root/radiance/ray/src/px/ximage.c
Revision 2.14
Fri Nov 5 03:31:38 2004 UTC (19 years, 7 months ago) by greg
FILE REMOVED
Fri Jan 2 12:47:01 2004 UTC (20 years, 5 months ago) by schorsch
Changes since 2.12: +8 -5 lines
Diff to previous 2.12 , to selected 1.15
Changes since 2.11: +3 -9 lines
Diff to previous 2.11 , to selected 1.15
Tue May 13 17:58:33 2003 UTC (21 years ago) by greg
Diff to previous 2.10 , to selected 1.15
Wed Apr 23 00:52:34 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.9 , to selected 1.15
Changes since 2.8: +7 -12 lines
Diff to previous 2.8 , to selected 1.15
Tue Oct 27 09:08:28 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 2.7: +2 -0 lines
Diff to previous 2.7 , to selected 1.15
Tue Sep 20 15:48:25 1994 UTC (29 years, 8 months ago) by greg
Diff to previous 2.6 , to selected 1.15
changed GAMMA environment variable to DISPLAY_GAMMA
Fri Aug 21 13:49:35 1992 UTC (31 years, 9 months ago) by greg
Diff to previous 2.5 , to selected 1.15
made getscan() slightly more efficient
Wed Jun 24 09:17:43 1992 UTC (31 years, 11 months ago) by greg
Changes since 2.4: +4 -0 lines
Diff to previous 2.4 , to selected 1.15
Tue Apr 28 09:40:36 1992 UTC (32 years, 1 month ago) by greg
Changes since 2.3: +2 -9 lines
Diff to previous 2.3 , to selected 1.15
changed calls to get view parameters from files
Mon Dec 23 23:20:06 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 2.2 , to selected 1.15
fixed CTRL(c) for ANSII preprocessors
Thu Dec 19 14:52:31 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 2.1 , to selected 1.15
Tue Nov 12 16:05:14 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.31: +2 -0 lines
Diff to previous 1.31 , to selected 1.15
Mon May 6 15:19:03 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.30: +4 -2 lines
Diff to previous 1.30 , to selected 1.15
improved monochrome dithering slightly
Wed May 1 12:40:03 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.29 , to selected 1.15
changed 'n' to 'L' in luminance display
Thu Apr 18 14:35:52 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.28: +9 -3 lines
Diff to previous 1.28 , to selected 1.15
Mon Mar 18 09:35:04 1991 UTC (33 years, 2 months ago) by greg
Changes since 1.27: +1 -1 lines
Diff to previous 1.27 , to selected 1.15
added luminance() macro to color.h
Wed Nov 7 13:10:39 1990 UTC (33 years, 7 months ago) by greg
Changes since 1.26: +1 -1 lines
Diff to previous 1.26 , to selected 1.15
minor improvement in gamma correction
Wed Oct 17 15:15:52 1990 UTC (33 years, 7 months ago) by greg
Changes since 1.25: +3 -3 lines
Diff to previous 1.25 , to selected 1.15
fixed calls to quit() that should have been to quiterr()
Sat Oct 13 21:31:45 1990 UTC (33 years, 7 months ago) by greg
Changes since 1.24: +3 -2 lines
Diff to previous 1.24 , to selected 1.15
added fisheye view types
Mon Mar 12 15:14:49 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.23: +5 -5 lines
Diff to previous 1.23 , to selected 1.15
changed "inline" to "inl" for compiler compatibility
Fri Jan 26 08:17:43 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.22: +1 -5 lines
Diff to previous 1.22 , to selected 1.15
Thu Jan 18 23:58:26 1990 UTC (34 years, 4 months ago) by greg
Diff to previous 1.21 , to selected 1.15
Mon Jan 8 14:47:11 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.20: +6 -10 lines
Diff to previous 1.20 , to selected 1.15
changed handling of view parameters
Fri Jan 5 17:52:57 1990 UTC (34 years, 5 months ago) by greg
Diff to previous 1.19 , to selected 1.15
changed EXPOSURE information interface
Sun Dec 10 12:12:55 1989 UTC (34 years, 6 months ago) by greg
Changes since 1.18: +0 -10 lines
Diff to previous 1.18 , to selected 1.15
moved sskip to image.c
Fri Dec 8 11:08:47 1989 UTC (34 years, 6 months ago) by greg
Diff to previous 1.17 , to selected 1.15
fixed remaining bug in picreadline3()
Fri Dec 1 15:50:26 1989 UTC (34 years, 6 months ago) by greg
Diff to previous 1.16 , to selected 1.15
Changed precision of display values
Wed Nov 29 17:42:27 1989 UTC (34 years, 6 months ago) by greg
Changes since 1.15: +15 -13 lines
Diff to previous 1.15
fixed bug in scale_rcolors()
Revision 1.15 - (view) (download) (annotate) - [selected]
Wed Nov 29 16:50:39 1989 UTC (34 years, 6 months ago) by greg
Changes since 1.14: +16 -1 lines
Diff to previous 1.14
added identify command for contours
Mon Nov 6 15:12:03 1989 UTC (34 years, 7 months ago) by greg
Diff to previous 1.13 , to selected 1.15
forgot scalefactor in picreadline3()
Mon Oct 23 09:10:22 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.12: +4 -2 lines
Diff to previous 1.12 , to selected 1.15
undid change at 1.10 which introduced bug
Fri Oct 20 20:36:10 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.11: +7 -26 lines
Diff to previous 1.11 , to selected 1.15
change to color normalization calls
Tue Oct 3 09:11:43 1989 UTC (34 years, 8 months ago) by greg
Diff to previous 1.10 , to selected 1.15
increased default gamma correction
Wed Sep 13 15:41:52 1989 UTC (34 years, 8 months ago) by greg
Changes since 1.9: +2 -4 lines
Diff to previous 1.9 , to selected 1.15
Fixed small error in ray calculation for 't' command
Tue Sep 12 13:04:42 1989 UTC (34 years, 9 months ago) by greg
Diff to previous 1.8 , to selected 1.15
Mon Jul 24 10:45:12 1989 UTC (34 years, 10 months ago) by greg
Diff to previous 1.7 , to selected 1.15
fixed comment (big deal(
Tue May 23 10:46:32 1989 UTC (35 years ago) by greg
Diff to previous 1.6 , to selected 1.15
Fixed color allocation check for monochrome mode
Thu May 11 08:25:21 1989 UTC (35 years, 1 month ago) by greg
Changes since 1.5: +2 -3 lines
Diff to previous 1.5 , to selected 1.15
added ^L as redraw character
Fri Apr 21 08:44:05 1989 UTC (35 years, 1 month ago) by greg
Changes since 1.4: +1 -3 lines
Diff to previous 1.4 , to selected 1.15
removed beep on null exposure
Tue Apr 18 11:07:12 1989 UTC (35 years, 1 month ago) by greg
Diff to previous 1.3 , to selected 1.15
macro for VIEWSTR
Tue Apr 11 17:09:13 1989 UTC (35 years, 2 months ago) by greg
Diff to previous 1.2 , to selected 1.15
clear window before color change
Fri Apr 7 16:36:10 1989 UTC (35 years, 2 months ago) by greg
Changes since 1.1: +109 -34 lines
Diff to previous 1.1 , to selected 1.15
Added adjust exposure option and command
Thu Feb 2 10:49:43 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 1.15
