root/radiance/ray/src/qtrvu/exposuredialog.ui
Revision: 1.1
Committed: Sat Oct 22 22:38:10 2011 UTC (13 years, 6 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R2P1, rad5R3, HEAD
Added qt interface for rvu and cmake files from Bill Hoffman
# User Rev Content
1 greg 1.1 <?xml version="1.0" encoding="UTF-8"?>
2     <ui version="4.0">
3     <class>exposureDialog</class>
4     <widget class="QDialog" name="exposureDialog">
5     <property name="geometry">
6     <rect>
7     <x>0</x>
8     <y>0</y>
9     <width>303</width>
10     <height>197</height>
11     </rect>
12     </property>
13     <property name="windowTitle">
14     <string>Exposure</string>
15     </property>
16     <property name="toolTip">
17     <string>adjust exposure here</string>
18     </property>
19     <layout class="QGridLayout" name="gridLayout">
20     <item row="0" column="0">
21     <widget class="QLabel" name="exposureValueLabel">
22     <property name="text">
23     <string>Current value:</string>
24     </property>
25     </widget>
26     </item>
27     <item row="0" column="1">
28     <widget class="QLabel" name="exposureValue">
29     <property name="text">
30     <string>1</string>
31     </property>
32     </widget>
33     </item>
34     <item row="1" column="0">
35     <widget class="QLabel" name="exposureModeLabel">
36     <property name="text">
37     <string>Mode:</string>
38     </property>
39     </widget>
40     </item>
41     <item row="1" column="1">
42     <widget class="QRadioButton" name="relative">
43     <property name="text">
44     <string>Relative</string>
45     </property>
46     <property name="checked">
47     <bool>true</bool>
48     </property>
49     <attribute name="buttonGroup">
50     <string>modeGroup</string>
51     </attribute>
52     </widget>
53     </item>
54     <item row="1" column="2">
55     <widget class="QRadioButton" name="absolute">
56     <property name="text">
57     <string>Absolute</string>
58     </property>
59     <attribute name="buttonGroup">
60     <string>modeGroup</string>
61     </attribute>
62     </widget>
63     </item>
64     <item row="2" column="1">
65     <widget class="QRadioButton" name="fstop">
66     <property name="text">
67     <string>F-stop</string>
68     </property>
69     <attribute name="buttonGroup">
70     <string>modeGroup</string>
71     </attribute>
72     </widget>
73     </item>
74     <item row="2" column="2">
75     <widget class="QRadioButton" name="natural">
76     <property name="text">
77     <string>Natural</string>
78     </property>
79     <attribute name="buttonGroup">
80     <string>modeGroup</string>
81     </attribute>
82     </widget>
83     </item>
84     <item row="3" column="0">
85     <widget class="QLabel" name="exposureBasedLabel">
86     <property name="text">
87     <string>Based on:</string>
88     </property>
89     </widget>
90     </item>
91     <item row="3" column="1">
92     <widget class="QRadioButton" name="average">
93     <property name="text">
94     <string>Average</string>
95     </property>
96     <property name="checked">
97     <bool>true</bool>
98     </property>
99     <attribute name="buttonGroup">
100     <string>basedGroup</string>
101     </attribute>
102     </widget>
103     </item>
104     <item row="3" column="2">
105     <widget class="QRadioButton" name="point">
106     <property name="text">
107     <string>Point</string>
108     </property>
109     <attribute name="buttonGroup">
110     <string>basedGroup</string>
111     </attribute>
112     </widget>
113     </item>
114     <item row="4" column="0">
115     <widget class="QLabel" name="exposureSettingLabel">
116     <property name="text">
117     <string>Setting:</string>
118     </property>
119     </widget>
120     </item>
121     <item row="4" column="1">
122     <widget class="QLineEdit" name="exposureSetting">
123     <property name="text">
124     <string>1</string>
125     </property>
126     </widget>
127     </item>
128     <item row="5" column="0" colspan="3">
129     <widget class="QDialogButtonBox" name="exposureButtonBox">
130     <property name="orientation">
131     <enum>Qt::Horizontal</enum>
132     </property>
133     <property name="standardButtons">
134     <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
135     </property>
136     </widget>
137     </item>
138     </layout>
139     </widget>
140     <resources/>
141     <connections>
142     <connection>
143     <sender>exposureButtonBox</sender>
144     <signal>accepted()</signal>
145     <receiver>exposureDialog</receiver>
146     <slot>accept()</slot>
147     <hints>
148     <hint type="sourcelabel">
149     <x>248</x>
150     <y>254</y>
151     </hint>
152     <hint type="destinationlabel">
153     <x>157</x>
154     <y>274</y>
155     </hint>
156     </hints>
157     </connection>
158     <connection>
159     <sender>exposureButtonBox</sender>
160     <signal>rejected()</signal>
161     <receiver>exposureDialog</receiver>
162     <slot>reject()</slot>
163     <hints>
164     <hint type="sourcelabel">
165     <x>316</x>
166     <y>260</y>
167     </hint>
168     <hint type="destinationlabel">
169     <x>286</x>
170     <y>274</y>
171     </hint>
172     </hints>
173     </connection>
174     </connections>
175     <buttongroups>
176     <buttongroup name="basedGroup"/>
177     <buttongroup name="modeGroup"/>
178     </buttongroups>
179     </ui>
