root/radiance/ray/src/px/ximage.c
Revision: 2.14
Committed: Fri Nov 5 03:31:38 2004 UTC (20 years, 7 months ago) by greg
State: FILE REMOVED
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.14 static const char RCSid[] = "$Id: ximage.c,v 2.13 2004/01/02 12:47:01 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * ximage.c - driver for X-windows
6     *
7     * 4/30/87
8     * 3/3/88 Added calls to xraster & Paul Heckbert's ciq routines
9     */
10
11     #include "standard.h"
12
13     #include <X/Xlib.h>
14     #include <X/cursors/bcross.cursor>
15     #include <X/cursors/bcross_mask.cursor>
16
17     #include <sys/types.h>
18 schorsch 2.12 #include <string.h>
19 greg 1.1 #include <ctype.h>
20 greg 2.9 #include <time.h>
21
22 greg 1.1 #include "color.h"
23 greg 2.1 #include "resolu.h"
24 greg 1.1 #include "xraster.h"
25     #include "view.h"
26     #include "pic.h"
27 greg 1.15 #include "random.h"
28
29 greg 1.1 #define controlshift(e) (((XButtonEvent *)(e))->detail & (ShiftMask|ControlMask))
30
31     #define FONTNAME "9x15" /* text font we'll use */
32
33 greg 2.3 #define CTRL(c) ((c)-'@')
34 greg 1.1
35     #define BORWIDTH 5 /* border width */
36     #define BARHEIGHT 25 /* menu bar size */
37
38 greg 1.11 double gamcor = 2.2; /* gamma correction */
39 greg 1.1
40 greg 1.2 XRASTER *ourras = NULL; /* our stored raster image */
41 greg 1.1
42     int dither = 1; /* dither colors? */
43     int fast = 0; /* keep picture in Pixmap? */
44
45     Window wind = 0; /* our output window */
46     Font fontid; /* our font */
47
48     int maxcolors = 0; /* maximum colors */
49     int greyscale = 0; /* in grey */
50
51 greg 1.2 int scale = 0; /* scalefactor; power of two */
52
53 greg 1.1 int xoff = 0; /* x image offset */
54     int yoff = 0; /* y image offset */
55
56 greg 1.21 VIEW ourview = STDVIEW; /* image view parameters */
57 greg 1.1 int gotview = 0; /* got parameters from file */
58
59     COLR *scanline; /* scan line buffer */
60
61     int xmax, ymax; /* picture resolution */
62     int width, height; /* window size */
63     char *fname = NULL; /* input file name */
64     FILE *fin = stdin; /* input file */
65     long *scanpos = NULL; /* scan line positions in file */
66     int cury = 0; /* current scan location */
67
68     double exposure = 1.0; /* exposure compensation used */
69
70 greg 1.29 int wrongformat = 0; /* input in another format */
71
72 greg 1.1 struct {
73     int xmin, ymin, xsiz, ysiz;
74     } box = {0, 0, 0, 0}; /* current box */
75
76     char *geometry = NULL; /* geometry specification */
77
78     char *progname;
79
80     char errmsg[128];
81
82 schorsch 2.13 static gethfunc headline;
83
84 greg 1.1
85     main(argc, argv)
86     int argc;
87     char *argv[];
88     {
89 greg 2.5 extern char *getenv();
90     char *gv;
91 greg 1.1 int i;
92
93     progname = argv[0];
94 greg 2.7 if ((gv = getenv("DISPLAY_GAMMA")) != NULL)
95 greg 2.5 gamcor = atof(gv);
96 greg 1.1
97     for (i = 1; i < argc; i++)
98     if (argv[i][0] == '-')
99     switch (argv[i][1]) {
100     case 'c':
101     maxcolors = atoi(argv[++i]);
102     break;
103     case 'b':
104     greyscale = !greyscale;
105     break;
106     case 'm':
107     maxcolors = 2;
108     break;
109     case 'd':
110     dither = !dither;
111     break;
112     case 'f':
113     fast = !fast;
