root/radiance/ray/src/px/xdebugamb.c
Revision: 3.1
Committed: Sat Feb 22 02:07:28 2003 UTC (22 years, 2 months ago) by greg
CVS Tags: rad3R6P1, rad3R5, rad3R6
4 ---
5 > static char SCCSid[] = "@(#)ambient.c 2.29 5/2/95 LBL";
6 68c68
7 < #define tracktime (shm_boundary == NULL || ambfp == NULL)
8 ---
9 > #define tracktime 0
10 249a250
11 > printf("check %e %e %e\n", av->pos[0], av->pos[1], av->pos[2]);
12 289a291
13 > printf("use %e %e %e\n", av->pos[0], av->pos[1], av->pos[2]);
14 508a511
15 > printf("insert %e %e %e\n", av->pos[0], av->pos[1], av->pos[2]);
16 */
17 /*
18 * Display an image and watch the rays get traced.
19 *
20 * 9/21/90 Greg Ward
21 */
22
23 #include "standard.h"
24 #include "view.h"
25 #include <time.h>
26 #include "resolu.h"
27 #include <ctype.h>
28 #include <X11/Xlib.h>
29
30 #define MAXDEPTH 32 /* ridiculous ray tree depth */
31
32 #ifdef SMLFLT
33 #define sscanvec(s,v) (sscanf(s,"%f %f %f",v,v+1,v+2)==3)
34 #else
35 #define sscanvec(s,v) (sscanf(s,"%lf %lf %lf",v,v+1,v+2)==3)
36 #endif
37
38 char rtcom[] = "rtrace -h- -otp -fa -x 1";
39 char xicom[] = "ximage -c 128";
40
41 VIEW ourview = STDVIEW; /* view for picture */
42 RESOLU ourres; /* picture resolution */
43
44 char *progname; /* program name */
45
46 char *picture; /* picture name */
47 float *zbuffer;
48
49 #define zval(x,y) (zbuffer[(y)*scanlen(&ourres)+(x)])
50
51 FILE *pin; /* input stream */
52
53 Display *theDisplay = NULL; /* connection to server */
54
55 struct node { /* ray tree node */
56 int ipt[2];
57 struct node *sister;
58 struct node *daughter;
59 };
60
61 #define newnode() (struct node *)calloc(1, sizeof(struct node))
62
63 int slow = 0; /* slow trace? */
64
65
66 main(argc, argv) /* takes both the octree and the image */
67 int argc;
68 char *argv[];
69 {
70 int i;
71 char combuf[256];
72
73 progname = argv[0];
74 for (i = 1; i < argc-3; i++)
75 if (!strcmp(argv[i], "-s"))
76 slow++;
77 else
78 break;
79 if (i > argc-3) {
80 fprintf(stderr, "Usage: %s [-s] [rtrace args] octree picture zbuffer\n",
81 progname);
82 exit(1);
83 }
84 picture = argv[argc-2];
85 /* get the viewing parameters */
86 if (viewfile(picture, &ourview, &ourres) <= 0 ||
87 setview(&ourview) != NULL) {
88 fprintf(stderr, "%s: cannot get view from \"%s\"\n",
89 progname, picture);
90 exit(1);
91 }
92 zbload(argv[argc-1]);
93 /* open the display */
94 if ((theDisplay = XOpenDisplay(NULL)) == NULL) {
95 fprintf(stderr,
96 "%s: cannot open display; DISPLAY variable set?\n",
97 progname);
98 exit(1);
99 }
100 /* build input command */
101 sprintf(combuf, "%s %s | %s", xicom, picture, rtcom);
102 for ( ; i < argc-2; i++) {
103 strcat(combuf, " ");
104 strcat(combuf, argv[i]);
105 }
106 /* start the damn thing */
