| 1 |
/* Copyright (c) 1987 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* ximage.c - driver for X-windows
| 9 |
| 10 |
* 4/30/87
| 11 |
* 3/3/88 Added calls to xraster & Paul Heckbert's ciq routines
| 12 |
| 13 |
| 14 |
#include "standard.h"
| 15 |
| 16 |
#include <X/Xlib.h>
| 17 |
#include <X/cursors/bcross.cursor>
| 18 |
#include <X/cursors/bcross_mask.cursor>
| 19 |
| 20 |
#include <sys/types.h>
| 21 |
| 22 |
#include <ctype.h>
| 23 |
| 24 |
#include "color.h"
| 25 |
| 26 |
#include "xraster.h"
| 27 |
| 28 |
#include "view.h"
| 29 |
| 30 |
#include "pic.h"
| 31 |
| 32 |
#define controlshift(e) (((XButtonEvent *)(e))->detail & (ShiftMask|ControlMask))
| 33 |
| 34 |
#define FONTNAME "9x15" /* text font we'll use */
| 35 |
| 36 |
#define CTRL(c) ('c'-'@')
| 37 |
| 38 |
#define BORWIDTH 5 /* border width */
| 39 |
#define BARHEIGHT 25 /* menu bar size */
| 40 |
| 41 |
double gamcor = 2.0; /* gamma correction */
| 42 |
| 43 |
XRASTER *ourras = NULL; /* our stored raster image */
| 44 |
| 45 |
int dither = 1; /* dither colors? */
| 46 |
int fast = 0; /* keep picture in Pixmap? */
| 47 |
| 48 |
Window wind = 0; /* our output window */
| 49 |
Font fontid; /* our font */
| 50 |
| 51 |
int maxcolors = 0; /* maximum colors */
| 52 |
int greyscale = 0; /* in grey */
| 53 |
| 54 |
int scale = 0; /* scalefactor; power of two */
| 55 |
| 56 |
int xoff = 0; /* x image offset */
| 57 |
int yoff = 0; /* y image offset */
| 58 |
| 59 |
VIEW ourview = STDVIEW(0); /* image view parameters */
| 60 |
int gotview = 0; /* got parameters from file */
| 61 |
| 62 |
COLR *scanline; /* scan line buffer */
| 63 |
| 64 |
int xmax, ymax; /* picture resolution */
| 65 |
int width, height; /* window size */
| 66 |
char *fname = NULL; /* input file name */
| 67 |
FILE *fin = stdin; /* input file */
| 68 |
long *scanpos = NULL; /* scan line positions in file */
| 69 |
int cury = 0; /* current scan location */
| 70 |
| 71 |
double exposure = 1.0; /* exposure compensation used */
| 72 |
| 73 |
struct {
| 74 |
int xmin, ymin, xsiz, ysiz;
| 75 |
} box = {0, 0, 0, 0}; /* current box */
| 76 |
| 77 |
char *geometry = NULL; /* geometry specification */
| 78 |
| 79 |
char *progname;
| 80 |
| 81 |
char errmsg[128];
| 82 |
| 83 |
extern long ftell();
| 84 |
| 85 |
extern char *malloc(), *calloc();
| 86 |
| 87 |
extern double atof(), pow(), log();
| 88 |
| 89 |
| 90 |
main(argc, argv)
| 91 |
int argc;
| 92 |
char *argv[];
| 93 |
| 94 |
int headline();
| 95 |
int i;
| 96 |
| 97 |
progname = argv[0];
| 98 |
| 99 |
for (i = 1; i < argc; i++)
| 100 |
if (argv[i][0] == '-')
| 101 |
switch (argv[i][1]) {
| 102 |
case 'c':
| 103 |
maxcolors = atoi(argv[++i]);
| 104 |
break;
| 105 |
case 'b':
| 106 |
greyscale = !greyscale;
| 107 |
