root/radiance/ray/src/qtrvu/mainwindow.cxx
Revision: 1.2
Committed: Wed May 30 18:31:11 2012 UTC (13 years ago) by greg
Changes since 1.1: +17 -0 lines
Patches to cmake build system and QT driver for rvu
1 #include "mainwindow.h"
2 #include "ui_mainwindow.h"
3 #include "ui_exposuredialog.h"
4 #include "ui_parameterdialog.h"
5 #include "ui_viewdialog.h"
6 #include "ui_incrementsdialog.h"
7 #include "ui_commandsdialog.h"
8
9 #include <QtGui/QMessageBox>
10 #include <QtGui/QLineEdit>
11 #include <QtGui/QCloseEvent>
12 #include <QtGui/QFileDialog>
13 #include <QtGui/QInputDialog>
14 #include <QtCore/QDebug>
15 #include <QtCore/QTime>
16 #include <QtCore/QTextStream>
17
18 #include <iostream>
19
20 // Process a command
21 extern "C" void qt_process_command(const char*);
22 // set the abort flag to stop a render in progress
23 extern "C" void qt_set_abort(int );
24 extern "C"
25 {
26 //externs for exposure dialog
27 extern VIEW ourview;
28 extern double exposure;
29 //externs for parameters dialog
30 extern COLOR ambval; /* ambient value */
31 extern int ambvwt; /* initial weight for ambient value */
32 extern double ambacc; /* ambient accuracy */
33 extern int ambres; /* ambient resolution */
34 extern int ambdiv; /* ambient divisions */
35 extern int ambssamp; /* ambient super-samples */
36 extern int ambounce; /* ambient bounces */
37 extern double shadcert; /* shadow testing certainty */
38 extern double shadthresh; /* shadow threshold */
39 extern int directvis; /* light sources visible to eye? */
40 extern COLOR cextinction; /* global extinction coefficient */
41 extern COLOR salbedo; /* global scattering albedo */
42 extern double seccg; /* global scattering eccentricity */
43 extern double ssampdist; /* scatter sampling distance */
44 extern double specthresh; /* specular sampling threshold */
45 extern double specjitter; /* specular sampling jitter */
46 extern int maxdepth; /* maximum recursion depth */
47 extern double minweight; /* minimum ray weight */
48 extern double dstrsrc; /* square source distribution */
49 extern double srcsizerat; /* maximum source size/dist. ratio */
50 extern int psample; /* pixel sample size */
51 extern double maxdiff; /* max. sample difference */
52 void quit(int code);
53 }
54 MainWindow::MainWindow(int width, int height, const char* name, const char* id)
55 {
56 m_ui = new Ui::MainWindow;
57 m_ui->setupUi(this);
58 m_exposureDialog = new QDialog();
59 m_exposureDialogUi = new Ui::exposureDialog;
60 m_exposureDialogUi->setupUi(m_exposureDialog);
61 m_parameterDialog = new QDialog();
62 m_parameterDialogUi = new Ui::parameterDialog;
63 m_parameterDialogUi->setupUi(m_parameterDialog);
64 m_viewDialog = new QDialog();
65 m_viewDialogUi = new Ui::viewDialog;
66 m_viewDialogUi->setupUi(m_viewDialog);
67 this->smallIncrement = 0.1;
68 this->largeIncrement = 0.5;
69 m_incrementsDialog = new QDialog();
70 m_incrementsDialogUi = new Ui::incrementsDialog;
71 m_incrementsDialogUi->setupUi(m_incrementsDialog);
72 m_commandsDialog = new QDialog();
73 m_commandsDialogUi = new Ui::commandsDialog;
74 m_commandsDialogUi->setupUi(m_commandsDialog);
75 this->currentImageName = "";
76 createActions();
77 connectSlots();
78 m_ui->progressBar->setMinimum(0);
79 m_ui->progressBar->setMaximum(100);
80 setWindowTitle(tr(id));
81 resize(width, height);
82 updatePositionLabels();
83 }
84
85 MainWindow::~MainWindow()
86 {
87 delete m_ui;
88 delete m_exposureDialog;
89 delete m_parameterDialog;
90 delete m_viewDialog;
91 delete m_incrementsDialog;
92 delete m_commandsDialog;
93 }
94
95 void MainWindow::setProgress(int p)
96 {
97 m_ui->progressBar->setValue(p);
98 }
99
100 RvuWidget* MainWindow::getRvuWidget() const
101 {
102 return m_ui->rvuWidget;
103 }
104
105 void MainWindow::closeEvent(QCloseEvent *event)
106 {
107 // Here is a good spot to shut down the rest of the code before exit.
