root/radiance/ray/src/px/xshowtrace.c
Revision: 2.7
Committed: Sat Feb 22 02:07:28 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.6: +2 -6 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.7 static const char RCSid[] = "$Id$";
3 greg 1.1 #endif
4     /*
5     * Display an image and watch the rays get traced.
6     *
7     * 9/21/90 Greg Ward
8     */
9
10     #include "standard.h"
11     #include "view.h"
12     #include <X11/Xlib.h>
13
14     #define MAXDEPTH 32 /* ridiculous ray tree depth */
15
16 greg 2.2 #ifdef SMLFLT
17     #define sscanvec(s,v) (sscanf(s,"%f %f %f",v,v+1,v+2)==3)
18     #else
19     #define sscanvec(s,v) (sscanf(s,"%lf %lf %lf",v,v+1,v+2)==3)
20     #endif
21
22 greg 1.6 char rtcom[] = "rtrace -h- -otp -fa -x 1";
23 greg 2.5 char xicom[] = "ximage -c 256";
24 greg 1.1
25     VIEW ourview = STDVIEW; /* view for picture */
26 greg 2.2 RESOLU ourres; /* picture resolution */
27 greg 1.1
28     char *progname; /* program name */
29
30 greg 1.5 char *picture; /* picture name */
31
32 greg 1.1 FILE *pin; /* input stream */
33
34     Display *theDisplay = NULL; /* connection to server */
35
36     struct node { /* ray tree node */
37 greg 2.2 int ipt[2];
38 greg 1.1 struct node *sister;
39     struct node *daughter;
40     };
41
42     #define newnode() (struct node *)calloc(1, sizeof(struct node))
43
44 greg 1.2 int slow = 0; /* slow trace? */
45 greg 1.1
46 greg 1.2
47 greg 1.1 main(argc, argv) /* takes both the octree and the image */
48     int argc;
49     char *argv[];
50     {
51     int i;
52     char combuf[256];
53
54     progname = argv[0];
55 greg 1.2 for (i = 1; i < argc-2; i++)
56     if (!strcmp(argv[i], "-s"))
57     slow++;
58     else
59     break;
60     if (i > argc-2) {
61     fprintf(stderr, "Usage: %s [-s] [rtrace args] octree picture\n",
62 greg 1.5 progname);
63 greg 1.1 exit(1);
64     }
65 greg 1.5 picture = argv[argc-1];
66 greg 1.1 /* get the viewing parameters */
67 greg 2.2 if (viewfile(picture, &ourview, &ourres) <= 0 ||
68 greg 1.1 setview(&ourview) != NULL) {
69     fprintf(stderr, "%s: cannot get view from \"%s\"\n",
70 greg 1.5 progname, picture);
71 greg 1.1 exit(1);
72     }
73     /* open the display */
74     if ((theDisplay = XOpenDisplay(NULL)) == NULL) {
75     fprintf(stderr,
76     "%s: cannot open display; DISPLAY variable set?\n",
77 greg 1.5 progname);
78 greg 1.1 exit(1);
79     }
80     /* build input command */
81 greg 1.5 sprintf(combuf, "%s %s | %s", xicom, picture, rtcom);
82 greg 1.2 for ( ; i < argc-1; i++) {
83 greg 1.1 strcat(combuf, " ");
84     strcat(combuf, argv[i]);
85     }
86     /* start the damn thing */
87     if ((pin = popen(combuf, "r")) == NULL)
88     exit(1);
89     /* loop on input */
90     mainloop();
91 greg 2.3 /* close pipe and exit */
92     pclose(pin);
93 greg 1.1 exit(0);
94     }
95
96
97     mainloop() /* get and process input */
98     {
99     static struct node *sis[MAXDEPTH];
100     register struct node *newp;
101     char buf[128];
102     int level;
103     register int i;
104
105     level = 0;
106     while (fgets(buf, sizeof(buf), pin) != NULL) {
107     if ((newp = newnode()) == NULL) {
108     fprintf(stderr, "%s: memory error\n", progname);
109     return;
110     }
111     for (i = 0; buf[i] == '\t'; i++)
112     ;
113     if (strtoipt(newp->ipt, buf+i) < 0) {
114     fprintf(stderr, "%s: bad read\n", progname);