break;
| 108 |
case 'm':
| 109 |
maxcolors = 2;
| 110 |
break;
| 111 |
case 'd':
| 112 |
dither = !dither;
| 113 |
break;
| 114 |
case 'f':
| 115 |
fast = !fast;
| 116 |
break;
| 117 |
case 'e':
| 118 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
| 119 |
goto userr;
| 120 |
scale = atoi(argv[++i]);
| 121 |
break;
| 122 |
case 'g':
| 123 |
gamcor = atof(argv[++i]);
| 124 |
break;
| 125 |
default:
| 126 |
goto userr;
| 127 |
| 128 |
else if (argv[i][0] == '=')
| 129 |
geometry = argv[i];
| 130 |
else
| 131 |
break;
| 132 |
| 133 |
if (argc-i == 1) {
| 134 |
fname = argv[i];
| 135 |
fin = fopen(fname, "r");
| 136 |
if (fin == NULL) {
| 137 |
sprintf(errmsg, "can't open file \"%s\"", fname);
| 138 |
quiterr(errmsg);
| 139 |
| 140 |
} else
| 141 |
goto userr;
| 142 |
| 143 |
/* get header */
| 144 |
getheader(fin, headline);
| 145 |
/* get picture dimensions */
| 146 |
if (fscanf(fin, "-Y %d +X %d\n", &ymax, &xmax) != 2)
| 147 |
quiterr("bad picture size");
| 148 |
/* set view parameters */
| 149 |
if (gotview) {
| 150 |
ourview.hresolu = xmax;
| 151 |
ourview.vresolu = ymax;
| 152 |
if (setview(&ourview) != NULL)
| 153 |
gotview = 0;
| 154 |
| 155 |
if ((scanline = (COLR *)malloc(xmax*sizeof(COLR))) == NULL)
| 156 |
quiterr("out of memory");
| 157 |
| 158 |
init(); /* get file and open window */
| 159 |
| 160 |
for ( ; ; )
| 161 |
getevent(); /* main loop */
| 162 |
userr:
| 163 |
fprintf(stderr,
| 164 |
"Usage: %s [=geometry][-b][-m][-d][-f][-c ncolors][-e +/-stops] file\n",
| 165 |
progname);
| 166 |
quit(1);
| 167 |
| 168 |
| 169 |
| 170 |
headline(s) /* get relevant info from header */
| 171 |
char *s;
| 172 |
| 173 |
static char *altname[] = {"rview","rpict","VIEW=",NULL};
| 174 |
register char **an;
| 175 |
| 176 |
if (!strncmp(s, "EXPOSURE=", 9))
| 177 |
exposure *= atof(s+9);
| 178 |
else
| 179 |
for (an = altname; *an != NULL; an++)
| 180 |
if (!strncmp(*an, s, strlen(*an))) {
| 181 |
if (sscanview(&ourview, s+strlen(*an)) == 0)
| 182 |
gotview++;
| 183 |
return;
| 184 |
| 185 |
| 186 |
| 187 |
| 188 |
char *
| 189 |
sskip(s) /* skip a word */
| 190 |
register char *s;
| 191 |
| 192 |
while (isspace(*s)) s++;
| 193 |
while (*s && !isspace(*s)) s++;
| 194 |
return(s);
| 195 |
| 196 |
| 197 |
| 198 |
init() /* get data and open window */
| 199 |
| 200 |
register int i;
| 201 |
OpaqueFrame mainframe;
| 202 |
char defgeom[32];
| 203 |
| 204 |
if (fname != NULL) {
| 205 |
scanpos = (long *)malloc(ymax*sizeof(long));
| 206 |
if (scanpos == NULL)
| 207 |
goto memerr;
| 208 |
for (i = 0; i < ymax; i++)
| 209 |
scanpos[i] = -1;
| 210 |
| 211 |
if (XOpenDisplay(NULL) == NULL)
| 212 |
quiterr("can't open display; DISPLAY variable set?");
| 213 |
#ifdef notdef
| 214 |
