--- ray/src/qtrvu/mainwindow.cxx 2011/10/22 22:38:10 1.1 +++ ray/src/qtrvu/mainwindow.cxx 2015/05/08 18:07:38 1.4 @@ -6,14 +6,14 @@ #include "ui_incrementsdialog.h" #include "ui_commandsdialog.h" -#include -#include -#include -#include -#include -#include -#include -#include +#include +#include +#include +#include +#include +#include +#include +#include #include @@ -150,6 +150,8 @@ void MainWindow::connectSlots() this, SLOT(saveImage())); connect(m_ui->loadView, SIGNAL(triggered()), this, SLOT(loadView())); + connect(m_ui->loadRif, SIGNAL(triggered()), + this, SLOT(loadRif())); connect(m_ui->backfaceVisibility, SIGNAL(triggered()), this, SLOT(toggleBackfaceVisibility())); connect(m_ui->grayscale, SIGNAL(triggered()), @@ -241,7 +243,7 @@ void MainWindow::doSubmit() enableInterface(true); return; } - qt_process_command(command.toAscii()); + qt_process_command(command.toLatin1()); QString msg; QTextStream(&msg) << "Render Time: " << t.elapsed() << " ms"; m_ui->messageBox->appendPlainText(msg); @@ -494,7 +496,7 @@ void MainWindow::adjustExposure() command += m_exposureDialogUi->exposureSetting->text(); } - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } void MainWindow::updatePointRadio() @@ -524,85 +526,85 @@ void MainWindow::adjustParameters() command += m_parameterDialogUi->valueY->text(); command += " "; command += m_parameterDialogUi->valueZ->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->weight->isModified()) { QString command = "set aw "; command += m_parameterDialogUi->weight->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->accuracy->isModified()) { QString command = "set aa "; command += m_parameterDialogUi->accuracy->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->divisions->isModified()) { QString command = "set ad "; command += m_parameterDialogUi->divisions->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->supersamples->isModified()) { QString command = "set as "; command += m_parameterDialogUi->supersamples->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->bounces->isModified()) { QString command = "set ab "; command += m_parameterDialogUi->bounces->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->resolution->isModified()) { QString command = "set ar "; command += m_parameterDialogUi->resolution->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->certainty->isModified()) { QString command = "set dc "; command += m_parameterDialogUi->certainty->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->threshold->isModified()) { QString command = "set dt "; command += m_parameterDialogUi->threshold->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->visibility->isModified()) { QString command = "set dv "; command += m_parameterDialogUi->visibility->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->jitter->isModified()) { QString command = "set dj "; command += m_parameterDialogUi->jitter->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->sampling->isModified()) { QString command = "set ds "; command += m_parameterDialogUi->sampling->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->limit_weight->isModified()) { QString command = "set lw "; command += m_parameterDialogUi->limit_weight->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->reflection->isModified()) { QString command = "set lr "; command += m_parameterDialogUi->reflection->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->albedoX->isModified() || m_parameterDialogUi->albedoY->isModified() || @@ -614,7 +616,7 @@ void MainWindow::adjustParameters() command += m_parameterDialogUi->albedoY->text(); command += " "; command += m_parameterDialogUi->albedoZ->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->extinctionX->isModified() || m_parameterDialogUi->extinctionY->isModified() || @@ -631,37 +633,37 @@ void MainWindow::adjustParameters() { QString command = "set mg "; command += m_parameterDialogUi->eccentricity->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->mistDistance->isModified()) { QString command = "set ms "; command += m_parameterDialogUi->mistDistance->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->sample->isModified()) { QString command = "set ps "; command += m_parameterDialogUi->sample->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->px_threshold->isModified()) { QString command = "set pt "; command += m_parameterDialogUi->px_threshold->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->sp_jitter->isModified()) { QString command = "set ss "; command += m_parameterDialogUi->sp_jitter->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } if(m_parameterDialogUi->sp_threshold->isModified()) { QString command = "set st "; command += m_parameterDialogUi->sp_threshold->text(); - runCommand(command.toAscii()); + runCommand(command.toLatin1()); } m_parameterDialog->hide(); } @@ -684,6 +686,10 @@ void MainWindow::showViewDialog() { m_viewDialogUi->angular->setChecked(true); } + else if(ourview.type==VT_PLS) + { + m_viewDialogUi->planispheric->setChecked(true); + } else if(ourview.type==VT_CYL) { m_viewDialogUi->cylindrical->setChecked(true); @@ -742,6 +748,11 @@ void MainWindow::adjustView() nv.type = VT_ANG; changed = true; } + if(m_viewDialogUi->planispheric->isChecked() && nv.type != VT_PLS) + { + nv.type = VT_PLS; + changed = true; + } if(m_viewDialogUi->cylindrical->isChecked() && nv.type != VT_CYL) { nv.type = VT_CYL; @@ -947,7 +958,7 @@ void MainWindow::saveImage() this->currentImageName = QFileDialog::getSaveFileName(this, tr("Save File"), "", tr(".hdr images (*.hdr)")); QString command = "write " + this->currentImageName; - this->runCommand(command.toAscii()); + this->runCommand(command.toLatin1()); } void MainWindow::saveCurrentImage() @@ -958,7 +969,7 @@ void MainWindow::saveCurrentImage() return; } QString command = "write " + this->currentImageName; - this->runCommand(command.toAscii()); + this->runCommand(command.toLatin1()); } void MainWindow::loadView() @@ -966,7 +977,7 @@ void MainWindow::loadView() QString viewFileName = QFileDialog::getOpenFileName(this, tr("Open View File"), "", tr("View Files (*.vp *.vf)")); QString command = "last " + viewFileName; - this->runCommand(command.toAscii()); + this->runCommand(command.toLatin1()); } void MainWindow::toggleGrayscale() @@ -980,7 +991,7 @@ void MainWindow::toggleGrayscale() { command += " 0"; } - this->runCommand(command.toAscii()); + this->runCommand(command.toLatin1()); this->runCommand("new"); } @@ -995,7 +1006,7 @@ void MainWindow::toggleBackfaceVisibility() { command += " 0"; } - this->runCommand(command.toAscii()); + this->runCommand(command.toLatin1()); this->runCommand("new"); } @@ -1010,10 +1021,25 @@ void MainWindow::toggleIrradiance() { command += " 0"; } - this->runCommand(command.toAscii()); + this->runCommand(command.toLatin1()); this->runCommand("new"); } +void MainWindow::loadRif() +{ + bool ok; + QString viewName = QInputDialog::getText(this, tr("Input view name"), + tr("Name of view:"), QLineEdit::Normal, + "", &ok); + if (ok && !viewName.isEmpty()) + { + QString radFileName = QFileDialog::getOpenFileName(this, tr("Open rad File"), + "", tr("rad files (*.rif)")); + QString command = "L " + viewName + " " + radFileName; + this->runCommand(command.toLatin1()); + } +} + void MainWindow::appendToRif() { bool ok; @@ -1025,7 +1051,7 @@ void MainWindow::appendToRif() QString radFileName = QFileDialog::getSaveFileName(this, tr("Save File"), "", tr("rad files (*.rif)"), 0, QFileDialog::DontConfirmOverwrite); QString command = "V " + viewName + " " + radFileName; - this->runCommand(command.toAscii()); + this->runCommand(command.toLatin1()); } } @@ -1036,7 +1062,7 @@ void MainWindow::appendToView() if(viewFileName != "") { QString command = "view " + viewFileName; - this->runCommand(command.toAscii()); + this->runCommand(command.toLatin1()); } }
