root/Development/ray/src/px/xshowtrace.c
Tue Jun 3 21:31:51 2025 UTC (5 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.13: +2 -4 lines
Diff to previous 2.13 , to selected 1.5
Fri Apr 11 20:27:23 2014 UTC (11 years, 7 months ago) by greg
CVS Tags: rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.12: +2 -6 lines
Diff to previous 2.12 , to selected 1.5
Made reading of vectors more consistent with FVFORMAT macro
Sat Jul 30 22:02:29 2005 UTC (20 years, 3 months ago) by greg
Diff to previous 2.11 , to selected 1.5
Fixed usage message
Tue Apr 19 18:44:22 2005 UTC (20 years, 7 months ago) by greg
Diff to previous 2.10 , to selected 1.5
Sun Mar 28 20:33:14 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 2.9: +37 -16 lines
Diff to previous 2.9 , to selected 1.5
Mon Nov 10 12:28:56 2003 UTC (22 years ago) by schorsch
Changes since 2.8: +6 -4 lines
Diff to previous 2.8 , to selected 1.5
Fixed size of command line buffers, and allow spaces in input file paths.
Fri Jun 27 06:53:22 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.7: +4 -2 lines
Diff to previous 2.7 , to selected 1.5
Sat Feb 22 02:07:28 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.6: +2 -6 lines
Diff to previous 2.6 , to selected 1.5
Mon May 3 11:21:30 1993 UTC (32 years, 6 months ago) by greg
Changes since 2.5: +9 -4 lines
Diff to previous 2.5 , to selected 1.5
fixed to work with new window naming in x11image.c
Fri Dec 11 18:28:43 1992 UTC (32 years, 11 months ago) by greg
Diff to previous 2.4 , to selected 1.5
added -c 256 to ximage command to avoid 24-bit mode
Fri Dec 11 18:24:29 1992 UTC (32 years, 11 months ago) by greg
Diff to previous 2.3 , to selected 1.5
deeper search for IRIS 4D window manager
Fri Oct 30 09:54:19 1992 UTC (33 years ago) by greg
Diff to previous 2.2 , to selected 1.5
added pclose() call for nicer exit
Tue Apr 21 17:24:51 1992 UTC (33 years, 7 months ago) by greg
Changes since 2.1: +27 -13 lines
Diff to previous 2.1 , to selected 1.5
fixed bugs resulting from changes to image.c
Tue Nov 12 16:04:29 1991 UTC (34 years ago) by greg
Diff to previous 1.7 , to selected 1.5
Mon Nov 11 14:01:49 1991 UTC (34 years ago) by greg
Changes since 1.6: +5 -3 lines
Diff to previous 1.6 , to selected 1.5
Fri Jul 26 14:14:03 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.5
changed command names and options
Fri May 3 10:22:02 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.4: +13 -10 lines
Diff to previous 1.4
Fri Dec 21 17:24:45 1990 UTC (34 years, 11 months ago) by greg
Changes since 1.3: +3 -2 lines
minor compiler complaints
Mon Sep 24 12:21:06 1990 UTC (35 years, 1 month ago) by greg
added -f option to x11image command
Sat Sep 22 18:53:15 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.1: +17 -5 lines
added -s option to slow trace
Sat Sep 22 10:53:57 1990 UTC (35 years, 2 months ago) by greg
Diff to selected 1.5
