root/radiance/ray/src/qtrvu/mainwindow.cxx
Revision: 1.3
Committed: Mon Aug 6 17:51:45 2012 UTC (12 years, 9 months ago) by greg
CVS Tags: rad4R2P2, rad4R2, rad4R2P1
Changes since 1.2: +9 -0 lines
Zack's patch to add stereographic view type
# User Rev Content
1 greg 1.1 #include "mainwindow.h"
2     #include "ui_mainwindow.h"
3     #include "ui_exposuredialog.h"
4     #include "ui_parameterdialog.h"
5     #include "ui_viewdialog.h"
6     #include "ui_incrementsdialog.h"
7     #include "ui_commandsdialog.h"
8
9     #include <QtGui/QMessageBox>
10     #include <QtGui/QLineEdit>
11     #include <QtGui/QCloseEvent>
12     #include <QtGui/QFileDialog>
13     #include <QtGui/QInputDialog>
14     #include <QtCore/QDebug>
15     #include <QtCore/QTime>
16     #include <QtCore/QTextStream>
17
18     #include <iostream>
19
20     // Process a command
21     extern "C" void qt_process_command(const char*);
22     // set the abort flag to stop a render in progress
23     extern "C" void qt_set_abort(int );
24     extern "C"
25     {
26     //externs for exposure dialog
27     extern VIEW ourview;
28     extern double exposure;
29     //externs for parameters dialog
30     extern COLOR ambval; /* ambient value */
31     extern int ambvwt; /* initial weight for ambient value */
32     extern double ambacc; /* ambient accuracy */
33     extern int ambres; /* ambient resolution */
34     extern int ambdiv; /* ambient divisions */
35     extern int ambssamp; /* ambient super-samples */
36     extern int ambounce; /* ambient bounces */
37     extern double shadcert; /* shadow testing certainty */
38     extern double shadthresh; /* shadow threshold */
39     extern int directvis; /* light sources visible to eye? */
40     extern COLOR cextinction; /* global extinction coefficient */
41     extern COLOR salbedo; /* global scattering albedo */
42     extern double seccg; /* global scattering eccentricity */
43     extern double ssampdist; /* scatter sampling distance */
44     extern double specthresh; /* specular sampling threshold */
45     extern double specjitter; /* specular sampling jitter */
46     extern int maxdepth; /* maximum recursion depth */
47     extern double minweight; /* minimum ray weight */
48     extern double dstrsrc; /* square source distribution */
49     extern double srcsizerat; /* maximum source size/dist. ratio */
50     extern int psample; /* pixel sample size */
51     extern double maxdiff; /* max. sample difference */
52     void quit(int code);
53     }
54     MainWindow::MainWindow(int width, int height, const char* name, const char* id)
55     {
56     m_ui = new Ui::MainWindow;
57     m_ui->setupUi(this);
58     m_exposureDialog = new QDialog();
59     m_exposureDialogUi = new Ui::exposureDialog;
60     m_exposureDialogUi->setupUi(m_exposureDialog);
61     m_parameterDialog = new QDialog();
62     m_parameterDialogUi = new Ui::parameterDialog;
63     m_parameterDialogUi->setupUi(m_parameterDialog);
64     m_viewDialog = new QDialog();
65     m_viewDialogUi = new Ui::viewDialog;
66     m_viewDialogUi->setupUi(m_viewDialog);
67     this->smallIncrement = 0.1;
68     this->largeIncrement = 0.5;
69     m_incrementsDialog = new QDialog();
70     m_incrementsDialogUi = new Ui::incrementsDialog;
71     m_incrementsDialogUi->setupUi(m_incrementsDialog);
72     m_commandsDialog = new QDialog();
73     m_commandsDialogUi = new Ui::commandsDialog;
74     m_commandsDialogUi->setupUi(m_commandsDialog);
75     this->currentImageName = "";
76     createActions();
77     connectSlots();
78     m_ui->progressBar->setMinimum(0);
79     m_ui->progressBar->setMaximum(100);
80     setWindowTitle(tr(id));
81     resize(width, height);
82     updatePositionLabels();
83     }
84
85     MainWindow::~MainWindow()
86     {
87     delete m_ui;
88     delete m_exposureDialog;
89     delete m_parameterDialog;
90     delete m_viewDialog;
91     delete m_incrementsDialog;
92     delete m_commandsDialog;
93     }
94
95     void MainWindow::setProgress(int p)
96     {
97     m_ui->progressBar->setValue(p);
98     }
99
100     RvuWidget* MainWindow::getRvuWidget() const
101     {
102     return m_ui->rvuWidget;
103     }
104
105     void MainWindow::closeEvent(QCloseEvent *event)
106     {
107     // Here is a good spot to shut down the rest of the code before exit.
