root/radiance/ray/src/px/xshowtrace.c
Revision: 2.13
Committed: Fri Apr 11 20:27:23 2014 UTC (11 years ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1, rad5R3, HEAD
Changes since 2.12: +2 -6 lines
Made reading of vectors more consistent with FVFORMAT macro
2 static const char RCSid[] = "$Id: xshowtrace.c,v 2.12 2005/07/30 22:02:29 greg Exp $";
5 * Display an image and watch the rays get traced.
6 *
7 * 9/21/90 Greg Ward
8 */
9
10 #include <X11/Xlib.h>
11
12 #include "standard.h"
13 #include "paths.h"
14 #include "view.h"
15
16 #define MAXDEPTH 32 /* ridiculous ray tree depth */
17
18 #define sscanvec(s,v) (sscanf(s,FVFORMAT,v,v+1,v+2)==3)
19
20 char rtcom[64] = "rtrace -h- -otp -fa -x 1";
21 char xicom[] = "ximage -c 256";
22
23 VIEW ourview = STDVIEW; /* view for picture */
24 RESOLU ourres; /* picture resolution */
25
26 char *progname; /* program name */
27
28 char *picture; /* picture name */
29
30 FILE *pin; /* input stream */
31
32 Display *theDisplay = NULL; /* connection to server */
33
34 struct node { /* ray tree node */
35 int ipt[2];
36 struct node *sister;
37 struct node *daughter;
38 };
39
40 #define newnode() (struct node *)calloc(1, sizeof(struct node))
41
42 int slow = 0; /* slow trace? */
43
44 void mainloop(void);
45 static void freetree(struct node *tp);
46 static void tracerays(struct node *tp);
47 static int strtoipt(int ipt[2], char *str);
48 static void setvec(int ipt[2]);
49 static void vector(int ip1[2], int ip2[2]);
50
51
52 int
53 main( /* takes both the octree and the image */
54 int argc,
55 char *argv[]
56 )
57 {
58 int i;
59 char combuf[PATH_MAX];
60
61 progname = argv[0];
62 for (i = 1; i < argc-2; i++)
63 if (!strcmp(argv[i], "-s"))
64 slow++;
65 else if (!strcmp(argv[i], "-T"))
66 strcat(rtcom, " -oTp");
67 else
68 break;
69 if (i > argc-2) {
70 fprintf(stderr, "Usage: %s [-s][-T] [rtrace args] octree picture\n",
71 progname);
72 exit(1);
73 }
74 picture = argv[argc-1];
75 /* get the viewing parameters */
76 if (viewfile(picture, &ourview, &ourres) <= 0 ||
77 setview(&ourview) != NULL) {
78 fprintf(stderr, "%s: cannot get view from \"%s\"\n",
79 progname, picture);
80 exit(1);
81 }
82 /* open the display */
83 if ((theDisplay = XOpenDisplay(NULL)) == NULL) {
84 fprintf(stderr,
85 "%s: cannot open display; DISPLAY variable set?\n",
86 progname);
87 exit(1);
88 }
89 /* build input command */
90 sprintf(combuf, "%s \"%s\" | %s", xicom, picture, rtcom);
91 for ( ; i < argc-1; i++) {
92 strcat(combuf, " ");
93 strcat(combuf, argv[i]);
94 }
95 /* start the damn thing */
96 if ((pin = popen(combuf, "r")) == NULL)
97 exit(1);
98 /* loop on input */
99 mainloop();
100 /* close pipe and exit */
101 pclose(pin);
102 exit(0);
103 }
104
105
106 void
107 mainloop(void) /* get and process input */
108 {
109 static struct node *sis[MAXDEPTH];
110 register struct node *newp;
111 char buf[128];
112 int level;
113 register int i;
114
115 level = 0;
116 while (fgets(buf, sizeof(buf), pin) != NULL) {
117 if ((newp = newnode()) == NULL) {
118 fprintf(stderr, "%s: memory error\n", progname);
