root/radiance/ray/src/px/xshowtrace.c
Fri Apr 11 20:27:23 2014 UTC (10 years ago) by greg
Changes since 2.12: +2 -6 lines
Made reading of vectors more consistent with FVFORMAT macro
Sat Jul 30 22:02:29 2005 UTC (18 years, 9 months ago) by greg
Fixed usage message
Tue Apr 19 18:44:22 2005 UTC (19 years ago) by greg
Changes since 2.9: +37 -16 lines
Mon Nov 10 12:28:56 2003 UTC (20 years, 5 months ago) by schorsch
Changes since 2.8: +6 -4 lines
Fixed size of command line buffers, and allow spaces in input file paths.
Changes since 2.7: +4 -2 lines
Changes since 2.6: +2 -6 lines
Mon May 3 11:21:30 1993 UTC (31 years ago) by greg
Changes since 2.5: +9 -4 lines
fixed to work with new window naming in x11image.c
Fri Dec 11 18:28:43 1992 UTC (31 years, 4 months ago) by greg
added -c 256 to ximage command to avoid 24-bit mode
Fri Dec 11 18:24:29 1992 UTC (31 years, 4 months ago) by greg
deeper search for IRIS 4D window manager
Fri Oct 30 09:54:19 1992 UTC (31 years, 6 months ago) by greg
added pclose() call for nicer exit
Tue Apr 21 17:24:51 1992 UTC (32 years ago) by greg
Changes since 2.1: +27 -13 lines
fixed bugs resulting from changes to image.c
Tue Nov 12 16:04:29 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.7 , to selected 2.10
Mon Nov 11 14:01:49 1991 UTC (32 years, 5 months ago) by greg
Changes since 1.6: +5 -3 lines
Diff to previous 1.6 , to selected 2.10
Fri Jul 26 14:14:03 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.5 , to selected 2.10
changed command names and options
Fri May 3 10:22:02 1991 UTC (33 years ago) by greg
Changes since 1.4: +13 -10 lines
Diff to previous 1.4 , to selected 2.10
Fri Dec 21 17:24:45 1990 UTC (33 years, 4 months ago) by greg
Changes since 1.3: +3 -2 lines
Diff to previous 1.3 , to selected 2.10
minor compiler complaints
Mon Sep 24 12:21:06 1990 UTC (33 years, 7 months ago) by greg
Diff to previous 1.2 , to selected 2.10
added -f option to x11image command
Sat Sep 22 18:53:15 1990 UTC (33 years, 7 months ago) by greg
Changes since 1.1: +17 -5 lines
Diff to previous 1.1 , to selected 2.10
added -s option to slow trace
Sat Sep 22 10:53:57 1990 UTC (33 years, 7 months ago) by greg
Diff to selected 2.10