108     this->m_exposureDialog->close();
109     this->m_parameterDialog->close();
110     this->m_viewDialog->close();
111     this->m_incrementsDialog->close();
112     this->m_commandsDialog->close();
113     }
114
115     void MainWindow::createActions()
116     {
117     m_minimizeAction = new QAction(tr("Mi&nimize"), this);
118     connect(m_minimizeAction, SIGNAL(triggered()), this, SLOT(hide()));
119
120     m_maximizeAction = new QAction(tr("Ma&ximize"), this);
121     connect(m_maximizeAction, SIGNAL(triggered()), this, SLOT(showMaximized()));
122
123     m_restoreAction = new QAction(tr("&Restore"), this);
124     connect(m_restoreAction, SIGNAL(triggered()), this, SLOT(showNormal()));
125     }
126
127     void MainWindow::connectSlots()
128     {
129     connect(m_ui->exit, SIGNAL(triggered()), qApp, SLOT(quit()));
130     connect(m_ui->pushButton, SIGNAL(clicked()), this, SLOT(buttonPressed()));
131     connect(m_ui->lineEdit, SIGNAL(returnPressed()),
132     this, SLOT(buttonPressed()));
133     connect(m_ui->redraw, SIGNAL(triggered()), this, SLOT(redraw()));
134     connect(m_ui->trace, SIGNAL(triggered()), this, SLOT(traceRay()));
135     connect(m_ui->toggleToolBar, SIGNAL(triggered()),
136     this, SLOT(toggleToolBar()));
137     connect(m_ui->toggleStatusBar, SIGNAL(triggered()),
138     this, SLOT(toggleStatusBar()));
139     connect(m_ui->toggleTranslateTool, SIGNAL(triggered()),
140     this, SLOT(toggleTranslateTool()));
141     connect(m_ui->exposure, SIGNAL(triggered()),
142     this, SLOT(showExposureDialog()));
143     connect(m_ui->parameters, SIGNAL(triggered()),
144     this, SLOT(showParameterDialog()));
145     connect(m_ui->view, SIGNAL(triggered()),
146     this, SLOT(showViewDialog()));
147     connect(m_ui->saveImage, SIGNAL(triggered()),
148     this, SLOT(saveCurrentImage()));
149     connect(m_ui->saveImageAs, SIGNAL(triggered()),
150     this, SLOT(saveImage()));
151     connect(m_ui->loadView, SIGNAL(triggered()),
152     this, SLOT(loadView()));
153 greg 1.2 connect(m_ui->loadRif, SIGNAL(triggered()),
154     this, SLOT(loadRif()));
155 greg 1.1 connect(m_ui->backfaceVisibility, SIGNAL(triggered()),
156     this, SLOT(toggleBackfaceVisibility()));
157     connect(m_ui->grayscale, SIGNAL(triggered()),
158     this, SLOT(toggleGrayscale()));
159     connect(m_ui->irradiance, SIGNAL(triggered()),
160     this, SLOT(toggleIrradiance()));
161     connect(m_ui->appendToRif, SIGNAL(triggered()),
162     this, SLOT(appendToRif()));
163     connect(m_ui->appendToView, SIGNAL(triggered()),
164     this, SLOT(appendToView()));
165     connect(m_ui->GUI_Increments, SIGNAL(triggered()),
166     this, SLOT(showIncrementsDialog()));
167     connect(m_ui->commands, SIGNAL(triggered()),
168     this, SLOT(showCommandsDialog()));
169     connect(m_ui->aboutRvu, SIGNAL(triggered()),
170     this, SLOT(showAbout()));
171
172     //movement buttons
173     connect(m_ui->xPlus1Button, SIGNAL(clicked()),
174     this, SLOT(moveXPlusOne()));
175     connect(m_ui->xPlus2Button, SIGNAL(clicked()),
176     this, SLOT(moveXPlusTwo()));
177     connect(m_ui->xMinus1Button, SIGNAL(clicked()),
178     this, SLOT(moveXMinusOne()));
179     connect(m_ui->xMinus2Button, SIGNAL(clicked()),
180     this, SLOT(moveXMinusTwo()));
181     connect(m_ui->yPlus1Button, SIGNAL(clicked()),
182     this, SLOT(moveYPlusOne()));
183     connect(m_ui->yPlus2Button, SIGNAL(clicked()),
184     this, SLOT(moveYPlusTwo()));
185     connect(m_ui->yMinus1Button, SIGNAL(clicked()),
186     this, SLOT(moveYMinusOne()));
187     connect(m_ui->yMinus2Button, SIGNAL(clicked()),
188     this, SLOT(moveYMinusTwo()));
189     connect(m_ui->zPlus1Button, SIGNAL(clicked()),
190     this, SLOT(moveZPlusOne()));
191     connect(m_ui->zPlus2Button, SIGNAL(clicked()),
192     this, SLOT(moveZPlusTwo()));
193     connect(m_ui->zMinus1Button, SIGNAL(clicked()),
194     this, SLOT(moveZMinusOne()));
195     connect(m_ui->zMinus2Button, SIGNAL(clicked()),
196     this, SLOT(moveZMinusTwo()));
197
198     //exposure dialog
199     connect(m_exposureDialogUi->exposureButtonBox, SIGNAL(accepted()),
200     this, SLOT(adjustExposure()));
201     connect(m_exposureDialogUi->exposureButtonBox, SIGNAL(rejected()),
202     this, SLOT(hideExposureDialog()));
203     connect(m_exposureDialogUi->natural, SIGNAL(toggled(bool)),
204     this, SLOT(updatePointRadio()));
205     connect(m_exposureDialogUi->relative, SIGNAL(toggled(bool)),
206     this, SLOT(updatePointRadio()));
207
208     //parameter dialog