if (DisplayWidth() - 2*BORWIDTH < xmax ||
| 215 |
DisplayHeight() - 2*BORWIDTH - BARHEIGHT < ymax)
| 216 |
quiterr("resolution mismatch");
| 217 |
#endif
| 218 |
if (maxcolors == 0) { /* get number of available colors */
| 219 |
maxcolors = 1<<DisplayPlanes();
| 220 |
if (maxcolors > 4) maxcolors -= 2;
| 221 |
| 222 |
/* store image */
| 223 |
getras();
| 224 |
| 225 |
mainframe.bdrwidth = BORWIDTH;
| 226 |
mainframe.border = WhitePixmap;
| 227 |
mainframe.background = BlackPixmap;
| 228 |
sprintf(defgeom, "=%dx%d+0+22", xmax, ymax);
| 229 |
wind = XCreate("Radiance Image", progname, geometry, defgeom,
| 230 |
&mainframe, 16, 16);
| 231 |
if (wind == 0)
| 232 |
quiterr("can't create window");
| 233 |
width = mainframe.width;
| 234 |
height = mainframe.height;
| 235 |
fontid = XGetFont(FONTNAME);
| 236 |
if (fontid == 0)
| 237 |
quiterr("can't get font");
| 238 |
XStoreName(wind, fname == NULL ? progname : fname);
| 239 |
XDefineCursor(wind, XCreateCursor(bcross_width, bcross_height,
| 240 |
bcross_bits, bcross_mask_bits,
| 241 |
bcross_x_hot, bcross_y_hot,
| 242 |
BlackPixel, WhitePixel, GXcopy));
| 243 |
XSelectInput(wind, ButtonPressed|ButtonReleased|UnmapWindow
| 244 |
|RightDownMotion|MiddleDownMotion|LeftDownMotion
| 245 |
|KeyPressed|ExposeWindow|ExposeRegion);
| 246 |
XMapWindow(wind);
| 247 |
return;
| 248 |
memerr:
| 249 |
| 250 |
| 251 |
| 252 |
| 253 |
quiterr(err) /* print message and exit */
| 254 |
char *err;
| 255 |
| 256 |
if (err != NULL)
| 257 |
fprintf(stderr, "%s: %s\n", progname, err);
| 258 |
| 259 |
exit(err == NULL ? 0 : 1);
| 260 |
| 261 |
| 262 |
| 263 |
eputs(s)
| 264 |
char *s;
| 265 |
| 266 |
fputs(s, stderr);
| 267 |
| 268 |
| 269 |
| 270 |
quit(code)
| 271 |
int code;
| 272 |
| 273 |
exit(code);
| 274 |
| 275 |
| 276 |
| 277 |
getras() /* get raster file */
| 278 |
| 279 |
colormap ourmap;
| 280 |
| 281 |
ourras = (XRASTER *)calloc(1, sizeof(XRASTER));
| 282 |
if (ourras == NULL)
| 283 |
goto memerr;
| 284 |
ourras->width = xmax;
| 285 |
ourras->height = ymax;
| 286 |
if (maxcolors <= 2) { /* monochrome */
| 287 |
ourras->data.m = (unsigned short *)malloc(BitmapSize(xmax,ymax));
| 288 |
if (ourras->data.m == NULL)
| 289 |
goto memerr;
| 290 |
getmono();
| 291 |
} else {
| 292 |
ourras->data.bz = (unsigned char *)malloc(BZPixmapSize(xmax,ymax));
| 293 |
if (ourras->data.bz == NULL)
| 294 |
goto memerr;
| 295 |
if (greyscale)
| 296 |
biq(dither,maxcolors,1,ourmap);
| 297 |
else
| 298 |
ciq(dither,maxcolors,1,ourmap);
| 299 |
if (init_rcolors(ourras, ourmap) == 0)
| 300 |
goto memerr;
| 301 |
| 302 |
return;
| 303 |
memerr:
| 304 |
quit("out of memory");
| 305 |
| 306 |
| 307 |
| 308 |
getevent() /* process the next event */
| 309 |
| 310 |
WindowInfo info;
| 311 |
XEvent e;