114     break;
115 greg 1.2 case 'e':
116     if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
117     goto userr;
118     scale = atoi(argv[++i]);
119     break;
120 greg 1.1 case 'g':
121     gamcor = atof(argv[++i]);
122     break;
123     default:
124     goto userr;
125     }
126     else if (argv[i][0] == '=')
127     geometry = argv[i];
128     else
129     break;
130
131     if (argc-i == 1) {
132     fname = argv[i];
133     fin = fopen(fname, "r");
134     if (fin == NULL) {
135     sprintf(errmsg, "can't open file \"%s\"", fname);
136     quiterr(errmsg);
137     }
138 greg 1.6 }
139 greg 1.1 /* get header */
140 greg 1.29 getheader(fin, headline, NULL);
141 greg 1.1 /* get picture dimensions */
142 greg 1.29 if (wrongformat || fgetresolu(&xmax, &ymax, fin) != (YMAJOR|YDECR))
143 greg 1.1 quiterr("bad picture size");
144     /* set view parameters */
145 greg 1.21 if (gotview && setview(&ourview) != NULL)
146     gotview = 0;
147 greg 1.1 if ((scanline = (COLR *)malloc(xmax*sizeof(COLR))) == NULL)
148     quiterr("out of memory");
149
150     init(); /* get file and open window */
151
152     for ( ; ; )
153     getevent(); /* main loop */
154     userr:
155     fprintf(stderr,
156 greg 1.2 "Usage: %s [=geometry][-b][-m][-d][-f][-c ncolors][-e +/-stops] file\n",
157 greg 1.1 progname);
158     quit(1);
159     }
160
161
162 schorsch 2.13 static int
163     headline( /* get relevant info from header */
164     char *s,
165     void *p
166     )
167 greg 1.1 {
168 greg 1.29 char fmt[32];
169 greg 1.1
170 greg 1.20 if (isexpos(s))
171     exposure *= exposval(s);
172 greg 1.29 else if (isformat(s)) {
173     formatval(fmt, s);
174     wrongformat = strcmp(fmt, COLRFMT);
175 greg 2.4 } else if (isview(s) && sscanview(&ourview, s) > 0)
176     gotview++;
177 gwlarson 2.8 return(0);
178 greg 1.1 }
179
180
181     init() /* get data and open window */
182     {
183     register int i;
184     OpaqueFrame mainframe;
185     char defgeom[32];
186
187     if (fname != NULL) {
188     scanpos = (long *)malloc(ymax*sizeof(long));
189     if (scanpos == NULL)
190     goto memerr;
191     for (i = 0; i < ymax; i++)
192     scanpos[i] = -1;
193     }
194     if (XOpenDisplay(NULL) == NULL)
195     quiterr("can't open display; DISPLAY variable set?");
196     #ifdef notdef
197     if (DisplayWidth() - 2*BORWIDTH < xmax ||
198     DisplayHeight() - 2*BORWIDTH - BARHEIGHT < ymax)
199     quiterr("resolution mismatch");
200     #endif
201     if (maxcolors == 0) { /* get number of available colors */
202     maxcolors = 1<<DisplayPlanes();
203     if (maxcolors > 4) maxcolors -= 2;
204     }
205     /* store image */
206 greg 1.2 getras();
207
208 greg 1.1 mainframe.bdrwidth = BORWIDTH;
209     mainframe.border = WhitePixmap;
210     mainframe.background = BlackPixmap;
211     sprintf(defgeom, "=%dx%d+0+22", xmax, ymax);
212     wind = XCreate("Radiance Image", progname, geometry, defgeom,
213     &mainframe, 16, 16);
214     if (wind == 0)
215     quiterr("can't create window");
216     width = mainframe.width;
217     height = mainframe.height;
218     fontid = XGetFont(FONTNAME);
219     if (fontid == 0)
220     quiterr("can't get font");
221     XStoreName(wind, fname == NULL ? progname : fname);
222     XDefineCursor(wind, XCreateCursor(bcross_width, bcross_height,