108 this->m_exposureDialog->close();
109 this->m_parameterDialog->close();
110 this->m_viewDialog->close();
111 this->m_incrementsDialog->close();
112 this->m_commandsDialog->close();
113 }
114
115 void MainWindow::createActions()
116 {
117 m_minimizeAction = new QAction(tr("Mi&nimize"), this);
118 connect(m_minimizeAction, SIGNAL(triggered()), this, SLOT(hide()));
119
120 m_maximizeAction = new QAction(tr("Ma&ximize"), this);
121 connect(m_maximizeAction, SIGNAL(triggered()), this, SLOT(showMaximized()));
122
123 m_restoreAction = new QAction(tr("&Restore"), this);
124 connect(m_restoreAction, SIGNAL(triggered()), this, SLOT(showNormal()));
125 }
126
127 void MainWindow::connectSlots()
128 {
129 connect(m_ui->exit, SIGNAL(triggered()), qApp, SLOT(quit()));
130 connect(m_ui->pushButton, SIGNAL(clicked()), this, SLOT(buttonPressed()));
131 connect(m_ui->lineEdit, SIGNAL(returnPressed()),
132 this, SLOT(buttonPressed()));
133 connect(m_ui->redraw, SIGNAL(triggered()), this, SLOT(redraw()));
134 connect(m_ui->trace, SIGNAL(triggered()), this, SLOT(traceRay()));
135 connect(m_ui->toggleToolBar, SIGNAL(triggered()),
136 this, SLOT(toggleToolBar()));
137 connect(m_ui->toggleStatusBar, SIGNAL(triggered()),
138 this, SLOT(toggleStatusBar()));
139 connect(m_ui->toggleTranslateTool, SIGNAL(triggered()),
140 this, SLOT(toggleTranslateTool()));
141 connect(m_ui->exposure, SIGNAL(triggered()),
142 this, SLOT(showExposureDialog()));
143 connect(m_ui->parameters, SIGNAL(triggered()),
144 this, SLOT(showParameterDialog()));
145 connect(m_ui->view, SIGNAL(triggered()),
146 this, SLOT(showViewDialog()));
147 connect(m_ui->saveImage, SIGNAL(triggered()),
148 this, SLOT(saveCurrentImage()));
149 connect(m_ui->saveImageAs, SIGNAL(triggered()),
150 this, SLOT(saveImage()));
151 connect(m_ui->loadView, SIGNAL(triggered()),
152 this, SLOT(loadView()));
153 connect(m_ui->loadRif, SIGNAL(triggered()),
154 this, SLOT(loadRif()));
155 connect(m_ui->backfaceVisibility, SIGNAL(triggered()),
156 this, SLOT(toggleBackfaceVisibility()));
157 connect(m_ui->grayscale, SIGNAL(triggered()),
158 this, SLOT(toggleGrayscale()));
159 connect(m_ui->irradiance, SIGNAL(triggered()),
160 this, SLOT(toggleIrradiance()));
161 connect(m_ui->appendToRif, SIGNAL(triggered()),
162 this, SLOT(appendToRif()));
163 connect(m_ui->appendToView, SIGNAL(triggered()),
164 this, SLOT(appendToView()));
165 connect(m_ui->GUI_Increments, SIGNAL(triggered()),
166 this, SLOT(showIncrementsDialog()));
167 connect(m_ui->commands, SIGNAL(triggered()),
168 this, SLOT(showCommandsDialog()));
169 connect(m_ui->aboutRvu, SIGNAL(triggered()),
170 this, SLOT(showAbout()));
171
172 //movement buttons
173 connect(m_ui->xPlus1Button, SIGNAL(clicked()),
174 this, SLOT(moveXPlusOne()));
175 connect(m_ui->xPlus2Button, SIGNAL(clicked()),
176 this, SLOT(moveXPlusTwo()));
177 connect(m_ui->xMinus1Button, SIGNAL(clicked()),
178 this, SLOT(moveXMinusOne()));
179 connect(m_ui->xMinus2Button, SIGNAL(clicked()),
180 this, SLOT(moveXMinusTwo()));
181 connect(m_ui->yPlus1Button, SIGNAL(clicked()),
182 this, SLOT(moveYPlusOne()));
183 connect(m_ui->yPlus2Button, SIGNAL(clicked()),
184 this, SLOT(moveYPlusTwo()));
185 connect(m_ui->yMinus1Button, SIGNAL(clicked()),
186 this, SLOT(moveYMinusOne()));
187 connect(m_ui->yMinus2Button, SIGNAL(clicked()),
188 this, SLOT(moveYMinusTwo()));
189 connect(m_ui->zPlus1Button, SIGNAL(clicked()),
190 this, SLOT(moveZPlusOne()));
191 connect(m_ui->zPlus2Button, SIGNAL(clicked()),
192 this, SLOT(moveZPlusTwo()));
193 connect(m_ui->zMinus1Button, SIGNAL(clicked()),
194 this, SLOT(moveZMinusOne()));
195 connect(m_ui->zMinus2Button, SIGNAL(clicked()),
196 this, SLOT(moveZMinusTwo()));
197
198 //exposure dialog
199 connect(m_exposureDialogUi->exposureButtonBox, SIGNAL(accepted()),
200 this, SLOT(adjustExposure()));
201 connect(m_exposureDialogUi->exposureButtonBox, SIGNAL(rejected()),
202 this, SLOT(hideExposureDialog()));
203 connect(m_exposureDialogUi->natural, SIGNAL(toggled(bool)),
