Made reading of vectors more consistent with FVFORMAT macro
Fixed usage message
Fixed size of command line buffers, and allow spaces in input file paths.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
fixed to work with new window naming in x11image.c
added -c 256 to ximage command to avoid 24-bit mode
deeper search for IRIS 4D window manager
added pclose() call for nicer exit
fixed bugs resulting from changes to image.c
changed command names and options
minor compiler complaints
added -f option to x11image command
added -s option to slow trace