107 if ((pin = popen(combuf, "r")) == NULL)
108 exit(1);
109 sleep(20);
110 /* loop on input */
111 mainloop();
112 /* close pipe and exit */
113 pclose(pin);
114 exit(0);
115 }
116
117
118 zbload(fname)
119 char *fname;
120 {
121 int fd;
122 zbuffer = (float *)malloc(ourres.xr*ourres.yr*sizeof(float));
123 fd = open(fname,0);
124 if (fd<0) exit(1);
125 read(fd,zbuffer,ourres.xr*ourres.yr*sizeof(float));
126 close(fd);
127 }
128
129
130 mainloop() /* get and process input */
131 {
132 static struct node *sis[MAXDEPTH];
133 register struct node *newp;
134 char buf[128];
135 int level;
136 register int i;
137
138 level = 0;
139 while (fgets(buf, sizeof(buf), pin) != NULL) {
140 if (isalpha(buf[0])) {
141 i = 0;
142 while (isalpha(buf[++i]))
143 ;
144 buf[i++] = '\0';
145 ambval(buf, buf+i);
146 continue;
147 }
148 if ((newp = newnode()) == NULL) {
149 fprintf(stderr, "%s: memory error\n", progname);
150 return;
151 }
152 for (i = 0; buf[i] == '\t'; i++)
153 ;
154 if (strtoipt(newp->ipt, buf+i) < 0) {
155 fprintf(stderr, "%s: bad read\n", progname);
156 return;
157 }
158 newp->sister = sis[i];
159 sis[i] = newp;
160 if (i < level) {
161 newp->daughter = sis[level];
162 sis[level] = NULL;
163 }
164 level = i;
165 if (i == 0) {
166 setvec(sis[0]->ipt);
167 tracerays(sis[0]);
168 freetree(sis[0]);
169 sis[0] = NULL;
170 if (!slow)
171 XFlush(theDisplay);
172 }
173 }
174 }
175
176
177 freetree(tp) /* free a trace tree */
178 struct node *tp;
179 {
180 register struct node *kid;
181
182 for (kid = tp->daughter; kid != NULL; kid = kid->sister)
183 freetree(kid);
184 free((void *)tp);
185 }
186
187
188 tracerays(tp) /* trace a ray tree */
189 struct node *tp;
190 {
191 register struct node *kid;
192
193 for (kid = tp->daughter; kid != NULL; kid = kid->sister) {
194 vector(tp->ipt, kid->ipt);
195 tracerays(kid);
196 }
197 }
198
199
200 strtoipt(ipt, str) /* convert string x y z to image point */
201 int ipt[2];
202 char *str;
203 {
204 FVECT im_pt, pt;
205
206 if (!sscanvec(str, pt))
207 return(-1);
208 if (DOT(pt,pt) <= FTINY) /* origin is really infinity */
209 ipt[0] = ipt[1] = -1; /* null vector */
210 else {
211 viewloc(im_pt, &ourview, pt);
212 loc2pix(ipt, &ourres, im_pt[0], im_pt[1]);
213 }
214 return(0);
215 }
216
217
218 #define rwind RootWindow(theDisplay,ourScreen)
219 #define ourScreen DefaultScreen(theDisplay)
220
221 GC insGC = 0;
222 GC accGC = 0;
223 GC useGC = 0;
224 GC vecGC = 0;
225 Window gwind = 0;
226 int xoff=0, yoff=0;
227
228
229 setvec(ipt) /* set up vector drawing for pick */
230 int *ipt;
231 {
232 extern Window xfindwind();
233 XWindowAttributes wa;
234 XColor xc;
235 XGCValues gcv;
236 int rx, ry, wx, wy;
237 Window rw, cw;
