--- ray/src/px/xshowtrace.c 1991/11/12 16:04:29 2.1 +++ ray/src/px/xshowtrace.c 1993/05/03 11:21:30 2.6 @@ -12,15 +12,22 @@ static char SCCSid[] = "$SunId$ LBL"; #include "standard.h" #include "view.h" +#include "resolu.h" #include #define MAXDEPTH 32 /* ridiculous ray tree depth */ +#ifdef SMLFLT +#define sscanvec(s,v) (sscanf(s,"%f %f %f",v,v+1,v+2)==3) +#else +#define sscanvec(s,v) (sscanf(s,"%lf %lf %lf",v,v+1,v+2)==3) +#endif + char rtcom[] = "rtrace -h- -otp -fa -x 1"; -char xicom[] = "ximage"; +char xicom[] = "ximage -c 256"; VIEW ourview = STDVIEW; /* view for picture */ -int xres, yres; +RESOLU ourres; /* picture resolution */ char *progname; /* program name */ @@ -31,7 +38,7 @@ FILE *pin; /* input stream */ Display *theDisplay = NULL; /* connection to server */ struct node { /* ray tree node */ - FVECT ipt; + int ipt[2]; struct node *sister; struct node *daughter; }; @@ -61,7 +68,7 @@ char *argv[]; } picture = argv[argc-1]; /* get the viewing parameters */ - if (viewfile(picture, &ourview, &xres, &yres) <= 0 || + if (viewfile(picture, &ourview, &ourres) <= 0 || setview(&ourview) != NULL) { fprintf(stderr, "%s: cannot get view from \"%s\"\n", progname, picture); @@ -85,7 +92,8 @@ char *argv[]; exit(1); /* loop on input */ mainloop(); - + /* close pipe and exit */ + pclose(pin); exit(0); } @@ -153,14 +161,19 @@ struct node *tp; strtoipt(ipt, str) /* convert string x y z to image point */ -FVECT ipt; +int ipt[2]; char *str; { - FVECT pt; + FVECT im_pt, pt; - if (sscanf(str, "%lf %lf %lf", &pt[0], &pt[1], &pt[2]) != 3) + if (!sscanvec(str, pt)) return(-1); - viewloc(ipt, &ourview, pt); + if (DOT(pt,pt) <= FTINY) /* origin is really infinity */ + ipt[0] = ipt[1] = -1; /* null vector */ + else { + viewloc(im_pt, &ourview, pt); + loc2pix(ipt, &ourres, im_pt[0], im_pt[1]); + } return(0); } @@ -174,8 +187,9 @@ int xoff, yoff; setvec(ipt) /* set up vector drawing for pick */ -double ipt[2]; +int ipt[2]; { + extern Window xfindwind(); XWindowAttributes wa; XColor xc; XGCValues gcv; @@ -183,14 +197,19 @@ double ipt[2]; Window rw, cw; unsigned int pm; /* compute pointer location */ - if (gwind == 0 && - (gwind = xfindwind(theDisplay, rwind, picture, 2)) == 0) { - fprintf(stderr, "%s: cannot find display window!\n", progname); - exit(1); + if (gwind == 0) { + register char *wn; + for (wn = picture; *wn; wn++); + while (wn > picture && wn[-1] != '/') wn--; + if ((gwind = xfindwind(theDisplay, rwind, wn, 4)) == 0) { + fprintf(stderr, "%s: cannot find display window!\n", + progname); + exit(1); + } } XQueryPointer(theDisplay, gwind, &rw, &cw, &rx, &ry, &wx, &wy, &pm); - xoff = wx - ipt[0]*xres; - yoff = wy - (1.-ipt[1])*yres; + xoff = wx - ipt[0]; + yoff = wy - ipt[1]; /* set graphics context */ if (vecGC == 0) { XGetWindowAttributes(theDisplay, gwind, &wa); @@ -208,11 +227,13 @@ double ipt[2]; vector(ip1, ip2) /* draw a vector */ -double ip1[2], ip2[2]; +int ip1[2], ip2[2]; { + if (ip2[0] == -1 && ip2[1] == -1) + return; /* null vector */ XDrawLine(theDisplay, gwind, vecGC, - (int)(ip1[0]*xres)+xoff, (int)((1.-ip1[1])*yres)+yoff, - (int)(ip2[0]*xres)+xoff, (int)((1.-ip2[1])*yres)+yoff); + ip1[0]+xoff, ip1[1]+yoff, + ip2[0]+xoff, ip2[1]+yoff); if (slow) { XFlush(theDisplay); sleep(1);