223     bcross_bits, bcross_mask_bits,
224     bcross_x_hot, bcross_y_hot,
225     BlackPixel, WhitePixel, GXcopy));
226     XSelectInput(wind, ButtonPressed|ButtonReleased|UnmapWindow
227     |RightDownMotion|MiddleDownMotion|LeftDownMotion
228     |KeyPressed|ExposeWindow|ExposeRegion);
229     XMapWindow(wind);
230     return;
231     memerr:
232     quiterr("out of memory");
233     }
234
235
236     quiterr(err) /* print message and exit */
237     char *err;
238     {
239     if (err != NULL)
240     fprintf(stderr, "%s: %s\n", progname, err);
241
242     exit(err == NULL ? 0 : 1);
243     }
244
245
246 greg 2.9 void
247 greg 1.1 eputs(s)
248     char *s;
249     {
250     fputs(s, stderr);
251     }
252
253
254 greg 2.9 void
255 greg 1.1 quit(code)
256     int code;
257     {
258     exit(code);
259     }
260
261
262 greg 1.2 getras() /* get raster file */
263     {
264     colormap ourmap;
265
266     ourras = (XRASTER *)calloc(1, sizeof(XRASTER));
267     if (ourras == NULL)
268     goto memerr;
269     ourras->width = xmax;
270     ourras->height = ymax;
271     if (maxcolors <= 2) { /* monochrome */
272     ourras->data.m = (unsigned short *)malloc(BitmapSize(xmax,ymax));
273     if (ourras->data.m == NULL)
274     goto memerr;
275     getmono();
276     } else {
277     ourras->data.bz = (unsigned char *)malloc(BZPixmapSize(xmax,ymax));
278     if (ourras->data.bz == NULL)
279     goto memerr;
280     if (greyscale)
281     biq(dither,maxcolors,1,ourmap);
282     else
283     ciq(dither,maxcolors,1,ourmap);
284     if (init_rcolors(ourras, ourmap) == 0)
285     goto memerr;
286     }
287     return;
288     memerr:
289 greg 1.26 quiterr("out of memory");
290 greg 1.2 }
291
292
293 greg 1.1 getevent() /* process the next event */
294     {
295     WindowInfo info;
296     XEvent e;
297
298     XNextEvent(&e);
299     switch (e.type) {
300     case KeyPressed:
301     docom(&e);
302     break;
303     case ExposeWindow:
304     XQueryWindow(wind, &info); /* in case resized */
305     width = info.width;
306     height = info.height;
307     /* fall through */
308     case ExposeRegion:
309     fixwindow(&e);
310     break;
311     case UnmapWindow:
312 greg 1.2 unmap_rcolors(ourras);
313 greg 1.1 break;
314     case ButtonPressed:
315     if (controlshift(&e))
316     moveimage(&e);
317     else
318     getbox(&e);
319     break;
320     }
321     }
322
323
324     fixwindow(eexp) /* fix new or stepped-on window */
325     XExposeEvent *eexp;
326     {
327     redraw(eexp->x, eexp->y, eexp->width, eexp->height);
328     }
329
330
331     redraw(x, y, w, h) /* redraw section of window */
332     int x, y;
333     int w, h;
334     {
335 greg 1.7 if (ourras->ncolors && map_rcolors(ourras) == NULL) {
336 greg 1.2 fprintf(stderr, "%s: cannot allocate colors\n", progname);
337     return(-1);
338     }
339 greg 1.1 if (fast)
340 greg 1.2 make_rpixmap(ourras);
341     return(patch_raster(wind,x-xoff,y-yoff,x,y,w,h,ourras) ? 0 : -1);
342 greg 1.1 }
343
344
345     docom(ekey) /* execute command */
346     XKeyEvent *ekey;
347     {
348     char buf[80];
349     COLOR cval;
350 greg 1.15 Color cvx;
351 greg 1.1 char *cp;
352     int n;
353 greg 1.2 double comp;
354 greg 1.1 FVECT rorg, rdir;
355
356     cp = XLookupMapping(ekey, &n);
357     if (n == 0)
358     return(0);