238 unsigned int pm;
239 /* compute pointer location */
240 if (gwind == 0) {
241 register char *wn;
242 for (wn = picture; *wn; wn++);
243 while (wn > picture && wn[-1] != '/') wn--;
244 if ((gwind = xfindwind(theDisplay, rwind, wn, 4)) == 0) {
245 fprintf(stderr, "%s: cannot find display window!\n",
246 progname);
247 exit(1);
248 }
249 }
250 if (ipt != NULL) {
251 XQueryPointer(theDisplay, gwind, &rw, &cw, &rx, &ry, &wx, &wy, &pm);
252 xoff = wx - ipt[0];
253 yoff = wy - ipt[1];
254 }
255 /* set graphics contexts */
256 if (vecGC == 0) {
257 XGetWindowAttributes(theDisplay, gwind, &wa);
258 xc.red = 65535; xc.green = 0; xc.blue = 0;
259 xc.flags = DoRed|DoGreen|DoBlue;
260 if (XAllocColor(theDisplay, wa.colormap, &xc)) {
261 gcv.foreground = xc.pixel;
262 vecGC = XCreateGC(theDisplay,gwind,GCForeground,&gcv);
263 } else {
264 gcv.function = GXinvert;
265 vecGC = XCreateGC(theDisplay,gwind,GCFunction,&gcv);
266 }
267 xc.red = 0; xc.green = 0; xc.blue = 65535;
268 xc.flags = DoRed|DoGreen|DoBlue;
269 XAllocColor(theDisplay, wa.colormap, &xc);
270 gcv.foreground = xc.pixel;
271 insGC = XCreateGC(theDisplay,gwind,GCForeground,&gcv);
272 xc.red = 32000; xc.green = 0; xc.blue = 10000;
273 xc.flags = DoRed|DoGreen|DoBlue;
274 XAllocColor(theDisplay, wa.colormap, &xc);
275 gcv.foreground = xc.pixel;
276 accGC = XCreateGC(theDisplay,gwind,GCForeground,&gcv);
277 xc.red = 0; xc.green = 65000; xc.blue = 0;
278 xc.flags = DoRed|DoGreen|DoBlue;
279 XAllocColor(theDisplay, wa.colormap, &xc);
280 gcv.foreground = xc.pixel;
281 useGC = XCreateGC(theDisplay,gwind,GCForeground,&gcv);
282 }
283 }
284
285
286 vector(ip1, ip2) /* draw a vector */
287 int ip1[2], ip2[2];
288 {
289 if (ip2[0] == -1 && ip2[1] == -1)
290 return; /* null vector */
291 XDrawLine(theDisplay, gwind, vecGC,
292 ip1[0]+xoff, ip1[1]+yoff,
293 ip2[0]+xoff, ip2[1]+yoff);
294 if (slow) {
295 XFlush(theDisplay);
296 sleep(1);
297 }
298 }
299
300
301 ambval(typ, str)
302 char *typ, *str;
303 {
304 int ipt[2];
305 FVECT im_pt, pt;
306
307 if (!sscanvec(str, pt))
308 return(-1);
309 viewloc(im_pt, &ourview, pt);
310 loc2pix(ipt, &ourres, im_pt[0], im_pt[1]);
311 if (ipt[0] < 0 || ipt[0] > scanlen(&ourres) ||
312 ipt[1] < 0 || ipt[1] > numscans(&ourres))
313 return;
314 if (im_pt[2] > zval(ipt[0],ipt[1])+.05)
315 return; /* obstructed */
316 setvec(NULL);
317 if (!strcmp(typ, "insert"))
318 XDrawRectangle(theDisplay, gwind, insGC,
319 ipt[0]+xoff, ipt[1]+yoff, 2, 2);
320 else if (!strcmp(typ, "check"))
321 XDrawRectangle(theDisplay, gwind, accGC,
322 ipt[0]+xoff, ipt[1]+yoff, 2, 2);
323 else if (!strcmp(typ, "use"))
324 XDrawRectangle(theDisplay, gwind, useGC,
325 ipt[0]+xoff, ipt[1]+yoff, 2, 2);
326 XFlush(theDisplay);
327 }
