| 1 |
greg |
1.1 |
<?xml version="1.0" encoding="UTF-8"?>
| 2 |
<ui version="4.0">
| 3 |
<class>commandsDialog</class>
| 4 |
<widget class="QDialog" name="commandsDialog">
| 5 |
<property name="geometry">
| 6 |
<rect>
| 7 |
<x>0</x>
| 8 |
<y>0</y>
| 9 |
<width>737</width>
| 10 |
<height>894</height>
| 11 |
</rect>
| 12 |
</property>
| 13 |
<property name="windowTitle">
| 14 |
<string>Rvu Commands</string>
| 15 |
</property>
| 16 |
<layout class="QVBoxLayout" name="verticalLayout">
| 17 |
<item>
| 18 |
<widget class="QTextEdit" name="textEdit">
| 19 |
<property name="documentTitle">
| 20 |
<string/>
| 21 |
</property>
| 22 |
<property name="readOnly">
| 23 |
<bool>true</bool>
| 24 |
</property>
| 25 |
<property name="html">
| 26 |
<string><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
| 27 |
<html><head><meta name="qrichtext" content="1" /><style type="text/css">
| 28 |
p, li { white-space: pre-wrap; }
| 29 |
</style></head><body style=" font-family:'Lucida Grande'; font-size:13pt; font-weight:400; font-style:normal;">
| 30 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">aim</span> <span style=" font-style:italic;">[ mag [ x y z ] ]</span></p>
| 31 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Zoom in by mag on point x y z . The view point is held constant; only the view direction</p>
| 32 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> and size are changed. If x y z is missing, the cursor is used to select the view center. A</p>
| 33 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> negative magnification factor means zoom out. The default factor is one.</p>
| 34 |
<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"></p>
| 35 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">exposure </span><span style=" font-style:italic;">[ spec ]</span></p>
| 36 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Adjust exposure. The number spec is a multiplier used to compensate the average</p>
| 37 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> exposure. A value of 1 renormalizes the image to the computed average, which is usually</p>
| 38 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> done immediately after startup. If spec begins with a ’+’ or ’-’, the compensation is</p>
| 39 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> interpreted in f-stops (ie. the power of two). If spec begins with an ’=’, an absolute</p>
| 40 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> setting is performed. An ’=’ by itself permits interactive display and setting of the</p>
| 41 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> exposure. If spec begins with an ’@’, the exposure is adjusted to present similar visibility</p>
| 42 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> to what would be experienced in the real environment. If spec is absent, or an ’@’ is</p>
| 43 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> followed by nothing, then the cursor is used to pick a specific image location for</p>
| 44 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> normalization.</p>
| 45 |
| 46 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">focus </span><span style=" font-style:italic;">[ distance ]</span></p>
| 47 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Set focus distance for depth-of-field sampling. If a distance in world coordinates is</p>
| 48 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> absent, then the cursor is used to choose a point in the scene on which to focus. (The</p>
| 49 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> focus distance setting does not affect rendering in <span style=" font-style:italic;">rvu</span>, but can be used in <span style=" font-style:italic;">rpict</span> with the</p>
| 50 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> -pd option to simulate depth-of-field on views saved from <span style=" font-style:italic;">rvu</span>.)</p>
| 51 |
| 52 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">frame </span><span style=" font-style:italic;">[ xmin ymin xmax ymax ]</span></p>
| 53 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Set frame for refinement. If coordinates are absent, the cursor is used to pick frame</p>
| 54 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> boundaries. If ‘‘all’’ is specified, the frame is reset to the entire image.</p>
| 55 |
| 56 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">free</span></p>
| 57 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Free cached object structures and associated data. This command may be useful when</p>
| 58 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> memory is low and a completely different view is being generated from the one previous.</p>
| 59 |
| 60 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">last </span><span style=" font-style:italic;">[ file ]</span></p>
| 61 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Restore the previous view. If a view or picture le is specified, the parameters are taken</p>
| 62 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> from the last view entry in the file.</p>
| 63 |
| 64 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">L</span> <span style=" font-style:italic;">[ vw [ rfile ] ]</span></p>
| 65 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Load parameters for view <span style=" font-style:italic;">vw</span> from the <span style=" font-style:italic;">rad</span> input file, <span style=" font-style:italic;">rfile</span>. Both <span style=" font-style:italic;">vw</span> and <span style=" font-style:italic;">rfile</span> must be given</p>
| 66 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> the first call, but subsequent calls will use the last <span style=" font-style:italic;">rfile</span> as a default, and &quot;1&quot; as the default</p>
| 67 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> view (ie. the first view appearing in <span style=" font-style:italic;">rfile</span>).</p>
| 68 |
| 69 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">move </span><span style=" font-style:italic;">[ mag [ x y z ] ]</span></p>
| 70 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Move camera mag times closer to point x y z . For a perspective projection (or fisheye</p>
| 71 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> view), only the view point is changed; the view direction and size remain constant. The</p>
| 72 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> view size must be modified in a parallel projection since it determines magnification. If</p>
| 73 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> <span style=" font-style:italic;">x y z</span> is missing, the cursor is used to select the view center. A negative magnification</p>