209     connect(m_parameterDialogUi->buttonBox, SIGNAL(accepted()),
210     this, SLOT(adjustParameters()));
211     connect(m_parameterDialogUi->buttonBox, SIGNAL(rejected()),
212     this, SLOT(hideParameterDialog()));
213
214     //view dialog
215     connect(m_viewDialogUi->buttonBox, SIGNAL(accepted()),
216     this, SLOT(adjustView()));
217     connect(m_viewDialogUi->buttonBox, SIGNAL(rejected()),
218     this, SLOT(hideViewDialog()));
219
220     //increments dialog
221     connect(m_incrementsDialogUi->buttonBox, SIGNAL(accepted()),
222     this, SLOT(adjustIncrements()));
223     connect(m_incrementsDialogUi->buttonBox, SIGNAL(rejected()),
224     this, SLOT(hideIncrementsDialog()));
225     }
226
227     void MainWindow::doSubmit()
228     {
229     QString command = m_ui->lineEdit->text();
230     bool centerCrossHairs = false;
231     if(command == "aim")
232     {
233     centerCrossHairs = true;
234     }
235     m_ui->lineEdit->setText("");
236     m_ui->progressBar->setEnabled(true);
237     this->setProgress(0);
238     QTime t;
239     t.start();
240     if (command.isEmpty())
241     {
242     this->m_ui->pushButton->setText("Submit");
243     enableInterface(true);
244     return;
245     }
246     qt_process_command(command.toAscii());
247     QString msg;
248     QTextStream(&msg) << "Render Time: " << t.elapsed() << " ms";
249     m_ui->messageBox->appendPlainText(msg);
250     this->m_ui->pushButton->setText("Submit");
251     enableInterface(true);
252     if(centerCrossHairs)
253     {
254     QPoint p = this->m_ui->rvuWidget->geometry().center();
255     this->m_ui->rvuWidget->setPosition(p.x(), p.y());
256     }
257     updatePositionLabels();
258     }
259
260
261     void MainWindow::buttonPressed()
262     {
263     if( m_ui->pushButton->text() == QString("Submit") )
264     {
265     qt_set_abort(0);
266     this->m_ui->pushButton->setText("Abort");
267     enableInterface(false);
268     this->doSubmit();
269     }
270     else if( m_ui->pushButton->text() == QString("Abort") )
271     {
272     qt_set_abort(1);
273     this->m_ui->pushButton->setText("Submit");
274     enableInterface(true);
275     }
276     }
277
278     void MainWindow::resizeImage(int width, int height)
279     {
280     int pad = m_ui->lineEdit->size().height();
281     pad += m_ui->menubar->size().height();
282     pad += m_ui->messageBox->size().height();
283     this->resize(width+4, height+pad+4);
284     this->m_ui->rvuWidget->resizeImage(width, height);
285     }
286
287     void MainWindow::setStatus(const char* m)
288     {
289     m_ui->messageBox->appendPlainText(QString(m).trimmed());
290     }
291
292     void MainWindow::redraw()
293     {
294     runCommand("redraw");
295     }
296
297     void MainWindow::traceRay()
298     {
299     runCommand("t");
300     }
301
302     void MainWindow::toggleToolBar()
303     {
304     m_ui->toolBar->setVisible(m_ui->toggleToolBar->isChecked());
305     }
306
307     void MainWindow::toggleStatusBar()
308     {
309     m_ui->messageBox->setVisible(m_ui->toggleStatusBar->isChecked());
310     }
311
312     void MainWindow::toggleTranslateTool()
313     {
314     m_ui->xWidget->setVisible(m_ui->toggleTranslateTool->isChecked());
315     m_ui->yWidget->setVisible(m_ui->toggleTranslateTool->isChecked());
316     m_ui->zWidget->setVisible(m_ui->toggleTranslateTool->isChecked());
317     }
318
319     void MainWindow::refreshView(VIEW *nv)
320     {
321     if (waitrays() < 0) /* clear ray queue */
322     quit(1);
323     newview(nv);
324     this->redraw();
325     }
326
327     void MainWindow::move(int direction, float amount)
328     {
329     if( m_ui->pushButton->text() == QString("Abort") )
330     {
331     qt_set_abort(1);
332     return;
333     }
334     VIEW nv = ourview;
335     nv.vp[direction] = nv.vp[direction] + amount;
336     this->refreshView(&nv);
337     updatePositionLabels();
338     }
339
340     void MainWindow::moveXPlusOne()
341     {
342     this->move(0, this->smallIncrement);
343     }
344
345     void MainWindow::moveXPlusTwo()
346     {
347     this->move(0, this->largeIncrement);
348     }
349
350     void MainWindow::moveXMinusOne()
351     {
352     this->move(0, -1 * this->smallIncrement);
353     }
354
355     void MainWindow::moveXMinusTwo()
356     {
357     this->move(0, -1 * this->largeIncrement);
358     }
359
360     void MainWindow::moveYPlusOne()
361     {
362     this->move(1, this->smallIncrement);
363     }
364
365     void MainWindow::moveYPlusTwo()
366     {
367     this->move(1, this->largeIncrement);
