root/radiance/ray/src/px/xshowtrace.c
Revision: 2.14
Committed: Tue Jun 3 21:31:51 2025 UTC (6 weeks, 6 days ago) by greg
Changes since 2.13: +2 -4 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.14 static const char RCSid[] = "$Id: xshowtrace.c,v 2.13 2014/04/11 20:27:23 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Display an image and watch the rays get traced.
6     *
7     * 9/21/90 Greg Ward
8     */
9
10 schorsch 2.9 #include <X11/Xlib.h>
11
12 greg 1.1 #include "standard.h"
13 schorsch 2.9 #include "paths.h"
14 greg 1.1 #include "view.h"
15
16     #define MAXDEPTH 32 /* ridiculous ray tree depth */
17
18 greg 2.13 #define sscanvec(s,v) (sscanf(s,FVFORMAT,v,v+1,v+2)==3)
19 greg 2.2
20 greg 2.11 char rtcom[64] = "rtrace -h- -otp -fa -x 1";
21 greg 2.5 char xicom[] = "ximage -c 256";
22 greg 1.1
23     VIEW ourview = STDVIEW; /* view for picture */
24 greg 2.2 RESOLU ourres; /* picture resolution */
25 greg 1.1
26 greg 1.5 char *picture; /* picture name */
27
28 greg 1.1 FILE *pin; /* input stream */
29
30     Display *theDisplay = NULL; /* connection to server */
31
32     struct node { /* ray tree node */
33 greg 2.2 int ipt[2];
34 greg 1.1 struct node *sister;
35     struct node *daughter;
36     };
37
38     #define newnode() (struct node *)calloc(1, sizeof(struct node))
39
40 greg 1.2 int slow = 0; /* slow trace? */
41 greg 1.1
42 schorsch 2.10 void mainloop(void);
43     static void freetree(struct node *tp);
44     static void tracerays(struct node *tp);
45     static int strtoipt(int ipt[2], char *str);
46     static void setvec(int ipt[2]);
47     static void vector(int ip1[2], int ip2[2]);
48 greg 1.2
49 schorsch 2.10
50     int
51     main( /* takes both the octree and the image */
52     int argc,
53     char *argv[]
54     )
55 greg 1.1 {
56     int i;
57 schorsch 2.9 char combuf[PATH_MAX];
58 greg 1.1
59 greg 2.14 fixargv0(argv[0]); /* sets global progname */
60 greg 1.2 for (i = 1; i < argc-2; i++)
61     if (!strcmp(argv[i], "-s"))
62     slow++;
63 greg 2.11 else if (!strcmp(argv[i], "-T"))
64     strcat(rtcom, " -oTp");
65 greg 1.2 else
66     break;
67     if (i > argc-2) {
68 greg 2.12 fprintf(stderr, "Usage: %s [-s][-T] [rtrace args] octree picture\n",
69 greg 1.5 progname);
70 greg 1.1 exit(1);
71     }
72 greg 1.5 picture = argv[argc-1];
73 greg 1.1 /* get the viewing parameters */
74 greg 2.2 if (viewfile(picture, &ourview, &ourres) <= 0 ||
75 greg 1.1 setview(&ourview) != NULL) {
76     fprintf(stderr, "%s: cannot get view from \"%s\"\n",
77 greg 1.5 progname, picture);
78 greg 1.1 exit(1);
79     }
80     /* open the display */
81     if ((theDisplay = XOpenDisplay(NULL)) == NULL) {
82     fprintf(stderr,
83     "%s: cannot open display; DISPLAY variable set?\n",
84 greg 1.5 progname);
85 greg 1.1 exit(1);
86     }
87     /* build input command */
88 schorsch 2.9 sprintf(combuf, "%s \"%s\" | %s", xicom, picture, rtcom);
89 greg 1.2 for ( ; i < argc-1; i++) {
90 greg 1.1 strcat(combuf, " ");
91     strcat(combuf, argv[i]);
92     }
93     /* start the damn thing */
94     if ((pin = popen(combuf, "r")) == NULL)
95     exit(1);
96     /* loop on input */
97     mainloop();
98 greg 2.3 /* close pipe and exit */
99     pclose(pin);
100 greg 1.1 exit(0);
101     }
102
103
104 schorsch 2.10 void
105     mainloop(void) /* get and process input */
106 greg 1.1 {
107     static struct node *sis[MAXDEPTH];
108     register struct node *newp;
109     char buf[128];
110     int level;
111     register int i;
112
113     level = 0;
114     while (fgets(buf, sizeof(buf), pin) != NULL) {
115     if ((newp = newnode()) == NULL) {
116     fprintf(stderr, "%s: memory error\n", progname);
117     return;
118     }
119     for (i = 0; buf[i] == '\t'; i++)
