verstretch>
643 </sizepolicy>
644 </property>
645 </widget>
646 </item>
647 <item row="4" column="2">
648 <widget class="QLineEdit" name="extinctionZ">
649 <property name="sizePolicy">
650 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
651 <horstretch>0</horstretch>
652 <verstretch>0</verstretch>
653 </sizepolicy>
654 </property>
655 </widget>
656 </item>
657 <item row="5" column="0">
658 <spacer name="horizontalSpacer_7">
659 <property name="orientation">
660 <enum>Qt::Horizontal</enum>
661 </property>
662 <property name="sizeHint" stdset="0">
663 <size>
664 <width>109</width>
665 <height>20</height>
666 </size>
667 </property>
668 </spacer>
669 </item>
670 <item row="5" column="1">
671 <widget class="QLabel" name="label_17">
672 <property name="sizePolicy">
673 <sizepolicy hsizetype="Maximum" vsizetype="Maximum">
674 <horstretch>0</horstretch>
675 <verstretch>0</verstretch>
676 </sizepolicy>
677 </property>
678 <property name="layoutDirection">
679 <enum>Qt::LeftToRight</enum>
680 </property>
681 <property name="text">
682 <string>Scattering eccentricity:</string>
683 </property>
684 </widget>
685 </item>
686 <item row="5" column="2">
687 <widget class="QLabel" name="label_18">
688 <property name="sizePolicy">
689 <sizepolicy hsizetype="Maximum" vsizetype="Maximum">
690 <horstretch>0</horstretch>
691 <verstretch>0</verstretch>
692 </sizepolicy>
693 </property>
694 <property name="layoutDirection">
695 <enum>Qt::LeftToRight</enum>
696 </property>
697 <property name="text">
698 <string>Mist sampling distance:</string>
699 </property>
700 </widget>
701 </item>
702 <item row="5" column="3">
703 <spacer name="horizontalSpacer_8">
704 <property name="orientation">
705 <enum>Qt::Horizontal</enum>
706 </property>
707 <property name="sizeHint" stdset="0">
708 <size>
709 <width>108</width>
710 <height>20</height>
711 </size>
712 </property>
713 </spacer>
714 </item>
715 <item row="6" column="1">
716 <widget class="QLineEdit" name="eccentricity">
717 <property name="sizePolicy">
718 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
719 <horstretch>0</horstretch>
720 <verstretch>0</verstretch>
721 </sizepolicy>
722 </property>
723 </widget>
724 </item>
725 <item row="6" column="2">
726 <widget class="QLineEdit" name="mistDistance">
727 <property name="sizePolicy">
728 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
729 <horstretch>0</horstretch>
730 <verstretch>0</verstretch>
731 </sizepolicy>
732 </property>
733 </widget>
734 </item>
735 <item row="7" column="1">
736 <spacer name="verticalSpacer_4">
737 <property name="orientation">
738 <enum>Qt::Vertical</enum>
739 </property>
740 <property name="sizeHint" stdset="0">
741 <size>
742 <width>20</width>
743 <height>28</height>
744 </size>
745 </property>
746 </spacer>
747 </item>
748 </layout>
749 </widget>
750 <widget class="QWidget" name="pixelTab">
751 <attribute name="title">
752 <string>Pixel</string>
753 </attribute>
754 <layout class="QGridLayout" name="gridLayout_5">
755 <item row="0" column="1">
756 <spacer name="verticalSpacer_6">
757 <property name="orientation">
758 <enum>Qt::Vertical</enum>
759 </property>
760 <property name="sizeHint" stdset="0">
761 <size>
762 <width>20</width>
763 <height>99</height>
764 </size>
765 </property>
766 </spacer>
767 </item>
768 <item row="1" column="0">
769 <spacer name="horizontalSpacer_9">
770 <property name="orientation">
771 <enum>Qt::Horizontal</enum>
772 </property>
773 <property name="sizeHint" stdset="0">
774 <size>
775 <width>156</width>
776 <height>20</height>
777 </size>
778 </property>
779 </spacer>
780 </item>
781 <item row="1" column="1">
782 <widget class="QLabel" name="label_19">
783 <property name="sizePolicy">
784 <sizepolicy hsizetype="Maximum" vsizetype="Preferred">
785 <horstretch>0</horstretch>
786 <verstretch>0</verstretch>
787 </sizepolicy>
788 </property>
789 <property name="layoutDirection">
790 <enum>Qt::LeftToRight</enum>
791 </property>
792 <property name="text">
793 <string>Sample:</string>
794 </property>
795 </widget>
796 </item>
797 <item row="1" column="2">
798 <widget class="QLineEdit" name="sample">
799 <property name="sizePolicy">
800 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
801 <horstretch>0</horstretch>
802 <verstretch>0</verstretch>
803 </sizepolicy>
804 </property>
805 </widget>
806 </item>
807 <item row="1" column="3">
808 <spacer name="horizontalSpacer_10">
809 <property name="orientation">
810 <enum>Qt::Horizontal</enum>
811 </property>
812 <property name="sizeHint" stdset="0">
813 <size>
814 <width>146</width>
815 <height>20</height>
816 </size>
817 </property>
818 </spacer>
819 </item>