368     }
369
370     void MainWindow::moveYMinusOne()
371     {
372     this->move(1, -1 * this->smallIncrement);
373     }
374
375     void MainWindow::moveYMinusTwo()
376     {
377     this->move(1, -1 * this->largeIncrement);
378     }
379
380     void MainWindow::moveZPlusOne()
381     {
382     this->move(2, this->smallIncrement);
383     }
384
385     void MainWindow::moveZPlusTwo()
386     {
387     this->move(2, this->largeIncrement);
388     }
389
390     void MainWindow::moveZMinusOne()
391     {
392     this->move(2, -1 * this->smallIncrement);
393     }
394
395     void MainWindow::moveZMinusTwo()
396     {
397     this->move(2, -1 * this->largeIncrement);
398     }
399
400     void MainWindow::updatePositionLabels()
401     {
402     m_ui->xValue->setText(QString::number(ourview.vp[0]));
403     m_ui->yValue->setText(QString::number(ourview.vp[1]));
404     m_ui->zValue->setText(QString::number(ourview.vp[2]));
405     }
406
407     void MainWindow::showExposureDialog()
408     {
409     m_exposureDialogUi->exposureValue->setText(QString::number(exposure));
410     m_exposureDialog->show();
411     }
412
413     void MainWindow::hideExposureDialog()
414     {
415     m_exposureDialog->hide();
416     }
417
418     void MainWindow::showParameterDialog()
419     {
420     //ambient tab
421     m_parameterDialogUi->valueX->setText(QString::number(ambval[0]));
422     m_parameterDialogUi->valueY->setText(QString::number(ambval[1]));
423     m_parameterDialogUi->valueZ->setText(QString::number(ambval[2]));
424     m_parameterDialogUi->weight->setText(QString::number(ambvwt));
425     m_parameterDialogUi->accuracy->setText(QString::number(ambacc));
426     m_parameterDialogUi->divisions->setText(QString::number(ambdiv));
427     m_parameterDialogUi->supersamples->setText(QString::number(ambssamp));
428     m_parameterDialogUi->bounces->setText(QString::number(ambounce));
429     m_parameterDialogUi->resolution->setText(QString::number(ambres));
430
431     //direct tab
432     m_parameterDialogUi->certainty->setText(QString::number(shadcert));
433     m_parameterDialogUi->threshold->setText(QString::number(shadthresh));
434     m_parameterDialogUi->visibility->setText(QString::number(directvis));
435     m_parameterDialogUi->jitter->setText(QString::number(dstrsrc));
436     m_parameterDialogUi->sampling->setText(QString::number(srcsizerat));
437     //values on direct tab that I can't find: reflection
438
439     //limit tab
440     m_parameterDialogUi->limit_weight->setText(QString::number(minweight));
441     m_parameterDialogUi->reflection->setText(QString::number(maxdepth));
442
443     //medium tab
444     m_parameterDialogUi->albedoX->setText(QString::number(salbedo[0]));
445     m_parameterDialogUi->albedoY->setText(QString::number(salbedo[1]));
446     m_parameterDialogUi->albedoZ->setText(QString::number(salbedo[2]));
447     m_parameterDialogUi->extinctionX->setText(QString::number(cextinction[0]));
448     m_parameterDialogUi->extinctionY->setText(QString::number(cextinction[1]));
449     m_parameterDialogUi->extinctionZ->setText(QString::number(cextinction[2]));
450     m_parameterDialogUi->eccentricity->setText(QString::number(seccg));
451     m_parameterDialogUi->mistDistance->setText(QString::number(ssampdist));
452
453     //pixel tab
454     m_parameterDialogUi->sample->setText(QString::number(psample));
455     m_parameterDialogUi->px_threshold->setText(QString::number(maxdiff));
456
457     //specular tab
458     m_parameterDialogUi->sp_jitter->setText(QString::number(specjitter));
459     m_parameterDialogUi->sp_threshold->setText(QString::number(specthresh));
460
461     m_parameterDialog->show();
462     }
463
464     void MainWindow::hideParameterDialog()
465     {
466     m_parameterDialog->hide();
467     }
468
469     void MainWindow::adjustExposure()
470     {
471     bool checkForPoint = false;
472
473     QString command = "exposure ";
474
475     if(m_exposureDialogUi->absolute->isChecked())
476     {
477     command += "=";
478     }
479     else if(m_exposureDialogUi->fstop->isChecked())
480     {
481     //TODO: check if the value is positive or not here
482     command += "+";
483     }
484     else if(m_exposureDialogUi->natural->isChecked())
485     {
486     command += "@";
487     checkForPoint = true;
488     }
489     else if(m_exposureDialogUi->relative->isChecked())
490     {
491     checkForPoint = true;
492     }
493
494     if(!(checkForPoint && m_exposureDialogUi->point->isChecked()))
495     {
