--- ray/src/px/ximage.c 1989/11/06 15:12:03 1.14 +++ ray/src/px/ximage.c 2004/01/02 12:47:01 2.13 @@ -1,9 +1,6 @@ -/* Copyright (c) 1987 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: ximage.c,v 2.13 2004/01/02 12:47:01 schorsch Exp $"; #endif - /* * ximage.c - driver for X-windows * @@ -18,22 +15,22 @@ static char SCCSid[] = "$SunId$ LBL"; #include #include - +#include #include +#include #include "color.h" - +#include "resolu.h" #include "xraster.h" - #include "view.h" - #include "pic.h" +#include "random.h" #define controlshift(e) (((XButtonEvent *)(e))->detail & (ShiftMask|ControlMask)) #define FONTNAME "9x15" /* text font we'll use */ -#define CTRL(c) ('c'-'@') +#define CTRL(c) ((c)-'@') #define BORWIDTH 5 /* border width */ #define BARHEIGHT 25 /* menu bar size */ @@ -56,7 +53,7 @@ int scale = 0; /* scalefactor; power of two */ int xoff = 0; /* x image offset */ int yoff = 0; /* y image offset */ -VIEW ourview = STDVIEW(0); /* image view parameters */ +VIEW ourview = STDVIEW; /* image view parameters */ int gotview = 0; /* got parameters from file */ COLR *scanline; /* scan line buffer */ @@ -70,6 +67,8 @@ int cury = 0; /* current scan location */ double exposure = 1.0; /* exposure compensation used */ +int wrongformat = 0; /* input in another format */ + struct { int xmin, ymin, xsiz, ysiz; } box = {0, 0, 0, 0}; /* current box */ @@ -80,21 +79,20 @@ char *progname; char errmsg[128]; -extern long ftell(); +static gethfunc headline; -extern char *malloc(), *calloc(); -extern double atof(), pow(), log(); - - main(argc, argv) int argc; char *argv[]; { - int headline(); + extern char *getenv(); + char *gv; int i; progname = argv[0]; + if ((gv = getenv("DISPLAY_GAMMA")) != NULL) + gamcor = atof(gv); for (i = 1; i < argc; i++) if (argv[i][0] == '-') @@ -139,17 +137,13 @@ char *argv[]; } } /* get header */ - getheader(fin, headline); + getheader(fin, headline, NULL); /* get picture dimensions */ - if (fgetresolu(&xmax, &ymax, fin) != (YMAJOR|YDECR)) + if (wrongformat || fgetresolu(&xmax, &ymax, fin) != (YMAJOR|YDECR)) quiterr("bad picture size"); /* set view parameters */ - if (gotview) { - ourview.hresolu = xmax; - ourview.vresolu = ymax; - if (setview(&ourview) != NULL) - gotview = 0; - } + if (gotview && setview(&ourview) != NULL) + gotview = 0; if ((scanline = (COLR *)malloc(xmax*sizeof(COLR))) == NULL) quiterr("out of memory"); @@ -165,34 +159,25 @@ userr: } -headline(s) /* get relevant info from header */ -char *s; +static int +headline( /* get relevant info from header */ + char *s, + void *p +) { - static char *altname[] = {"rview","rpict",VIEWSTR,NULL}; - register char **an; + char fmt[32]; - if (!strncmp(s, "EXPOSURE=", 9)) - exposure *= atof(s+9); - else - for (an = altname; *an != NULL; an++) - if (!strncmp(*an, s, strlen(*an))) { - if (sscanview(&ourview, s+strlen(*an)) == 0) - gotview++; - return; - } + if (isexpos(s)) + exposure *= exposval(s); + else if (isformat(s)) { + formatval(fmt, s); + wrongformat = strcmp(fmt, COLRFMT); + } else if (isview(s) && sscanview(&ourview, s) > 0) + gotview++; + return(0); } -char * -sskip(s) /* skip a word */ -register char *s; -{ - while (isspace(*s)) s++; - while (*s && !isspace(*s)) s++; - return(s); -} - - init() /* get data and open window */ { register int i; @@ -258,6 +243,7 @@ char *err; } +void eputs(s) char *s; { @@ -265,6 +251,7 @@ char *s; } +void quit(code) int code; { @@ -299,7 +286,7 @@ getras() /* get raster file */ } return; memerr: - quit("out of memory"); + quiterr("out of memory"); } @@ -360,6 +347,7 @@ XKeyEvent *ekey; { char buf[80]; COLOR cval; + Color cvx; char *cp; int n; double comp; @@ -370,7 +358,7 @@ XKeyEvent *ekey; return(0); switch (*cp) { /* interpret command */ case 'q': - case CTRL(D): /* quiterr */ + case CTRL('D'): /* quit */ quit(0); case '\n': case '\r': @@ -381,10 +369,10 @@ XKeyEvent *ekey; switch (*cp) { case '\n': case '\r': /* radiance */ - sprintf(buf, "%-3g", intens(cval)/exposure); + sprintf(buf, "%.3f", intens(cval)/exposure); break; case 'l': /* luminance */ - sprintf(buf, "%-3gL", bright(cval)*683.0/exposure); + sprintf(buf, "%.0fL", luminance(cval)/exposure); break; case 'c': /* color */ comp = pow(2.0, (double)scale); @@ -397,6 +385,17 @@ XKeyEvent *ekey; XText(wind, box.xmin, box.ymin, buf, strlen(buf), fontid, BlackPixel, WhitePixel); return(0); + case 'i': /* identify (contour) */ + if (ourras->pixels == NULL) + return(-1); + n = ourras->data.bz[ekey->x-xoff+BZPixmapSize(xmax,ekey->y-yoff)]; + n = ourras->pmap[n]; + cvx.pixel = ourras->cdefs[n].pixel; + cvx.red = random() & 65535; + cvx.green = random() & 65535; + cvx.blue = random() & 65535; + XStoreColor(&cvx); + return(0); case 'p': /* position */ sprintf(buf, "(%d,%d)", ekey->x-xoff, ymax-1-ekey->y+yoff); XText(wind, ekey->x, ekey->y, buf, strlen(buf), @@ -407,8 +406,9 @@ XKeyEvent *ekey; XFeep(0); return(-1); } - rayview(rorg, rdir, &ourview, - ekey->x-xoff + .5, ymax-1-ekey->y+yoff + .5); + if (viewray(rorg, rdir, &ourview, (ekey->x-xoff+.5)/xmax, + (ymax-1-ekey->y+yoff+.5)/ymax) < 0) + return(-1); printf("%e %e %e ", rorg[0], rorg[1], rorg[2]); printf("%e %e %e\n", rdir[0], rdir[1], rdir[2]); fflush(stdout); @@ -428,8 +428,9 @@ XKeyEvent *ekey; free_raster(ourras); getras(); /* fall through */ - case CTRL(R): /* redraw */ - case CTRL(L): + case CTRL('R'): /* redraw */ + case CTRL('L'): + unmap_rcolors(ourras); XClear(wind); return(redraw(0, 0, width, height)); case ' ': /* clear */ @@ -540,30 +541,32 @@ getmono() /* get monochrome data */ { register unsigned short *dp; register int x, err; - int y; - rgbpixel *inline; + int y, errp; + rgbpixel *inl; short *cerr; - if ((inline = (rgbpixel *)malloc(xmax*sizeof(rgbpixel))) == NULL + if ((inl = (rgbpixel *)malloc(xmax*sizeof(rgbpixel))) == NULL || (cerr = (short *)calloc(xmax,sizeof(short))) == NULL) - quit("out of memory in getmono"); + quiterr("out of memory in getmono"); dp = ourras->data.m - 1; for (y = 0; y < ymax; y++) { - picreadline3(y, inline); + picreadline3(y, inl); err = 0; for (x = 0; x < xmax; x++) { if (!