--- ray/src/px/ximage.c 1990/11/07 13:10:39 1.27 +++ ray/src/px/ximage.c 1994/09/20 15:48:25 2.7 @@ -23,6 +23,8 @@ static char SCCSid[] = "$SunId$ LBL"; #include "color.h" +#include "resolu.h" + #include "xraster.h" #include "view.h" @@ -35,7 +37,7 @@ static char SCCSid[] = "$SunId$ LBL"; #define FONTNAME "9x15" /* text font we'll use */ -#define CTRL(c) ('c'-'@') +#define CTRL(c) ((c)-'@') #define BORWIDTH 5 /* border width */ #define BARHEIGHT 25 /* menu bar size */ @@ -72,6 +74,8 @@ int cury = 0; /* current scan location */ double exposure = 1.0; /* exposure compensation used */ +int wrongformat = 0; /* input in another format */ + struct { int xmin, ymin, xsiz, ysiz; } box = {0, 0, 0, 0}; /* current box */ @@ -86,17 +90,21 @@ extern long ftell(); extern char *malloc(), *calloc(); -extern double atof(), pow(), log(); +extern double pow(), log(); main(argc, argv) int argc; char *argv[]; { + extern char *getenv(); + char *gv; int headline(); int i; progname = argv[0]; + if ((gv = getenv("DISPLAY_GAMMA")) != NULL) + gamcor = atof(gv); for (i = 1; i < argc; i++) if (argv[i][0] == '-') @@ -141,9 +149,9 @@ char *argv[]; } } /* get header */ - getheader(fin, headline); + getheader(fin, headline, NULL); /* get picture dimensions */ - if (fgetresolu(&xmax, &ymax, fin) != (YMAJOR|YDECR)) + if (wrongformat || fgetresolu(&xmax, &ymax, fin) != (YMAJOR|YDECR)) quiterr("bad picture size"); /* set view parameters */ if (gotview && setview(&ourview) != NULL) @@ -166,18 +174,15 @@ userr: headline(s) /* get relevant info from header */ char *s; { - static char *altname[] = {"rview","rpict",VIEWSTR,NULL}; - register char **an; + char fmt[32]; if (isexpos(s)) exposure *= exposval(s); - else - for (an = altname; *an != NULL; an++) - if (!strncmp(*an, s, strlen(*an))) { - if (sscanview(&ourview, s+strlen(*an)) > 0) - gotview++; - return; - } + else if (isformat(s)) { + formatval(fmt, s); + wrongformat = strcmp(fmt, COLRFMT); + } else if (isview(s) && sscanview(&ourview, s) > 0) + gotview++; } @@ -359,7 +364,7 @@ XKeyEvent *ekey; return(0); switch (*cp) { /* interpret command */ case 'q': - case CTRL(D): /* quit */ + case CTRL('D'): /* quit */ quit(0); case '\n': case '\r': @@ -373,7 +378,7 @@ XKeyEvent *ekey; sprintf(buf, "%.3f", intens(cval)/exposure); break; case 'l': /* luminance */ - sprintf(buf, "%.0fn", bright(cval)*683.0/exposure); + sprintf(buf, "%.0fL", luminance(cval)/exposure); break; case 'c': /* color */ comp = pow(2.0, (double)scale); @@ -429,8 +434,8 @@ XKeyEvent *ekey; free_raster(ourras); getras(); /* fall through */ - case CTRL(R): /* redraw */ - case CTRL(L): + case CTRL('R'): /* redraw */ + case CTRL('L'): unmap_rcolors(ourras); XClear(wind); return(redraw(0, 0, width, height)); @@ -542,7 +547,7 @@ getmono() /* get monochrome data */ { register unsigned short *dp; register int x, err; - int y; + int y, errp; rgbpixel *inl; short *cerr; @@ -556,12 +561,14 @@ getmono() /* get monochrome data */ for (x = 0; x < xmax; x++) { if (!(x&0xf)) *++dp = 0; + errp = err; err += rgb_bright(&inl[x]) + cerr[x]; if (err > 127) err -= 255; else *dp |= 1<<(x&0xf); - cerr[x] = err >>= 1; + err /= 3; + cerr[x] = err + errp; } } free((char *)inl); @@ -637,7 +644,7 @@ int y; if (fseek(fin, scanpos[y], 0) == -1) quiterr("fseek error"); cury = y; - } else if (scanpos != NULL) + } else if (scanpos != NULL && scanpos[y] == -1) scanpos[y] = ftell(fin); if (freadcolrs(scanline, xmax, fin) < 0)