496     command += m_exposureDialogUi->exposureSetting->text();
497     }
498
499     runCommand(command.toAscii());
500     }
501
502     void MainWindow::updatePointRadio()
503     {
504     if(m_exposureDialogUi->relative->isChecked() ||
505     m_exposureDialogUi->natural->isChecked())
506     {
507     m_exposureDialogUi->point->setEnabled(true);
508     m_exposureDialogUi->average->setEnabled(true);
509     }
510     else
511     {
512     m_exposureDialogUi->point->setEnabled(false);
513     m_exposureDialogUi->average->setEnabled(false);
514     }
515     }
516
517     void MainWindow::adjustParameters()
518     {
519     if(m_parameterDialogUi->valueX->isModified() ||
520     m_parameterDialogUi->valueY->isModified() ||
521     m_parameterDialogUi->valueZ->isModified())
522     {
523     QString command = "set av ";
524     command += m_parameterDialogUi->valueX->text();
525     command += " ";
526     command += m_parameterDialogUi->valueY->text();
527     command += " ";
528     command += m_parameterDialogUi->valueZ->text();
529     runCommand(command.toAscii());
530     }
531     if(m_parameterDialogUi->weight->isModified())
532     {
533     QString command = "set aw ";
534     command += m_parameterDialogUi->weight->text();
535     runCommand(command.toAscii());
536     }
537     if(m_parameterDialogUi->accuracy->isModified())
538     {
539     QString command = "set aa ";
540     command += m_parameterDialogUi->accuracy->text();
541     runCommand(command.toAscii());
542     }
543     if(m_parameterDialogUi->divisions->isModified())
544     {
545     QString command = "set ad ";
546     command += m_parameterDialogUi->divisions->text();
547     runCommand(command.toAscii());
548     }
549     if(m_parameterDialogUi->supersamples->isModified())
550     {
551     QString command = "set as ";
552     command += m_parameterDialogUi->supersamples->text();
553     runCommand(command.toAscii());
554     }
555     if(m_parameterDialogUi->bounces->isModified())
556     {
557     QString command = "set ab ";
558     command += m_parameterDialogUi->bounces->text();
559     runCommand(command.toAscii());
560     }
561     if(m_parameterDialogUi->resolution->isModified())
562     {
563     QString command = "set ar ";
564     command += m_parameterDialogUi->resolution->text();
565     runCommand(command.toAscii());
566     }
567     if(m_parameterDialogUi->certainty->isModified())
568     {
569     QString command = "set dc ";
570     command += m_parameterDialogUi->certainty->text();
571     runCommand(command.toAscii());
572     }
573     if(m_parameterDialogUi->threshold->isModified())
574     {
575     QString command = "set dt ";
576     command += m_parameterDialogUi->threshold->text();
577     runCommand(command.toAscii());
578     }
579     if(m_parameterDialogUi->visibility->isModified())
580     {
581     QString command = "set dv ";
582     command += m_parameterDialogUi->visibility->text();
583     runCommand(command.toAscii());
584     }
585     if(m_parameterDialogUi->jitter->isModified())
586     {
587     QString command = "set dj ";
588     command += m_parameterDialogUi->jitter->text();
589     runCommand(command.toAscii());
590     }
591     if(m_parameterDialogUi->sampling->isModified())
592     {
593     QString command = "set ds ";
594     command += m_parameterDialogUi->sampling->text();
595     runCommand(command.toAscii());
596     }
597     if(m_parameterDialogUi->limit_weight->isModified())
598     {
599     QString command = "set lw ";
600     command += m_parameterDialogUi->limit_weight->text();
601     runCommand(command.toAscii());
602     }
603     if(m_parameterDialogUi->reflection->isModified())
604     {
605     QString command = "set lr ";
606     command += m_parameterDialogUi->reflection->text();
607     runCommand(command.toAscii());
608     }
609     if(m_parameterDialogUi->albedoX->isModified() ||
610     m_parameterDialogUi->albedoY->isModified() ||
611     m_parameterDialogUi->albedoZ->isModified())
612     {
613     QString command = "set ma ";
614     command += m_parameterDialogUi->albedoX->text();
615     command += " ";
616     command += m_parameterDialogUi->albedoY->text();
617     command += " ";
618     command += m_parameterDialogUi->albedoZ->text();
619     runCommand(command.toAscii());
620     }
621     if(m_parameterDialogUi->extinctionX->isModified() ||
622     m_parameterDialogUi->extinctionY->isModified() ||
623     m_parameterDialogUi->extinctionZ->isModified())
624     {
625     QString command = "set me ";
626     command += m_parameterDialogUi->extinctionX->text();