119 return;
120 }
121 for (i = 0; buf[i] == '\t'; i++)
122 ;
123 if (strtoipt(newp->ipt, buf+i) < 0) {
124 fprintf(stderr, "%s: bad read\n", progname);
125 return;
126 }
127 newp->sister = sis[i];
128 sis[i] = newp;
129 if (i < level) {
130 newp->daughter = sis[level];
131 sis[level] = NULL;
132 }
133 level = i;
134 if (i == 0) {
135 setvec(sis[0]->ipt);
136 tracerays(sis[0]);
137 freetree(sis[0]);
138 sis[0] = NULL;
139 if (!slow)
140 XFlush(theDisplay);
141 }
142 }
143 }
144
145
146 static void
147 freetree( /* free a trace tree */
148 struct node *tp
149 )
150 {
151 register struct node *kid, *k2;
152
153 for (kid = tp->daughter; kid != NULL; kid = k2) {
154 k2 = kid->sister;
155 freetree(kid);
156 }
157 free((void *)tp);
158 }
159
160
161 static void
162 tracerays( /* trace a ray tree */
163 struct node *tp
164 )
165 {
166 register struct node *kid;
167
168 for (kid = tp->daughter; kid != NULL; kid = kid->sister) {
169 vector(tp->ipt, kid->ipt);
170 tracerays(kid);
171 }
172 }
173
174
175 static int
176 strtoipt( /* convert string x y z to image point */
177 int ipt[2],
178 char *str
179 )
180 {
181 FVECT im_pt, pt;
182
183 if (!sscanvec(str, pt))
184 return(-1);
185 if (DOT(pt,pt) <= FTINY) /* origin is really infinity */
186 ipt[0] = ipt[1] = -1; /* null vector */
187 else {
188 viewloc(im_pt, &ourview, pt);
189 loc2pix(ipt, &ourres, im_pt[0], im_pt[1]);
190 }
191 return(0);
192 }
193
194
195 #define rwind RootWindow(theDisplay,ourScreen)
196 #define ourScreen DefaultScreen(theDisplay)
197
198 GC vecGC = 0;
199 Window gwind = 0;
200 int xoff, yoff;
201
202
203 static void
204 setvec( /* set up vector drawing for pick */
205 int ipt[2]
206 )
207 {
208 extern Window xfindwind();
209 XWindowAttributes wa;
210 XColor xc;
211 XGCValues gcv;
212 int rx, ry, wx, wy;
213 Window rw, cw;
214 unsigned int pm;
215 /* compute pointer location */
216 if (gwind == 0) {
217 register char *wn;
218 for (wn = picture; *wn; wn++);
219 while (wn > picture && wn[-1] != '/') wn--;
220 if ((gwind = xfindwind(theDisplay, rwind, wn, 4)) == 0) {
221 fprintf(stderr, "%s: cannot find display window!\n",
222 progname);
223 exit(1);
224 }
225 }
226 XQueryPointer(theDisplay, gwind, &rw, &cw, &rx, &ry, &wx, &wy, &pm);
227 xoff = wx - ipt[0];
228 yoff = wy - ipt[1];
229 /* set graphics context */
230 if (vecGC == 0) {
231 XGetWindowAttributes(theDisplay, gwind, &wa);
232 xc.red = 65535; xc.green = 0; xc.blue = 0;
233 xc.flags = DoRed|DoGreen|DoBlue;
234 if (XAllocColor(theDisplay, wa.colormap, &xc)) {
235 gcv.foreground = xc.pixel;
236 vecGC = XCreateGC(theDisplay,gwind,GCForeground,&gcv);
237 } else {
238 gcv.function = GXinvert;
239 vecGC = XCreateGC(theDisplay,gwind,GCFunction,&gcv);
240 }
241 }
242 }
243
244
245 static void
246 vector( /* draw a vector */
247 int ip1[2],
248 int ip2[2]
249 )
250 {
251 if (ip2[0] == -1 && ip2[1] == -1)
252 return; /* null vector */
253 XDrawLine(theDisplay, gwind, vecGC,
254 ip1[0]+xoff, ip1[1]+yoff,
255 ip2[0]+xoff, ip2[1]+yoff);
256 if (slow) {
257 XFlush(theDisplay);
258 sleep(1);
259 }
260 }