| 74 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> factor decreases the object size. The default factor is one. Care must be taken to avoid</p>
| 75 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> moving behind or inside other objects.</p>
| 76 |
| 77 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">new </span><span style=" font-style:italic;">[ nproc ]</span></p>
| 78 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Restart the image, using the specified number of rendering processes. Usually used after</p>
| 79 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> the &quot;set&quot; command.</p>
| 80 |
| 81 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">pivot </span><span style=" font-style:italic;">angle [ elev [ mag [ x y z ] ] ]</span></p>
| 82 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Similar to the &quot;move&quot; command, but pivots the view about a selected point. The <span style=" font-style:italic;">angle</span> is</p>
| 83 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> measured in degrees around the view up vector using the right hand rule. The optional</p>
| 84 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-style:italic;"> elev</span> is the elevation in degrees from the pivot point; positive raises the view point to look</p>
| 85 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> downward and negative lowers the view point to look upward.</p>
| 86 |
| 87 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">quit</span></p>
| 88 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;"> </span>Quit the program.</p>
| 89 |
| 90 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">^R</span> </p>
| 91 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Redraw the image. Use when the display gets corrupted. On some displays, occassionally</p>
| 92 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> forcing a redraw can improve appearance, as more color information is available and the</p>
| 93 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> driver can make a better color table selection.</p>
| 94 |
| 95 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">rotate </span><span style=" font-style:italic;">angle [ elev [ mag ] ]</span></p>
| 96 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Rotate the camera horizontally by <span style=" font-style:italic;">angle</span> degrees. If an elevation is specified, the camera</p>
| 97 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> looks upward <span style=" font-style:italic;">elev</span> degrees. (Negative means look downward.)</p>
| 98 |
| 99 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">set </span><span style=" font-style:italic;">[ var [ val ] ]</span></p>
| 100 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Check/change program variable. If <span style=" font-style:italic;">var</span> is absent, the list of available variables is</p>
| 101 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> displayed. If <span style=" font-style:italic;">val</span> is absent, the current value of the variable is displayed and changed</p>
| 102 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> interactively. Otherwise, the variable <span style=" font-style:italic;">var</span> assumes the value <span style=" font-style:italic;">val</span>. Variables include:</p>
| 103 |
| 104 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> ambient value (av), ambient value weight (aw), ambient bounces (ab),</p>
| 105 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> ambient accuracy (aa), ambient divisions (ad), ambi- ent radius (ar),</p>
| 106 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> ambient samples (as), black&amp;white (b), back face visibility (bv), direct jitter (dj),</p>
| 107 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> direct sampling (ds), direct threshold (dt), direct visibility (dv), irradiance (i),</p>
| 108 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> limit weight (lw), limit recursion (lr), medium extinction (me), medium albedo (ma),</p>
| 109 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> medium eccentricity (mg), medium sampling (ms), pixel sample (ps), pixel threshold (pt),</p>
| 110 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> specular jitter (sj), specular threshold (st), and uncorrelated sampling (u).</p>
| 111 |
| 112 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Once a variable has been changed, the &quot;new&quot; command can be used to recompute the</p>
| 113 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> image with the new parameters. If a program variable is not available here, it may show</p>
| 114 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> up under some other command or it may be impossible to change once the program is</p>
| 115 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> running.</p>
| 116 |
| 117 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">trace </span><span style=" font-style:italic;">[ xbeg ybeg zbeg xdir ydir zdir ]</span></p>
| 118 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-style:italic;"> </span>Trace a ray. If the ray origin and direction are absent, the cursor is used to pick a location</p>
| 119 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> in the image to trace. The object intersected and its material, location and value are</p>
| 120 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> displayed.</p>
| 121 |
| 122 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">V </span><span style=" font-style:italic;">[ vw [ rfile ] ]</span></p>
| 123 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Append the current view as view <span style=" font-style:italic;">vw</span> in the rad file <span style=" font-style:italic;">rfile</span>. Compliment to <span style=" font-style:italic;">L</span> command. Note</p>
| 124 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> that the view is simply appended to the file, and previous views with the same name</p>
| 125 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> should be removed before using the file with <span style=" font-style:italic;">rad</span>.</p>
| 126 |
| 127 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">write </span><span style=" font-style:italic;">[ file ]</span></p>
| 128 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Write picture to <span style=" font-style:italic;">file</span>. If argument is missing, the current file name is used.</p>
| 129 |
| 130 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">^Z</span></p>
| 131 |
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"> Stop the program. The screen will be redrawn when the program resumes.</p></body></html></string>
| 132 |
</property>
| 133 |
</widget>
| 134 |
</item>
| 135 |
</layout>
| 136 |
</widget>
| 137 |
<resources/>
| 138 |
<connections/>
| 139 |
</ui>