204 this, SLOT(updatePointRadio()));
205 connect(m_exposureDialogUi->relative, SIGNAL(toggled(bool)),
206 this, SLOT(updatePointRadio()));
207
208 //parameter dialog
209 connect(m_parameterDialogUi->buttonBox, SIGNAL(accepted()),
210 this, SLOT(adjustParameters()));
211 connect(m_parameterDialogUi->buttonBox, SIGNAL(rejected()),
212 this, SLOT(hideParameterDialog()));
213
214 //view dialog
215 connect(m_viewDialogUi->buttonBox, SIGNAL(accepted()),
216 this, SLOT(adjustView()));
217 connect(m_viewDialogUi->buttonBox, SIGNAL(rejected()),
218 this, SLOT(hideViewDialog()));
219
220 //increments dialog
221 connect(m_incrementsDialogUi->buttonBox, SIGNAL(accepted()),
222 this, SLOT(adjustIncrements()));
223 connect(m_incrementsDialogUi->buttonBox, SIGNAL(rejected()),
224 this, SLOT(hideIncrementsDialog()));
225 }
226
227 void MainWindow::doSubmit()
228 {
229 QString command = m_ui->lineEdit->text();
230 bool centerCrossHairs = false;
231 if(command == "aim")
232 {
233 centerCrossHairs = true;
234 }
235 m_ui->lineEdit->setText("");
236 m_ui->progressBar->setEnabled(true);
237 this->setProgress(0);
238 QTime t;
239 t.start();
240 if (command.isEmpty())
241 {
242 this->m_ui->pushButton->setText("Submit");
243 enableInterface(true);
244 return;
245 }
246 qt_process_command(command.toAscii());
247 QString msg;
248 QTextStream(&msg) << "Render Time: " << t.elapsed() << " ms";
249 m_ui->messageBox->appendPlainText(msg);
250 this->m_ui->pushButton->setText("Submit");
251 enableInterface(true);
252 if(centerCrossHairs)
253 {
254 QPoint p = this->m_ui->rvuWidget->geometry().center();
255 this->m_ui->rvuWidget->setPosition(p.x(), p.y());
256 }
257 updatePositionLabels();
258 }
259
260
261 void MainWindow::buttonPressed()
262 {
263 if( m_ui->pushButton->text() == QString("Submit") )
264 {
265 qt_set_abort(0);
266 this->m_ui->pushButton->setText("Abort");
267 enableInterface(false);
268 this->doSubmit();
269 }
270 else if( m_ui->pushButton->text() == QString("Abort") )
271 {
272 qt_set_abort(1);
273 this->m_ui->pushButton->setText("Submit");
274 enableInterface(true);
275 }
276 }
277
278 void MainWindow::resizeImage(int width, int height)
279 {
280 int pad = m_ui->lineEdit->size().height();
281 pad += m_ui->menubar->size().height();
282 pad += m_ui->messageBox->size().height();
283 this->resize(width+4, height+pad+4);
284 this->m_ui->rvuWidget->resizeImage(width, height);
285 }
286
287 void MainWindow::setStatus(const char* m)
288 {
289 m_ui->messageBox->appendPlainText(QString(m).trimmed());
290 }
291
292 void MainWindow::redraw()
293 {
294 runCommand("redraw");
295 }
296
297 void MainWindow::traceRay()
298 {
299 runCommand("t");
300 }
301
302 void MainWindow::toggleToolBar()
303 {
304 m_ui->toolBar->setVisible(m_ui->toggleToolBar->isChecked());
305 }
306
307 void MainWindow::toggleStatusBar()
308 {
309 m_ui->messageBox->setVisible(m_ui->toggleStatusBar->isChecked());
310 }
311
312 void MainWindow::toggleTranslateTool()
313 {
314 m_ui->xWidget->setVisible(m_ui->toggleTranslateTool->isChecked());
315 m_ui->yWidget->setVisible(m_ui->toggleTranslateTool->isChecked());
316 m_ui->zWidget->setVisible(m_ui->toggleTranslateTool->isChecked());
317 }
318
319 void MainWindow::refreshView(VIEW *nv)
320 {
321 if (waitrays() < 0) /* clear ray queue */
322 quit(1);
323 newview(nv);
324 this->redraw();
325 }
326
327 void MainWindow::move(int direction, float amount)
328 {
329 if( m_ui->pushButton->text() == QString("Abort") )
330 {
331 qt_set_abort(1);
332 return;
333 }
334 VIEW nv = ourview;
335 nv.vp[direction] = nv.vp[direction] + amount;
336 this->refreshView(&nv);
337 updatePositionLabels();
338 }
339
340 void MainWindow::moveXPlusOne()
341 {
342 this->move(0, this->smallIncrement);
343 }
344
345 void MainWindow::moveXPlusTwo()
346 {
347 this->move(0, this->largeIncrement);
348 }
349
350 void MainWindow::moveXMinusOne()
351 {
352 this->move(0, -1 * this->smallIncrement);
353 }
354
355 void MainWindow::moveXMinusTwo()
356 {
357 this->move(0, -1 * this->largeIncrement);