627     command += " ";
628     command += m_parameterDialogUi->extinctionY->text();
629     command += " ";
630     command += m_parameterDialogUi->extinctionZ->text();
631     }
632     if(m_parameterDialogUi->eccentricity->isModified())
633     {
634     QString command = "set mg ";
635     command += m_parameterDialogUi->eccentricity->text();
636     runCommand(command.toAscii());
637     }
638     if(m_parameterDialogUi->mistDistance->isModified())
639     {
640     QString command = "set ms ";
641     command += m_parameterDialogUi->mistDistance->text();
642     runCommand(command.toAscii());
643     }
644     if(m_parameterDialogUi->sample->isModified())
645     {
646     QString command = "set ps ";
647     command += m_parameterDialogUi->sample->text();
648     runCommand(command.toAscii());
649     }
650     if(m_parameterDialogUi->px_threshold->isModified())
651     {
652     QString command = "set pt ";
653     command += m_parameterDialogUi->px_threshold->text();
654     runCommand(command.toAscii());
655     }
656     if(m_parameterDialogUi->sp_jitter->isModified())
657     {
658     QString command = "set ss ";
659     command += m_parameterDialogUi->sp_jitter->text();
660     runCommand(command.toAscii());
661     }
662     if(m_parameterDialogUi->sp_threshold->isModified())
663     {
664     QString command = "set st ";
665     command += m_parameterDialogUi->sp_threshold->text();
666     runCommand(command.toAscii());
667     }
668     m_parameterDialog->hide();
669     }
670
671     void MainWindow::showViewDialog()
672     {
673     if(ourview.type==VT_PER)
674     {
675     m_viewDialogUi->perspective->setChecked(true);
676     }
677     else if(ourview.type==VT_PAR)
678     {
679     m_viewDialogUi->parallel->setChecked(true);
680     }
681     else if(ourview.type==VT_HEM)
682     {
683     m_viewDialogUi->hemispherical->setChecked(true);
684     }
685     else if(ourview.type==VT_ANG)
686     {
687     m_viewDialogUi->angular->setChecked(true);
688     }
689 greg 1.3 else if(ourview.type==VT_PLS)
690     {
691     m_viewDialogUi->planispheric->setChecked(true);
692     }
693 greg 1.1 else if(ourview.type==VT_CYL)
694     {
695     m_viewDialogUi->cylindrical->setChecked(true);
696     }
697
698     m_viewDialogUi->viewX->setText(QString::number(ourview.vp[0]));
699     m_viewDialogUi->viewY->setText(QString::number(ourview.vp[1]));
700     m_viewDialogUi->viewZ->setText(QString::number(ourview.vp[2]));
701
702     m_viewDialogUi->dirX->setText(QString::number(ourview.vdir[0], 'f', 4));
703     m_viewDialogUi->dirY->setText(QString::number(ourview.vdir[1], 'f', 4));
704     m_viewDialogUi->dirZ->setText(QString::number(ourview.vdir[2], 'f', 4));
705
706     m_viewDialogUi->upX->setText(QString::number(ourview.vup[0]));
707     m_viewDialogUi->upY->setText(QString::number(ourview.vup[1]));
708     m_viewDialogUi->upZ->setText(QString::number(ourview.vup[2]));
709
710     m_viewDialogUi->sizeHoriz->setText(QString::number(ourview.horiz));
711     m_viewDialogUi->sizeVert->setText(QString::number(ourview.vert));
712     m_viewDialogUi->fore->setText(QString::number(ourview.vfore));
713     m_viewDialogUi->aft->setText(QString::number(ourview.vaft));
714     m_viewDialogUi->offsetHoriz->setText(QString::number(ourview.hoff));
715     m_viewDialogUi->offsetVert->setText(QString::number(ourview.voff));
716
717     m_viewDialog->show();
718     }
719
720     void MainWindow::hideViewDialog()
721     {
722     m_viewDialog->hide();
723     }
724
725     void MainWindow::adjustView()
726     {
727     bool changed = false;
728     VIEW nv = ourview;
729
730     //type
731     if(m_viewDialogUi->perspective->isChecked() && nv.type != VT_PER)
732     {
733     nv.type = VT_PER;
734     changed = true;
735     }
736     if(m_viewDialogUi->parallel->isChecked() && nv.type != VT_PAR)
737     {
738     nv.type = VT_PAR;
739     changed = true;
740     }
741     if(m_viewDialogUi->hemispherical->isChecked() && nv.type != VT_HEM)
742     {
743     nv.type = VT_HEM;
744     changed = true;
745     }
746     if(m_viewDialogUi->angular->isChecked() && nv.type != VT_ANG)
747     {
748     nv.type = VT_ANG;
749     changed = true;
750     }
751 greg 1.3 if(m_viewDialogUi->planispheric->isChecked() && nv.type != VT_PLS)
752     {
753     nv.type = VT_PLS;
754     changed = true;
755     }
756 greg 1.1 if(m_viewDialogUi->cylindrical->isChecked() && nv.type != VT_CYL)
757     {
758     nv.type = VT_CYL;
759     changed = true;
760     }
761
762     //viewpoint