359     switch (*cp) { /* interpret command */
360     case 'q':
361 greg 2.3 case CTRL('D'): /* quit */
362 greg 1.1 quit(0);
363     case '\n':
364     case '\r':
365     case 'l':
366     case 'c': /* value */
367     if (avgbox(cval) == -1)
368     return(-1);
369     switch (*cp) {
370     case '\n':
371     case '\r': /* radiance */
372 greg 1.17 sprintf(buf, "%.3f", intens(cval)/exposure);
373 greg 1.1 break;
374     case 'l': /* luminance */
375 greg 1.30 sprintf(buf, "%.0fL", luminance(cval)/exposure);
376 greg 1.1 break;
377     case 'c': /* color */
378 greg 1.2 comp = pow(2.0, (double)scale);
379 greg 1.1 sprintf(buf, "(%.2f,%.2f,%.2f)",
380 greg 1.2 colval(cval,RED)*comp,
381     colval(cval,GRN)*comp,
382     colval(cval,BLU)*comp);
383 greg 1.1 break;
384     }
385     XText(wind, box.xmin, box.ymin, buf, strlen(buf),
386     fontid, BlackPixel, WhitePixel);
387     return(0);
388 greg 1.15 case 'i': /* identify (contour) */
389 greg 1.16 if (ourras->pixels == NULL)
390 greg 1.15 return(-1);
391     n = ourras->data.bz[ekey->x-xoff+BZPixmapSize(xmax,ekey->y-yoff)];
392     n = ourras->pmap[n];
393     cvx.pixel = ourras->cdefs[n].pixel;
394     cvx.red = random() & 65535;
395     cvx.green = random() & 65535;
396     cvx.blue = random() & 65535;
397     XStoreColor(&cvx);
398     return(0);
399 greg 1.1 case 'p': /* position */
400     sprintf(buf, "(%d,%d)", ekey->x-xoff, ymax-1-ekey->y+yoff);
401     XText(wind, ekey->x, ekey->y, buf, strlen(buf),
402     fontid, BlackPixel, WhitePixel);
403     return(0);
404     case 't': /* trace */
405     if (!gotview) {
406     XFeep(0);
407     return(-1);
408     }
409 greg 1.25 if (viewray(rorg, rdir, &ourview, (ekey->x-xoff+.5)/xmax,
410     (ymax-1-ekey->y+yoff+.5)/ymax) < 0)
411     return(-1);
412 greg 1.1 printf("%e %e %e ", rorg[0], rorg[1], rorg[2]);
413     printf("%e %e %e\n", rdir[0], rdir[1], rdir[2]);
414     fflush(stdout);
415     return(0);
416 greg 1.2 case '=': /* adjust exposure */
417     if (avgbox(cval) == -1)
418     return(-1);
419     n = log(.5/bright(cval))/.69315 - scale; /* truncate */
420 greg 1.5 if (n == 0)
421 greg 1.2 return(0);
422     scale_rcolors(ourras, pow(2.0, (double)n));
423     scale += n;
424     sprintf(buf, "%+d", scale);
425     XText(wind, box.xmin, box.ymin, buf, strlen(buf),
426     fontid, BlackPixel, WhitePixel);
427     XFlush();
428     free_raster(ourras);
429     getras();
430 greg 1.3 /* fall through */
431 greg 2.3 case CTRL('R'): /* redraw */
432     case CTRL('L'):
433 greg 1.16 unmap_rcolors(ourras);
434 greg 1.1 XClear(wind);
435     return(redraw(0, 0, width, height));
436     case ' ': /* clear */
437     return(redraw(box.xmin, box.ymin, box.xsiz, box.ysiz));
438     default:
439     XFeep(0);
440     return(-1);
441     }
442     }
443
444
445     moveimage(ep) /* shift the image */
446     XButtonEvent *ep;
447     {
448     XButtonEvent eb;
449
450     XMaskEvent(ButtonReleased, &eb);
451     xoff += eb.x - ep->x;
452     yoff += eb.y - ep->y;
453     XClear(wind);
454     return(redraw(0, 0, width, height));
455     }
456
457
458     getbox(ebut) /* get new box */
459     XButtonEvent *ebut;
460     {
461     union {
462     XEvent e;
463     XButtonEvent b;
464     XMouseMovedEvent m;
465     } e;
466
467     XMaskEvent(ButtonReleased|MouseMoved, &e.e);