358 }
359
360 void MainWindow::moveYPlusOne()
361 {
362 this->move(1, this->smallIncrement);
363 }
364
365 void MainWindow::moveYPlusTwo()
366 {
367 this->move(1, this->largeIncrement);
368 }
369
370 void MainWindow::moveYMinusOne()
371 {
372 this->move(1, -1 * this->smallIncrement);
373 }
374
375 void MainWindow::moveYMinusTwo()
376 {
377 this->move(1, -1 * this->largeIncrement);
378 }
379
380 void MainWindow::moveZPlusOne()
381 {
382 this->move(2, this->smallIncrement);
383 }
384
385 void MainWindow::moveZPlusTwo()
386 {
387 this->move(2, this->largeIncrement);
388 }
389
390 void MainWindow::moveZMinusOne()
391 {
392 this->move(2, -1 * this->smallIncrement);
393 }
394
395 void MainWindow::moveZMinusTwo()
396 {
397 this->move(2, -1 * this->largeIncrement);
398 }
399
400 void MainWindow::updatePositionLabels()
401 {
402 m_ui->xValue->setText(QString::number(ourview.vp[0]));
403 m_ui->yValue->setText(QString::number(ourview.vp[1]));
404 m_ui->zValue->setText(QString::number(ourview.vp[2]));
405 }
406
407 void MainWindow::showExposureDialog()
408 {
409 m_exposureDialogUi->exposureValue->setText(QString::number(exposure));
410 m_exposureDialog->show();
411 }
412
413 void MainWindow::hideExposureDialog()
414 {
415 m_exposureDialog->hide();
416 }
417
418 void MainWindow::showParameterDialog()
419 {
420 //ambient tab
421 m_parameterDialogUi->valueX->setText(QString::number(ambval[0]));
422 m_parameterDialogUi->valueY->setText(QString::number(ambval[1]));
423 m_parameterDialogUi->valueZ->setText(QString::number(ambval[2]));
424 m_parameterDialogUi->weight->setText(QString::number(ambvwt));
425 m_parameterDialogUi->accuracy->setText(QString::number(ambacc));
426 m_parameterDialogUi->divisions->setText(QString::number(ambdiv));
427 m_parameterDialogUi->supersamples->setText(QString::number(ambssamp));
428 m_parameterDialogUi->bounces->setText(QString::number(ambounce));
429 m_parameterDialogUi->resolution->setText(QString::number(ambres));
430
431 //direct tab
432 m_parameterDialogUi->certainty->setText(QString::number(shadcert));
433 m_parameterDialogUi->threshold->setText(QString::number(shadthresh));
434 m_parameterDialogUi->visibility->setText(QString::number(directvis));
435 m_parameterDialogUi->jitter->setText(QString::number(dstrsrc));
436 m_parameterDialogUi->sampling->setText(QString::number(srcsizerat));
437 //values on direct tab that I can't find: reflection
438
439 //limit tab
440 m_parameterDialogUi->limit_weight->setText(QString::number(minweight));
441 m_parameterDialogUi->reflection->setText(QString::number(maxdepth));
442
443 //medium tab
444 m_parameterDialogUi->albedoX->setText(QString::number(salbedo[0]));
445 m_parameterDialogUi->albedoY->setText(QString::number(salbedo[1]));
446 m_parameterDialogUi->albedoZ->setText(QString::number(salbedo[2]));
447 m_parameterDialogUi->extinctionX->setText(QString::number(cextinction[0]));
448 m_parameterDialogUi->extinctionY->setText(QString::number(cextinction[1]));
449 m_parameterDialogUi->extinctionZ->setText(QString::number(cextinction[2]));
450 m_parameterDialogUi->eccentricity->setText(QString::number(seccg));
451 m_parameterDialogUi->mistDistance->setText(QString::number(ssampdist));
452
453 //pixel tab
454 m_parameterDialogUi->sample->setText(QString::number(psample));
455 m_parameterDialogUi->px_threshold->setText(QString::number(maxdiff));
456
457 //specular tab
458 m_parameterDialogUi->sp_jitter->setText(QString::number(specjitter));
459 m_parameterDialogUi->sp_threshold->setText(QString::number(specthresh));
460
461 m_parameterDialog->show();
462 }
463
464 void MainWindow::hideParameterDialog()
465 {
466 m_parameterDialog->hide();
467 }
468
469 void MainWindow::adjustExposure()
470 {
471 bool checkForPoint = false;
472
473 QString command = "exposure ";
474
475 if(m_exposureDialogUi->absolute->isChecked())
476 {
477 command += "=";
478 }
479 else if(m_exposureDialogUi->fstop->isChecked())
480 {
481 //TODO: check if the value is positive or not here
482 command += "+";