| 312 |
| 313 |
XNextEvent(&e);
| 314 |
switch (e.type) {
| 315 |
case KeyPressed:
| 316 |
docom(&e);
| 317 |
break;
| 318 |
case ExposeWindow:
| 319 |
XQueryWindow(wind, &info); /* in case resized */
| 320 |
width = info.width;
| 321 |
height = info.height;
| 322 |
/* fall through */
| 323 |
case ExposeRegion:
| 324 |
fixwindow(&e);
| 325 |
break;
| 326 |
case UnmapWindow:
| 327 |
unmap_rcolors(ourras);
| 328 |
break;
| 329 |
case ButtonPressed:
| 330 |
if (controlshift(&e))
| 331 |
moveimage(&e);
| 332 |
else
| 333 |
getbox(&e);
| 334 |
break;
| 335 |
| 336 |
| 337 |
| 338 |
| 339 |
fixwindow(eexp) /* fix new or stepped-on window */
| 340 |
XExposeEvent *eexp;
| 341 |
| 342 |
redraw(eexp->x, eexp->y, eexp->width, eexp->height);
| 343 |
| 344 |
| 345 |
| 346 |
redraw(x, y, w, h) /* redraw section of window */
| 347 |
int x, y;
| 348 |
int w, h;
| 349 |
| 350 |
if (map_rcolors(ourras) == NULL) {
| 351 |
fprintf(stderr, "%s: cannot allocate colors\n", progname);
| 352 |
return(-1);
| 353 |
| 354 |
if (fast)
| 355 |
make_rpixmap(ourras);
| 356 |
return(patch_raster(wind,x-xoff,y-yoff,x,y,w,h,ourras) ? 0 : -1);
| 357 |
| 358 |
| 359 |
| 360 |
docom(ekey) /* execute command */
| 361 |
XKeyEvent *ekey;
| 362 |
| 363 |
char buf[80];
| 364 |
COLOR cval;
| 365 |
char *cp;
| 366 |
int n;
| 367 |
double comp;
| 368 |
FVECT rorg, rdir;
| 369 |
| 370 |
cp = XLookupMapping(ekey, &n);
| 371 |
if (n == 0)
| 372 |
return(0);
| 373 |
switch (*cp) { /* interpret command */
| 374 |
case 'q':
| 375 |
case CTRL(D): /* quiterr */
| 376 |
quit(0);
| 377 |
case '\n':
| 378 |
case '\r':
| 379 |
case 'l':
| 380 |
case 'c': /* value */
| 381 |
if (avgbox(cval) == -1)
| 382 |
return(-1);
| 383 |
switch (*cp) {
| 384 |
case '\n':
| 385 |
case '\r': /* radiance */
| 386 |
sprintf(buf, "%-3g", intens(cval)/exposure);
| 387 |
break;
| 388 |
case 'l': /* luminance */
| 389 |
sprintf(buf, "%-3gL", bright(cval)*683.0/exposure);
| 390 |
break;
| 391 |
case 'c': /* color */
| 392 |
comp = pow(2.0, (double)scale);
| 393 |
sprintf(buf, "(%.2f,%.2f,%.2f)",
| 394 |
colval(cval,RED)*comp,
| 395 |
colval(cval,GRN)*comp,
| 396 |
colval(cval,BLU)*comp);
| 397 |
break;
| 398 |
| 399 |
XText(wind, box.xmin, box.ymin, buf, strlen(buf),
| 400 |
fontid, BlackPixel, WhitePixel);
| 401 |
return(0);
| 402 |
case 'p': /* position */
| 403 |
sprintf(buf, "(%d,%d)", ekey->x-xoff, ymax-1-ekey->y+yoff);
| 404 |
XText(wind, ekey->x, ekey->y, buf, strlen(buf),
| 405 |
| 406 |
return(0);
| 407 |
case 't': /* trace */
| 408 |
if (!gotview) {
| 409 |
XFeep(0);
| 410 |
return(-1);
| 411 |
| 412 |
rayview(rorg, rdir, &ourview,
| 413 |
ekey->x-xoff + .5, ymax-1-ekey->y+yoff + .5);
| 414 |
printf("%e %e %e ", rorg[0], rorg[1], rorg[2]);
| 415 |
