root/radiance/ray/src/px/xshowtrace.c
Revision: 1.5
Committed: Fri May 3 10:22:02 1991 UTC (34 years ago) by greg
Changes since 1.4: +13 -10 lines
2 static char SCCSid[] = "$SunId$ LBL";
4
5 /*
6 * Display an image and watch the rays get traced.
7 *
8 * 9/21/90 Greg Ward
9 */
10
11 #include "standard.h"
12 #include "view.h"
13 #include <X11/Xlib.h>
14
15 #define MAXDEPTH 32 /* ridiculous ray tree depth */
16
17 char rtcom[] = "rtrace -h -otp -fa -x 1";
18 char xicom[] = "x11image -f";
19
20 VIEW ourview = STDVIEW; /* view for picture */
21 int xres, yres;
22
23 char *progname; /* program name */
24
25 char *picture; /* picture name */
26
27 FILE *pin; /* input stream */
28
29 Display *theDisplay = NULL; /* connection to server */
30
31 struct node { /* ray tree node */
32 double ipt[2];
33 struct node *sister;
34 struct node *daughter;
35 };
36
37 #define newnode() (struct node *)calloc(1, sizeof(struct node))
38
39 int slow = 0; /* slow trace? */
40
41
42 main(argc, argv) /* takes both the octree and the image */
43 int argc;
44 char *argv[];
45 {
46 int i;
47 char combuf[256];
48
49 progname = argv[0];
50 for (i = 1; i < argc-2; i++)
51 if (!strcmp(argv[i], "-s"))
52 slow++;
53 else
54 break;
55 if (i > argc-2) {
56 fprintf(stderr, "Usage: %s [-s] [rtrace args] octree picture\n",
57 progname);
58 exit(1);
59 }
60 picture = argv[argc-1];
61 /* get the viewing parameters */
62 if (viewfile(picture, &ourview, &xres, &yres) <= 0 ||
63 setview(&ourview) != NULL) {
64 fprintf(stderr, "%s: cannot get view from \"%s\"\n",
65 progname, picture);
66 exit(1);
67 }
68 /* open the display */
69 if ((theDisplay = XOpenDisplay(NULL)) == NULL) {
70 fprintf(stderr,
71 "%s: cannot open display; DISPLAY variable set?\n",
72 progname);
73 exit(1);
74 }
75 /* build input command */
76 sprintf(combuf, "%s %s | %s", xicom, picture, rtcom);
77 for ( ; i < argc-1; i++) {
78 strcat(combuf, " ");
79 strcat(combuf, argv[i]);
80 }
81 /* start the damn thing */
82 if ((pin = popen(combuf, "r")) == NULL)
83 exit(1);
84 /* loop on input */
85 mainloop();
86
87 exit(0);
88 }
89
90
91 mainloop() /* get and process input */
92 {
93 static struct node *sis[MAXDEPTH];
94 register struct node *newp;
95 char buf[128];
96 int level;
97 register int i;
98
99 level = 0;
100 while (fgets(buf, sizeof(buf), pin) != NULL) {
101 if ((newp = newnode()) == NULL) {
102 fprintf(stderr, "%s: memory error\n", progname);
103 return;
104 }
105 for (i = 0; buf[i] == '\t'; i++)
106 ;
107 if (strtoipt(newp->ipt, buf+i) < 0) {
108 fprintf(stderr, "%s: bad read\n", progname);
109 return;
110 }
111 newp->sister = sis[i];
112 sis[i] = newp;
113 if (i < level) {
114 newp->daughter = sis[level];
115 sis[level] = NULL;
116 }
117 level = i;
118 if (i == 0) {
119 setvec(sis[0]->ipt);
120 tracerays(sis[0]);
121 freetree(sis[0]);
122 sis[0] = NULL;
123 if (!slow)
124 XFlush(theDisplay);
125 }
126 }
127 }
128
129
130 freetree(tp) /* free a trace tree */
131 struct node *tp;
132 {
133 register struct node *kid;
134
135 for (kid = tp->daughter; kid != NULL; kid = kid->sister)
136 freetree(kid);
137 free((char *)tp);
138 }
139
140
141 tracerays(tp) /* trace a ray tree */
142 struct node *tp;
143 {
144 register struct node *kid;
145
146 for (kid = tp->daughter; kid != NULL; kid = kid->sister) {
147 vector(tp->ipt, kid->ipt);
148 tracerays(kid);
149 }
150 }
151
152
153 strtoipt(ipt, str) /* convert string x y z to image point */
154 double ipt[2];
155 char *str;
156 {
157 FVECT pt;
158
159 if (sscanf(str, "%lf %lf %lf", &pt[0], &pt[1], &pt[2]) != 3)
160 return(-1);
161 viewpixel(&ipt[0], &ipt[1], NULL, &ourview, pt);
162 return(0);
163 }
164
165
166 #define rwind RootWindow(theDisplay,ourScreen)
167 #define ourScreen DefaultScreen(theDisplay)
168
169 GC vecGC = 0;
170 Window gwind = 0;
171 int xoff, yoff;
172
173
174 setvec(ipt) /* set up vector drawing for pick */
175 double ipt[2];
176 {
177 XWindowAttributes wa;
178 XColor xc;
179 XGCValues gcv;
180 int rx, ry, wx, wy;
181 Window rw, cw;
182 unsigned int pm;
183 /* compute pointer location */
184 if (gwind == 0 &&
185 (gwind = xfindwind(theDisplay, rwind, picture, 2)) == 0) {
186 fprintf(stderr, "%s: cannot find display window!\n", progname);
187 exit(1);
188 }
189 XQueryPointer(theDisplay, gwind, &rw, &cw, &rx, &ry, &wx, &wy, &pm);
190 xoff = wx - ipt[0]*xres;
191 yoff = wy - (1.-ipt[1])*yres;
192 /* set graphics context */
193 if (vecGC == 0) {
194 XGetWindowAttributes(theDisplay, gwind, &wa);
195 xc.red = 65535; xc.green = 0; xc.blue = 0;
196 xc.flags = DoRed|DoGreen|DoBlue;
197 if (XAllocColor(theDisplay, wa.colormap, &xc)) {
198 gcv.foreground = xc.pixel;
199 vecGC = XCreateGC(theDisplay,gwind,GCForeground,&gcv);
200 } else {
201 gcv.function = GXinvert;
202 vecGC = XCreateGC(theDisplay,gwind,GCFunction,&gcv);
203 }
204 }
205 }
206
207
208 vector(ip1, ip2) /* draw a vector */
209 double ip1[2], ip2[2];
210 {
211 XDrawLine(theDisplay, gwind, vecGC,
212 (int)(ip1[0]*xres)+xoff, (int)((1.-ip1[1])*yres)+yoff,
213 (int)(ip2[0]*xres)+xoff, (int)((1.-ip2[1])*yres)+yoff);
214 if (slow) {
215 XFlush(theDisplay);
216 sleep(1);
217 }
218 }