483 }
484 else if(m_exposureDialogUi->natural->isChecked())
485 {
486 command += "@";
487 checkForPoint = true;
488 }
489 else if(m_exposureDialogUi->relative->isChecked())
490 {
491 checkForPoint = true;
492 }
493
494 if(!(checkForPoint && m_exposureDialogUi->point->isChecked()))
495 {
496 command += m_exposureDialogUi->exposureSetting->text();
497 }
498
499 runCommand(command.toAscii());
500 }
501
502 void MainWindow::updatePointRadio()
503 {
504 if(m_exposureDialogUi->relative->isChecked() ||
505 m_exposureDialogUi->natural->isChecked())
506 {
507 m_exposureDialogUi->point->setEnabled(true);
508 m_exposureDialogUi->average->setEnabled(true);
509 }
510 else
511 {
512 m_exposureDialogUi->point->setEnabled(false);
513 m_exposureDialogUi->average->setEnabled(false);
514 }
515 }
516
517 void MainWindow::adjustParameters()
518 {
519 if(m_parameterDialogUi->valueX->isModified() ||
520 m_parameterDialogUi->valueY->isModified() ||
521 m_parameterDialogUi->valueZ->isModified())
522 {
523 QString command = "set av ";
524 command += m_parameterDialogUi->valueX->text();
525 command += " ";
526 command += m_parameterDialogUi->valueY->text();
527 command += " ";
528 command += m_parameterDialogUi->valueZ->text();
529 runCommand(command.toAscii());
530 }
531 if(m_parameterDialogUi->weight->isModified())
532 {
533 QString command = "set aw ";
534 command += m_parameterDialogUi->weight->text();
535 runCommand(command.toAscii());
536 }
537 if(m_parameterDialogUi->accuracy->isModified())
538 {
539 QString command = "set aa ";
540 command += m_parameterDialogUi->accuracy->text();
541 runCommand(command.toAscii());
542 }
543 if(m_parameterDialogUi->divisions->isModified())
544 {
545 QString command = "set ad ";
546 command += m_parameterDialogUi->divisions->text();
547 runCommand(command.toAscii());
548 }
549 if(m_parameterDialogUi->supersamples->isModified())
550 {
551 QString command = "set as ";
552 command += m_parameterDialogUi->supersamples->text();
553 runCommand(command.toAscii());
554 }
555 if(m_parameterDialogUi->bounces->isModified())
556 {
557 QString command = "set ab ";
558 command += m_parameterDialogUi->bounces->text();
559 runCommand(command.toAscii());
560 }
561 if(m_parameterDialogUi->resolution->isModified())
562 {
563 QString command = "set ar ";
564 command += m_parameterDialogUi->resolution->text();
565 runCommand(command.toAscii());
566 }
567 if(m_parameterDialogUi->certainty->isModified())
568 {
569 QString command = "set dc ";
570 command += m_parameterDialogUi->certainty->text();
571 runCommand(command.toAscii());
572 }
573 if(m_parameterDialogUi->threshold->isModified())
574 {
575 QString command = "set dt ";
576 command += m_parameterDialogUi->threshold->text();
577 runCommand(command.toAscii());
578 }
579 if(m_parameterDialogUi->visibility->isModified())
580 {
581 QString command = "set dv ";
582 command += m_parameterDialogUi->visibility->text();
583 runCommand(command.toAscii());
584 }
585 if(m_parameterDialogUi->jitter->isModified())
586 {
587 QString command = "set dj ";
588 command += m_parameterDialogUi->jitter->text();
589 runCommand(command.toAscii());
590 }
591 if(m_parameterDialogUi->sampling->isModified())
592 {
593 QString command = "set ds ";
594 command += m_parameterDialogUi->sampling->text();
595 runCommand(command.toAscii());
596 }
597 if(m_parameterDialogUi->limit_weight->isModified())
598 {
599 QString command = "set lw ";
600 command += m_parameterDialogUi->limit_weight->text();
601 runCommand(command.toAscii());
602 }
603 if(m_parameterDialogUi->reflection->isModified())
604 {
605 QString command = "set lr ";
606 command += m_parameterDialogUi->reflection->text();
607 runCommand(command.toAscii());
608 }
609 if(m_parameterDialogUi->albedoX->isModified() ||
610 m_parameterDialogUi->albedoY->isModified() ||
611 m_parameterDialogUi->albedoZ->isModified())
612 {
613 QString command = "set ma ";
614 command += m_parameterDialogUi->albedoX->text();
615 command += " ";
616 command += m_parameterDialogUi->albedoY->text();
