root/Development/ray/src/px/xshowtrace.c
Revision: 2.13
Committed: Fri Apr 11 20:27:23 2014 UTC (11 years, 7 months ago) by greg
CVS Tags: rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2
Changes since 2.12: +2 -6 lines
Made reading of vectors more consistent with FVFORMAT macro
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.13 static const char RCSid[] = "$Id: xshowtrace.c,v 2.12 2005/07/30 22:02:29 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Display an image and watch the rays get traced.
6     *
7     * 9/21/90 Greg Ward
8     */
9
10 schorsch 2.9 #include <X11/Xlib.h>
11
12 greg 1.1 #include "standard.h"
13 schorsch 2.9 #include "paths.h"
14 greg 1.1 #include "view.h"
15
16     #define MAXDEPTH 32 /* ridiculous ray tree depth */
17
18 greg 2.13 #define sscanvec(s,v) (sscanf(s,FVFORMAT,v,v+1,v+2)==3)
19 greg 2.2
20 greg 2.11 char rtcom[64] = "rtrace -h- -otp -fa -x 1";
21 greg 2.5 char xicom[] = "ximage -c 256";
22 greg 1.1
23     VIEW ourview = STDVIEW; /* view for picture */
24 greg 2.2 RESOLU ourres; /* picture resolution */
25 greg 1.1
26     char *progname; /* program name */
27
28 greg 1.5 char *picture; /* picture name */
29
30 greg 1.1 FILE *pin; /* input stream */
31
32     Display *theDisplay = NULL; /* connection to server */
33
34     struct node { /* ray tree node */
35 greg 2.2 int ipt[2];
36 greg 1.1 struct node *sister;
37     struct node *daughter;
38     };
39
40     #define newnode() (struct node *)calloc(1, sizeof(struct node))
41
42 greg 1.2 int slow = 0; /* slow trace? */
43 greg 1.1
44 schorsch 2.10 void mainloop(void);
45     static void freetree(struct node *tp);
46     static void tracerays(struct node *tp);
47     static int strtoipt(int ipt[2], char *str);
48     static void setvec(int ipt[2]);
49     static void vector(int ip1[2], int ip2[2]);
50 greg 1.2
51 schorsch 2.10
52     int
53     main( /* takes both the octree and the image */
54     int argc,
55     char *argv[]
56     )
57 greg 1.1 {
58     int i;
59 schorsch 2.9 char combuf[PATH_MAX];
60 greg 1.1
61     progname = argv[0];
62 greg 1.2 for (i = 1; i < argc-2; i++)
63     if (!strcmp(argv[i], "-s"))
64     slow++;
65 greg 2.11 else if (!strcmp(argv[i], "-T"))
66     strcat(rtcom, " -oTp");
67 greg 1.2 else
68     break;
69     if (i > argc-2) {
70 greg 2.12 fprintf(stderr, "Usage: %s [-s][-T] [rtrace args] octree picture\n",
71 greg 1.5 progname);
72 greg 1.1 exit(1);
73     }
74 greg 1.5 picture = argv[argc-1];
75 greg 1.1 /* get the viewing parameters */
76 greg 2.2 if (viewfile(picture, &ourview, &ourres) <= 0 ||
77 greg 1.1 setview(&ourview) != NULL) {
78     fprintf(stderr, "%s: cannot get view from \"%s\"\n",
79 greg 1.5 progname, picture);
80 greg 1.1 exit(1);
81     }
82     /* open the display */
83     if ((theDisplay = XOpenDisplay(NULL)) == NULL) {
84     fprintf(stderr,
85     "%s: cannot open display; DISPLAY variable set?\n",
86 greg 1.5 progname);
87 greg 1.1 exit(1);
88     }
89     /* build input command */
90 schorsch 2.9 sprintf(combuf, "%s \"%s\" | %s", xicom, picture, rtcom);
91 greg 1.2 for ( ; i < argc-1; i++) {
92 greg 1.1 strcat(combuf, " ");
93     strcat(combuf, argv[i]);
94     }
95     /* start the damn thing */
96     if ((pin = popen(combuf, "r")) == NULL)
97     exit(1);
98     /* loop on input */
99     mainloop();
100 greg 2.3 /* close pipe and exit */
101     pclose(pin);
102 greg 1.1 exit(0);
103     }
104
105
106 schorsch 2.10 void
107     mainloop(void) /* get and process input */
108 greg 1.1 {
109     static struct node *sis[MAXDEPTH];
110     register struct node *newp;
111     char buf[128];
112     int level;
113     register int i;
114
115     level = 0;
116     while (fgets(buf, sizeof(buf), pin) != NULL) {
117     if ((newp = newnode()) == NULL) {
118     fprintf(stderr, "%s: memory error\n", progname);
