| 1 |
<?xml version="1.0" encoding="UTF-8"?>
| 2 |
<ui version="4.0">
| 3 |
<class>incrementsDialog</class>
| 4 |
<widget class="QDialog" name="incrementsDialog">
| 5 |
<property name="geometry">
| 6 |
<rect>
| 7 |
<x>0</x>
| 8 |
<y>0</y>
| 9 |
<width>400</width>
| 10 |
<height>300</height>
| 11 |
</rect>
| 12 |
</property>
| 13 |
<property name="windowTitle">
| 14 |
<string>GUI Increments</string>
| 15 |
</property>
| 16 |
<layout class="QGridLayout" name="gridLayout">
| 17 |
<item row="0" column="0" colspan="2">
| 18 |
<widget class="QLabel" name="label">
| 19 |
<property name="text">
| 20 |
<string>Translation step size</string>
| 21 |
</property>
| 22 |
</widget>
| 23 |
</item>
| 24 |
<item row="1" column="0">
| 25 |
<widget class="QLabel" name="label_2">
| 26 |
| 27 |
<string>Small:</string>
| 28 |
</property>
| 29 |
</widget>
| 30 |
</item>
| 31 |
<item row="1" column="1">
| 32 |
<widget class="QLineEdit" name="small"/>
| 33 |
</item>
| 34 |
<item row="2" column="0">
| 35 |
<widget class="QLabel" name="label_3">
| 36 |
| 37 |
<string>Large:</string>
| 38 |
</property>
| 39 |
</widget>
| 40 |
</item>
| 41 |
<item row="2" column="1">
| 42 |
<widget class="QLineEdit" name="large"/>
| 43 |
</item>
| 44 |
<item row="3" column="0" colspan="2">
| 45 |
<widget class="QDialogButtonBox" name="buttonBox">
| 46 |
<property name="orientation">
| 47 |
<enum>Qt::Horizontal</enum>
| 48 |
</property>
| 49 |
<property name="standardButtons">
| 50 |
<set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
| 51 |
</property>
| 52 |
</widget>
| 53 |
</item>
| 54 |
</layout>
| 55 |
</widget>
| 56 |
<resources/>
| 57 |
<connections>
| 58 |
<connection>
| 59 |
<sender>buttonBox</sender>
| 60 |
<signal>accepted()</signal>
| 61 |
<receiver>incrementsDialog</receiver>
| 62 |
<slot>accept()</slot>
| 63 |
<hints>
| 64 |
<hint type="sourcelabel">
| 65 |
<x>248</x>
| 66 |
<y>254</y>
| 67 |
</hint>
| 68 |
<hint type="destinationlabel">
| 69 |
<x>157</x>
| 70 |
<y>274</y>
| 71 |
</hint>
| 72 |
</hints>
| 73 |
</connection>
| 74 |
<connection>
| 75 |
| 76 |
<signal>rejected()</signal>
| 77 |
| 78 |
<slot>reject()</slot>
| 79 |
<hints>
| 80 |
| 81 |
<x>316</x>
| 82 |
<y>260</y>
| 83 |
</hint>
| 84 |
| 85 |
<x>286</x>
| 86 |
<y>274</y>
| 87 |
</hint>
| 88 |
</hints>
| 89 |
</connection>
| 90 |
</connections>
| 91 |
</ui>