617 command += " ";
618 command += m_parameterDialogUi->albedoZ->text();
619 runCommand(command.toAscii());
620 }
621 if(m_parameterDialogUi->extinctionX->isModified() ||
622 m_parameterDialogUi->extinctionY->isModified() ||
623 m_parameterDialogUi->extinctionZ->isModified())
624 {
625 QString command = "set me ";
626 command += m_parameterDialogUi->extinctionX->text();
627 command += " ";
628 command += m_parameterDialogUi->extinctionY->text();
629 command += " ";
630 command += m_parameterDialogUi->extinctionZ->text();
631 }
632 if(m_parameterDialogUi->eccentricity->isModified())
633 {
634 QString command = "set mg ";
635 command += m_parameterDialogUi->eccentricity->text();
636 runCommand(command.toAscii());
637 }
638 if(m_parameterDialogUi->mistDistance->isModified())
639 {
640 QString command = "set ms ";
641 command += m_parameterDialogUi->mistDistance->text();
642 runCommand(command.toAscii());
643 }
644 if(m_parameterDialogUi->sample->isModified())
645 {
646 QString command = "set ps ";
647 command += m_parameterDialogUi->sample->text();
648 runCommand(command.toAscii());
649 }
650 if(m_parameterDialogUi->px_threshold->isModified())
651 {
652 QString command = "set pt ";
653 command += m_parameterDialogUi->px_threshold->text();
654 runCommand(command.toAscii());
655 }
656 if(m_parameterDialogUi->sp_jitter->isModified())
657 {
658 QString command = "set ss ";
659 command += m_parameterDialogUi->sp_jitter->text();
660 runCommand(command.toAscii());
661 }
662 if(m_parameterDialogUi->sp_threshold->isModified())
663 {
664 QString command = "set st ";
665 command += m_parameterDialogUi->sp_threshold->text();
666 runCommand(command.toAscii());
667 }
668 m_parameterDialog->hide();
669 }
670
671 void MainWindow::showViewDialog()
672 {
673 if(ourview.type==VT_PER)
674 {
675 m_viewDialogUi->perspective->setChecked(true);
676 }
677 else if(ourview.type==VT_PAR)
678 {
679 m_viewDialogUi->parallel->setChecked(true);
680 }
681 else if(ourview.type==VT_HEM)
682 {
683 m_viewDialogUi->hemispherical->setChecked(true);
684 }
685 else if(ourview.type==VT_ANG)
686 {
687 m_viewDialogUi->angular->setChecked(true);
688 }
689 else if(ourview.type==VT_CYL)
690 {
691 m_viewDialogUi->cylindrical->setChecked(true);
692 }
693
694 m_viewDialogUi->viewX->setText(QString::number(ourview.vp[0]));
695 m_viewDialogUi->viewY->setText(QString::number(ourview.vp[1]));
696 m_viewDialogUi->viewZ->setText(QString::number(ourview.vp[2]));
697
698 m_viewDialogUi->dirX->setText(QString::number(ourview.vdir[0], 'f', 4));
699 m_viewDialogUi->dirY->setText(QString::number(ourview.vdir[1], 'f', 4));
700 m_viewDialogUi->dirZ->setText(QString::number(ourview.vdir[2], 'f', 4));
701
702 m_viewDialogUi->upX->setText(QString::number(ourview.vup[0]));
703 m_viewDialogUi->upY->setText(QString::number(ourview.vup[1]));
704 m_viewDialogUi->upZ->setText(QString::number(ourview.vup[2]));
705
706 m_viewDialogUi->sizeHoriz->setText(QString::number(ourview.horiz));
707 m_viewDialogUi->sizeVert->setText(QString::number(ourview.vert));
708 m_viewDialogUi->fore->setText(QString::number(ourview.vfore));
709 m_viewDialogUi->aft->setText(QString::number(ourview.vaft));
710 m_viewDialogUi->offsetHoriz->setText(QString::number(ourview.hoff));
711 m_viewDialogUi->offsetVert->setText(QString::number(ourview.voff));
712
713 m_viewDialog->show();
714 }
715
716 void MainWindow::hideViewDialog()
717 {
718 m_viewDialog->hide();
719 }
720
721 void MainWindow::adjustView()
722 {
723 bool changed = false;
724 VIEW nv = ourview;
725
726 //type
727 if(m_viewDialogUi->perspective->isChecked() && nv.type != VT_PER)
728 {
729 nv.type = VT_PER;
730 changed = true;
731 }
732 if(m_viewDialogUi->parallel->isChecked() && nv.type != VT_PAR)
733 {
734 nv.type = VT_PAR;
735 changed = true;
736 }
737 if(m_viewDialogUi->hemispherical->isChecked() && nv.type != VT_HEM)
738 {
739 nv.type = VT_HEM;
740 changed = true;
741 }
742 if(m_viewDialogUi->angular->isChecked() && nv.type != VT_ANG)
743 {