468     while (e.e.type == MouseMoved) {
469     revbox(ebut->x, ebut->y, box.xmin = e.m.x, box.ymin = e.m.y);
470     XMaskEvent(ButtonReleased|MouseMoved, &e.e);
471     revbox(ebut->x, ebut->y, box.xmin, box.ymin);
472     }
473     box.xmin = e.b.x<0 ? 0 : (e.b.x>=width ? width-1 : e.b.x);
474     box.ymin = e.b.y<0 ? 0 : (e.b.y>=height ? height-1 : e.b.y);
475     if (box.xmin > ebut->x) {
476     box.xsiz = box.xmin - ebut->x + 1;
477     box.xmin = ebut->x;
478     } else {
479     box.xsiz = ebut->x - box.xmin + 1;
480     }
481     if (box.ymin > ebut->y) {
482     box.ysiz = box.ymin - ebut->y + 1;
483     box.ymin = ebut->y;
484     } else {
485     box.ysiz = ebut->y - box.ymin + 1;
486     }
487     }
488
489
490     revbox(x0, y0, x1, y1) /* draw box with reversed lines */
491     int x0, y0, x1, y1;
492     {
493     XLine(wind, x0, y0, x1, y0, 1, 1, 0, GXinvert, AllPlanes);
494     XLine(wind, x0, y1, x1, y1, 1, 1, 0, GXinvert, AllPlanes);
495     XLine(wind, x0, y0, x0, y1, 1, 1, 0, GXinvert, AllPlanes);
496     XLine(wind, x1, y0, x1, y1, 1, 1, 0, GXinvert, AllPlanes);
497     }
498
499
500     avgbox(clr) /* average color over current box */
501     COLOR clr;
502     {
503     int left, right, top, bottom;
504     int y;
505     double d;
506     COLOR ctmp;
507     register int x;
508
509     setcolor(clr, 0.0, 0.0, 0.0);
510     left = box.xmin - xoff;
511     right = left + box.xsiz;
512     if (left < 0)
513     left = 0;
514     if (right > xmax)
515     right = xmax;
516     if (left >= right)
517     return(-1);
518     top = box.ymin - yoff;
519     bottom = top + box.ysiz;
520     if (top < 0)
521     top = 0;
522     if (bottom > ymax)
523     bottom = ymax;
524     if (top >= bottom)
525     return(-1);
526     for (y = top; y < bottom; y++) {
527     if (getscan(y) == -1)
528     return(-1);
529     for (x = left; x < right; x++) {
530     colr_color(ctmp, scanline[x]);
531     addcolor(clr, ctmp);
532     }
533     }
534     d = 1.0/((right-left)*(bottom-top));
535     scalecolor(clr, d);
536     return(0);
537     }
538
539
540     getmono() /* get monochrome data */
541     {
542     register unsigned short *dp;
543     register int x, err;
544 greg 1.31 int y, errp;
545 greg 1.24 rgbpixel *inl;
546 greg 1.1 short *cerr;
547
548 greg 1.24 if ((inl = (rgbpixel *)malloc(xmax*sizeof(rgbpixel))) == NULL
549 greg 1.1 || (cerr = (short *)calloc(xmax,sizeof(short))) == NULL)
550 greg 1.26 quiterr("out of memory in getmono");
551 greg 1.2 dp = ourras->data.m - 1;
552 greg 1.1 for (y = 0; y < ymax; y++) {
553 greg 1.24 picreadline3(y, inl);
554 greg 1.1 err = 0;
555     for (x = 0; x < xmax; x++) {
556     if (!(x&0xf))
557     *++dp = 0;
558 greg 1.31 errp = err;
559 greg 1.24 err += rgb_bright(&inl[x]) + cerr[x];
560 greg 1.1 if (err > 127)
561     err -= 255;
562     else
563     *dp |= 1<<(x&0xf);
564 greg 1.31 err /= 3;
565     cerr[x] = err + errp;
566 greg 1.1 }
567     }
568 greg 2.9 free((void *)inl);
569     free((void *)cerr);
570 greg 1.1 }
571
572
573 greg 1.2 init_rcolors(xr, cmap) /* (re)assign color values */
574 greg 1.1 register XRASTER *xr;
575     colormap cmap;
576     {
577     register int i;
578     register unsigned char *p;
579
580     xr->pmap = (int *)malloc(256*sizeof(int));
581     if (xr->pmap == NULL)
582     return(0);
