root/radiance/ray/src/px/ximage.c
Revision: 1.11
Committed: Tue Oct 3 09:11:43 1989 UTC (34 years, 7 months ago) by greg
increased default gamma correction
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * ximage.c - driver for X-windows
9 *
10 * 4/30/87
11 * 3/3/88 Added calls to xraster & Paul Heckbert's ciq routines
12 */
13
14 #include "standard.h"
15
16 #include <X/Xlib.h>
17 #include <X/cursors/bcross.cursor>
18 #include <X/cursors/bcross_mask.cursor>
19
20 #include <sys/types.h>
21
22 #include <ctype.h>
23
24 #include "color.h"
25
26 #include "xraster.h"
27
28 #include "view.h"
29
30 #include "pic.h"
31
32 #define controlshift(e) (((XButtonEvent *)(e))->detail & (ShiftMask|ControlMask))
33
34 #define FONTNAME "9x15" /* text font we'll use */
35
36 #define CTRL(c) ('c'-'@')
37
38 #define BORWIDTH 5 /* border width */
39 #define BARHEIGHT 25 /* menu bar size */
40
41 double gamcor = 2.2; /* gamma correction */
42
43 XRASTER *ourras = NULL; /* our stored raster image */
44
45 int dither = 1; /* dither colors? */
46 int fast = 0; /* keep picture in Pixmap? */
47
48 Window wind = 0; /* our output window */
49 Font fontid; /* our font */
50
51 int maxcolors = 0; /* maximum colors */
52 int greyscale = 0; /* in grey */
53
54 int scale = 0; /* scalefactor; power of two */
55
56 int xoff = 0; /* x image offset */
57 int yoff = 0; /* y image offset */
58
59 VIEW ourview = STDVIEW(0); /* image view parameters */
60 int gotview = 0; /* got parameters from file */
61
62 COLR *scanline; /* scan line buffer */
63
64 int xmax, ymax; /* picture resolution */
65 int width, height; /* window size */
66 char *fname = NULL; /* input file name */
67 FILE *fin = stdin; /* input file */
68 long *scanpos = NULL; /* scan line positions in file */
69 int cury = 0; /* current scan location */
70
71 double exposure = 1.0; /* exposure compensation used */
72
73 struct {
74 int xmin, ymin, xsiz, ysiz;
75 } box = {0, 0, 0, 0}; /* current box */
76
77 char *geometry = NULL; /* geometry specification */
78
79 char *progname;
80
81 char errmsg[128];
82
83 extern long ftell();
84
85 extern char *malloc(), *calloc();
86
87 extern double atof(), pow(), log();
88
89
90 main(argc, argv)
91 int argc;
92 char *argv[];
93 {
94 int headline();
95 int i;
96
97 progname = argv[0];
98
99 for (i = 1; i < argc; i++)
100 if (argv[i][0] == '-')
101 switch (argv[i][1]) {
102 case 'c':
103 maxcolors = atoi(argv[++i]);
104 break;
105 case 'b':
106 greyscale = !greyscale;
107 break;
108 case 'm':
109 maxcolors = 2;
110 break;
111 case 'd':
112 dither = !dither;
113 break;
114 case 'f':
115 fast = !fast;
116 break;
117 case 'e':
118 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
119 goto userr;
120 scale = atoi(argv[++i]);
121 break;
122 case 'g':
123 gamcor = atof(argv[++i]);
124 break;
125 default:
126 goto userr;
127 }
128 else if (argv[i][0] == '=')
129 geometry = argv[i];
130 else
131 break;
132
133 if (argc-i == 1) {
134 fname = argv[i];
135 fin = fopen(fname, "r");
136 if (fin == NULL) {
137 sprintf(errmsg, "can't open file \"%s\"", fname);
138 quiterr(errmsg);
139 }
140 }
141 /* get header */
142 getheader(fin, headline);
143 /* get picture dimensions */
144 if (fgetresolu(&xmax, &ymax, fin) != (YMAJOR|YDECR))
145 quiterr("bad picture size");
146 /* set view parameters */
147 if (gotview)
148 if (setview(&ourview) != NULL)
149 gotview = 0;
150
151 if ((scanline = (COLR *)malloc(xmax*sizeof(COLR))) == NULL)
152 quiterr("out of memory");
153
154 init(); /* get file and open window */
155
156 for ( ; ; )
157 getevent(); /* main loop */
158 userr:
159 fprintf(stderr,