744 nv.type = VT_ANG;
745 changed = true;
746 }
747 if(m_viewDialogUi->cylindrical->isChecked() && nv.type != VT_CYL)
748 {
749 nv.type = VT_CYL;
750 changed = true;
751 }
752
753 //viewpoint
754 if(m_viewDialogUi->viewX->isModified())
755 {
756 bool okay = true;
757 float f = m_viewDialogUi->viewX->text().toFloat(&okay);
758 if(okay)
759 {
760 nv.vp[0] = f;
761 changed = true;
762 }
763 }
764 if(m_viewDialogUi->viewY->isModified())
765 {
766 bool okay = true;
767 float f = m_viewDialogUi->viewY->text().toFloat(&okay);
768 if(okay)
769 {
770 nv.vp[1] = f;
771 changed = true;
772 }
773 }
774 if(m_viewDialogUi->viewZ->isModified())
775 {
776 bool okay = true;
777 float f = m_viewDialogUi->viewZ->text().toFloat(&okay);
778 if(okay)
779 {
780 nv.vp[2] = f;
781 changed = true;
782 }
783 }
784
785 //direction
786 if(m_viewDialogUi->dirX->isModified())
787 {
788 bool okay = true;
789 float f = m_viewDialogUi->dirX->text().toFloat(&okay);
790 if(okay)
791 {
792 nv.vdir[0] = f;
793 changed = true;
794 }
795 }
796 if(m_viewDialogUi->dirY->isModified())
797 {
798 bool okay = true;
799 float f = m_viewDialogUi->dirY->text().toFloat(&okay);
800 if(okay)
801 {
802 nv.vdir[1] = f;
803 changed = true;
804 }
805 }
806 if(m_viewDialogUi->dirZ->isModified())
807 {
808 bool okay = true;
809 float f = m_viewDialogUi->dirZ->text().toFloat(&okay);
810 if(okay)
811 {
812 nv.vdir[2] = f;
813 changed = true;
814 }
815 }
816
817 //up
818 if(m_viewDialogUi->upX->isModified())
819 {
820 bool okay = true;
821 float f = m_viewDialogUi->upX->text().toFloat(&okay);
822 if(okay)
823 {
824 nv.vup[0] = f;
825 changed = true;
826 }
827 }
828 if(m_viewDialogUi->upY->isModified())
829 {
830 bool okay = true;
831 float f = m_viewDialogUi->upY->text().toFloat(&okay);
832 if(okay)
833 {
834 nv.vup[1] = f;
835 changed = true;
836 }
837 }
838 if(m_viewDialogUi->upZ->isModified())
839 {
840 bool okay = true;
841 float f = m_viewDialogUi->upZ->text().toFloat(&okay);
842 if(okay)
843 {
844 nv.vup[2] = f;
845 changed = true;
846 }
847 }
848
849 //size
850 if(m_viewDialogUi->sizeHoriz->isModified())
851 {
852 bool okay = true;
853 double d = m_viewDialogUi->sizeHoriz->text().toDouble(&okay);
854 if(okay)
855 {
856 nv.horiz = d;
857 changed = true;
858 }
859 }
860 if(m_viewDialogUi->sizeVert->isModified())
861 {
862 bool okay = true;
863 double d = m_viewDialogUi->sizeVert->text().toDouble(&okay);
864 if(okay)
865 {
866 nv.vert = d;
867 changed = true;
868 }
869 }
870
871 //clipping plane
872 if(m_viewDialogUi->fore->isModified())
873 {
874 bool okay = true;
875 double d = m_viewDialogUi->fore->text().toDouble(&okay);
876 if(okay)
877 {
878 nv.vfore = d;
879 changed = true;
880 }
881 }
882 if(m_viewDialogUi->aft->isModified())
883 {
884 bool okay = true;
885 double d = m_viewDialogUi->aft->text().toDouble(&okay);
886 if(okay)
887 {
888 nv.vaft = d;
889 changed = true;
890 }
891 }
892
893 //clipping plane
894 if(m_viewDialogUi->offsetHoriz->isModified())
895 {
896 bool okay = true;
897 double d = m_viewDialogUi->offsetHoriz->text().toDouble(&okay);
898 if(okay)
899 {
900 nv.hoff = d;
901 changed = true;
902 }
903 }
904 if(m_viewDialogUi->offsetVert->isModified())
905 {
906 bool okay = true;
907 double d = m_viewDialogUi->offsetVert->text().toDouble(&okay);
908 if(okay)
909 {
910 nv.voff = d;
911 changed = true;
912 }
913 }
914
915 if(changed)
916 {
917 this->refreshView(&nv);
918 }
919 }
920
921 void MainWindow::enableInterface(bool enable)
922 {
923 m_ui->toolBar->setEnabled(enable);
924 m_ui->progressBar->setEnabled(!enable);
925 }
926
927 void MainWindow::runCommand(const char *command)
928 {
929 qt_set_abort(0);
930 this->m_ui->pushButton->setText("Abort");
931 enableInterface(false);
932 qt_process_command(command);
933 qt_set_abort(1);
934 this->m_ui->pushButton->setText("Submit");
935 enableInterface(true);
936 }
937
938 void MainWindow::pick(int* x, int* y)
939 {
940 QCursor oldCursor = this->cursor();
941 this->setCursor(Qt::CrossCursor);
942 this->getRvuWidget()->getPosition(x, y);