119     return;
120     }
121     for (i = 0; buf[i] == '\t'; i++)
122     ;
123     if (strtoipt(newp->ipt, buf+i) < 0) {
124     fprintf(stderr, "%s: bad read\n", progname);
125     return;
126     }
127     newp->sister = sis[i];
128     sis[i] = newp;
129     if (i < level) {
130     newp->daughter = sis[level];
131     sis[level] = NULL;
132     }
133     level = i;
134     if (i == 0) {
135     setvec(sis[0]->ipt);
136     tracerays(sis[0]);
137     freetree(sis[0]);
138     sis[0] = NULL;
139 greg 1.2 if (!slow)
140     XFlush(theDisplay);
141 greg 1.1 }
142     }
143     }
144
145
146 schorsch 2.10 static void
147     freetree( /* free a trace tree */
148     struct node *tp
149     )
150 greg 1.1 {
151 greg 2.8 register struct node *kid, *k2;
152 greg 1.1
153 greg 2.8 for (kid = tp->daughter; kid != NULL; kid = k2) {
154     k2 = kid->sister;
155 greg 1.1 freetree(kid);
156 greg 2.8 }
157 greg 2.7 free((void *)tp);
158 greg 1.1 }
159
160
161 schorsch 2.10 static void
162     tracerays( /* trace a ray tree */
163     struct node *tp
164     )
165 greg 1.1 {
166     register struct node *kid;
167
168     for (kid = tp->daughter; kid != NULL; kid = kid->sister) {
169 greg 1.2 vector(tp->ipt, kid->ipt);
170 greg 1.1 tracerays(kid);
171     }
172     }
173
174
175 schorsch 2.10 static int
176     strtoipt( /* convert string x y z to image point */
177     int ipt[2],
178     char *str
179     )
180 greg 1.1 {
181 greg 2.2 FVECT im_pt, pt;
182 greg 1.1
183 greg 2.2 if (!sscanvec(str, pt))
184 greg 1.1 return(-1);
185 greg 2.2 if (DOT(pt,pt) <= FTINY) /* origin is really infinity */
186     ipt[0] = ipt[1] = -1; /* null vector */
187     else {
188     viewloc(im_pt, &ourview, pt);
189     loc2pix(ipt, &ourres, im_pt[0], im_pt[1]);
190     }
191 greg 1.1 return(0);
192     }
193
194
195     #define rwind RootWindow(theDisplay,ourScreen)
196     #define ourScreen DefaultScreen(theDisplay)
197
198     GC vecGC = 0;
199     Window gwind = 0;
200     int xoff, yoff;
201
202
203 schorsch 2.10 static void
204     setvec( /* set up vector drawing for pick */
205     int ipt[2]
206     )
207 greg 1.1 {
208 greg 2.4 extern Window xfindwind();
209 greg 1.1 XWindowAttributes wa;
210     XColor xc;
211     XGCValues gcv;
212 greg 1.4 int rx, ry, wx, wy;
213     Window rw, cw;
214     unsigned int pm;
215 greg 1.1 /* compute pointer location */
216 greg 2.6 if (gwind == 0) {
217     register char *wn;
218     for (wn = picture; *wn; wn++);
219     while (wn > picture && wn[-1] != '/') wn--;
220     if ((gwind = xfindwind(theDisplay, rwind, wn, 4)) == 0) {
221     fprintf(stderr, "%s: cannot find display window!\n",
222     progname);
223     exit(1);
224     }
225 greg 1.1 }
226 greg 1.5 XQueryPointer(theDisplay, gwind, &rw, &cw, &rx, &ry, &wx, &wy, &pm);
227 greg 2.2 xoff = wx - ipt[0];
228     yoff = wy - ipt[1];
229 greg 1.1 /* set graphics context */
230     if (vecGC == 0) {
231     XGetWindowAttributes(theDisplay, gwind, &wa);
232     xc.red = 65535; xc.green = 0; xc.blue = 0;
233     xc.flags = DoRed|DoGreen|DoBlue;
234     if (XAllocColor(theDisplay, wa.colormap, &xc)) {
235     gcv.foreground = xc.pixel;
236     vecGC = XCreateGC(theDisplay,gwind,GCForeground,&gcv);
237     } else {
238     gcv.function = GXinvert;
239     vecGC = XCreateGC(theDisplay,gwind,GCFunction,&gcv);
240     }
241     }
242     }
243
244
245 schorsch 2.10 static void
246     vector( /* draw a vector */
247     int ip1[2],
248     int ip2[2]
249     )
250 greg 1.1 {
251 greg 2.2 if (ip2[0] == -1 && ip2[1] == -1)
252     return; /* null vector */
253 greg 1.1 XDrawLine(theDisplay, gwind, vecGC,
254 greg 2.2 ip1[0]+xoff, ip1[1]+yoff,
255     ip2[0]+xoff, ip2[1]+yoff);
256 greg 1.2 if (slow) {
257     XFlush(theDisplay);
258     sleep(1);
259     }
260 greg 1.1 }