763     if(m_viewDialogUi->viewX->isModified())
764     {
765     bool okay = true;
766     float f = m_viewDialogUi->viewX->text().toFloat(&okay);
767     if(okay)
768     {
769     nv.vp[0] = f;
770     changed = true;
771     }
772     }
773     if(m_viewDialogUi->viewY->isModified())
774     {
775     bool okay = true;
776     float f = m_viewDialogUi->viewY->text().toFloat(&okay);
777     if(okay)
778     {
779     nv.vp[1] = f;
780     changed = true;
781     }
782     }
783     if(m_viewDialogUi->viewZ->isModified())
784     {
785     bool okay = true;
786     float f = m_viewDialogUi->viewZ->text().toFloat(&okay);
787     if(okay)
788     {
789     nv.vp[2] = f;
790     changed = true;
791     }
792     }
793
794     //direction
795     if(m_viewDialogUi->dirX->isModified())
796     {
797     bool okay = true;
798     float f = m_viewDialogUi->dirX->text().toFloat(&okay);
799     if(okay)
800     {
801     nv.vdir[0] = f;
802     changed = true;
803     }
804     }
805     if(m_viewDialogUi->dirY->isModified())
806     {
807     bool okay = true;
808     float f = m_viewDialogUi->dirY->text().toFloat(&okay);
809     if(okay)
810     {
811     nv.vdir[1] = f;
812     changed = true;
813     }
814     }
815     if(m_viewDialogUi->dirZ->isModified())
816     {
817     bool okay = true;
818     float f = m_viewDialogUi->dirZ->text().toFloat(&okay);
819     if(okay)
820     {
821     nv.vdir[2] = f;
822     changed = true;
823     }
824     }
825
826     //up
827     if(m_viewDialogUi->upX->isModified())
828     {
829     bool okay = true;
830     float f = m_viewDialogUi->upX->text().toFloat(&okay);
831     if(okay)
832     {
833     nv.vup[0] = f;
834     changed = true;
835     }
836     }
837     if(m_viewDialogUi->upY->isModified())
838     {
839     bool okay = true;
840     float f = m_viewDialogUi->upY->text().toFloat(&okay);
841     if(okay)
842     {
843     nv.vup[1] = f;
844     changed = true;
845     }
846     }
847     if(m_viewDialogUi->upZ->isModified())
848     {
849     bool okay = true;
850     float f = m_viewDialogUi->upZ->text().toFloat(&okay);
851     if(okay)
852     {
853     nv.vup[2] = f;
854     changed = true;
855     }
856     }
857
858     //size
859     if(m_viewDialogUi->sizeHoriz->isModified())
860     {
861     bool okay = true;
862     double d = m_viewDialogUi->sizeHoriz->text().toDouble(&okay);
863     if(okay)
864     {
865     nv.horiz = d;
866     changed = true;
867     }
868     }
869     if(m_viewDialogUi->sizeVert->isModified())
870     {
871     bool okay = true;
872     double d = m_viewDialogUi->sizeVert->text().toDouble(&okay);
873     if(okay)
874     {
875     nv.vert = d;
876     changed = true;
877     }
878     }
879
880     //clipping plane
881     if(m_viewDialogUi->fore->isModified())
882     {
883     bool okay = true;
884     double d = m_viewDialogUi->fore->text().toDouble(&okay);
885     if(okay)
886     {
887     nv.vfore = d;
888     changed = true;
889     }
890     }
891     if(m_viewDialogUi->aft->isModified())
892     {
893     bool okay = true;
894     double d = m_viewDialogUi->aft->text().toDouble(&okay);
895     if(okay)
896     {
897     nv.vaft = d;
898     changed = true;
899     }
900     }
901
902     //clipping plane
903     if(m_viewDialogUi->offsetHoriz->isModified())
904     {
905     bool okay = true;
906     double d = m_viewDialogUi->offsetHoriz->text().toDouble(&okay);
907     if(okay)
908     {
909     nv.hoff = d;
910     changed = true;
911     }
912     }
913     if(m_viewDialogUi->offsetVert->isModified())
914     {
915     bool okay = true;
916     double d = m_viewDialogUi->offsetVert->text().toDouble(&okay);
917     if(okay)
918     {
919     nv.voff = d;
920     changed = true;
921     }
922     }
923
924     if(changed)
925     {
926     this->refreshView(&nv);
927     }
928     }
929
930     void MainWindow::enableInterface(bool enable)
931     {
932     m_ui->toolBar->setEnabled(enable);
933     m_ui->progressBar->setEnabled(!enable);
934     }
935
936     void MainWindow::runCommand(const char *command)
937     {
938     qt_set_abort(0);
939     this->m_ui->pushButton->setText("Abort");
940     enableInterface(false);
941     qt_process_command(command);
942     qt_set_abort(1);
943     this->m_ui->pushButton->setText("Submit");
944     enableInterface(true);
945     }
946
947     void MainWindow::pick(int* x, int* y)
948     {
949     QCursor oldCursor = this->cursor();
950     this->setCursor(Qt::CrossCursor);
951     this->getRvuWidget()->getPosition(x, y);
952     // restore state