120     ;
121     if (strtoipt(newp->ipt, buf+i) < 0) {
122     fprintf(stderr, "%s: bad read\n", progname);
123     return;
124     }
125     newp->sister = sis[i];
126     sis[i] = newp;
127     if (i < level) {
128     newp->daughter = sis[level];
129     sis[level] = NULL;
130     }
131     level = i;
132     if (i == 0) {
133     setvec(sis[0]->ipt);
134     tracerays(sis[0]);
135     freetree(sis[0]);
136     sis[0] = NULL;
137 greg 1.2 if (!slow)
138     XFlush(theDisplay);
139 greg 1.1 }
140     }
141     }
142
143
144 schorsch 2.10 static void
145     freetree( /* free a trace tree */
146     struct node *tp
147     )
148 greg 1.1 {
149 greg 2.8 register struct node *kid, *k2;
150 greg 1.1
151 greg 2.8 for (kid = tp->daughter; kid != NULL; kid = k2) {
152     k2 = kid->sister;
153 greg 1.1 freetree(kid);
154 greg 2.8 }
155 greg 2.7 free((void *)tp);
156 greg 1.1 }
157
158
159 schorsch 2.10 static void
160     tracerays( /* trace a ray tree */
161     struct node *tp
162     )
163 greg 1.1 {
164     register struct node *kid;
165
166     for (kid = tp->daughter; kid != NULL; kid = kid->sister) {
167 greg 1.2 vector(tp->ipt, kid->ipt);
168 greg 1.1 tracerays(kid);
169     }
170     }
171
172
173 schorsch 2.10 static int
174     strtoipt( /* convert string x y z to image point */
175     int ipt[2],
176     char *str
177     )
178 greg 1.1 {
179 greg 2.2 FVECT im_pt, pt;
180 greg 1.1
181 greg 2.2 if (!sscanvec(str, pt))
182 greg 1.1 return(-1);
183 greg 2.2 if (DOT(pt,pt) <= FTINY) /* origin is really infinity */
184     ipt[0] = ipt[1] = -1; /* null vector */
185     else {
186     viewloc(im_pt, &ourview, pt);
187     loc2pix(ipt, &ourres, im_pt[0], im_pt[1]);
188     }
189 greg 1.1 return(0);
190     }
191
192
193     #define rwind RootWindow(theDisplay,ourScreen)
194     #define ourScreen DefaultScreen(theDisplay)
195
196     GC vecGC = 0;
197     Window gwind = 0;
198     int xoff, yoff;
199
200
201 schorsch 2.10 static void
202     setvec( /* set up vector drawing for pick */
203     int ipt[2]
204     )
205 greg 1.1 {
206 greg 2.4 extern Window xfindwind();
207 greg 1.1 XWindowAttributes wa;
208     XColor xc;
209     XGCValues gcv;
210 greg 1.4 int rx, ry, wx, wy;
211     Window rw, cw;
212     unsigned int pm;
213 greg 1.1 /* compute pointer location */
214 greg 2.6 if (gwind == 0) {
215     register char *wn;
216     for (wn = picture; *wn; wn++);
217     while (wn > picture && wn[-1] != '/') wn--;
218     if ((gwind = xfindwind(theDisplay, rwind, wn, 4)) == 0) {
219     fprintf(stderr, "%s: cannot find display window!\n",
220     progname);
221     exit(1);
222     }
223 greg 1.1 }
224 greg 1.5 XQueryPointer(theDisplay, gwind, &rw, &cw, &rx, &ry, &wx, &wy, &pm);
225 greg 2.2 xoff = wx - ipt[0];
226     yoff = wy - ipt[1];
227 greg 1.1 /* set graphics context */
228     if (vecGC == 0) {
229     XGetWindowAttributes(theDisplay, gwind, &wa);
230     xc.red = 65535; xc.green = 0; xc.blue = 0;
231     xc.flags = DoRed|DoGreen|DoBlue;
232     if (XAllocColor(theDisplay, wa.colormap, &xc)) {
233     gcv.foreground = xc.pixel;
234     vecGC = XCreateGC(theDisplay,gwind,GCForeground,&gcv);
235     } else {
236     gcv.function = GXinvert;
237     vecGC = XCreateGC(theDisplay,gwind,GCFunction,&gcv);
238     }
239     }
240     }
241
242
243 schorsch 2.10 static void
244     vector( /* draw a vector */
245     int ip1[2],
246     int ip2[2]
247     )
248 greg 1.1 {
249 greg 2.2 if (ip2[0] == -1 && ip2[1] == -1)
250     return; /* null vector */
251 greg 1.1 XDrawLine(theDisplay, gwind, vecGC,
252 greg 2.2 ip1[0]+xoff, ip1[1]+yoff,
253     ip2[0]+xoff, ip2[1]+yoff);
254 greg 1.2 if (slow) {
255     XFlush(theDisplay);
256     sleep(1);
257     }
258 greg 1.1 }