820 <item row="2" column="1">
821 <widget class="QLabel" name="label_20">
822 <property name="sizePolicy">
823 <sizepolicy hsizetype="Maximum" vsizetype="Preferred">
824 <horstretch>0</horstretch>
825 <verstretch>0</verstretch>
826 </sizepolicy>
827 </property>
828 <property name="layoutDirection">
829 <enum>Qt::LeftToRight</enum>
830 </property>
831 <property name="text">
832 <string>Threshold</string>
833 </property>
834 </widget>
835 </item>
836 <item row="2" column="2">
837 <widget class="QLineEdit" name="px_threshold"/>
838 </item>
839 <item row="3" column="1">
840 <spacer name="verticalSpacer_5">
841 <property name="orientation">
842 <enum>Qt::Vertical</enum>
843 </property>
844 <property name="sizeHint" stdset="0">
845 <size>
846 <width>20</width>
847 <height>99</height>
848 </size>
849 </property>
850 </spacer>
851 </item>
852 </layout>
853 </widget>
854 <widget class="QWidget" name="specularTab">
855 <attribute name="title">
856 <string>Specular</string>
857 </attribute>
858 <layout class="QGridLayout" name="gridLayout_6">
859 <item row="0" column="1">
860 <spacer name="verticalSpacer_7">
861 <property name="orientation">
862 <enum>Qt::Vertical</enum>
863 </property>
864 <property name="sizeHint" stdset="0">
865 <size>
866 <width>20</width>
867 <height>99</height>
868 </size>
869 </property>
870 </spacer>
871 </item>
872 <item row="1" column="0">
873 <spacer name="horizontalSpacer_12">
874 <property name="orientation">
875 <enum>Qt::Horizontal</enum>
876 </property>
877 <property name="sizeHint" stdset="0">
878 <size>
879 <width>155</width>
880 <height>20</height>
881 </size>
882 </property>
883 </spacer>
884 </item>
885 <item row="1" column="1">
886 <widget class="QLabel" name="label_22">
887 <property name="sizePolicy">
888 <sizepolicy hsizetype="Maximum" vsizetype="Preferred">
889 <horstretch>0</horstretch>
890 <verstretch>0</verstretch>
891 </sizepolicy>
892 </property>
893 <property name="layoutDirection">
894 <enum>Qt::LeftToRight</enum>
895 </property>
896 <property name="text">
897 <string>Jitter:</string>
898 </property>
899 </widget>
900 </item>
901 <item row="1" column="2">
902 <widget class="QLineEdit" name="sp_jitter">
903 <property name="sizePolicy">
904 <sizepolicy hsizetype="Maximum" vsizetype="Fixed">
905 <horstretch>0</horstretch>
906 <verstretch>0</verstretch>
907 </sizepolicy>
908 </property>
909 </widget>
910 </item>
911 <item row="1" column="3">
912 <spacer name="horizontalSpacer_11">
913 <property name="orientation">
914 <enum>Qt::Horizontal</enum>
915 </property>
916 <property name="sizeHint" stdset="0">
917 <size>
918 <width>145</width>
919 <height>20</height>
920 </size>
921 </property>
922 </spacer>
923 </item>
924 <item row="2" column="1">
925 <widget class="QLabel" name="label_23">
926 <property name="sizePolicy">
927 <sizepolicy hsizetype="Maximum" vsizetype="Preferred">
928 <horstretch>0</horstretch>
929 <verstretch>0</verstretch>
930 </sizepolicy>
931 </property>
932 <property name="layoutDirection">
933 <enum>Qt::LeftToRight</enum>
934 </property>
935 <property name="text">
936 <string>Threshold:</string>
937 </property>
938 </widget>
939 </item>
940 <item row="2" column="2">
941 <widget class="QLineEdit" name="sp_threshold"/>
942 </item>
943 <item row="3" column="1">
944 <spacer name="verticalSpacer_8">
945 <property name="orientation">
946 <enum>Qt::Vertical</enum>
947 </property>
948 <property name="sizeHint" stdset="0">
949 <size>
950 <width>20</width>
951 <height>99</height>
952 </size>
953 </property>
954 </spacer>
955 </item>
956 </layout>
957 </widget>
958 </widget>
959 </item>
960 <item>
961 <widget class="QDialogButtonBox" name="buttonBox">
962 <property name="orientation">
963 <enum>Qt::Horizontal</enum>
964 </property>
965 <property name="standardButtons">
966 <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
967 </property>
968 </widget>
969 </item>
970 </layout>
971 </widget>
972 <resources/>
973 <connections>
974 <connection>
975 <sender>buttonBox</sender>
976 <signal>accepted()</signal>
977 <receiver>parameterDialog</receiver>
978 <slot>accept()</slot>
979 <hints>
980 <hint type="sourcelabel">
981 <x>248</x>
982 <y>254</y>
983 </hint>
984 <hint type="destinationlabel">
985 <x>157</x>
986 <y>274</y>
987 </hint>
988 </hints>
989 </connection>
990 <connection>
991 <sender>buttonBox</sender>
992 <signal>rejected()</signal>
993 <receiver>parameterDialog</receiver>
994 <slot>reject()</slot>
995 <hints>
996 <hint type="sourcelabel">
997 <x>316</x>
998 <y>260</y>
999 </hint>
1000 <hint type="destinationlabel">
1001 <x>286</x>
1002 <y>274</y>
1003 </hint>
1004 </hints>
1005 </connection>
1006 </connections>
1007 </ui>
