root/radiance/ray/src/qtrvu/exposuredialog.ui
Revision: 1.1
Committed: Sat Oct 22 22:38:10 2011 UTC (11 years, 7 months ago) by greg
CVS Tags: rad5R0, rad5R2, rad4R2P2, rad4R2P1, rad5R1, rad4R2, rad4R1, rad5R3, HEAD
Added qt interface for rvu and cmake files from Bill Hoffman
1 <?xml version="1.0" encoding="UTF-8"?>
2 <ui version="4.0">
3 <class>exposureDialog</class>
4 <widget class="QDialog" name="exposureDialog">
5 <property name="geometry">
6 <rect>
7 <x>0</x>
8 <y>0</y>
9 <width>303</width>
10 <height>197</height>
11 </rect>
12 </property>
13 <property name="windowTitle">
14 <string>Exposure</string>
15 </property>
16 <property name="toolTip">
17 <string>adjust exposure here</string>
18 </property>
19 <layout class="QGridLayout" name="gridLayout">
20 <item row="0" column="0">
21 <widget class="QLabel" name="exposureValueLabel">
22 <property name="text">
23 <string>Current value:</string>
24 </property>
25 </widget>
26 </item>
27 <item row="0" column="1">
28 <widget class="QLabel" name="exposureValue">
29 <property name="text">
30 <string>1</string>
31 </property>
32 </widget>
33 </item>
34 <item row="1" column="0">
35 <widget class="QLabel" name="exposureModeLabel">
36 <property name="text">
37 <string>Mode:</string>
38 </property>
39 </widget>
40 </item>
41 <item row="1" column="1">
42 <widget class="QRadioButton" name="relative">
43 <property name="text">
44 <string>Relative</string>
45 </property>
46 <property name="checked">
47 <bool>true</bool>
48 </property>
49 <attribute name="buttonGroup">
50 <string>modeGroup</string>
51 </attribute>
52 </widget>
53 </item>
54 <item row="1" column="2">
55 <widget class="QRadioButton" name="absolute">
56 <property name="text">
57 <string>Absolute</string>
58 </property>
59 <attribute name="buttonGroup">
60 <string>modeGroup</string>
61 </attribute>
62 </widget>
63 </item>
64 <item row="2" column="1">
65 <widget class="QRadioButton" name="fstop">
66 <property name="text">
67 <string>F-stop</string>
68 </property>
69 <attribute name="buttonGroup">
70 <string>modeGroup</string>
71 </attribute>
72 </widget>
73 </item>
74 <item row="2" column="2">
75 <widget class="QRadioButton" name="natural">
76 <property name="text">
77 <string>Natural</string>
78 </property>
79 <attribute name="buttonGroup">
80 <string>modeGroup</string>
81 </attribute>
82 </widget>
83 </item>
84 <item row="3" column="0">
85 <widget class="QLabel" name="exposureBasedLabel">
86 <property name="text">
87 <string>Based on:</string>
88 </property>
89 </widget>
90 </item>
91 <item row="3" column="1">
92 <widget class="QRadioButton" name="average">
93 <property name="text">
94 <string>Average</string>
95 </property>
96 <property name="checked">
97 <bool>true</bool>
98 </property>
99 <attribute name="buttonGroup">
100 <string>basedGroup</string>
101 </attribute>
102 </widget>
103 </item>
104 <item row="3" column="2">
105 <widget class="QRadioButton" name="point">
106 <property name="text">
107 <string>Point</string>
108 </property>
109 <attribute name="buttonGroup">
110 <string>basedGroup</string>
111 </attribute>
112 </widget>
113 </item>
114 <item row="4" column="0">
115 <widget class="QLabel" name="exposureSettingLabel">
116 <property name="text">
117 <string>Setting:</string>
118 </property>
119 </widget>
120 </item>
121 <item row="4" column="1">
122 <widget class="QLineEdit" name="exposureSetting">
123 <property name="text">
124 <string>1</string>
125 </property>
126 </widget>
127 </item>
128 <item row="5" column="0" colspan="3">
129 <widget class="QDialogButtonBox" name="exposureButtonBox">
130 <property name="orientation">
131 <enum>Qt::Horizontal</enum>
132 </property>
133 <property name="standardButtons">
134 <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
135 </property>
136 </widget>
137 </item>
138 </layout>
139 </widget>
140 <resources/>
141 <connections>
142 <connection>
143 <sender>exposureButtonBox</sender>
144 <signal>accepted()</signal>
145 <receiver>exposureDialog</receiver>
146 <slot>accept()</slot>
147 <hints>
148 <hint type="sourcelabel">
149 <x>248</x>
150 <y>254</y>
151 </hint>
152 <hint type="destinationlabel">
153 <x>157</x>
154 <y>274</y>
155 </hint>
156 </hints>
157 </connection>
158 <connection>
159 <sender>exposureButtonBox</sender>
160 <signal>rejected()</signal>
161 <receiver>exposureDialog</receiver>
162 <slot>reject()</slot>
163 <hints>
164 <hint type="sourcelabel">
165 <x>316</x>
166 <y>260</y>
167 </hint>
168 <hint type="destinationlabel">
169 <x>286</x>
170 <y>274</y>
171 </hint>
172 </hints>
173 </connection>
174 </connections>
175 <buttongroups>
176 <buttongroup name="basedGroup"/>
177 <buttongroup name="modeGroup"/>
178 </buttongroups>
179 </ui>