(x&0xf)) *++dp = 0; - err += rgb_bright(&inline[x]) + cerr[x]; + errp = err; + err += rgb_bright(&inl[x]) + cerr[x]; if (err > 127) err -= 255; else *dp |= 1<<(x&0xf); - cerr[x] = err >>= 1; + err /= 3; + cerr[x] = err + errp; } } - free((char *)inline); - free((char *)cerr); + free((void *)inl); + free((void *)cerr); } @@ -591,7 +594,7 @@ colormap cmap; xr->cdefs[xr->ncolors].pixel = *p; xr->pmap[*p] = xr->ncolors++; } - xr->cdefs = (Color *)realloc((char *)xr->cdefs, xr->ncolors*sizeof(Color)); + xr->cdefs = (Color *)realloc((void *)xr->cdefs, xr->ncolors*sizeof(Color)); if (xr->cdefs == NULL) return(0); return(1); @@ -603,24 +606,26 @@ register XRASTER *xr; double sf; { register int i; - int maxv; + long maxv; + if (xr->pixels == NULL) + return; + sf = pow(sf, 1.0/gamcor); - maxv = (1<<16) / sf; + maxv = 65535/sf; for (i = xr->ncolors; i--; ) { - xr->cdefs[i].red = xr->cdefs[i].red >= maxv ? - (1<<16)-1 : + xr->cdefs[i].red = xr->cdefs[i].red > maxv ? + 65535 : xr->cdefs[i].red * sf; - xr->cdefs[i].green = xr->cdefs[i].green >= maxv ? - (1<<16)-1 : + xr->cdefs[i].green = xr->cdefs[i].green > maxv ? + 65535 : xr->cdefs[i].green * sf; - xr->cdefs[i].blue = xr->cdefs[i].blue >= maxv ? - (1<<16)-1 : + xr->cdefs[i].blue = xr->cdefs[i].blue > maxv ? + 65535 : xr->cdefs[i].blue * sf; } - if (xr->pixels != NULL) - XStoreColors(xr->ncolors, xr->cdefs); + XStoreColors(xr->ncolors, xr->cdefs); } @@ -631,9 +636,9 @@ int y; if (scanpos == NULL || scanpos[y] == -1) return(-1); if (fseek(fin, scanpos[y], 0) == -1) - quit("fseek error"); + quiterr("fseek error"); cury = y; - } else if (scanpos != NULL) + } else if (scanpos != NULL && scanpos[y] == -1) scanpos[y] = ftell(fin); if (freadcolrs(scanline, xmax, fin) < 0) @@ -653,11 +658,7 @@ register rgbpixel *l3; if (getscan(y) < 0) quiterr("cannot seek for picreadline"); /* convert scanline */ - if (scale != 0) - for (i = 0; i < xmax; i++) - if (scanline[i][EXP]+scale >= 0) - scanline[i][EXP] += scale; - normcolrs(scanline, xmax); + normcolrs(scanline, xmax, scale); for (i = 0; i < xmax; i++) { l3[i].r = scanline[i][RED]; l3[i].g = scanline[i][GRN]; @@ -670,7 +671,7 @@ picwriteline(y, l) /* add 8-bit scanline to image */ int y; pixel *l; { - bcopy(l, ourras->data.bz+BZPixmapSize(xmax,y), BZPixmapSize(xmax,1)); + memcpy((void *)ourras->data.bz+BZPixmapSize(xmax,y), (void *)l, BZPixmapSize(xmax,1)); } @@ -681,7 +682,7 @@ colormap map; register int i, val; for (i = 0; i < 256; i++) { - val = pow(i/256.0, 1.0/gamcor) * 256.0; + val = pow((i+0.5)/256.0, 1.0/gamcor) * 256.0; map[0][i] = map[1][i] = map[2][i] = val; } }