115     return;
116     }
117     newp->sister = sis[i];
118     sis[i] = newp;
119     if (i < level) {
120     newp->daughter = sis[level];
121     sis[level] = NULL;
122     }
123     level = i;
124     if (i == 0) {
125     setvec(sis[0]->ipt);
126     tracerays(sis[0]);
127     freetree(sis[0]);
128     sis[0] = NULL;
129 greg 1.2 if (!slow)
130     XFlush(theDisplay);
131 greg 1.1 }
132     }
133     }
134
135
136     freetree(tp) /* free a trace tree */
137     struct node *tp;
138     {
139     register struct node *kid;
140
141     for (kid = tp->daughter; kid != NULL; kid = kid->sister)
142     freetree(kid);
143 greg 2.7 free((void *)tp);
144 greg 1.1 }
145
146
147     tracerays(tp) /* trace a ray tree */
148     struct node *tp;
149     {
150     register struct node *kid;
151
152     for (kid = tp->daughter; kid != NULL; kid = kid->sister) {
153 greg 1.2 vector(tp->ipt, kid->ipt);
154 greg 1.1 tracerays(kid);
155     }
156     }
157
158
159     strtoipt(ipt, str) /* convert string x y z to image point */
160 greg 2.2 int ipt[2];
161 greg 1.1 char *str;
162     {
163 greg 2.2 FVECT im_pt, pt;
164 greg 1.1
165 greg 2.2 if (!sscanvec(str, pt))
166 greg 1.1 return(-1);
167 greg 2.2 if (DOT(pt,pt) <= FTINY) /* origin is really infinity */
168     ipt[0] = ipt[1] = -1; /* null vector */
169     else {
170     viewloc(im_pt, &ourview, pt);
171     loc2pix(ipt, &ourres, im_pt[0], im_pt[1]);
172     }
173 greg 1.1 return(0);
174     }
175
176
177     #define rwind RootWindow(theDisplay,ourScreen)
178     #define ourScreen DefaultScreen(theDisplay)
179
180     GC vecGC = 0;
181     Window gwind = 0;
182     int xoff, yoff;
183
184
185     setvec(ipt) /* set up vector drawing for pick */
186 greg 2.2 int ipt[2];
187 greg 1.1 {
188 greg 2.4 extern Window xfindwind();
189 greg 1.1 XWindowAttributes wa;
190     XColor xc;
191     XGCValues gcv;
192 greg 1.4 int rx, ry, wx, wy;
193     Window rw, cw;
194     unsigned int pm;
195 greg 1.1 /* compute pointer location */
196 greg 2.6 if (gwind == 0) {
197     register char *wn;
198     for (wn = picture; *wn; wn++);
199     while (wn > picture && wn[-1] != '/') wn--;
200     if ((gwind = xfindwind(theDisplay, rwind, wn, 4)) == 0) {
201     fprintf(stderr, "%s: cannot find display window!\n",
202     progname);
203     exit(1);
204     }
205 greg 1.1 }
206 greg 1.5 XQueryPointer(theDisplay, gwind, &rw, &cw, &rx, &ry, &wx, &wy, &pm);
207 greg 2.2 xoff = wx - ipt[0];
208     yoff = wy - ipt[1];
209 greg 1.1 /* set graphics context */
210     if (vecGC == 0) {
211     XGetWindowAttributes(theDisplay, gwind, &wa);
212     xc.red = 65535; xc.green = 0; xc.blue = 0;
213     xc.flags = DoRed|DoGreen|DoBlue;
214     if (XAllocColor(theDisplay, wa.colormap, &xc)) {
215     gcv.foreground = xc.pixel;
216     vecGC = XCreateGC(theDisplay,gwind,GCForeground,&gcv);
217     } else {
218     gcv.function = GXinvert;
219     vecGC = XCreateGC(theDisplay,gwind,GCFunction,&gcv);
220     }
221     }
222     }
223
224
225     vector(ip1, ip2) /* draw a vector */
226 greg 2.2 int ip1[2], ip2[2];
227 greg 1.1 {
228 greg 2.2 if (ip2[0] == -1 && ip2[1] == -1)
229     return; /* null vector */
230 greg 1.1 XDrawLine(theDisplay, gwind, vecGC,
231 greg 2.2 ip1[0]+xoff, ip1[1]+yoff,
232     ip2[0]+xoff, ip2[1]+yoff);
233 greg 1.2 if (slow) {
234     XFlush(theDisplay);
235     sleep(1);
236     }
237 greg 1.1 }