943 // restore state
944 this->setCursor(oldCursor);
945 }
946
947 void MainWindow::saveImage()
948 {
949 this->currentImageName = QFileDialog::getSaveFileName(this, tr("Save File"),
950 "", tr(".hdr images (*.hdr)"));
951 QString command = "write " + this->currentImageName;
952 this->runCommand(command.toAscii());
953 }
954
955 void MainWindow::saveCurrentImage()
956 {
957 if(this->currentImageName == "")
958 {
959 this->saveImage();
960 return;
961 }
962 QString command = "write " + this->currentImageName;
963 this->runCommand(command.toAscii());
964 }
965
966 void MainWindow::loadView()
967 {
968 QString viewFileName = QFileDialog::getOpenFileName(this, tr("Open View File"),
969 "", tr("View Files (*.vp *.vf)"));
970 QString command = "last " + viewFileName;
971 this->runCommand(command.toAscii());
972 }
973
974 void MainWindow::toggleGrayscale()
975 {
976 QString command = "set b ";
977 if(m_ui->grayscale->isChecked())
978 {
979 command += " 1";
980 }
981 else
982 {
983 command += " 0";
984 }
985 this->runCommand(command.toAscii());
986 this->runCommand("new");
987 }
988
989 void MainWindow::toggleBackfaceVisibility()
990 {
991 QString command = "set bv";
992 if(m_ui->backfaceVisibility->isChecked())
993 {
994 command += " 1";
995 }
996 else
997 {
998 command += " 0";
999 }
1000 this->runCommand(command.toAscii());
1001 this->runCommand("new");
1002 }
1003
1004 void MainWindow::toggleIrradiance()
1005 {
1006 QString command = "set i";
1007 if(m_ui->irradiance->isChecked())
1008 {
1009 command += " 1";
1010 }
1011 else
1012 {
1013 command += " 0";
1014 }
1015 this->runCommand(command.toAscii());
1016 this->runCommand("new");
1017 }
1018
1019 void MainWindow::loadRif()
1020 {
1021 bool ok;
1022 QString viewName = QInputDialog::getText(this, tr("Input view name"),
1023 tr("Name of view:"), QLineEdit::Normal,
1024 "", &ok);
1025 if (ok && !viewName.isEmpty())
1026 {
1027 QString radFileName = QFileDialog::getOpenFileName(this, tr("Open rad File"),
1028 "", tr("rad files (*.rif)"));
1029 QString command = "L " + viewName + " " + radFileName;
1030 this->runCommand(command.toAscii());
1031 }
1032 }
1033
1034 void MainWindow::appendToRif()
1035 {
1036 bool ok;
1037 QString viewName = QInputDialog::getText(this, tr("Input view name"),
1038 tr("Name of view:"), QLineEdit::Normal,
1039 "", &ok);
1040 if (ok && !viewName.isEmpty())
1041 {
1042 QString radFileName = QFileDialog::getSaveFileName(this, tr("Save File"),
1043 "", tr("rad files (*.rif)"), 0, QFileDialog::DontConfirmOverwrite);
1044 QString command = "V " + viewName + " " + radFileName;
1045 this->runCommand(command.toAscii());
1046 }
1047 }
1048
1049 void MainWindow::appendToView()
1050 {
1051 QString viewFileName = QFileDialog::getSaveFileName(this, tr("Save File"),
1052 "", tr("view files (*.vp *.vf)"), 0, QFileDialog::DontConfirmOverwrite);
1053 if(viewFileName != "")
1054 {
1055 QString command = "view " + viewFileName;
1056 this->runCommand(command.toAscii());
1057 }
1058 }
1059
1060 void MainWindow::showIncrementsDialog()
1061 {
1062 m_incrementsDialogUi->small->setText(QString::number(this->smallIncrement));
1063 m_incrementsDialogUi->large->setText(QString::number(this->largeIncrement));
1064 m_incrementsDialog->show();
1065 }
1066
1067 void MainWindow::hideIncrementsDialog()
1068 {
1069 m_incrementsDialog->hide();
1070 }
1071
1072 void MainWindow::adjustIncrements()
1073 {
1074 bool okay = true;
1075 float f = m_incrementsDialogUi->small->text().toFloat(&okay);
1076 if(okay)
1077 {
1078 this->smallIncrement = f;
1079 }
1080 f = m_incrementsDialogUi->large->text().toFloat(&okay);
1081 if(okay)
1082 {
1083 this->largeIncrement = f;
1084 }
1085 }
1086
1087 void MainWindow::showCommandsDialog()
1088 {
1089 m_commandsDialog->show();
1090 }
1091
1092 void MainWindow::showAbout()
1093 {
1094 QString aboutText =
1095 "rvu was written mainly by Greg Ward.\nThe Qt-based GUI was developed by Kitware, Inc. in 2011";
1096 QMessageBox::about(this, "About rvu", aboutText);
1097 }
