root/Development/ray/src/qtrvu/incrementsdialog.ui
Revision: 1.1
Committed: Sat Oct 22 22:38:10 2011 UTC (13 years, 11 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R1, rad4R2P1, rad4R2P2, HEAD
Added qt interface for rvu and cmake files from Bill Hoffman
1 <?xml version="1.0" encoding="UTF-8"?>
2 <ui version="4.0">
3 <class>incrementsDialog</class>
4 <widget class="QDialog" name="incrementsDialog">
5 <property name="geometry">
6 <rect>
7 <x>0</x>
8 <y>0</y>
9 <width>400</width>
10 <height>300</height>
11 </rect>
12 </property>
13 <property name="windowTitle">
14 <string>GUI Increments</string>
15 </property>
16 <layout class="QGridLayout" name="gridLayout">
17 <item row="0" column="0" colspan="2">
18 <widget class="QLabel" name="label">
19 <property name="text">
20 <string>Translation step size</string>
21 </property>
22 </widget>
23 </item>
24 <item row="1" column="0">
25 <widget class="QLabel" name="label_2">
26 <property name="text">
27 <string>Small:</string>
28 </property>
29 </widget>
30 </item>
31 <item row="1" column="1">
32 <widget class="QLineEdit" name="small"/>
33 </item>
34 <item row="2" column="0">
35 <widget class="QLabel" name="label_3">
36 <property name="text">
37 <string>Large:</string>
38 </property>
39 </widget>
40 </item>
41 <item row="2" column="1">
42 <widget class="QLineEdit" name="large"/>
43 </item>
44 <item row="3" column="0" colspan="2">
45 <widget class="QDialogButtonBox" name="buttonBox">
46 <property name="orientation">
47 <enum>Qt::Horizontal</enum>
48 </property>
49 <property name="standardButtons">
50 <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
51 </property>
52 </widget>
53 </item>
54 </layout>
55 </widget>
56 <resources/>
57 <connections>
58 <connection>
59 <sender>buttonBox</sender>
60 <signal>accepted()</signal>
61 <receiver>incrementsDialog</receiver>
62 <slot>accept()</slot>
63 <hints>
64 <hint type="sourcelabel">
65 <x>248</x>
66 <y>254</y>
67 </hint>
68 <hint type="destinationlabel">
69 <x>157</x>
70 <y>274</y>
71 </hint>
72 </hints>
73 </connection>
74 <connection>
75 <sender>buttonBox</sender>
76 <signal>rejected()</signal>
77 <receiver>incrementsDialog</receiver>
78 <slot>reject()</slot>
79 <hints>
80 <hint type="sourcelabel">
81 <x>316</x>
82 <y>260</y>
83 </hint>
84 <hint type="destinationlabel">
85 <x>286</x>
86 <y>274</y>
87 </hint>
88 </hints>
89 </connection>
90 </connections>
91 </ui>