583     xr->cdefs = (Color *)malloc(256*sizeof(Color));
584     if (xr->cdefs == NULL)
585     return(0);
586     for (i = 0; i < 256; i++)
587     xr->pmap[i] = -1;
588     xr->ncolors = 0;
589     for (p = xr->data.bz, i = BZPixmapSize(xr->width,xr->height); i--; p++)
590     if (xr->pmap[*p] == -1) {
591     xr->cdefs[xr->ncolors].red = cmap[0][*p] << 8;
592     xr->cdefs[xr->ncolors].green = cmap[1][*p] << 8;
593     xr->cdefs[xr->ncolors].blue = cmap[2][*p] << 8;
594     xr->cdefs[xr->ncolors].pixel = *p;
595     xr->pmap[*p] = xr->ncolors++;
596     }
597 greg 2.10 xr->cdefs = (Color *)realloc((void *)xr->cdefs, xr->ncolors*sizeof(Color));
598 greg 1.1 if (xr->cdefs == NULL)
599     return(0);
600     return(1);
601     }
602
603
604 greg 1.2 scale_rcolors(xr, sf) /* scale color map */
605     register XRASTER *xr;
606     double sf;
607     {
608     register int i;
609 greg 1.16 long maxv;
610 greg 1.2
611 greg 1.16 if (xr->pixels == NULL)
612     return;
613
614 greg 1.2 sf = pow(sf, 1.0/gamcor);
615 greg 1.16 maxv = 65535/sf;
616 greg 1.2
617     for (i = xr->ncolors; i--; ) {
618 greg 1.16 xr->cdefs[i].red = xr->cdefs[i].red > maxv ?
619     65535 :
620 greg 1.2 xr->cdefs[i].red * sf;
621 greg 1.16 xr->cdefs[i].green = xr->cdefs[i].green > maxv ?
622     65535 :
623 greg 1.2 xr->cdefs[i].green * sf;
624 greg 1.16 xr->cdefs[i].blue = xr->cdefs[i].blue > maxv ?
625     65535 :
626 greg 1.2 xr->cdefs[i].blue * sf;
627     }
628 greg 1.16 XStoreColors(xr->ncolors, xr->cdefs);
629 greg 1.2 }
630
631
632 greg 1.1 getscan(y)
633     int y;
634     {
635     if (y != cury) {
636     if (scanpos == NULL || scanpos[y] == -1)
637     return(-1);
638     if (fseek(fin, scanpos[y], 0) == -1)
639 greg 1.26 quiterr("fseek error");
640 greg 1.1 cury = y;
641 greg 2.6 } else if (scanpos != NULL && scanpos[y] == -1)
642 greg 1.1 scanpos[y] = ftell(fin);
643
644     if (freadcolrs(scanline, xmax, fin) < 0)
645     quiterr("read error");
646
647     cury++;
648     return(0);
649     }
650
651
652     picreadline3(y, l3) /* read in 3-byte scanline */
653     int y;
654     register rgbpixel *l3;
655     {
656 greg 1.12 register int i;
657     /* read scanline */
658 greg 1.1 if (getscan(y) < 0)
659     quiterr("cannot seek for picreadline");
660     /* convert scanline */
661 greg 1.23 normcolrs(scanline, xmax, scale);
662 greg 1.12 for (i = 0; i < xmax; i++) {
663     l3[i].r = scanline[i][RED];
664     l3[i].g = scanline[i][GRN];
665     l3[i].b = scanline[i][BLU];
666 greg 1.1 }
667     }
668
669
670     picwriteline(y, l) /* add 8-bit scanline to image */
671     int y;
672     pixel *l;
673     {
674 schorsch 2.12 memcpy((void *)ourras->data.bz+BZPixmapSize(xmax,y), (void *)l, BZPixmapSize(xmax,1));
675 greg 1.1 }
676
677
678 greg 1.8 picreadcm(map) /* do gamma correction */
679 greg 1.1 colormap map;
680     {
681     extern double pow();
682     register int i, val;
683
684     for (i = 0; i < 256; i++) {
685 greg 1.27 val = pow((i+0.5)/256.0, 1.0/gamcor) * 256.0;
686 greg 1.1 map[0][i] = map[1][i] = map[2][i] = val;
687     }
688     }
689
690
691     picwritecm(map) /* handled elsewhere */
692     colormap map;
693     {
694 greg 1.2 #ifdef DEBUG
695     register int i;
696
697     for (i = 0; i < 256; i++)
698     printf("%d %d %d\n", map[0][i],map[1][i],map[2][i]);
699     #endif
700 greg 1.1 }