printf("%e %e %e\n", rdir[0], rdir[1], rdir[2]);
| 416 |
fflush(stdout);
| 417 |
return(0);
| 418 |
case '=': /* adjust exposure */
| 419 |
| 420 |
return(-1);
| 421 |
n = log(.5/bright(cval))/.69315 - scale; /* truncate */
| 422 |
if (n == 0) {
| 423 |
XFeep(0);
| 424 |
return(0);
| 425 |
| 426 |
scale_rcolors(ourras, pow(2.0, (double)n));
| 427 |
scale += n;
| 428 |
sprintf(buf, "%+d", scale);
| 429 |
| 430 |
| 431 |
XFlush();
| 432 |
free_raster(ourras);
| 433 |
getras();
| 434 |
/* fall through */
| 435 |
case CTRL(R): /* redraw */
| 436 |
XClear(wind);
| 437 |
return(redraw(0, 0, width, height));
| 438 |
case ' ': /* clear */
| 439 |
return(redraw(box.xmin, box.ymin, box.xsiz, box.ysiz));
| 440 |
default:
| 441 |
XFeep(0);
| 442 |
return(-1);
| 443 |
| 444 |
| 445 |
| 446 |
| 447 |
moveimage(ep) /* shift the image */
| 448 |
XButtonEvent *ep;
| 449 |
| 450 |
XButtonEvent eb;
| 451 |
| 452 |
XMaskEvent(ButtonReleased, &eb);
| 453 |
xoff += eb.x - ep->x;
| 454 |
yoff += eb.y - ep->y;
| 455 |
XClear(wind);
| 456 |
| 457 |
| 458 |
| 459 |
| 460 |
getbox(ebut) /* get new box */
| 461 |
XButtonEvent *ebut;
| 462 |
| 463 |
union {
| 464 |
XEvent e;
| 465 |
XButtonEvent b;
| 466 |
XMouseMovedEvent m;
| 467 |
} e;
| 468 |
| 469 |
XMaskEvent(ButtonReleased|MouseMoved, &e.e);
| 470 |
while (e.e.type == MouseMoved) {
| 471 |
revbox(ebut->x, ebut->y, box.xmin = e.m.x, box.ymin = e.m.y);
| 472 |
| 473 |
revbox(ebut->x, ebut->y, box.xmin, box.ymin);
| 474 |
| 475 |
box.xmin = e.b.x<0 ? 0 : (e.b.x>=width ? width-1 : e.b.x);
| 476 |
box.ymin = e.b.y<0 ? 0 : (e.b.y>=height ? height-1 : e.b.y);
| 477 |
if (box.xmin > ebut->x) {
| 478 |
box.xsiz = box.xmin - ebut->x + 1;
| 479 |
box.xmin = ebut->x;
| 480 |
} else {
| 481 |
box.xsiz = ebut->x - box.xmin + 1;
| 482 |
| 483 |
if (box.ymin > ebut->y) {
| 484 |
box.ysiz = box.ymin - ebut->y + 1;
| 485 |
box.ymin = ebut->y;
| 486 |
} else {
| 487 |
box.ysiz = ebut->y - box.ymin + 1;
| 488 |
| 489 |
| 490 |
| 491 |
| 492 |
revbox(x0, y0, x1, y1) /* draw box with reversed lines */
| 493 |
int x0, y0, x1, y1;
| 494 |
| 495 |
XLine(wind, x0, y0, x1, y0, 1, 1, 0, GXinvert, AllPlanes);
| 496 |
XLine(wind, x0, y1, x1, y1, 1, 1, 0, GXinvert, AllPlanes);
| 497 |
XLine(wind, x0, y0, x0, y1, 1, 1, 0, GXinvert, AllPlanes);
| 498 |
XLine(wind, x1, y0, x1, y1, 1, 1, 0, GXinvert, AllPlanes);
| 499 |
| 500 |
| 501 |
| 502 |
avgbox(clr) /* average color over current box */
| 503 |
COLOR clr;
| 504 |
| 505 |
int left, right, top, bottom;
| 506 |
int y;
| 507 |
double d;
| 508 |
COLOR ctmp;
| 509 |
register int x;
| 510 |
| 511 |
setcolor(clr, 0.0, 0.0, 0.0);
| 512 |
left = box.xmin - xoff;
| 513 |
right = left + box.xsiz;
| 514 |
if (left < 0)
| 515 |
left = 0;
| 516 |
if (right > xmax)