160 "Usage: %s [=geometry][-b][-m][-d][-f][-c ncolors][-e +/-stops] file\n",
161 progname);
162 quit(1);
163 }
164
165
166 headline(s) /* get relevant info from header */
167 char *s;
168 {
169 static char *altname[] = {"rview","rpict",VIEWSTR,NULL};
170 register char **an;
171
172 if (!strncmp(s, "EXPOSURE=", 9))
173 exposure *= atof(s+9);
174 else
175 for (an = altname; *an != NULL; an++)
176 if (!strncmp(*an, s, strlen(*an))) {
177 if (sscanview(&ourview, s+strlen(*an)) == 0)
178 gotview++;
179 return;
180 }
181 }
182
183
184 char *
185 sskip(s) /* skip a word */
186 register char *s;
187 {
188 while (isspace(*s)) s++;
189 while (*s && !isspace(*s)) s++;
190 return(s);
191 }
192
193
194 init() /* get data and open window */
195 {
196 register int i;
197 OpaqueFrame mainframe;
198 char defgeom[32];
199
200 if (fname != NULL) {
201 scanpos = (long *)malloc(ymax*sizeof(long));
202 if (scanpos == NULL)
203 goto memerr;
204 for (i = 0; i < ymax; i++)
205 scanpos[i] = -1;
206 }
207 if (XOpenDisplay(NULL) == NULL)
208 quiterr("can't open display; DISPLAY variable set?");
209 #ifdef notdef
210 if (DisplayWidth() - 2*BORWIDTH < xmax ||
211 DisplayHeight() - 2*BORWIDTH - BARHEIGHT < ymax)
212 quiterr("resolution mismatch");
213 #endif
214 if (maxcolors == 0) { /* get number of available colors */
215 maxcolors = 1<<DisplayPlanes();
216 if (maxcolors > 4) maxcolors -= 2;
217 }
218 /* store image */
219 getras();
220
221 mainframe.bdrwidth = BORWIDTH;
222 mainframe.border = WhitePixmap;
223 mainframe.background = BlackPixmap;
224 sprintf(defgeom, "=%dx%d+0+22", xmax, ymax);
225 wind = XCreate("Radiance Image", progname, geometry, defgeom,
226 &mainframe, 16, 16);
227 if (wind == 0)
228 quiterr("can't create window");
229 width = mainframe.width;
230 height = mainframe.height;
231 fontid = XGetFont(FONTNAME);
232 if (fontid == 0)
233 quiterr("can't get font");
234 XStoreName(wind, fname == NULL ? progname : fname);
235 XDefineCursor(wind, XCreateCursor(bcross_width, bcross_height,
236 bcross_bits, bcross_mask_bits,
237 bcross_x_hot, bcross_y_hot,
238 BlackPixel, WhitePixel, GXcopy));
239 XSelectInput(wind, ButtonPressed|ButtonReleased|UnmapWindow
240 |RightDownMotion|MiddleDownMotion|LeftDownMotion
241 |KeyPressed|ExposeWindow|ExposeRegion);
242 XMapWindow(wind);
243 return;
244 memerr:
245 quiterr("out of memory");
246 }
247
248
249 quiterr(err) /* print message and exit */
250 char *err;
251 {
252 if (err != NULL)
253 fprintf(stderr, "%s: %s\n", progname, err);
254
255 exit(err == NULL ? 0 : 1);
256 }
257
258
259 eputs(s)
260 char *s;
261 {
262 fputs(s, stderr);
263 }
264
265
266 quit(code)
267 int code;
268 {
269 exit(code);
270 }
271
272
273 getras() /* get raster file */
274 {
275 colormap ourmap;
276
277 ourras = (XRASTER *)calloc(1, sizeof(XRASTER));
278 if (ourras == NULL)
279 goto memerr;
280 ourras->width = xmax;
281 ourras->height = ymax;
282 if (maxcolors <= 2) { /* monochrome */
283 ourras->data.m = (unsigned short *)malloc(BitmapSize(xmax,ymax));
284 if (ourras->data.m == NULL)
285 goto memerr;
286 getmono();
287 } else {
288 ourras->data.bz = (unsigned char *)malloc(BZPixmapSize(xmax,ymax));
289 if (ourras->data.bz == NULL)
290 goto memerr;
291 if (greyscale)
292 biq(dither,maxcolors,1,ourmap);
293 else
294 ciq(dither,maxcolors,1,ourmap);
295 if (init_rcolors(ourras, ourmap) == 0)
296 goto memerr;
297 }
298 return;
299 memerr:
300 quit("out of memory");
301 }
302
303
304 getevent() /* process the next event */
305 {
306 WindowInfo info;
307 XEvent e;
308
309 XNextEvent(&e);
310 switch (e.type) {
311 case KeyPressed:
312 docom(&e);
313 break;
314 case ExposeWindow:
315 XQueryWindow(wind, &info); /* in case resized */
316 width = info.width;
317 height = info.height;
318 /* fall through */
319 case ExposeRegion:
320 fixwindow(&e);
321 break;
322 case UnmapWindow:
323 unmap_rcolors(ourras);
324 break;
325 case ButtonPressed:
326 if (controlshift(&e))
327 moveimage(&e);
328 else
329 getbox(&e);
330 break;
331 }
332 }
333
334
335 fixwindow(eexp) /* fix new or stepped-on window */
336 XExposeEvent *eexp;
337 {
338 redraw(eexp->x, eexp->y, eexp->width, eexp->height);
339 }
340
341
342 redraw(x, y, w, h) /* redraw section of window */
343 int x, y;
344 int w, h;
345 {
346 if (ourras->ncolors && map_rcolors(ourras) == NULL) {
347 fprintf(stderr, "%s: cannot allocate colors\n", progname);
348 return(-1);
349 }
350 if (fast)
351 make_rpixmap(ourras);
352 return(patch_raster(wind,x-xoff,y-yoff,x,y,w,h,ourras) ? 0 : -1);
353 }
354
355
356 docom(ekey) /* execute command */
357 XKeyEvent *ekey;
358 {
359 char buf[80];
360 COLOR cval;
361 char *cp;
362 int n;
363 double comp;
364 FVECT rorg, rdir;
365
366 cp = XLookupMapping(ekey, &n);
367 if (n == 0)
368 return(0);
369 switch (*cp) { /* interpret command */
370 case 'q':
371 case CTRL(D): /* quiterr */
372 quit(0);
373 case '\n':
374 case '\r':
375 case 'l':
376 case 'c': /* value */
377 if (avgbox(cval) == -1)
378 return(-1);
379 switch (*cp) {
380 case '\n':
381 case '\r': /* radiance */
382 sprintf(buf, "%-3g", intens(cval)/exposure);
383 break;
384 case 'l': /* luminance */
385 sprintf(buf, "%-3gL", bright(cval)*683.0/exposure);
386 break;
387 case 'c': /* color */
388 comp = pow(2.0, (double)scale);
389 sprintf(buf, "(%.2f,%.2f,%.2f)",
390 colval(cval,RED)*comp,
391 colval(cval,GRN)*comp,
392 colval(cval,BLU)*comp);
393 break;
394 }
395 XText(wind, box.xmin, box.ymin, buf, strlen(buf),
396 fontid, BlackPixel, WhitePixel);
397 return(0);
398 case 'p': /* position */
399 sprintf(buf, "(%d,%d)", ekey->x-xoff, ymax-1-ekey->y+yoff);
400 XText(wind, ekey->x, ekey->y, buf, strlen(buf),
401 fontid, BlackPixel, WhitePixel);
402 return(0);
403 case 't': /* trace */
404 if (!gotview) {
405 XFeep(0);
406 return(-1);
407 }
408 rayview(rorg, rdir, &ourview,
409 ekey->x-xoff + .5, ymax-1-ekey->y+yoff + .5);
410 printf("%e %e %e ", rorg[0], rorg[1], rorg[2]);
411 printf("%e %e %e\n", rdir[0], rdir[1], rdir[2]);
412 fflush(stdout);
413 return(0);
414 case '=': /* adjust exposure */
415 if (avgbox(cval) == -1)
416 return(-1);
417 n = log(.5/bright(cval))/.69315 - scale; /* truncate */
418 if (n == 0)
419 return(0);
420 scale_rcolors(ourras, pow(2.0, (double)n));
421 scale += n;
422 sprintf(buf, "%+d", scale);
423 XText(wind, box.xmin, box.ymin, buf, strlen(buf),
424 fontid, BlackPixel, WhitePixel);
425 XFlush();
426 free_raster(ourras);
427 getras();
428 /* fall through */
429 case CTRL(R): /* redraw */
430 case CTRL(L):
431 XClear(wind);
432 return(redraw(0, 0, width, height));
433 case ' ': /* clear */
434 return(redraw(box.xmin, box.ymin, box.xsiz, box.ysiz));
435 default:
436 XFeep(0);
437 return(-1);
438 }
439 }
440
441
442 moveimage(ep) /* shift the image */
443 XButtonEvent *ep;
444 {
445 XButtonEvent eb;
446
447 XMaskEvent(ButtonReleased, &eb);
448 xoff += eb.x - ep->x;
449 yoff += eb.y - ep->y;
450 XClear(wind);
451 return(redraw(0, 0, width, height));
452 }
453
454
455 getbox(ebut) /* get new box */
456 XButtonEvent *ebut;
457 {
458 union {
459 XEvent e;
460 XButtonEvent b;
461 XMouseMovedEvent m;
462 } e;
463
464 XMaskEvent(ButtonReleased|MouseMoved, &e.e);
465 while (e.e.type == MouseMoved) {
466 revbox(ebut->x, ebut->y, box.xmin = e.m.x, box.ymin = e.m.y);
