--- ray/src/px/x11raster.h 2003/07/14 22:24:00 2.3 +++ ray/src/px/x11raster.h 2004/03/28 20:33:14 2.4 @@ -1,4 +1,4 @@ -/* RCSid: $Id: x11raster.h,v 2.3 2003/07/14 22:24:00 schorsch Exp $ */ +/* RCSid: $Id: x11raster.h,v 2.4 2004/03/28 20:33:14 schorsch Exp $ */ /* * x11raster.h - header file for X routines using images. * @@ -26,13 +26,17 @@ typedef struct { Pixmap pm; /* storage on server side */ } XRASTER; -extern Colormap newcmap(); - -extern unsigned long *map_rcolors(); - -extern Pixmap make_rpixmap(); - -extern XRASTER *make_raster(); +extern Colormap newcmap(Display *disp, int scrn, Visual *vis); +extern int init_rcolors(XRASTER *xr, BYTE cmap[][3]); +extern unsigned long * map_rcolors(XRASTER *xr, Window w); +extern Pixmap make_rpixmap(XRASTER *xr, Window w); +extern XRASTER * make_raster( Display *disp, XVisualInfo *vis, + int npixbits, char *data, int width, int height, int bm_pad); +extern void patch_raster(Drawable d, int xsrc, int ysrc, + int xdst, int ydst, int width, int height, register XRASTER *xr); +extern void unmap_rcolors(XRASTER *xr); +extern void free_rpixmap(XRASTER *xr); +extern void free_raster(XRASTER *xr); #define put_raster(d,xdst,ydst,xr) patch_raster(d,0,0,xdst,ydst, \ (xr)->image->width,(xr)->image->height,xr)