| 517 |
right = xmax;
| 518 |
if (left >= right)
| 519 |
return(-1);
| 520 |
top = box.ymin - yoff;
| 521 |
bottom = top + box.ysiz;
| 522 |
if (top < 0)
| 523 |
top = 0;
| 524 |
if (bottom > ymax)
| 525 |
bottom = ymax;
| 526 |
if (top >= bottom)
| 527 |
return(-1);
| 528 |
for (y = top; y < bottom; y++) {
| 529 |
if (getscan(y) == -1)
| 530 |
return(-1);
| 531 |
for (x = left; x < right; x++) {
| 532 |
colr_color(ctmp, scanline[x]);
| 533 |
addcolor(clr, ctmp);
| 534 |
| 535 |
| 536 |
d = 1.0/((right-left)*(bottom-top));
| 537 |
scalecolor(clr, d);
| 538 |
return(0);
| 539 |
| 540 |
| 541 |
| 542 |
getmono() /* get monochrome data */
| 543 |
| 544 |
register unsigned short *dp;
| 545 |
register int x, err;
| 546 |
int y;
| 547 |
rgbpixel *inline;
| 548 |
short *cerr;
| 549 |
| 550 |
if ((inline = (rgbpixel *)malloc(xmax*sizeof(rgbpixel))) == NULL
| 551 |
|| (cerr = (short *)calloc(xmax,sizeof(short))) == NULL)
| 552 |
quit("out of memory in getmono");
| 553 |
dp = ourras->data.m - 1;
| 554 |
for (y = 0; y < ymax; y++) {
| 555 |
picreadline3(y, inline);
| 556 |
err = 0;
| 557 |
for (x = 0; x < xmax; x++) {
| 558 |
if (!(x&0xf))
| 559 |
*++dp = 0;
| 560 |
err += rgb_bright(&inline[x]) + cerr[x];
| 561 |
if (err > 127)
| 562 |
err -= 255;
| 563 |
else
| 564 |
*dp |= 1<<(x&0xf);
| 565 |
cerr[x] = err >>= 1;
| 566 |
| 567 |
| 568 |
free((char *)inline);
| 569 |
free((char *)cerr);
| 570 |
| 571 |
| 572 |
| 573 |
init_rcolors(xr, cmap) /* (re)assign color values */
| 574 |
register XRASTER *xr;
| 575 |
colormap cmap;
| 576 |
| 577 |
register int i;
| 578 |
register unsigned char *p;
| 579 |
| 580 |
xr->pmap = (int *)malloc(256*sizeof(int));
| 581 |
if (xr->pmap == NULL)
| 582 |
return(0);
| 583 |
xr->cdefs = (Color *)malloc(256*sizeof(Color));
| 584 |
if (xr->cdefs == NULL)
| 585 |
return(0);
| 586 |
for (i = 0; i < 256; i++)
| 587 |
xr->pmap[i] = -1;
| 588 |
xr->ncolors = 0;
| 589 |
for (p = xr->data.bz, i = BZPixmapSize(xr->width,xr->height); i--; p++)
| 590 |
if (xr->pmap[*p] == -1) {
| 591 |
xr->cdefs[xr->ncolors].red = cmap[0][*p] << 8;
| 592 |
xr->cdefs[xr->ncolors].green = cmap[1][*p] << 8;
| 593 |
xr->cdefs[xr->ncolors].blue = cmap[2][*p] << 8;
| 594 |
xr->cdefs[xr->ncolors].pixel = *p;
| 595 |
xr->pmap[*p] = xr->ncolors++;
| 596 |
| 597 |
xr->cdefs = (Color *)realloc((char *)xr->cdefs, xr->ncolors*sizeof(Color));
| 598 |
| 599 |
return(0);
| 600 |
return(1);
| 601 |
| 602 |
| 603 |
| 604 |
scale_rcolors(xr, sf) /* scale color map */
| 605 |
| 606 |
double sf;
| 607 |
| 608 |
register int i;
| 609 |
int maxv;
| 610 |
| 611 |
sf = pow(sf, 1.0/gamcor);
| 612 |
maxv = (1<<16) / sf;
| 613 |
| 614 |
for (i = xr->ncolors; i--; ) {
| 615 |
xr->cdefs[i].red = xr->cdefs[i].red >= maxv ?