467 XMaskEvent(ButtonReleased|MouseMoved, &e.e);
468 revbox(ebut->x, ebut->y, box.xmin, box.ymin);
469 }
470 box.xmin = e.b.x<0 ? 0 : (e.b.x>=width ? width-1 : e.b.x);
471 box.ymin = e.b.y<0 ? 0 : (e.b.y>=height ? height-1 : e.b.y);
472 if (box.xmin > ebut->x) {
473 box.xsiz = box.xmin - ebut->x + 1;
474 box.xmin = ebut->x;
475 } else {
476 box.xsiz = ebut->x - box.xmin + 1;
477 }
478 if (box.ymin > ebut->y) {
479 box.ysiz = box.ymin - ebut->y + 1;
480 box.ymin = ebut->y;
481 } else {
482 box.ysiz = ebut->y - box.ymin + 1;
483 }
484 }
485
486
487 revbox(x0, y0, x1, y1) /* draw box with reversed lines */
488 int x0, y0, x1, y1;
489 {
490 XLine(wind, x0, y0, x1, y0, 1, 1, 0, GXinvert, AllPlanes);
491 XLine(wind, x0, y1, x1, y1, 1, 1, 0, GXinvert, AllPlanes);
492 XLine(wind, x0, y0, x0, y1, 1, 1, 0, GXinvert, AllPlanes);
493 XLine(wind, x1, y0, x1, y1, 1, 1, 0, GXinvert, AllPlanes);
494 }
495
496
497 avgbox(clr) /* average color over current box */
498 COLOR clr;
499 {
500 int left, right, top, bottom;
501 int y;
502 double d;
503 COLOR ctmp;
504 register int x;
505
506 setcolor(clr, 0.0, 0.0, 0.0);
507 left = box.xmin - xoff;
508 right = left + box.xsiz;
509 if (left < 0)
510 left = 0;
511 if (right > xmax)
512 right = xmax;
513 if (left >= right)
514 return(-1);
515 top = box.ymin - yoff;
516 bottom = top + box.ysiz;
517 if (top < 0)
518 top = 0;
519 if (bottom > ymax)
520 bottom = ymax;
521 if (top >= bottom)
522 return(-1);
523 for (y = top; y < bottom; y++) {
524 if (getscan(y) == -1)
525 return(-1);
526 for (x = left; x < right; x++) {
527 colr_color(ctmp, scanline[x]);
528 addcolor(clr, ctmp);
529 }
530 }
531 d = 1.0/((right-left)*(bottom-top));
532 scalecolor(clr, d);
533 return(0);
534 }
535
536
537 getmono() /* get monochrome data */
538 {
539 register unsigned short *dp;
540 register int x, err;
541 int y;
542 rgbpixel *inline;
543 short *cerr;
544
545 if ((inline = (rgbpixel *)malloc(xmax*sizeof(rgbpixel))) == NULL
546 || (cerr = (short *)calloc(xmax,sizeof(short))) == NULL)
547 quit("out of memory in getmono");
548 dp = ourras->data.m - 1;
549 for (y = 0; y < ymax; y++) {
550 picreadline3(y, inline);
551 err = 0;
552 for (x = 0; x < xmax; x++) {
553 if (!(x&0xf))
554 *++dp = 0;
555 err += rgb_bright(&inline[x]) + cerr[x];
556 if (err > 127)
557 err -= 255;
558 else
559 *dp |= 1<<(x&0xf);
560 cerr[x] = err >>= 1;
561 }
562 }
563 free((char *)inline);
564 free((char *)cerr);
565 }
566
567
568 init_rcolors(xr, cmap) /* (re)assign color values */
569 register XRASTER *xr;
570 colormap cmap;
571 {
572 register int i;
573 register unsigned char *p;
574
575 xr->pmap = (int *)malloc(256*sizeof(int));
576 if (xr->pmap == NULL)
577 return(0);
578 xr->cdefs = (Color *)malloc(256*sizeof(Color));
579 if (xr->cdefs == NULL)
580 return(0);
581 for (i = 0; i < 256; i++)
582 xr->pmap[i] = -1;
583 xr->ncolors = 0;
584 for (p = xr->data.bz, i = BZPixmapSize(xr->width,xr->height); i--; p++)
585 if (xr->pmap[*p] == -1) {
586 xr->cdefs[xr->ncolors].red = cmap[0][*p] << 8;
587 xr->cdefs[xr->ncolors].green = cmap[1][*p] << 8;
588 xr->cdefs[xr->ncolors].blue = cmap[2][*p] << 8;
589 xr->cdefs[xr->ncolors].pixel = *p;
590 xr->pmap[*p] = xr->ncolors++;
591 }
592 xr->cdefs = (Color *)realloc((char *)xr->cdefs, xr->ncolors*sizeof(Color));
593 if (xr->cdefs == NULL)
594 return(0);
595 return(1);
596 }
597
598
599 scale_rcolors(xr, sf) /* scale color map */
600 register XRASTER *xr;
601 double sf;
602 {
603 register int i;
604 int maxv;
605
606 sf = pow(sf, 1.0/gamcor);
607 maxv = (1<<16) / sf;
608
609 for (i = xr->ncolors; i--; ) {
610 xr->cdefs[i].red = xr->cdefs[i].red >= maxv ?