953     this->setCursor(oldCursor);
954     }
955
956     void MainWindow::saveImage()
957     {
958     this->currentImageName = QFileDialog::getSaveFileName(this, tr("Save File"),
959     "", tr(".hdr images (*.hdr)"));
960     QString command = "write " + this->currentImageName;
961     this->runCommand(command.toAscii());
962     }
963
964     void MainWindow::saveCurrentImage()
965     {
966     if(this->currentImageName == "")
967     {
968     this->saveImage();
969     return;
970     }
971     QString command = "write " + this->currentImageName;
972     this->runCommand(command.toAscii());
973     }
974
975     void MainWindow::loadView()
976     {
977     QString viewFileName = QFileDialog::getOpenFileName(this, tr("Open View File"),
978     "", tr("View Files (*.vp *.vf)"));
979     QString command = "last " + viewFileName;
980     this->runCommand(command.toAscii());
981     }
982
983     void MainWindow::toggleGrayscale()
984     {
985     QString command = "set b ";
986     if(m_ui->grayscale->isChecked())
987     {
988     command += " 1";
989     }
990     else
991     {
992     command += " 0";
993     }
994     this->runCommand(command.toAscii());
995     this->runCommand("new");
996     }
997
998     void MainWindow::toggleBackfaceVisibility()
999     {
1000     QString command = "set bv";
1001     if(m_ui->backfaceVisibility->isChecked())
1002     {
1003     command += " 1";
1004     }
1005     else
1006     {
1007     command += " 0";
1008     }
1009     this->runCommand(command.toAscii());
1010     this->runCommand("new");
1011     }
1012
1013     void MainWindow::toggleIrradiance()
1014     {
1015     QString command = "set i";
1016     if(m_ui->irradiance->isChecked())
1017     {
1018     command += " 1";
1019     }
1020     else
1021     {
1022     command += " 0";
1023     }
1024     this->runCommand(command.toAscii());
1025     this->runCommand("new");
1026     }
1027
1028 greg 1.2 void MainWindow::loadRif()
1029     {
1030     bool ok;
1031     QString viewName = QInputDialog::getText(this, tr("Input view name"),
1032     tr("Name of view:"), QLineEdit::Normal,
1033     "", &ok);
1034     if (ok && !viewName.isEmpty())
1035     {
1036     QString radFileName = QFileDialog::getOpenFileName(this, tr("Open rad File"),
1037     "", tr("rad files (*.rif)"));
1038     QString command = "L " + viewName + " " + radFileName;
1039     this->runCommand(command.toAscii());
1040     }
1041     }
1042
1043 greg 1.1 void MainWindow::appendToRif()
1044     {
1045     bool ok;
1046     QString viewName = QInputDialog::getText(this, tr("Input view name"),
1047     tr("Name of view:"), QLineEdit::Normal,
1048     "", &ok);
1049     if (ok && !viewName.isEmpty())
1050     {
1051     QString radFileName = QFileDialog::getSaveFileName(this, tr("Save File"),
1052     "", tr("rad files (*.rif)"), 0, QFileDialog::DontConfirmOverwrite);
1053     QString command = "V " + viewName + " " + radFileName;
1054     this->runCommand(command.toAscii());
1055     }
1056     }
1057
1058     void MainWindow::appendToView()
1059     {
1060     QString viewFileName = QFileDialog::getSaveFileName(this, tr("Save File"),
1061     "", tr("view files (*.vp *.vf)"), 0, QFileDialog::DontConfirmOverwrite);
1062     if(viewFileName != "")
1063     {
1064     QString command = "view " + viewFileName;
1065     this->runCommand(command.toAscii());
1066     }
1067     }
1068
1069     void MainWindow::showIncrementsDialog()
1070     {
1071     m_incrementsDialogUi->small->setText(QString::number(this->smallIncrement));
1072     m_incrementsDialogUi->large->setText(QString::number(this->largeIncrement));
1073     m_incrementsDialog->show();
1074     }
1075
1076     void MainWindow::hideIncrementsDialog()
1077     {
1078     m_incrementsDialog->hide();
1079     }
1080
1081     void MainWindow::adjustIncrements()
1082     {
1083     bool okay = true;
1084     float f = m_incrementsDialogUi->small->text().toFloat(&okay);
1085     if(okay)
1086     {
1087     this->smallIncrement = f;
1088     }
1089     f = m_incrementsDialogUi->large->text().toFloat(&okay);
1090     if(okay)
1091     {
1092     this->largeIncrement = f;
1093     }
1094     }
1095
1096     void MainWindow::showCommandsDialog()
1097     {
1098     m_commandsDialog->show();
1099     }
1100
1101     void MainWindow::showAbout()
1102     {
1103     QString aboutText =
1104     "rvu was written mainly by Greg Ward.\nThe Qt-based GUI was developed by Kitware, Inc. in 2011";
1105     QMessageBox::about(this, "About rvu", aboutText);
1106     }