| 616 |
(1<<16)-1 :
| 617 |
xr->cdefs[i].red * sf;
| 618 |
xr->cdefs[i].green = xr->cdefs[i].green >= maxv ?
| 619 |
(1<<16)-1 :
| 620 |
xr->cdefs[i].green * sf;
| 621 |
xr->cdefs[i].blue = xr->cdefs[i].blue >= maxv ?
| 622 |
(1<<16)-1 :
| 623 |
xr->cdefs[i].blue * sf;
| 624 |
| 625 |
if (xr->pixels != NULL)
| 626 |
XStoreColors(xr->ncolors, xr->cdefs);
| 627 |
| 628 |
| 629 |
| 630 |
getscan(y)
| 631 |
int y;
| 632 |
| 633 |
if (y != cury) {
| 634 |
if (scanpos == NULL || scanpos[y] == -1)
| 635 |
return(-1);
| 636 |
if (fseek(fin, scanpos[y], 0) == -1)
| 637 |
quit("fseek error");
| 638 |
cury = y;
| 639 |
} else if (scanpos != NULL)
| 640 |
scanpos[y] = ftell(fin);
| 641 |
| 642 |
if (freadcolrs(scanline, xmax, fin) < 0)
| 643 |
quiterr("read error");
| 644 |
| 645 |
cury++;
| 646 |
return(0);
| 647 |
| 648 |
| 649 |
| 650 |
picreadline3(y, l3) /* read in 3-byte scanline */
| 651 |
int y;
| 652 |
register rgbpixel *l3;
| 653 |
| 654 |
register BYTE *l4;
| 655 |
register int shift, c;
| 656 |
int i;
| 657 |
| 658 |
if (getscan(y) < 0)
| 659 |
quiterr("cannot seek for picreadline");
| 660 |
/* convert scanline */
| 661 |
for (l4=scanline[0], i=xmax; i--; l4+=4, l3++) {
| 662 |
shift = l4[EXP] - COLXS + scale;
| 663 |
if (shift >= 8) {
| 664 |
l3->r = l3->g = l3->b = 255;
| 665 |
} else if (shift <= -8) {
| 666 |
l3->r = l3->g = l3->b = 0;
| 667 |
} else if (shift > 0) {
| 668 |
c = l4[RED] << shift;
| 669 |
l3->r = c > 255 ? 255 : c;
| 670 |
c = l4[GRN] << shift;
| 671 |
l3->g = c > 255 ? 255 : c;
| 672 |
c = l4[BLU] << shift;
| 673 |
l3->b = c > 255 ? 255 : c;
| 674 |
} else if (shift < 0) {
| 675 |
l3->r = l4[RED] >> -shift;
| 676 |
l3->g = l4[GRN] >> -shift;
| 677 |
l3->b = l4[BLU] >> -shift;
| 678 |
} else {
| 679 |
l3->r = l4[RED];
| 680 |
l3->g = l4[GRN];
| 681 |
l3->b = l4[BLU];
| 682 |
| 683 |
| 684 |
| 685 |
| 686 |
| 687 |
picwriteline(y, l) /* add 8-bit scanline to image */
| 688 |
int y;
| 689 |
pixel *l;
| 690 |
| 691 |
bcopy(l, ourras->data.bz+BZPixmapSize(xmax,y), BZPixmapSize(xmax,1));
| 692 |
| 693 |
| 694 |
| 695 |
picreadcm(map) /* do gamcor correction */
| 696 |
colormap map;
| 697 |
| 698 |
extern double pow();
| 699 |
register int i, val;
| 700 |
| 701 |
for (i = 0; i < 256; i++) {
| 702 |
val = pow(i/256.0, 1.0/gamcor) * 256.0;
| 703 |
map[0][i] = map[1][i] = map[2][i] = val;
| 704 |
| 705 |
| 706 |
| 707 |
| 708 |
picwritecm(map) /* handled elsewhere */
| 709 |
colormap map;
| 710 |
| 711 |
#ifdef DEBUG
| 712 |
register int i;
| 713 |
| 714 |
| 715 |
printf("%d %d %d\n", map[0][i],map[1][i],map[2][i]);
| 716 |
#endif
| 717 |