611 (1<<16)-1 :
612 xr->cdefs[i].red * sf;
613 xr->cdefs[i].green = xr->cdefs[i].green >= maxv ?
614 (1<<16)-1 :
615 xr->cdefs[i].green * sf;
616 xr->cdefs[i].blue = xr->cdefs[i].blue >= maxv ?
617 (1<<16)-1 :
618 xr->cdefs[i].blue * sf;
619 }
620 if (xr->pixels != NULL)
621 XStoreColors(xr->ncolors, xr->cdefs);
622 }
623
624
625 getscan(y)
626 int y;
627 {
628 if (y != cury) {
629 if (scanpos == NULL || scanpos[y] == -1)
630 return(-1);
631 if (fseek(fin, scanpos[y], 0) == -1)
632 quit("fseek error");
633 cury = y;
634 } else if (scanpos != NULL)
635 scanpos[y] = ftell(fin);
636
637 if (freadcolrs(scanline, xmax, fin) < 0)
638 quiterr("read error");
639
640 cury++;
641 return(0);
642 }
643
644
645 picreadline3(y, l3) /* read in 3-byte scanline */
646 int y;
647 register rgbpixel *l3;
648 {
649 register BYTE *l4;
650 register int shift, c;
651 int i;
652
653 if (getscan(y) < 0)
654 quiterr("cannot seek for picreadline");
655 /* convert scanline */
656 for (l4=scanline[0], i=xmax; i--; l4+=4, l3++) {
657 shift = l4[EXP] - COLXS + scale;
658 if (shift >= 8) {
659 l3->r = l3->g = l3->b = 255;
660 } else if (shift <= -8) {
661 l3->r = l3->g = l3->b = 0;
662 } else if (shift > 0) {
663 c = l4[RED] << shift;
664 l3->r = c > 255 ? 255 : c;
665 c = l4[GRN] << shift;
666 l3->g = c > 255 ? 255 : c;
667 c = l4[BLU] << shift;
668 l3->b = c > 255 ? 255 : c;
669 } else if (shift < 0) {
670 l3->r = l4[RED] >> -shift;
671 l3->g = l4[GRN] >> -shift;
672 l3->b = l4[BLU] >> -shift;
673 } else {
674 l3->r = l4[RED];
675 l3->g = l4[GRN];
676 l3->b = l4[BLU];
677 }
678 }
679 }
680
681
682 picwriteline(y, l) /* add 8-bit scanline to image */
683 int y;
684 pixel *l;
685 {
686 bcopy(l, ourras->data.bz+BZPixmapSize(xmax,y), BZPixmapSize(xmax,1));
687 }
688
689
690 picreadcm(map) /* do gamma correction */
691 colormap map;
692 {
693 extern double pow();
694 register int i, val;
695
696 for (i = 0; i < 256; i++) {
697 val = pow(i/256.0, 1.0/gamcor) * 256.0;
698 map[0][i] = map[1][i] = map[2][i] = val;
699 }
700 }
701
702
703 picwritecm(map) /* handled elsewhere */
704 colormap map;
705 {
706 #ifdef DEBUG
707 register int i;
708
709 for (i = 0; i < 256; i++)
710 printf("%d %d %d\n", map[0][i],map[1][i],map[2][i]);
711 #endif
712 }
